1usmus Custom Power Plan for Ryzen 3000 Zen 2 Processors
7 (0.00/day)
Maybe I'm missing something here, but for the record, I observe no difference/improvement in Cinebench R15 and Cinebench R20 (multi and single) between this and the default High performance power plan. But I also can't find the CPPC (I did find Preferred Cores), AMD Cool'n'Quiet and PPC Adjustment options in my bios. Disabled PBO.
My setup:
  • Ryzen 7 3700X
  • Corsair H110i GT 280mm
  • Gigabyte Aorus X570 Elite (BIOS F10a, AGESA 1.0.0.4В)
  • Windows 10 64-bit 1903
  • AMD Chipset Driver 1.9.27.1033
//edit: Or is it only the way it schedules and assigns cores that changes with the power plan? No synthetic benchmark improvements?
21,917 (3.42/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Software Gentoo Linux x64
TechCat
3 (0.00/day)
Lets remember this shows most improvement over 8 cores muti-chiplet CPUs Both this and 1004B increase efficiency whie lowering temps and will be improved going foward MS Windows is the culprit here and has dropped the ball and had plenty of time, has the resources so has no excuse
xxquaaxx
2 (0.00/day)
Happy user :)
232 (0.04/day)
Processor AMD R5 3600
Motherboard ASUS X370 Prime Pro
Memory 32GB (4x8GB) Crucial Ballistix DDR4 3000Mhz C15 @ 3600Mhz C16
Video Card(s) Nvidia RTX 2060 6GB GDDR6 FE
Storage 4x 1TB SSD
Display(s) Benq XL2411Z 144Hz + Asus VS24H
Case Corsair 270R
Audio Device(s) Yamaha AG03 + Rode Procaster
Power Supply Corsair AX 650W 90+ Gold
Mouse Logitech G Pro Superlight
Keyboard KBD67 Lite R3 (Gazzew Boba U4 + AKKO Midnight)
VR HMD Valve Index
R5 3600, performance is mostly the same but I did notice a small improvement in AIDA64 latency for some reason, guess the thread isn't hopped around by the W10 scheduler?
Pretty happy with this overall, before I had PSS & C-States disabled in BIOS and I was using the Ryzen High Performance plan to eliminate some random micro-stutter in games. Haven't tried any games yet with 1usmus' power plan, but so far so good.
19 (0.01/day)
Processor Ryzen 5800X3D
Motherboard MSI B450 TOMAHAWK MAX
Cooling Noctua NH-D15S
Memory Crucial Ballistix 32GB DDR4 3600MHZ
Video Card(s) Gigabyte GeForce 4070 Ti Gaming OC
Display(s) Gigabyte G24F-2
Case BeQuiet 500DX
Audio Device(s) Creative Sound BlasterX AE-5 Plus
Power Supply Seasonic Focus GX 750W
Mouse Razer Mamba Elite Optical
Keyboard Razer Huntsman
Just created an account to thank 1usmus for this wonderful fix and recommended ZEN2 BIOS settings. After switching to the recommended BIOS settings on my Tomahawk MAX B450 (version 3.4 Agesa 1.0.0.4B) and applying the power plan, I was able to notice max boost clock (4.2) across 4 cores out of 6 , on my Ryzen 3600, and for a more sustained time. Finally i get the performance that i was initially promised by AMD.
P.S : Maybe we should create a petition, to claim 1usmus's immediate hiring in AMD
everythingj
1 (0.00/day)
two questions:
does this plan need to be run 1.0.0.3 or 1.0.0.4? Or do either work?
and also, if i'm on a 3900x and was already seeing 4550 sporadically on 4 cores, is that about all that can be expected? i tried applying this hoping it would have those cores hit 4600 but it's not having any effect (on 1.0.0.4)
ironically on 1.0.0.3 i had one core that could hit 4600 but the 1.0.0.4 update has let more cores boost higher so i've kept it applied
714 (0.19/day)
I'm really confused here, I have the 3900X and my "stock" clocks (with the bundled Wraith cooler) are way better than those in review, does that mean my results with this new power plan would be too? And why are my clocks/scores better? :S
*EDIT*
Ahh, just noticed in the review, the comparison is made vs the bog standard Windows Balanced power scheme, not the Ryzen Balanced optimised power scheme installed by the chip-set drivers.
19,378 (3.49/day)
I'm still wondering how much this really improves things past pbo and stock (with ryzen pp)...I'm not convinced the effort is worth the result from what we've seen.
4,213 (0.71/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
I'm still only getting a maximum 1-core boost to 4.1 and all core boost to 3.9 on my R5 3600 :(
19 (0.00/day)
3800x up 25Mhz in all core tests.Single core boost same as before 4550+.
THANKS
3,881 (0.83/day)
This is going to confuse a lot because not all Motherboard vendors enable these options and they might be tied to certain features depending on vendor.
34 (0.02/day)
Thanks 1usmus for your dedication to the community!
Personally I'd have to say that differences are hard to spot on the 3800X on my system but peak boosts are a bit more evident across cores.
I think I got a few more single core points on R20 but within margin of error and the threads still bouncing around. Although they bounced around on the same core.
Used advised bios settings and PBO enabled and disabled. No difference.
In gaming cores won't run 4500+
but small peak speeds raised slightly across cores that before maybe 1 core boosted 4550 on max peaks and 1 to 4525 and the rest all below 4500. Now I get a few more cores hitting those 4550 speeds only with peaks. But I feel it doesn't make a difference in real performance. Aida Latency is the same. I ran LatencyMon to check about system Latency, couldn't spot much difference there either.
Temps are the same. No decrease in power usage also.
I might have to include that I'm already on Windows 10 19H2 1909 for quite a while. Agesa 1.0.0.4 B and I felt ABBA boosted better for me.
Overall more cores seem to hit their Max boost clocks but nothing shocking. Remind you, I'm on a 3800X.
I'll do some more testing of course. Later this week I'll also rip out the H80i V2 AIO and replace it for a 360 rad to unleash the full potential of the processor and see if that is what's holding it back. Or maybe I just have poor silicon.
UPDATE:
Checking and testing a bit more I find that CPU-Z single core test did improve by more than 10 points. So there is definitely something going on here and not for the worse. System feels smooth and responsive. I'll give it a few more days of testing.
8,235 (2.12/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
@1usmus I Dont have a ryzen rig but I use custom power plans, I Thought maybe you could incorporate this into your research and maybe add some options to this awesome work you did.
Here is the link to the article: Chose Power Plan context menu
169 (0.08/day)
My setup:
  • Ryzen 7 3700X
Same with my friends rig. Thought we were doing something wrong but it's the same performance as before (Latest agesa f10a - Gigabyte Aorus pro, 3700x)
rchiwawa
1 (0.00/day)
Using a 3900x and an Asus Crosshair VII motherboard I am seeing a 75MHz increase in my all core clock speed while running a folding@home on the 22 of 24 threads. Seems like a winner to me.
EDIT: This is for the same coolant temp under said load
47 (0.02/day)
The article didn't make clear if this was doing something risky and unsupported to the AMD hardware, or it was only a fix to stupid behavior of Windows 10 that did not involve risking pushing the CPU beyond its limits. While parts of the article seemed to hint at the latter, it also stated that the power plans for AMD processors, instead of being written by Microsoft, were supplied by AMD. I think this means that the custom power plan simply works around bad algorithms that were written by Microsoft. In any case, I learned not to use the "High Performance" plan.
43,990 (6.81/day)
Yes Windows 10 sucks.
3,984 (1.09/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
I still need to get 1.0.0.4 flashed but I already get over 4.6 on my 3900x on five cores 4.6 on a sixth. Not sure of the averages but I'll do some brief before and Afters.
wkdzel
1 (0.00/day)
3700X on an MSI X570-A Pro.
I have a baseline on PassMark from 2019-09-05 to compare with (AGESA 1.0.0.3ABB)
Comparing to the latest BIOS I have access to today (AGESA 1.0.0.4B) plus the 1usmus power plan I find that my single core performance tends to be just a few points higher and it does, in fact, tend to keep heavy single threaded workloads on the best core (monitored using Ryzen Master) however it does seem to have transient moments where it tries to move it to a different core and then goes right back to the best core. However all the other tests tend to trend 1-2% lower that my baseline however that is independent from the power plan (I also checked the default AMD power plan) so apparently I lost a bit of performance from 1003abb to 1004b. I benched with both PBO set to disabled and set to Automatic and I saw a slightly better performance with PBO set to automatic but the difference was within 1% so, could just be a fluke. I rant the tests multiple times and it did tend to average higher with PBO on auto but it's a bit too close to call. Honestly I doubt you'd feel the difference in game but I can confirm that with 1usmus's power profile it WANTS to keep the heaviest load on your best core, despite the fact that it will occasionally try to move it for a second and then puts it right back on the best core. (C03 is my best core and it occasionally tried to move it to C01, then right back to C03, every time) where as the default AMD power plan tends to toss the single core test all over the place.
I hope this input helps, thanks for the work!
wolf
Better Than Native
8,536 (1.31/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
I need to Flash 1.0.0.4 B stable bios and try this out, My gigabyte X570 I (ITX) doesn't want to let PBO work properly at all (wont exceed standard 88w limit) so my best clocks have been in default mode, if this increases efficiency I should see marginally higher clocks within that envelope.
1,512 (0.61/day)
1.0.0.4B didn't do anything over 1.0.0.3ABBA on my Gigabyte Aorus X570 Elite and 3900X, it lowered the max. boost a bit (from 4.650 to 4.575), but all the results stayed the same (within 1%) - processor doesn't do any work at max boost anyhow.
Tried 1usmus bios settings an power plan, no difference. Tried to push PBO overclocking, minimal increase in scores but massive amount of extra heat.
A bit underwhelming for a supposed massive bios overhaul...
68 (0.03/day)
An Island
System Name ashpc-3950x
Processor Ryzen 9 3950X 16-core @ 105W ppt
Motherboard Asrock X570M Pro4
Cooling Be Quiet Shadow Rock TF2
Memory 32 GB (4x8) 3600 MHz 16-16-16-36
Video Card(s) ASUS RTX 2070 Dual EVO
Storage Aorus 1TB NVMe Gen4, Corsair MP510 480GB NVMe, 2x SATA HDD, 2x SATA SSD
Display(s) Acer ED242QR-A 24" 144Hz 1920x1080
Case Silverstone RedLine RL08 (red) Micro ATX
Audio Device(s) Onboard + Creative T40 V2
Power Supply Seasonic Focus+ 850W Gold
Mouse Sharkoon Fireglider
Keyboard Logitech G413 Carbon
Benchmark Scores idc
Hi, I am really interested in this, especially since I do use a lot of 1T software alongside the heavily threaded ones and the Windows 10 scheduler seems intent on putting the load on the weakest cores in the system. Unfortunately, I tried to use this power plan and it didn't affect anything. CPUz Single-thread uses two threads apparently, and one isn't even on the same CCX. The xEdit software for Fallout 4 uses just on thread on one core, and even with the power plan it still uses the weakest core, sometimes losing 100 MHz of performance which is quite significant.
I am on 1.0.0.3 ABBA and my motherboard is Asrock X570M Pro4, my CPU is Ryzen 7 3700X. Everything is at stock.
However, I couldn't find the:
  • CPPC
  • CPPC Preferred Cores
Options in the bios. They are simply not there, unless I missed them. So maybe that is why it is not working for me. Any advice would be appreciated. Thanks
