5800x (and other Zen 3 chips) PBO settings/Temperature fix
14 (0.03/day)
Processor AMD Ryzen 7 5900x B2
Motherboard ASUS TUF GAMING B550-PLUS
Cooling Thermalright Peerless Assassin 120 SE + 2x ARCTIC BioniX P120
Memory 2 x 16 GB Crucial Ballistix BL2K16G32C16U4R - DDR4 3200 @3800 CAS 16
Video Card(s) GeForce RTX 3070 FE
Storage WD Black SN770 1 TB|Samsung 970 Evo Plus 1 TB|Sandisk Ultra II 960GB|WD Blue 4 TB|2x WD Green 3 TB
Display(s) Huawei GT27 & LG OLED55B9
Case Fractal Design Define R5
Audio Device(s) SMSL Q5 PRO & ELTAX Monitor III|FOSI AUDIO K5 PRO MINI & SENNHEISER HD 598 PRO
Power Supply Seasonic FOCUS Plus 550 Gold
Mouse Logitech MX Master 3
Keyboard Logitech MX Keys
Right. What's your Temps on stress full load?
And finally my 5900X with PBO 185/130/185 and CO per core (tested with CoreCycler). + 50 MHz boost to achieve 5 GHz on ST.
freeagent
9,912 (4.21/day)
Winnipeg, Canada
Processor AMD R9 9900X
Cooling Thermalright Frozen Edge 360, 3x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 26-36-36-68 1.45v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
For me gaming load is good enough. So as long as it's stable in what you do good enough and I game
Whatever floats your boat :)
1,797 (1.00/day)
Over the Hill UK
System Name AMDWeapon
Case Montech 903 MAX AIR
VR HMD -
Software Windows 11 Pro 24H2
freeagent
9,912 (4.21/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
What's a sufficient load Mr Freeagent? Cinebench is what I always use. You on about prime/pi?
I am a Linpack guy :)
If you build for that, everything else is a joke :)
1,797 (1.00/day)
Over the Hill UK
VR HMD -
freeagent
9,912 (4.21/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
If I ran Linpack, instant 89C, guaranteed. 79C with Linpack is silly...
That is why when I see R23 being used, I just think teehee..
1,797 (1.00/day)
Over the Hill UK
VR HMD -
freeagent
9,912 (4.21/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
1,797 (1.00/day)
Over the Hill UK
VR HMD -
5,602 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
OneMoar
There is Always Moar
8,814 (1.62/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
OneMoar
8,814 (1.62/day)
Rochester area
What's the Core/SoC voltages like?
No idea this was a hail marry run and is NOT stable first time I have seen a CO offset cause a page fault in non paged
664 (0.31/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Motherboard TUF GAMING B550-PLUS WIFI II
Memory 32 gigs - 3600hz
Video Card(s) EVGA GeForce GTX 1080 SC2 GAMING
Storage NvmE x2 + SSD + spinning rust
Display(s) BenQ XL2420Z - lenovo both 27" and 1080p 144/60
Case Fractal Design Meshify C TG Black
Audio Device(s) Logitech Z-2300 2.1 200w Speaker /w 8 inch subwoofer
Power Supply Seasonic Prime Ultra Platinum 550w
Mouse Logitech G900
Keyboard Corsair k100 Air Wireless RGB Cherry MX
Software win 10
Benchmark Scores Super-PI 1M T: 7,993 s :CinebR20: 5755 point GeekB: 2097 S-11398-M 3D :TS 7674/12260
Nutt sure if i´m offtopic, but what should i use as
PPT - TDC - EDC on my 5800x3d with a 360 AIO, if i wanted to abUSE it ?
freeagent
9,912 (4.21/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I just leave my power limits alone on my 58X3D. I give it a -28 all core curve and call it a day.
664 (0.31/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
Yea Curve optimizing i got covered, i just wondered what is what.
freeagent
9,912 (4.21/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
That's it pretty much.. set your if/mem speed and enjoy.
If you are into tweaking.. not a good CPU for that..
3,876 (1.93/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 85C temp limit, CO -8~14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
X3Ds are pretty much "locked" at their advertised speed.
Not much you can do, other than trying to make them run cooler with CO.
NonX3Ds can boost way higher than default specs as long as you keep them cooled
5,602 (1.02/day)
Gougeland (NZ)
GET SHAT ON @ ThreadShitter 1950X
not to worry gentlemen, I know its not an impressive score at all but this is my first and only ryzen cpu so im still testing the waters as it were, and this felt quite nice smiley face
That's pretty much what I used to get on mine with 4.75GHz all core OC couldn't do more than that though because it would get oodles whea errors and eventually BSOD but 4.75 all day everyday was sweet as a nut
4 (0.03/day)
Motherboard MSI X570 Tomahawk
Cooling Coolermaster Ml120
Memory 4x8GB Corsair RGB Pro @ 3600 cl 16-8-20-16-30-58
Video Card(s) Rtx 3090
Storage Samsung 980 Pro, WD Sn350
Display(s) OLED Samsung S90C 2nd gen
Case Fractal design Define r5
Audio Device(s) Arctis Pro Gamedac
Power Supply Corsair ax1200
Mouse Razer Basilisk V2
Keyboard Corsair k90 RGB
Hey everyone, been reading into PBOI and Curve offsets for my 5800x. Hoping someone here can check out my current situation. Am I supposed to be getting worse multi and single core scores on CB after enabling CO + PBO vs just PBO? I expected single core to improve, and multi core to stay the same or get worse by a small margin. after finding my offsets which took a while, I tested stability with Corecycler for 7 hours and OCCT for 1hr.
AGESA 1.2.0..ca (Bios date 7/16/24). Also, in bios I have my Vcore offset set at -0.004, and boost override set to +100mhz
My PC is aging and I would like to get the most out of it. I just finished OC'ing my memory which was one hell of a 3 weeklong adventure. Ram is TM5 @ Anta777 Extreme 12hr stable and OCCT stable for 3hrs.
Offsets and PBO limits along with test results in the pictures below. If anything looks off, let me know. I'm still new to this.
For ease, I'll write offsets as well.
-8 -6 -20 -22 -20 -13 -10 -15
160W PPT
100A TDC
85A EDC
Memory+Timings
Showing my PBO Limits + Curve Offsets in ROPbench
HWInfo With PBO + CO after 1HR of OCCT Core Cycling FFT Small CPU Stress Test
CBR23 With PBO + CO results
CBR23 PBO Enabled, No CO
1,780 (0.88/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
Results below. If anything looks off, let me know. I'm still new to this.
Memory+Timings
What is your CO values? Have you set them to negative?
A free boost you can get easy for gaming is trying 3800/1900 or 3733/1866 on ram. Raise rcd to 21, rc to 60 and rfc to 560. Rest may woek fine as is. Maybe you need a bit more iod voltage.
izy
1,072 (1.10/day)
Memory+Timings
You can use PBO2Tuner to adjust the CO and PBO in windows while u testing (this worked best for me).
You can find it here (i just google it , you can also get it if you download CoreCycler)
It should look something like this
4 (0.03/day)
my 2nd pic lists my co offsets but I will put them in my initial post and here.
Also, the ram I have took a long time to get to the timings and frequency. its rated for 3200mhz. It was very difficult to get it to the timings and speed it is at now. But if you really think that it will increase my gaming performance noticeably, I will work on it. Aida64 reports my memory latency as 61ns. With XMP, that value was 67ns.
Thank you, I should have specified that I already have my CO offsets in the 2nd pic I posted. It shows ROPbench and has my offsets along with my PBO values. ROPbench Imo does the same thing as pbotuner2 plus more.
I would like to know something. I ran OCCT CPU + Ram test. It maxes out my limits further than just a CPU test. I wanted to know the effect of setting PBO limits in real time, so I played with them and watched my clock speed. If I was at 100% Utilization of my PBO limits, my clock speed would drop on TDC and PPT. With EDC even at 100% utilization, the "Sweet spot" seemed to be 85A. Any lower or higher and my effective clock speed would drop. I did the same thing with TDC and PPT. With PPT it was 160W. 10W below max usage during OCCT. Any lower or higher and my effective clock speed would go down. TDC was a little harder to gauge, but I noticed clocks being affected when TDC was below or higher than 100A. Im curious if this test I did is only specific to stress testing with OCCT, or If I set the PBO values I found, will they be correct for gaming as well?
