5800x (and other Zen 3 chips) PBO settings/Temperature fix
1,775 (1.00/day)
Over the Hill UK
System Name AMDWeapon
Case Montech 903 MAX AIR
VR HMD -
Software Windows 11 Pro 24H2
I can run Y Cruncher 2.5B, no crashes. Cinebench, any of them, no crashes. CPU-Z, no crashes. COD MW2 multiplayer, CRASH! I just don't get what I've done wrong. No CO on any core. PPT 120 TDC 80 EDC 110 boost override 125mhz. That is all I have done. Anyone got any ideas for me? I can get nearly 16.000 in R23, but I can't play my game. I understand I'm just annoying now, constantly asking endless stupid questions, but I feel I have no choice as I don't understand. Sorry.
OneMoar
There is Always Moar
8,802 (1.63/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
cod crashes
game is broken
1,775 (1.00/day)
Over the Hill UK
VR HMD -
cod crashes
game is broken
I know what you mean. But the game hanging and rebooting isn't a standard crash for COD. Until I started overclocking, it has been pretty solid!
6,177 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Check event viewer for critical errors.
1,775 (1.00/day)
Over the Hill UK
VR HMD -
No critical errors. Just the usual ones.
OneMoar
8,802 (1.63/day)
Rochester area
turn the boost clock overide off
it does NOTHING except add instablity in most cases
the problem is that at load it doesn't matter because it will never boost that high under the load
but when launching a program it MAY try and boost to its maxium where its simply not stable
23 (0.03/day)
System Name CYX PC
Processor Ryzen 7 5800X
Motherboard Asus Rog Strix B550 E-Gaming
Cooling Arctic Liquid Freezer II 360 - x11 total case fans - Arctic P12 120mm (x9) - Arctic F8 PWM 80mm (x2)
Memory GSkill TridentZ 3200mHz 16CL (32GB - 4x8GB)
Video Card(s) Gigabyte RTX 3070 Ti - Gaming OC (Rev 1.0)
Storage Samsung 970 Evo Plus M2 (500GB) - Samsung 970 Evo Plus M2 (2TB) - Toshiba P300 HDD (3TB)
Display(s) Acer Nitro XV342 CKP (IPS 144hz - 1ms - Flat Ultrawide - GSynch Compatibility)
Case LianLi Dynamic O11 Midi (Black)
Audio Device(s) Fenton Studio Speakers 120W/Yamaha Sub 80W - Logitech G Pro X Gaming - AudioTechnica ATH-M50x Studio
Power Supply Corsair RMx 650W (2018)
Mouse Razer Deathadder Elite
Keyboard Motospeed CK-104
Yesss. The COD stress the cpu all time.
Turn off the boost. This game is unstable with OC.
1,775 (1.00/day)
Over the Hill UK
VR HMD -
Well I have since turned the boost clock off and R23 gave me 15,777. All cores @ 4600's and only 68C!
CoD now works without a hitch. So I'll leave the boost alone. Until someone knows how to have boost and for it to be properly stable.
Thank you @OneMoar @cyx2111 for the advice.
6,177 (2.85/day)
Poland
Or it can try to boost on super low loads like during map change and then boom, black screen reset.
1,981 (0.43/day)
Denmark
Processor Ryzen 5 7600
Motherboard Asrock B650 PG LIgtning
Cooling arctic freezer 36
Memory 2 x Team Group T-Create Expert DDR5-6000 - 32GB - CL30 (64gb)
Video Card(s) ASUS Dual GeForce RTX 4070 EVO
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case Corsair 5000D airflow tg
Audio Device(s) Yamaha R-N800A Syatem audio signature 5
Power Supply Corsair RM850X White
Mouse Asus Rog Gladius III Wireless Aimpoint
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit, Free Avira Security
not enough vcore or unstable memory
23 (0.03/day)
System Name CYX PC
Τhe best OC @AllCores of 5800X its the 4.600@1.25V Offset (SWEET SPOT). Its 100% stable with low temps. I attach one excell of all OC tests for classic overclocking (ALL CORES)
The other way which does not kill the processor but you have to spend a lot of time until you find the volts its the Undervolt PER CORES.
Just hold the 1st method. 4600 @1.25V. Your score in R23 (15.777) is P.E.R.F.E.C.T.
If you play WARZONE 2 the 68C is good when CPU loading the main screen. Ingame with this OC i had 63-64C max.
1,775 (1.00/day)
Over the Hill UK
VR HMD -
I forgot to mention, this is a 5700X, in case you thought I had a 5800X, lol.
Oh yeah, I play multiplayer not Warzone. I'm mental and sprint at people with a sniper.
23 (0.03/day)
System Name CYX PC
1 1/2 years I analyze and works on 5600X/5800X. I have not dealt with the 5700X atm. Finally your score and the temps its cool. Just check if you are stable. Run the OCCT for 1h and check for errors and check your temps. Use these settings.
1,775 (1.00/day)
Over the Hill UK
VR HMD -
I will run that tomorrow and find out. After a little while in cod 61C was the max it got to.
tabascosauz
8,209 (2.34/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Not inconceivable that boost override alone could be the culprit, but then again if you're unstable at +125 with no offset then it's hard to believe that you would be stable at +0. For late prod Zen 3 the V-F curve is not that dramatic below 4.8GHz at the very least.
CODs have been very hard on GPU stability and mem stability since MW19, so check both your undervolt (if running one) and do some TM5 testing. It is a bit less CPU-bound on average compared to MW19.
MW2 isn't the most polished game ever, but at this point it's pretty hard to blame crashes on "game bad lol".
61C sounds about right, game is not so CPU-heavy, only shader loading is.
1,981 (0.43/day)
Denmark
ryzen 7 5800x, prime 95 small fft stable 77c 4525mhz dark rock pro 4, just under 850 rpm
blend 69c, under 800 rpm, offset 0.500volt curve optimizer -30, cpu boost clock override 50mhz (4900mhz)
aida64 cpu,fpu,cache,gpu (rx 6700 xt) 81c just under 1000 rpm
Mussels
Freshwater Moderator
58,413 (7.87/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
That's a simple one: turn the boost overclock off and see if the crashes stop
Theres no guarantees its related to the PBO settings
Random app crashes are far more likely to be memory related, tbh.
1,775 (1.00/day)
Over the Hill UK
VR HMD -
Boost overdrive is off and I'm just finishing occt 1 hour stress test.
Finished 1 hour occt test. Max temp was 65C. Effective all-core 4630mhz the whole time.
Mussels
58,413 (7.87/day)
Oystralia
That's a good result - my 5800x wouldnt do that without a curve undervolt, it sat around 4.4GHz on my asus board (the gigabyte board with its less honest wattages does around 4.5 stock)
izy
1,065 (1.13/day)
What speed is your ram at? My 5700x works with +200 boosts and curve but only 3733 mhz on RAM, CB 15850 and in games it turbos to max (4850 mhz). I think it can be some RAM related problem.
offtopic, go ask ChatGPT :)
1,775 (1.00/day)
Over the Hill UK
VR HMD -
3800mhz
1,775 (1.00/day)
Over the Hill UK
VR HMD -
@izy On 3733/1867, 200mhz boost. Tried cod and numerous benchmarks, seems to be holding up.
Correction. Did not like cod at all. Now on 3600/1800 50mhz boost and it's okay.
OneMoar
8,802 (1.63/day)
Rochester area
semi on-topic @Blaeza
but it looks like IW disabled Multi Threading with the S2 update
would explain the extreme instablity with boost override on
tabascosauz
8,209 (2.34/day)
Western Canada
System Name ab┃ob
Done any TM5 lately on these RAM profiles you're running? Event Viewer look clean?
You sure? Been monitoring HWInfo and so far performance, CPU load and GPU load seem unchanged in the S2 update. I never noticed either MW19 or MW2 to be super multi threaded during gameplay, beyond maybe 2 cores.
Except for updates and shader loading, which are all-core and have been happening a bit more frequently lately.
