Alienware's 34-inch QD-OLED Monitor Gets a Price
2,733 (1.96/day)
Your point being?
I suppose I'm old, but the cringe level on that video is over 9000 even just seeing those two duckfaces on the thumbnail. Holy crap please shoot me off to Mars already.
Nice panel. Too bad about the marketing :D
One of the lines in the vid:
'Hi, what do you do?'
'I'm a Youtuber'
This species is fked.
Oh I have no idea, I was just looking for a product page of some kind and found this stream and skipped around until I found the product announcement :D
840 (0.21/day)
Poland
System Name Proper
Processor 5900X + OC
Motherboard GB X570s Elite AX
Cooling WC Heatkiller 3.0 LT
Memory G.Skill 3600 CL16
Display(s) GB M32Q
Case Fractal Define R6 USB C
Mouse Log G502 X LS
Software Win10 Pro
I'll get the 42" LG OLED TV instead. No 32" is coming this year. I also like the much lighter housing LG is using this year, finally LG OLED TVs would be a total pain to get in and out of the package or move around.
While LG OLEDs can be great as monitors, especially the upcoming 42" one, there's one minor problem - TVs don't have the "sleep/wake-up" function, when You do anything on Your PC. So everytime You walk away from Your computer You'd have to remember to turn the screen off (don't wanna any burn-ins) and then turn it on again after You return.
IPS to better OLED in just $100. Doesn't sound too bad until you notice how garbage monitor price is in general compared to TVs or even mobiles.
It's mostly about the 4k 120Hz+ displays - their price is just ridiculous. Lower res models are acceptable - I just got Gigabyte M32Q (1440p 170Hz with wide gamut) for ~350$.
18,374 (2.46/day)
6,390 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Screensavers are your friend. Other than that these Samsung panels will probably still need to run compensation cycles in standby so turning display off whenever you're away might be a no-no.
Like @TheLostSwede said, QD-OLED is a new tech, it will take time before we'll get first reports on actual burn-in issues.
2,733 (1.96/day)
That this version of HDR is still nonsense.
I disagree, this is very far from what HDR400 or 600 are able to deliver. If you look at the specs, the most significat downgrade you get from HDR1000 is peak luminance required but you also get a massive upgrade in the contrast requirements - mainly because they do a better test.
If anything, HDR should be scrapped entirely and be replaced by True Black that fixes some of it's initial flaws. HDR1000 has been rare in the monitor space imo because monitor manufacturers have been surprisingly honest at not trying to make a mockery of the standard but as has been seen a couple times it's not that difficult to pass even HDR1000 certification with a sub par crappy edge lit panel (Sceptre C345B-QUN168 as an example)
317 (0.08/day)
Does anyone else prefer flat screens vs curved? Having tried 2 different curved widescreens, and gone back to flat, for some reason didn't appreciate the curve
2,272 (0.98/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
very nice, good price too shame i havnt the eyes for it :) .
315 (0.21/day)
System Name Back in Black
Processor Ryzen 7 5700X
Motherboard MSI B550 Tomahawk Max WIFI
Cooling ID-Cooling SE-224-XT Black
Memory ADATA XPG 16GB (2x8) 3200mhz C16
Video Card(s) XFX RX 6700 XT Speedster Merc 319 _larry Edition
Storage Solidigm P41 Plus 1TB / Crucial MX500 500GB
Display(s) Samsung 32" TV 1080p
Case Montech Air X Black
Power Supply Thermaltake Toughpower GF1 750W Gold
Mouse Redragon M711 Cobra
Keyboard Corsair K55
I set my PC to turn off the display after 15 minutes, my old (2014) Samsung TV goes to "no display detected" and turns off automatically after another 10 minutes or so (depending on how long I set it on).
2,048 (0.48/day)
$1300 i very competitive. Especially considering that the G-Sync module costs about $200 by itself and Alienware is always higher priced compared to other monitor manufacturers in the gaming category (well except ASUS perhaps).
Thankfully Samsung Display is allowed to sell QD-OLED panels to others so i have no doubt we will see cheaper alternatives. Perhaps even under $999 (tho not by much).
Im rather suprised tho at the supposedly weak HDR performance of this panel. It seems like LCD's still hold and edge in terms of brightness. Especially Mini-LED ones that are supposed to be half step between LED and Micro-LED.
But for a first generation product QD-OLED seems to be pretty strong overall. Im sure they will increase brightness with 2nd gen panels.
Nvidia should get off its ass and produce an updated G-Sync module that has HDMI 2.1 and DP 2.0 included. Because currently the only advantage a native G-Sync module has compared to G-Sync compatible certification is variable overdrive. Meaning a consistant experience across the refresh range. Diplays that lack variable overdrive often suffer at lower refresh rates in terms of ghosting or other artifacts related to overdrive.
Tho it is possible to properly tune the overdrive to play nice across the range without the module. Problem is that most manufactures dont bother doing it.
1,318 (0.23/day)
CO
System Name 4k
Processor AMD 5800x3D
Motherboard MSI MAG b550m Mortar Wifi
Cooling ARCTIC Liquid Freezer II 240
Memory 4x8Gb Crucial Ballistix 3600 CL16 bl8g36c16u4b.m8fe1
Video Card(s) Nvidia Reference 3080Ti
Storage ADATA XPG SX8200 Pro 1TB
Display(s) LG 48" C1
Case CORSAIR Carbide AIR 240 Micro-ATX
Power Supply EVGA SuperNOVA 650W
Software Microsoft Windows10 Pro x64
ill keep my 48 c1, I want to see a 2nd gen 16:9, flat monitor with HDMI 2.1
840 (0.21/day)
Poland
System Name Proper
Display(s) GB M32Q
Mouse Log G502 X LS
Software Win10 Pro
Still - for the 15min Your display can show nice white planes and tables in excel, or some light coloured website. Whether we want it, or not, OLEDs still do require some care if we want them to work their best.
315 (0.21/day)
Absolutely. The 15 minutes was an example, cause that's what I set up to, but you can set it up to as low as 1 minute. The TV will go to no display and turn off.
610 (0.29/day)
System Name Fractal
Processor Intel Core i5 13600K
Motherboard Asus ProArt Z790 Creator WiFi
Cooling Arctic Cooling Liquid Freezer II 360
Memory 16GBx2 G.SKILL Ripjaws S5 DDR5 6000 CL30-40-40-96 (F5-6000J3040F16GX2-RS5K)
Video Card(s) PNY RTX A2000 6GB
Storage SK Hynix Platinum P41 2TB
Display(s) LG 34GK950F-B (34"/IPS/1440p/21:9/144Hz/FreeSync)
Case Fractal Design R6 Gunmetal Blackout w/ USB-C
Audio Device(s) Steelseries Arctis 7 Wireless/Klipsch Pro-Media 2.1BT
Power Supply Seasonic Prime 850w 80+ Titanium
Mouse Logitech G700S
Keyboard Corsair K68
7,762 (2.68/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Audio Device(s) Optoma Nuforce ÎĽDAC 3
Mouse Logitech G603
Is it though? HDR is mainly about colour space and dynamic range after all, not absolute brightness, and lowering the black level is the easiest way of increasing overall dynamic range (halving the black point is a much smaller change than doubling peak white, after all). I'd imagine even HDR400 True Black can exceed the HDR-minimum 13 stops of DR easily. At 1 nit of minimum brightness you'll need 1000 nits peak just to reach 10 stops (and 2000 for 11 stops, etc.), but cutting that to even 0,02 nits - 40 times brighter than the HDR400 true black permissible black level - sees you hitting 13 stops at just ~160 nits, and 15 stops at ~650 nits. Of course you'll need a reasonably dark room to experience this, and it certainly isn't suited for a brightly lit room. But whether something is true HDR or not is quite separate from whether it's able to display perceptible HDR in any given setting. So if this has decent near-black performance and can hit 1000 nits for small flashes of light, it's probably going to deliver a pretty great HDR experience as long as the room isn't too bright. All the while, most high-end FALD LCDs can at best reach black levels of 0.05 nits, meaning they need much higher peak brightness to display the same dynamic range - ~410 nits to hit 13 stops, and 1600 nits for 15. OLEDs still really struggle in brightly lit rooms - that's why we went Samsung QLED in our living room - but you can't deny their HDR prowess.
Regular HDR400 is pretty much nonsense, especially as those monitors rarely have anything like FALD and thus don't come even remotely close to 0,05 nits black on a screen with a bright spot, but HDR400 True Black can deliver pretty good HDR as long as the room isn't too bright.
(For anyone wondering: contrast ratio is a pretty decent indicator of HDR performance for non-FALD displays, as it maps directly to dynamic range. 1000:1 contrast ratio = ~10 stops of dynamic range, 3000:1 = ~11.5 stops, etc. For true HDR you need at least 8000:1 effective contrast ratio, though that's highly dependent on how close your two measurement points are and the dimming zones of the monitor. Techspot/Hardware Unboxed's bar of 50 000:1 best case single frame contrast and 5 000:1 checkerboard contrast is a pretty good bar for good HDR - and AFAIK the only monitors to hit that bar are the Samsung Odyssey Neo G9 and that insane $4000 Asus one, with the Predator X35 coming very close, while an LG C1 48" hits it easily.)
This chart illustrates well how LCDs struggle to achieve good HDR results without cranking the brightness, while OLEDs can do it without breaking a sweat:
3,913 (0.81/day)
Processor AMD Ryzen 7 5700X3D
Video Card(s) Sapphire AMD Radeon RX 9070 XT NITRO+
Display(s) Hisense 55" U7K 4K@144Hz
Case Thermaltake Ceres 500 TG ARGB
Mouse Razer Deathadder Chroma
Keyboard Logitech UltraX
Price doesn't seem too bad considering it's such new tech, bodes well for future releases I guess.
One of the reasons I went for a QN90A is I did want to have to worry about burn in (or uneven wear) as I bought it specifially to used as a monitor, despite all the screen real estate I always have the habit of keeping my browser window centered too, which would make me uncomfortable on a OLED day in day out. Tick all the other boxes too of 4K, 120Hz, VRR, great HDR etc.
2,048 (0.48/day)
Anther good mitigation is using dark themes whenever possible. It's easier on the eyes (especially at night or after waking up) but also lowers power consumption and extends monitor lifetime (even LCD's not just OLED's).
The first thing i do on an LCD is lower the brightness to 30-50%. By default they come out of factory with 100%. 400nits is too much. Around 150-200 is much better for daily use. Especially combined with dark mode.
2,733 (1.96/day)
I keep my monitor at 100% pretty much always but it's also only a 250 nits panel :D
I'll replace it as soon as there's something worth buying (anything would be an upgrade but I'm not into insane refresh rates and don't want to waste money on the same expensive rehashed panels that have been out for years with barely any improvements - qd-oled might very well be it).
294 (0.09/day)
System Name MacBook Pro 16"
Processor M1 Pro
Memory 16GB unified memory
Storage 1 TB
Might be better just top get the new LG C2 42-inch than this.
2,341 (0.33/day)
Toronto, Ontario
System Name The Expanse
Processor AMD Ryzen 7 9800X3D
Motherboard Asus Prime X670E-Pro Wifi BIOS 3222 AGESA PI 1.2.0.3a
Cooling Corsair H150i Elite LCD XT
Memory 64GB G.SKILL Trident Z5 Neo RGB DDR5 6000 CL 30-40-40-96 1T
Benchmark Scores https://valid.x86.fr/0412jp https://browser.geekbench.com/v6/cpu/11073923
My Current Ultrawide has a 1900R curve which is very mild. I don't like1000R which is a very aggressive curve.
818 (0.18/day)
Poland
System Name THU
Processor Intel Core i5-13600KF
Motherboard ASUS PRIME Z790-P D4
Cooling SilentiumPC Fortis 3 v2 + Arctic Cooling MX-2
Memory Crucial Ballistix 2x16 GB DDR4-3600 CL16 (dual rank)
Video Card(s) MSI GeForce RTX 4070 Ventus 3X OC 12 GB GDDR6X (2610/21000 @ 0.91 V)
Storage Lexar NM790 2 TB + Corsair MP510 960 GB + PNY XLR8 CS3030 500 GB + Toshiba E300 3 TB
Display(s) LG OLED C8 55" + ASUS VP229Q
Case Fractal Design Define R6
Audio Device(s) Yamaha RX-V4A + Monitor Audio Bronze 6 + Bronze FX | FiiO E10K-TC + Koss Porta Pro
Power Supply Corsair RM650
Mouse Logitech M705 Marathon
Keyboard Corsair K55 RGB PRO
Software Windows 10 Home
Benchmark Scores Benchmarks in 2025?
Prices of these monitors are ridiculous. You can get an OLED TV at this price (or cheaper), run a custom 3840x1600 res on it and get 120 Hz, perfect blacks and awesome HDR.
294 (0.09/day)
Processor M1 Pro
Storage 1 TB
That is why the LG C2 42-inch will be a wicked option for gaming.. you get so much more than just a simple computer monitor
2,048 (0.48/day)
Not everyone has space for a tall 42" model. Plus it has agressive auto brightness that cant be turned off.
How so? 1300 (1100 without the G-Sync module) is roughly the same price is see the current 48" CX model being sold. Even cheaper than higher size OLED's.
So the price is very competitive like others have said. Sure it has slightly lower resolution (3440x1440) but it's also more compact to fit on a desk and has higher 175Hz refreshrate.
2,363 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
I'll wait for the AW382# version to be released.
I don't even understand why the comparison is being made. They're two different products with staggered production cycles. This isn't replacing the 38" it's replacing the previous 34" that was discontinued last year. The current 38 is most likely going to be discontinued this year and refreshed the following.
23,718 (6.15/day)
Exactly this.
When VESA started their DisplayHDR spec it was clear as day - literally - that it served shitty LCDs with overtuned backlights. Even so they 'needed' 4-5 different labels to create product segmentation where anything up to and IMHO including HDR600 was just a total PoS, or more of the same nonsense we saw ever since marketing invented 'dynamic brightness'. Its just the next step really to fool us into thinking what we have now is some sort of standard...
Meanwhile after several decades of 'innovation' the only real gain over CRT is resolution and perhaps color accuracy. Not motion response; not black levels and not even static contrast. All those are thrown in the shitter with LCD no matter how many cool stickers you invent.
Vesa then saw OLED enter the market and finally managed to adopt a real standard... even still needing several stickers but now the standard is in fact 'honest' - it provides limitations for a tangible improvement in your viewing experience. True Black is really just 'any self emissive display' and yet, by being yet another sticker in the VESA stickerworld, fooled customers compare it to LCD stickers as if that is even remotely comparable. And VESA achieved some level if credibility and even premium 'feel' for so called 'top' HDR1000 screens.
LCD is still inferior as it always will be. 1000 nits meant nothing other than more fools and money parted while looking straight into a light bulb. Common sense, really, should have dictated extreme peak brightness is never going to be comfortable looking at. The real differentiatior was always 'static contrast'; the reason VA was a nice in between over IPS.
HDR is ultimately 'contrast steps'. If your black 'floor' is low, you have much better control over the entire brightness range. Its a total no brainer OLED is most capable here.
