9070 and 9070XT power consumption leaked by HUB
1,793 (0.88/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
2,979 (6.41/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
That is impressive :)
You’d think so, but RDNA 2 was notoriously shit in RT. Add a decent overall performance uplift and this is less “impressive” and more “actually what it should be to compete”.
It should also be noted that we are talking what is essentially 1080p with frame gen. Not surprising for heavy RT, but still kinda stings when put in perspective. Granted, NV ain’t doing much better here once you turn up their gimmicks up on mid-range cards either.
1,022 (0.17/day)
System Name HTPC whhaaaat?
Processor 2600k @ 4500mhz
Cooling Noctua NH-C14
Memory Gskill Ripjaw 2x4gb
Display(s) Vizio P 65'' 4k tv
Case Lian Li pc-c50b
Audio Device(s) Denon 3311
Power Supply Corsair 620HX
I would say so, yes.
As always, I look at mins. But still, if 1080p->4k raytracing is actually realistic on this thing...That's pretty sweet.
Ofc, I wonder how it (FSR4) looks. I'm sure it isn't bad, and will only get better, but I'm not going to go bananas just yet given how that ToyShop demo looked.
I'll say it again, I do champion good framerates across resolutions (and up-scaled resolutions) with this technology over better IQ that is not, but, you know, better IQ is better than worse IQ.
1,128 (1.73/day)
Apparently this results are not gpu only, so it would be better to judge by differences rather than absolute values while comparing. Eg. 9070XT system consumes about 80w more than 5070TI.
It does not look good at all. It seems that they clocked the 9070XT as far as it was possible out of the box.
I wonder how idle power draw will look like, my MSI 5070 Ti somehow refuses to draw less than 30W with two monitors hooked up.
1,022 (0.17/day)
So the 9070xt likely is similar to a 4080s in performance? That's how I would read those charts.
Accurate, afaict. This is my interpretation right now (we'll know more soon):
If similar-ish to 4080:
Stock: slightly under 60fps 1080p BMW
OC: 1080p60mins in BMW
OC + 4k up-scale + FG: 60fps perhaps in BMW (with perhaps tolerable latency)
If that's true, and it's really important if it is or isn't IMHO, that's a win. That's exactly what people need. I hope IQ is good, I hope it gets better, but that's a good 'mid-range' card RN imho if it can do that.
I'm also very curious how it will do in Outlaws at 1440p and 1440p->4k. These are kind of important dividing lines (imho), and *could* be what separates something like a XT/XTX (or future tiers of cards).
If it can all of those things okay, I'll be impressed.
14,404 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Doesn't look like they improved efficiency much (based on performance claims) and the cards are still very power hungry compared to Nvidia equivalent.
Tell me you're an Nvidia fanboi without telling me. *sigh.
1,022 (0.17/day)
I mean, it's fair to an extent, though, right?
I mean, I very much am on the side of cheaper cards with less units that can (over)clock higher, even if they use more power.
Some are in the camp of lower-clocked cards with more units that are more energy-efficient. (That you'll desire to upgrade every gen bc planned obsolescence.)
Both are fair opinions depending upon how you view the world. I will always argue people are not stressing their card 100% 24/7 etc, and to think about that, but it truly is somebody's prerogative.
I just ask people keep an open mind and be realistic; it's fine if you value one thing over another (especially, for instance, if you're running a SFF with limited thermal allowance, etc).
If you like to tinker and play around, sometimes power be damned, hoping that the limit of your card will surpass the next setting you can toggle at 60fps mins, which AMD card's often can, then that's cool too.
In many ways it really just depends on what kind of person you are, and what you're trying to accomplish.
14,404 (3.80/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
I mean, I very much am on the side of cheaper cards with less units that can (over)clock higher and cost less money, even if they use more power.
I just ask people keep an open mind and be realistic; it's fine if you value one thing over another (especially, for instance, if you were running a SFF with limited thermal allowance, etc).
I want AMD and Nvidia to get their act together and lower power consumption without loss of performance. Every other industry can do it, why can't they.
7,782 (5.08/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Frame Generation seems to be enabled, and 19 fps seems like a notoriously poor result, especially with frame generation enabled. This would be a supreme edge case, mostly because it exposes the absolute worst case scenario for a RX 6800 XT - which was horrible at ray tracing to begin with. Personally, I expect somewhere around 80% faster than 6800 XT in "real world" RT workloads, less in pure raster, which should slot it in the RTX 4070 Ti Super's performance level or thereabouts. Guess we'll see in a couple of hours, although I'm probably going to be asleep when W1zz publishes the reviews.
Given the leaked results, it does seem like the extra 100 to 120 watts over the 5070 non-Ti is relatively consistent, although it should also be faster. I did notice something though, the 5070 uses a good chunk more power than the 4070 did. GDDR7 is supposed to be more efficient, so I'll chalk that to more aggressive clock speeds and more shaders, I suppose.
1,022 (0.17/day)
Many times I feel it comes down to optimal configurations (unit/clock ratios that line up for the ability of libraries on a process matched with available bw/buffer options), and then somewhat matching markets. Sometimes that means optimal perf/w, sometimes maximum perf per design. It all depends.
I really do think it could be potentially interesting next-gen, if say AMD continues to use a high-clocking process and nVIDIA a more power-efficient one, with similar designs...what will people choose?
It would be then people would have to put their money where their mouth is.
Right, but it's not about the 6800xt at all, which is (pretty much) a raster card. It's about what the 9070 xt can do.
Given your expectations, I think you will be pleasantly surprised. I mean, again, I think it's going to be like a 4080 more-or-less when it's OC'ed. Is it miraculous? No. Good value? Yeah.
7,782 (5.08/day)
São Paulo, Brazil
Cautiously optimistic, really. I'm hoping to be pleasantly surprised when I wake up. They might just be able to steer the ship around, the press releases of a few days ago left me satisfied.
The lead time on my RTX 5090 was meant to be around ~68 days (currently we're at day 35 since launch day event), and that's more than I'm honestly willing to wait as it is. If there are any further delays I think I'll cancel my order and buy one of these.
14,404 (3.80/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Jayz2Cent gave a sly hint they will be worth waiting for
6,203 (0.85/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Because you don't understand the fundamental physical limitations of silicon fabrication at the Moore's Law wall. Go away and learn that and then you won't post such stupid things.
1,888 (0.40/day)
Romania
I bet that undervolting does miracles once again.
I am a strong advocate for undervolting. But i did not have any luck with my 6650 XT, unless i drop the frequency too. On the 7xxx and upcoming 9xxx there might be a better results.
1,022 (0.17/day)
Well, in what regard? In the respect they may be binned at a higher voltage (for yield) and then power-limited, so then you under-volt them to see where it will hit the PL while clocking higher?
I mean, I don't really call that under-volting. I call that the new overclocking. If you're *really* under-volting, you're trying to find the point of diminishing returns.
In that respect, I think these will be well-matched at stock. If you're not going to touch the memory, you might be able to undervolt ~10% and lower PL ~20%, but you could just as well up everything ~10%.
In the end, you might save 20% power or gain 10% performance for 20% more power, but in the grand scheme of these cards I think it's going to be worth pushing them as they *appear* to be on the brink of a lot of settings at 60fps. JMO based on what we've seen. We'll have to see which side of the fence they typically fall at stock, and then people can/will correct accordingly.
980 (0.62/day)
System Name 1. Glasshouse 2. Odin OneEye
Processor 1. Ryzen 9 5900X (manual PBO) 2. Ryzen 9 7900X
Motherboard 1. MSI x570 Tomahawk wifi 2. Gigabyte Aorus Extreme 670E
Cooling 1. Noctua NH D15 Chromax Black 2. Custom Loop 3x360mm (60mm) rads & T30 fans/Aquacomputer NEXT w/b
Memory 1. G Skill Neo 16GBx4 (3600MHz 16/16/16/36) 2. Kingston Fury 16GBx2 DDR5 CL36
Video Card(s) 1. Asus Strix Vega 64 2. Powercolor Liquid Devil 7900XTX
Storage 1. Corsair Force MP600 (1TB) & Sabrent Rocket 4 (2TB) 2. Kingston 3000 (1TB) and Hynix p41 (2TB)
Display(s) 1. Samsung U28E590 10bit 4K@60Hz 2. LG C2 42 inch 10bit 4K@120Hz
Case 1. Corsair Crystal 570X White 2. Cooler Master HAF 700 EVO
Audio Device(s) 1. Creative Speakers 2. Built in LG monitor speakers
Power Supply 1. Corsair RM850x 2. Superflower Titanium 1600W
Mouse 1. Microsoft IntelliMouse Pro (grey) 2. Microsoft IntelliMouse Pro (black)
Keyboard Leopold High End Mechanical
These numbers are quite odd. Even so, it will still be more efficient than the previous generation, and the 9070 will undoubtedly be more efficient than the 5070.
Someone has been busy with photoshop.
183 (0.29/day)
Holy Roman Empire
System Name DeathStar /// DeathStar II
Processor AMD Ryzen 7 7700 /// AMD Ryzen 9 5900X
Motherboard Asus ROG Strix X670E-E Gaming /// Asus ROG Strix B550-E Gaming
Cooling Noctua NH-D15S chromax.black /// Thermalright Royal Knight 120 SE
Memory Kingston Fury Beast RGB 6000C30 2x16GB /// G.Skill Trident Z RGB 3200C14 4x8GB
Video Card(s) Zotac GeForce RTX 4080 Trinity 16GB /// XFX Radeon RX 6600XT 8GB
Storage Kingston KC3000 2TB + Samsung 970EVO 2TB + 2x WD Red 4TB /// Samsung 970EVO 1TB + WD Red 4TB
Display(s) Gigabyte M27Q /// Dell U2715H
Case Fractal Define 7 Black /// Fractal Define R5 Black
Power Supply Seasonic SS-750KM3 /// Seasonic SS-660KM
Mouse Logitech MX Master 2S /// Logitech MX Master
Software Linux Debian 12 x64 + MS Windows 10 Pro x64
Looking good :)
1,128 (1.73/day)
Post more! :)
Oh, you just copied a picture from Videocardz without giving them credit, do not bother then.
3x0
998 (1.13/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB Noctua NF-A12x25 Edition
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Endgame Gear OP1 8K
Keyboard HyperX Alloy Origins Aqua
183 (0.29/day)
Holy Roman Empire
Post more! :)
It is YouTube screenshot from TYC and their logo is visible.
183 (0.29/day)
Holy Roman Empire
I knew the source, you just made me search for more without a chance for finding more.
Sorry about that, I was posting via mobile phone while taking a sh1t.
229 (2.60/day)
Missouri
System Name The
Processor Ryzen 7 5800X
Motherboard ASUS PRIME B550-PLUS AC-HES
Memory Silicon Power 32GB (2 x 16GB) DDR4 3200
Video Card(s) RTX 2080S FE | 1060 3GB & 1050Ti 4GB In Storage
Display(s) Gigabyte G27Q (1440p / 170hz DP)
Case SAMA SV01
Power Supply Firehazard in the making
Mouse Corsair Nightsword
Keyboard Steelseries Apex Pro
Yea, we will eventually start hitting i9-9900k levels of insanity with the TDP's on GPU's, and then something will kick them in the balls to make them go 'okay maybe we shouldn't just turn up the TDP..", for Intel, it was the higher TDP 13th and 14th gen processors going caput.
