5800x (and other Zen 3 chips) PBO settings/Temperature fix
5,602 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
4.4 all core with 4.85 single threaded is default behaviour
4.7 all core is extremely uncommon
I can literally send you my settings bruh, i could actually save my BIOS settings to a file and send it :p
Make sure you're on the new W11 happy BIOS as it has other improvements, i'll go take a photo for ya
Make sure to use the advanced menu PBO, not AI tweaker
I also have negative 10 on core optimiser (lower can hurt boost clocks, but help MT. gotta find the balance)
1.15v SOC and 1.4V DRAM let me go all the way to 4GHz on this ram totally stable (but with WHEA errors) so if you wanted to try OCing the ram later, thats how
Bar the ram settings that's pretty much what I have in my BOS settings and yeah already running the 4021 BIOS
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Lowering the max boost over-ride increases all core boost
50/100 seems to be the sweet spot between single thread boost and all core
Whea Warnings mean your system is unstable fullstop
it causes stuttering and other performance loss as re-transmission data is slow
@mussles whats your IOD voltage ?
Interesting, i didnt know that
IOD is at stock, whatever that may be
OneMoar
There is Always Moar
8,814 (1.62/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
welp there is your problem
under the vddg voltages there is two settings
vddg ccd and vddg iod
set the iod to 1.040-1.060 _imc/ i/o die voltage
set the ccd to 1.020-1.040 voltage for the ccd complex and interconnects doesn't usually need much over stock doesn't really scale with more voltage
and your wher warnings will go away keep those voltages at least 0.040 below Your LOAD vsoc voltage
*warning some boards only control that voltage as a whole number so use 1060 and not 1600 lol
Mussels
58,412 (7.85/day)
Oystralia
I've been doing this since the 386 days, my brain is *melting* at all these new controls and voltages
5,602 (1.02/day)
Gougeland (NZ)
How do think I feel I've doing this since the 286 days so my brains actually have leaked out onto the floor and slid away and hid someplace
Mussels
58,412 (7.85/day)
Oystralia
System did not like those voltages at all, led to a lot of bootlooping and fails
496 (0.23/day)
Texas
System Name i'm done in
Processor AMD 5950x
Memory GSkil 64gb 3600 cl16
Video Card(s) Power Color R7900xtx Hell Hound oh hell ya
Storage 2x wd sn770 2tb 1-4tb wd- hd 2x8tb wd hd actually 1 fire cuda
Display(s) LG Ultra Gear 1440p 32" 165hz hdr monitor might go oled
Case Corsair 4000D Air Flow
Power Supply EVGA SuperNOVA 1000w G5 80+ Gold
Mouse logitech and roccet wcord
Keyboard logitech
Software W10 forever
i have run iod at .950 and ccd at .900. don't know what stock is anyway. don't make any difference in stability. I was able to get 4.925ghz stable by setting cores 2,3,4 to -30 in bios pbo to +75. tried to set pbo higher but, 4.925ghz is all it's going to do so end of story here. setting the cores as stated killed mt performance as in 4.2ghz. using ppt=125,tdc=80,tdc=110 every thing else is stock other than docp enabled. 4.85ghz does it for me.
btw i do have a 5900x that I have not used I may sale both processor's and buy a 5950x and call it a day for the next serval years.
OneMoar
8,814 (1.62/day)
Rochester area
interesting you might have one with negative voltage scaling
my research indicates that
-some chips like vsoc and nothing else
-some chips like more iod voltage and nothing else
-some chips scale negatively with more voltage usually above 1.100 VSOC but sometimes iod/>950
iod/ccd is .700 most boards set it to .900 or 1.0 when enabling xmp
amd has made this quiet 'fun'
run zen timings to get your current iod/ccd voltage
freeagent
9,823 (4.18/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
AMD has no consistency like the “other” guys. That my guess on why every chip is so different.
88 (0.06/day)
System Name NR200 SuperSport Speed Machine yet quiet
Processor Ryzen 7 5800x
Motherboard Gigabyte B550I AORUS PRO AX
Cooling Noctua NH-D15 w/Thermal Grizzly Kryonaut
Memory Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4 3600Mhz
Video Card(s) Sapphire AMD Radeon RX 6800 Nitro plus 16GB With SAM and OCed
Storage Samsung 970 EVO PLUS 1TB NVMe M.2 Solid State Drive
Display(s) Gigabyte G27Q GAMING MONITOR 1440p 144hz IPS HDR "1ms"
Case Cooler Master NR200P w/Mods w/Full Noctua fans
Audio Device(s) Beyerdynamic DT 770 PRO 80 Ohm/Ifi Zen Dac v2
Power Supply Corsair SF 600 W 80+ Platinum Certified Fully Modular SFX
Mouse Glorious Model D Matte White w/Mousepad: Cooler Master MP511 (Size XL)
Keyboard Cooler Master CK550 Gateron Red Switch w/Tai-Hao Doubleshot PBT Backlit - Cool Gray/Navy
Software Microsoft Windows 10 Pro Full - USB 32/64-bit
Benchmark Scores https://www.3dmark.com/spy/27840416
Whats the max PBO settings for a 5800x? Because My D15 arrives soon :D
(As in PTT TDC EDC)
496 (0.23/day)
Texas
Processor AMD 5950x
Keyboard logitech
about 4.85ghz out of the box. Some tinkering around 5.05ghz is possible but no guarantees.
Mussels
58,412 (7.85/day)
Oystralia
(As in PTT TDC EDC)
999 in every field is the max
496 (0.23/day)
Texas
Processor AMD 5950x
Keyboard logitech
Default for ppt:142,tdc:90,edc:140
88 (0.06/day)
Which power settings should I have for a bit above stock? Because I have temp headroom :D
496 (0.23/day)
Texas
Processor AMD 5950x
Keyboard logitech
That’s where the
this is where the fun starts, if you are a masochist.:laugh:
88 (0.06/day)
Thanks
Take EDC .9x of PPT. Either elevate PPT to 156W, or reduce EDC to 126A.
so like PPT 156, EDC 140 and then how much for TDC? :D 90? 100?
496 (0.23/day)
Texas
Processor AMD 5950x
Keyboard logitech
there is a lot more to it than ppt,tdc,edc, that's just the tip
88 (0.06/day)
I Already adjusted my Ram speed/timings, GPU, PBO2 CO and Auto OC :D
496 (0.23/day)
Texas
Processor AMD 5950x
Keyboard logitech
I Already adjusted my Ram speed/timings, PBO2 CO and Auto OC :D
stability testing will tell you if you are going in the right direction.
88 (0.06/day)
Those tuned parts are all stable and because I'm replacing my NH-L12s to a D15 I need to adjust my PBO power settings :D
496 (0.23/day)
Texas
Processor AMD 5950x
Keyboard logitech
4.7ghz AC of course.:eek::D
88 (0.06/day)
freeagent
9,823 (4.18/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
496 (0.23/day)
Texas
Processor AMD 5950x
Keyboard logitech
CO core 2,3,4 -30.
