5800x (and other Zen 3 chips) PBO settings/Temperature fix
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
23 (0.03/day)
System Name CYX PC
Processor Ryzen 7 5800X
Motherboard Asus Rog Strix B550 E-Gaming
Cooling Arctic Liquid Freezer II 360 - x11 total case fans - Arctic P12 120mm (x9) - Arctic F8 PWM 80mm (x2)
Memory GSkill TridentZ 3200mHz 16CL (32GB - 4x8GB)
Video Card(s) Gigabyte RTX 3070 Ti - Gaming OC (Rev 1.0)
Storage Samsung 970 Evo Plus M2 (500GB) - Samsung 970 Evo Plus M2 (2TB) - Toshiba P300 HDD (3TB)
Display(s) Acer Nitro XV342 CKP (IPS 144hz - 1ms - Flat Ultrawide - GSynch Compatibility)
Case LianLi Dynamic O11 Midi (Black)
Audio Device(s) Fenton Studio Speakers 120W/Yamaha Sub 80W - Logitech G Pro X Gaming - AudioTechnica ATH-M50x Studio
Power Supply Corsair RMx 650W (2018)
Mouse Razer Deathadder Elite
Keyboard Motospeed CK-104
After many hours tests have some results and settings.
BEST CURVE OPTIMIZE TEMPS AND PERFORMANCE
PPT: 120W - TDC: 75A - EDC: 130A
FITSCALAR: X1
FMAX ENCH: OFF (BY ASUS)
BEST TWO CORES: (-18 AND -19)
THE THIRD MORE ACTIVE CORE: (-21)
SLEEP CORES (-28)
POWER MODE: BALANCHE MIN CPU: 5% - 100% MAX
PERFORMANCE: 100% - TURBO MODE: 0% VIA QUICKCPU PROGRAM
CB'R23 SCORE: 15.453 (12 RUNS)
PUMP: FULL RPM 100% (ARCTIC FREEZER II 360 ARGB)
FANS AIO (PUSH/PULL X6 120MM) 20C/40% 60C/70% 70C/100%
MIN TEMP: 30.1C IDDLE IN WINDOWS
MAX: 72C (RUNNING 10MINS CB'R23)
MAX: 75.5C PRIME 95 (30MINS WITHOUT ERRORS)
VRMs: 31C IDDLE - 39C MAX
CASE INSIDE TEMPS: 27C MAX VIA THERMAL CABLE
CPU CORE POWER: 1.18W IDDLE - 101.10W MAX
CORE CLOCKS: 2.880MHZ IDDLE - 4.850MHZ MAX
CPU CORE VOLTAGE: 1.22V IDDLE - 1.42V MAX
SPECS:
CASE: LIANLI DYNAMIC O11
AIO: ARCTIC LIQUID FREEZER II 360 ARGB / MX6 THERMAL PASTE
MOTHERBOARD: ASUS ROGSTRIX B550 E-GAMING
CPU: RYZEN 7 5800X
RAM: GSKILL TRIDENTZ DDR4 3200MHZ 16CL (8GB X4) 32GB
GPU: GIGABYTE RTX 3070 TI GAMING OC
PSU: CORSAIR RMX 650W GOLD - FULL MODULAR
M2: SAMSUNG EVO 970 PLUS 1TB
SSD: CRUCIAL MX500 2TB
HDD: TOSHIBA P300 3TB
CASE FANS: ARCTIC 120MM ARGB (TOTAL X12 INCLUDE AIO)
CASE FANS: ARCTIC 80MM (TOTAL X2)
MONITOR: ACER 34' ULTRAWIDE FLAT 3440X1440 GAMING 144MHZ 1MS
GAMING: 45C-67C MAX
ATTACH STOCK 5800X RESULTS - AND STANDAR OC ALL CORES 4.600MHZ @1.25V - PBO OFF - FMAX ENCH: OFF
CINEBENCH R23 BEST RESULTS (CURVE OPT. PER CORES)
Pleiades
1 (0.00/day)
FITSCALAR: X1
SLEEP CORES (-28)
SPECS:
CPU: RYZEN 7 5800X
GAMING: 45C-67C MAX
How is the CPU stability with such aggressive negative curve? I heard it can be unstable at low loads.
Mussels
58,412 (7.85/day)
Oystralia
It can take time for that instability to show up, when mine was right on the edge of stability i'd get maybe one game crash a week before i tuned it in fully
23 (0.03/day)
System Name CYX PC
Nothing stability when undervolting. 4 months now I never had any crash. Have 14 titles on my main pc like WarZone 2.0, Arma 3, DayZ, Fifa 23, DCS World, NBA 2K23, F1 22, Automobilista 2, WRC Generations, ELDEN RING, Dead Stranding, The Forest and 2 more. I play 4-5 hours per day. My Pc still open 12h/24h. Im works Photoshop and some music programs like Fruit Loops. Im ok atm with better performance and excellent temps.
With the 5600x I used Core Cycler. I'm bored now....Really I hate wasting time on something like that.
These values give the Ryzen Master after Curve Optimization by Per Core with custom settings by BIOS as:
FITSCALAR: X1 (or Auto) *with X1 is better for me.
FMAX ENCH: OFF
My board its one of the best B550 such as MSI B550 Unify, Gigabyte B550 Aorus Master......with 14+2 phases - Dual Output, VRM type DrMOS - excellent Mofset and one of the best PWM Controller.
Also the ARCTIC AIO for me is the "best AIO" ever at all. I tryed before 3 ΑIO's mores on my old 5600X: Raijintek EOS, Orcus, Thermaltake, Coolemaster. The Liquid Freezer II 360 is top on another level of performance and quiet peaks.
I can oc more +75mhz without problem with different high negative curve but I don't need it - the differences are non-existent in the gaming and i don't care to be a slave to the Cinebench scores.
Yes dude, need time
Mussels
58,412 (7.85/day)
Oystralia
Instability varies a lot depending on how you set it up
If you do the +200 for low threaded boost, you'll find it a lot harder to undervolt - my 5800x only did -5 with +200, and -15 with 0
These days we have a lot more automated tools to find problems much faster
193 (0.08/day)
System Name Zen4
Processor Ryzen 9 7950x
Motherboard Asus Strix B650E-E Gaming WiFi
Cooling Some oem 240 AIO
Memory 2xKingston DDR5 2x16GB (Hynix M die)@6000 CL26-35-35-27
Video Card(s) Gainward Phantom 4090 (@2.82GHz .95V UV, 350W PL)
Storage WD Black SN850X
Display(s) LG OLED C1 48"
Case Phanteks P600S
Power Supply Corsair RM1000i
Mouse Logitech G Pro X Superlight
Keyboard Corsair K70
VR HMD HP Reverb G2
Software Win11
Curious as to how zen3 fares with AVX2 stability. Particularly 1 threaded load. I'm currently building and testing a new zen4 computer, and have been plagued by random reboots at idle. Very hard to replicate, but one test I've seen that fails even at "stock" (BIOS defaults for Asus motherboards tends to be a little out of spec), is the Prime95 1 Core Smallest FFT AVX2 test (with hyperthreading turned off for single thread boosting and max clocks). I have managed to make it run stable, by lowering Vcore 0.015V and adding +5 Curve Optimizer for two problematic cores, one being Core 0 which probably is bad, and might reveal the issue I'm having, but also might not be related at all. I started this testing using P95 30.8 manually assigning affinity using Process Lasso (testing 1 thread for each core), but using Core Cycler is easier. I've attached two CoreCycler config.ini files, that should automate this (testing all cores). The torture one (rename it to config.ini before using) also includes the suspendPeriodically = 1 setting which makes it even harder stability wise, if anyone is up for giving it a try :)
  • config_files.zip
Mussels
58,412 (7.85/day)
Oystralia
idle reboots on zen3 are entirely related to SoC issues, too low an SoC voltage or too high infinity fabric
Everything would be stable at load and stress tests but crash at low loads - when the CPU was boosting individual cores to higher clocks vs the lower all core loads a stress test provides
193 (0.08/day)
System Name Zen4
Case Phanteks P600S
VR HMD HP Reverb G2
Software Win11
Interesting, I'm going to test if this might apply in my case. It's my first Ryzen build, so I missed a lot of the "history" of previous gens.
Mussels
58,412 (7.85/day)
Oystralia
Whats the full hardware setup of the PC?
Everyone, and i mean everyone forgets that Zen3 only supports 3200MT/s with two single rank sticks out of the box, and then tries to get 4 or 8 ranks running at 3600 off XMP and scratches their heads why it has issues
99% of the time raising SoC voltage to 1.10v or 1.15v resolves the common ryzen issues of low-load crashes and USB disconnects, because the SoC inside the CPU is memory, PCI-E and USB in one - errors or problems on one part, causes the others to risk resets or freezes (Hence PCI-E risers causing errors making USB ports reset and drop in/out)
193 (0.08/day)
System Name Zen4
Case Phanteks P600S
VR HMD HP Reverb G2
Software Win11
Full specs are:
ROG STRIX B650E-E GAMING WIFI
Ryzen 9 7950X cooled with a Cooler Master 240 AIO
Kingston Fury Renegade DDR5 6400MHz 32GB (KF564C32RSK2-32), RAM speed doesn't matter for my problems, equally unstable at 4800 as 6200, and all RAM stability tests shows 0 errors
Western Digital Black SN850X 2TB (WDS200T2X0E)
I tested all the BIOS files available for this board, and played with the Infinity Fabric speed (tried 1600, 1800 and default 2000), and interestingly, with all voltages on Auto, Vsoc doesn't budge from 1.040V (BIOS thinks 1.040Vsoc is fine for 1600, 1800 and 2000IF). However, messing with RAM speed, Vsoc went all the way up to 1.335V for 6200 (4800 is BIOS default-> Vsoc=1.040V). So the BIOS ups the SOC voltage depending on RAM speed, and not IF. I tried to increase Vsoc manually (up to +0.25), but stability didn't improve.
I posted in another thread here, that maybe I have encountered some sort of PBO/Curve Optimizer bug, that somehow survives clear BIOS/BIOS flashing/loading optimized defaults. But the more I think about it, I wonder if I'm being pranked by Ryzen Master. At some point early on when I got this system running, being new to Ryzen, I had to try Ryzen Master. And, of course, I also tried the Curve Optimizer "auto" optimizing feature. But after the initial "Reboot Required" prompt from Ryzen Master, the system refused to post. Which felt really odd at the time, and I tried powering the PSU off, let all power drain and start again, still nothing, and I had to Clear CMOS and load my good BIOS profile to get it back up. So somehow Ryzen Master made my BIOS settings unpostable. I didn't think of it at the time, but I wonder if this is where my problems started. Random reboots while gaming, hard to tell when it started, and soon also while just browsing the web. Most stability testers showed no problems however, until I tried P95 AVX2, which also made my system reboot.
So, how does Ryzen Master work? Does it mess with BIOS settings? Maybe there's some broken driver or service loaded in windows that still is trying to Curve Optimize my system...lol, I don't know, but I'm still on the same windows install.
Mussels
58,412 (7.85/day)
Oystralia
Be aware that's an entry level cooler and a poor one at that, it's not going to do well on a 7950x
People always forget that the memory controller is not RAM
Just because your RAM passes a RAM stability test doesn't mean that your memory controller can't have stability problems, since it's tied to other hardware as part of the SoC
6400 is too high for zen3, I'm not aware of many kits running on expo/XMP above 6000 without needing tweaking
No, auto doesnt think it's fine for X Y and Z IF - auto just has a few presets that are nothing more than guesses since DDR5 is in it's infancy, and it cant compensate for more memory modules or ranks
ryzen master literally changes your BIOS settings. That's what it does, and what it tells you it's doing before it restarts to apply them.
193 (0.08/day)
System Name Zen4
Case Phanteks P600S
VR HMD HP Reverb G2
Software Win11
Yes, that makes sense. Full story is that I installed Ryzen Master, tried the Curve Optimizer once, which stopped my system from posting. After that I only used it to verify my settings in Windows (which is useful), and everything looked normal, all the PBO and CO stuff I applied in BIOS was reported as expected in Ryzen Master. I never used it to tweak my system after the first fail which didn't instill much trust (lol). But over the last few weeks I have tested many PBO and CO settings (via BIOS), and would expect anything once done by Curve Optimizer to be overwritten? I did flash my BIOS many times, Clear CMOS load Defaults. I'm thinking Ryzen Master was loading something in Windows that whacks up PBO/CO so my system became seriously flaky. And have done so completely hidden from view, not reported anywhere...
Anyway, Ryzen Master is gone now. And I will go back tomorrow and see if I can touch anything PBO/CO related again without my system going haywire.
Mussels
58,412 (7.85/day)
Oystralia
Yeah but if you loaded ryzen master again, it could have altered those settings again - even ones you're not aware of
Reset to optimised defaults and try fresh
tabascosauz
8,226 (2.33/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Can't say how AM5 has changed the layouts exactly, but in all recent Asus AM4 BIOSes there are multiple locations for both PBO and Curve Optimizer (except 5800X3D).
The most accessible PBO menu for most people is found under Tweaker tab, but when Ryzen Master changes your settings it instead edits the PBO menu found under AMD Overclocking.
If you're testing Curve Optimizer, use your choice of something proper like corecycler, OCCT, or ycruncher with custom affinity. The "testing" tool for CO in Ryzen Master is not even on the radar in terms of effective testing
Mussels
58,412 (7.85/day)
Oystralia
the x3D can show up in both locations now too, as its been added to the latest agesa
47 (0.06/day)
On my 5800x3d i dont even have PBO... i cant change ANYthing on ryzen master. Or in the bios. Its on a gigabyte x570 aorus elite wifi.
I dunno if gigabyte disabled it or what is going on.. but i cant even overclock my 5800x3d if i wanted too. First time in 23 years ive been locked outa overclocking. Its funny. Only thing i can do is flck and memory timings and overclock.
I mesn its fine.. i guess.. cpu does what i need it too lol.. but dang. At least with athlon xps i could use a pencil to unlock it !!! LOL
6,245 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
PBO settings for 5800x3d are dependent on the mobo vendor. Officially there's no tuning available for it. Either you get it with a BIOS update or you have to use modded BIOS. Alternative is PBO tuner in Windows with autoload on startup.
Mussels
58,412 (7.85/day)
Oystralia
He's gone. Problems in other threads.
His board doesnt have that BIOS update yet
20 (0.02/day)
Germany
System Name sadness
Processor 5800x 4.4 1.2V
Motherboard MSI B450M Mortar Max
Cooling NZXT Kraken V53
Memory 2x 8GB G.SKILL TridentZ 3200 not B-Die
Video Card(s) Zotac RTX 2070 Mini 2050MHz OC
Storage 1x Samsung 970 Evo Plus 2x Seagate 2TB HDD 7200RPM
Display(s) 1x BENQ 60hz 1x 144hz AOC C24G1
Case idk some rando Corsair one
Audio Device(s) DT 770 Pro 250Ohm on Fiio DAC
Power Supply China-D Boeller
Mouse Glorious Model D White
Keyboard custom built
So ive used the 4.6Ghz 1.25V one that was sent by @cyx2111 with PBO auto and -20 all cores and some other settings like SpreadSpectrum Off and got this run.
Realtime as Process Priority and Windows 11. Could i even run 4.75 Ghz with 1.25V on this 24/7? Anyone know that?
Mussels
58,412 (7.85/day)
Oystralia
If you use an all core OC, PBO and curve setting are completely ignored
6,134 (0.84/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Such as? I assume your 1st post is outdated and I'm not really willing to dig through 25 pages of threads to find the nuggets...
Assume you meant "Zen 4"?
Mussels
58,412 (7.85/day)
Oystralia
ryzen master has a tool in it now, and another who's name i forgot
and yeah shush, it's like number dyslexia sometimes
978 (0.42/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
This is not 100% true.
Even if you lock your CPU to an all core load running any PBO limt (EDC TDC PPT) will still work and CO will still work in the sense that it will still reduce voltage to the core but not increase its clock speed.
New version of PBO2 tuner has a builtin monitor function and I can confirm that locking all core and running -CO does indeed reduce voltage per core on my 5800X. So you don't get the boost in clock
speed because your clocks (multiplier) are locked, but you do get the reduced voltage and power.
Using a negative CO can help you pass R23 for example with a locked all cores like 4700. I need to use a specific CO of -30 -30 -5 -30 -30 -30 -30 -30 to pass R23 with 4700 all cores.
Mussels
58,412 (7.85/day)
Oystralia
If you set them in the BIOS, they definitely do nothing
VID is a requested voltage, and doesnt mean jack for the actual voltage
