- Aug 9, 2019
- 1,795 (0.88/day)
Processor | 7800X3D 2x16GB CO |
Motherboard | Asrock B650m HDV |
Cooling | Peerless Assassin SE |
Memory | 2x16GB DR A-die@6000c30 tuned |
Video Card(s) | Asus 4070 dual OC 2610@915mv |
Storage | WD blue 1TB nvme |
Display(s) | Lenovo G24-10 144Hz |
Case | Corsair D4000 Airflow |
Power Supply | EVGA GQ 650W |
Software | Windows 10 home 64 |
Benchmark Scores | Superposition 8k 5267 Aida64 58.5ns |
It is strange that you get lower scores using these values. Is edc/tdc/ppt the same with and w/o co? Can you post a screenshot with hwmonitor running when running cinebench? I want to see corevoltage, frequency, temps and power.my 2nd pic lists my co offsets but I will put them in my initial post and here.
-8 -6 -20 -22 -20 -13 -10 -15
Also, the ram I have took a long time to get to the timings and frequency. its rated for 3200mhz. It was very difficult to get it to the timings and speed it is at now. But if you really think that it will increase my gaming performance noticeably, I will work on it. Aida64 reports my memory latency as 61ns. With XMP, that value was 67ns.
Thank you, I should have specified that I already have my CO offsets in the 2nd pic I posted. It shows ROPbench and has my offsets along with my PBO values. ROPbench Imo does the same thing as pbotuner2 plus more.
I would like to know something. I ran OCCT CPU + Ram test. It maxes out my limits further than just a CPU test. I wanted to know the effect of setting PBO limits in real time, so I played with them and watched my clock speed. If I was at 100% Utilization of my PBO limits, my clock speed would drop on TDC and PPT. With EDC even at 100% utilization, the "Sweet spot" seemed to be 85A. Any lower or higher and my effective clock speed would drop. I did the same thing with TDC and PPT. With PPT it was 160W. 10W below max usage during OCCT. Any lower or higher and my effective clock speed would go down. TDC was a little harder to gauge, but I noticed clocks being affected when TDC was below or higher than 100A. Im curious if this test I did is only specific to stress testing with OCCT, or If I set the PBO values I found, will they be correct for gaming as well?
Save your current ramprofile and try my suggested settings if you like. This ram looks like Micron rev E DR or rev B SR from the timings. They should both be quite easy to run at 3800 You may have to play a bit with resistances.
