- Jan 25, 2023
- 34 (0.04/day)
Air is always more logical than water in with a bunch of expensive equipment...that's how.How is this possibly better than a single slot water block.
System Name | boomer--->zoomer not your typical millenial build |
Processor | i5-760 @ 3.8ghz + turbo ~goes wayyyyyyyyy fast cuz turboooooz~ |
Motherboard | P55-GD80 ~best motherboard ever designed~ |
Cooling | NH-D15 ~double stack thot twerk all day~ |
Memory | 16GB Crucial Ballistix LP ~memory gone AWOL~ |
Video Card(s) | MSI GTX 970 ~*~GOLDEN EDITION~*~ RAWRRRRRR |
Storage | 500GB Samsung 850 Evo (OS X, *nix), 128GB Samsung 840 Pro (W10 Pro), 1TB SpinPoint F3 ~best in class |
Display(s) | ASUS VW246H ~best 24" you've seen *FULL HD* *1O80PP* *SLAPS*~ |
Case | FT02-W ~the W stands for white but it's brushed aluminum except for the disgusting ODD bays; *cries* |
Audio Device(s) | A LOT |
Power Supply | 850W EVGA SuperNova G2 ~hot fire like champagne~ |
Mouse | CM Spawn ~cmcz R c00l seth mcfarlane darawss~ |
Keyboard | CM QF Rapid - Browns ~fastrrr kees for fstr teens~ |
Software | integrated into the chassis |
Benchmark Scores | 9999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999 |
I agree with this comment. I also refuse to work on water cooling rigs now. It's a damn mess and the clean up is just awful. If you keep a regular maintenance to your rig, you can make your components last a long time.Rad fans fail just the same, so I don't see how even that case is valid.
Both can be made user replacable too, we've seen Gainward coolers with replacable fans.
There is no question whatsoever air is more fool proof, its not even a debate lol
Boy you said it. I haven't run an air cooled video card or CPU in like a decade or more and every release makes me glad I switched to water way back when and haven't looked back. When you buy high end video cards today, there should be a drop-down on the store site to select which cooler between air or a full-cover WB. At this point, it makes me wonder if a waterblock wouldn't be cheaper to manufacture considering it may be less overall material than that in an air cooler the size of the one shown in this article and saves cost on fans as well.How is this possibly better than a single slot water block.
Processor | E5-4627 v4 |
Motherboard | VEINEDA X99 |
Memory | 32 GB |
Video Card(s) | 2080 Ti |
Storage | NE-512 |
Display(s) | G27Q |
Case | MATREXX 50 |
Power Supply | SF850L |
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
System Name | HELLSTAR |
Processor | AMD RYZEN 9 5950X |
Motherboard | ASUS Strix X570-E |
Cooling | 2x 360 + 280 rads. 3x Gentle Typhoons, 3x Phanteks T30, 2x TT T140 . EK-Quantum Momentum Monoblock. |
Memory | 4x8GB G.SKILL Trident Z RGB F4-4133C19D-16GTZR 14-16-12-30-44 |
Video Card(s) | Sapphire Pulse RX 7900XTX. Water block. Crossflashed. |
Storage | Optane 900P[Fedora] + WD BLACK SN850X 4TB + 750 EVO 500GB + 1TB 980PRO+SN560 1TB(W11) |
Display(s) | Philips PHL BDM3270 + Acer XV242Y |
Case | Lian Li O11 Dynamic EVO |
Audio Device(s) | SMSL RAW-MDA1 DAC |
Power Supply | Fractal Design Newton R3 1000W |
Mouse | Razer Basilisk |
Keyboard | Razer BlackWidow V3 - Yellow Switch |
Software | FEDORA 41 |
I miss GPU's having standardised screwholes so a cooler would fit an entire series, instead of every GPU having its own custom layout for some goddamned reason.
System Name | Tiny the White Yeti |
Processor | 7800X3D |
Motherboard | MSI MAG Mortar b650m wifi |
Cooling | CPU: Thermalright Peerless Assassin / Case: Phanteks T30-120 x3 |
Memory | 32GB Corsair Vengeance 30CL6000 |
Video Card(s) | ASRock RX7900XT Phantom Gaming |
Storage | Lexar NM790 4TB + Samsung 850 EVO 1TB + Samsung 980 1TB + Crucial BX100 250GB |
Display(s) | Gigabyte G34QWC (3440x1440) |
Case | Lian Li A3 mATX White |
Audio Device(s) | Harman Kardon AVR137 + 2.1 |
Power Supply | EVGA Supernova G2 750W |
Mouse | Steelseries Aerox 5 |
Keyboard | Lenovo Thinkpad Trackpoint II |
VR HMD | HD 420 - Green Edition ;) |
Software | W11 IoT Enterprise LTSC |
Benchmark Scores | Over 9000 |
Bloody consumers keep buying, too.There is no absolute reason for not doing it.
The most sad story is actually we only generate e-waste by doing like that with each generation. Bloody corporate mind does not get the idea that we are screwing up hard our environment and do not properly reuse our resources.
There is no regulator that can force something about it either way.
They can but then who would grease their palms? I mean how do you explain Apple charging ~100 to 200 USD for 256GB upgrade & if course everything's solderedThere is no regulator that can force something about it either way.
Tada ~ you don't have 3 trillion dollar Megacorps without brain dead zealots following them! Of course not all of them are but I'd argue the majority would beBloody consumers keep buying, too.
Exactly. Nvidia also acts like they want to be the Apple of GPUs, a full service provider etc. They shifted the importance of their FE's exactly because of it as the first move (Pascal). It went downhill stupid fast after that: the demise of SLI/mGPU, the entry of RT, the skyrocketing of pricing and then the cutting down of the die while maintaining the price.They can but then who would grease their palms? I mean how do you explain Apple charging ~100 to 200 USD for 256GB upgrade & if course everything's soldered
Tada ~ you don't have 3 trillion dollar Megacorps without brain dead zealots following them! Of course not all of them are but I'd argue the majority would be![]()
Nvidia market share even in discrete gaming is higher than it's ever been. Go figure
Where is Nvidia's program...There is a thing about Apple, that rarely emerges as an argument. They offer trade in for their products, to get a discount and then the product gets properly recycled.
Where is Nvidia's program...![]()
System Name | Firelance. |
Processor | Threadripper 3960X |
Motherboard | ROG Strix TRX40-E Gaming |
Cooling | IceGem 360 + 6x Arctic Cooling P12 |
Memory | 8x 16GB Patriot Viper DDR4-3200 CL16 |
Video Card(s) | MSI GeForce RTX 4060 Ti Ventus 2X OC |
Storage | 2TB WD SN850X (boot), 4TB Crucial P3 (data) |
Display(s) | Dell S3221QS(A) (32" 38x21 60Hz) + 2x AOC Q32E2N (32" 25x14 75Hz) |
Case | Enthoo Pro II Server Edition (Closed Panel) + 6 fans |
Power Supply | Fractal Design Ion+ 2 Platinum 760W |
Mouse | Logitech G604 |
Keyboard | Razer Pro Type Ultra |
Software | Windows 10 Professional x64 |
100%, I believe that every manufacturer should be required to offer trade-in/trade-up programs for older hardware. Apart from being good economic and environmental sense, it helps to build brand loyalty and ensure consumers stick to that specific manufacturer, thus it makes sense for them too in the long term. Really surprised that companies other than Apple haven't cottoned onto this.Where is Nvidia's program...![]()
Sorry.Which is? The image's blocked.
Trade in or buy in still doesn't address the real problem, ok no one does expandable RAM for phones/tablets & expandable storage is getting rarer still, but as far as Macs or MacBooks are concerned there's literally zero effin ways to justify non expandable RAM & storage! Yes I get that they're going with LPDDR5x but there's also massive obsolescence baked into these products, if you can't see the obvious that's on you
As for other manufacturers, well pretty much every major (r)etailer offers exchange programs here & relatively good prices, so no Apple's not special in that sense!
Mobile Phones: Buy New Mobiles Online at Best Prices in India | Buy Cell Phones Online - Amazon.in
Shop for the best mobiles online at Amazon.in and get up to 60% off. Explore Mobile Phones from Samsung, OnePlus, Redmi & more. Grab top mobile deals today!www.amazon.inLaptops: Buy Laptop Online with Up to 40% OFF on Amazon.in
Find the best deals on new laptops online from top brands such as Dell, HP, Apple, Lenovo & many more. Get Up to 18,000 off on exchange & 6 Months No Cost EMIwww.amazon.in
Do they really get that much just from precious materials? I'm getting up to 30k rupees for an 7 years old i5 laptop, which is up to 30-40% of some new models with RTX 4xxx then for new phones the Galaxy S21 FE fetches up to 30-50% of the MRP. That sounds way too high if you're talking about only recycling, the retailers of course also sell a lot of them as renewed/used probably at higher prices.
Wait!Do they really get that much just from precious materials? I'm getting up to 30k rupees for an 7 years old i5 laptop, which is up to 30-40% of some new models with RTX 4xxx then for new phones the Galaxy S21 FE fetches up to 30-50% of the MRP. That sounds way too high if you're talking about only recycling, the retailers of course also sell a lot of them as renewed/used probably at higher prices.
Still sounds an awful lot like Nvidia's game to meTrade in or buy in still doesn't address the real problem, ok no one does expandable RAM for phones/tablets & expandable storage is getting rarer still, but as far as Macs or MacBooks are concerned there's literally zero effin ways to justify non expandable RAM & storage! Yes I get that they're going with LPDDR5x but there's also massive obsolescence baked into these products, if you can't see the obvious that's on you
