Alienware's 34-inch QD-OLED Monitor Gets a Price
203 (0.07/day)
I have had the Acer Predator x34 for about 6 or 7 years. Paid a crazy amount for it at the time and it is an amazing monitor. I have not considered an upgrade, but OLED's look great and maybe its getting close to time for an upgrade.
7,762 (2.71/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
Prices of these monitors are ridiculous. You can get an OLED TV at this price (or cheaper), run a custom 3840x1600 res on it and get 120 Hz, perfect blacks and awesome HDR.
Did you miss the part where this is QD-OLED, i.e. a more advanced OLED technology than literally every TV on the market? Sure, monitors are generally stupidly expensive, but this is ... kind of understandable, in a way. Certainly more understandable than $900 edge-lit 2160p HDR400 (or at best 600) 144Hz IPS monitors, that's for sure.
Exactly this.
When VESA started their DisplayHDR spec it was clear as day - literally - that it served shitty LCDs with overtuned backlights. Even so they 'needed' 4-5 different labels to create product segmentation where anything up to and IMHO including HDR600 was just a total PoS, or more of the same nonsense we saw ever since marketing invented 'dynamic brightness'. Its just the next step really to fool us into thinking what we have now is some sort of standard...
Meanwhile after several decades of 'innovation' the only real gain over CRT is resolution and perhaps color accuracy. Not motion response; not black levels and not even static contrast. All those are thrown in the shitter with LCD no matter how many cool stickers you invent.
Vesa then saw OLED enter the market and finally managed to adopt a real standard... even still needing several stickers but now the standard is in fact 'honest' - it provides limitations for a tangible improvement in your viewing experience. True Black is really just 'any self emissive display' and yet, by being yet another sticker in the VESA stickerworld, fooled customers compare it to LCD stickers as if that is even remotely comparable. And VESA achieved some level if credibility and even premium 'feel' for so called 'top' HDR1000 screens.
LCD is still inferior as it always will be. 1000 nits meant nothing other than more fools and money parted while looking straight into a light bulb. Common sense, really, should have dictated extreme peak brightness is never going to be comfortable looking at. The real differentiatior was always 'static contrast'; the reason VA was a nice in between over IPS.
HDR is ultimately 'contrast steps'. If your black 'floor' is low, you have much better control over the entire brightness range. Its a total no brainer OLED is most capable here.
IMO LCD definitely has its uses - as I noted in my first post here I'm still skeptical of OLED for my main desktop monitor due to image retention (a lot of mostly static windows for most of the time on there), and for the living room, which is rather bright, we went for a Samsung Q80 which we've been very happy with. And considering it at times has been just bright enough, an OLED wouldn't have been acceptable in the same location. I'm not particularly sensitive to blooming though, but I can't say I've ever really noticed it at all.
Still, VESA's standards are, as you say, crap. HWUB recently covered just how broken their testing systems are as well, which is downright atrocious (they don't even require their contrast measurements to be made on the same image!), which renders the regular HDRXXXX standard essentially useless - they can be cheated quite easily, and you can pass even HDR1000 with a pretty crap display, as seen in that link.
That is why the LG C2 42-inch will be a wicked option for gaming.. you get so much more than just a simple computer monitor
But you also get some pretty serious drawbacks - a "monitor" that you need to manually switch on and off every time you turn on your PC, that doesn't go to sleep when the PC does or when the PC turns off the monitor, that makes you navigate a relatively slow and clunky OS for simple things like input switching, etc. And no DP or USB-C inputs, of course, or USB hubs or other basic monitor features. Minor annoyances to some, major to others, but they're there regardless.
Does anyone else prefer flat screens vs curved? Having tried 2 different curved widescreens, and gone back to flat, for some reason didn't appreciate the curve
Curved for a 16:9 panel at reasonable sizes (</= 32") doesn't make much sense - there's a relatively small combination of viewing distances and screen sizes (particularly widths) where it does. Ultrawides are another thing entirely though, as their with is so extreme that the curve dramatically minimizes the change in viewing distance between the centre and edges of the screen. A flat ultrawide at a desktop viewing distance would be really difficult and tiring for your eyes to pan around, as they would need to noticeably refocus between the edges and the centre. And, of course, you'd be far enough to the side of that part of the panel that you'd likely start noticing colour shifting on a VA panel or severe IPS glow on an IPS. None of these issues are relevant on a 16:9 panel at the same viewing distances unless it's huge.
3,907 (0.81/day)
Processor AMD Ryzen 7 5700X3D
Display(s) Hisense 55" U7K
Case Antec 1200
Mouse Razer Deathadder Chroma
Keyboard Logitech UltraX
That's the thing, if you use a TV in a bright well lit room as many do an OLED can still lack the brightness required when compared to even a more convential LCD based tech TV even in just SDR content, and it will certainly lack the pop of HDR content as it just doesn't get bright enough.
As always Vincent is superb and explains why they fall short in HDR:
There is a reason why OLED EX are getting brighter. :p
595 (0.42/day)
System Name Jedi Survivor Gaming PC
Processor AMD Ryzen 7800X3D
Motherboard Asus TUF B650M Plus Wifi
Cooling ThermalRight CPU Cooler
Memory G.Skill 32GB DDR5-5600 CL28
Video Card(s) MSI RTX 3080 10GB
Storage 2TB Samsung 990 Pro SSD
Display(s) MSI 32" 4K OLED 240hz Monitor
Case Asus Prime AP201
Power Supply FSP 1000W Platinum PSU
Mouse Logitech G403
Keyboard Asus Mechanical Keyboard
Garbage monitor prices are paid so you don't have a netflix button on your bezel. And an Amazon button. And a Facebook button. And Youtube.
And smart menus when you push OSD buttons filled with ads and half working functions.
And constant updates and connectivity issues.
PLEASE, let me pay more to avoid that shit.
come on, I use an xbox with my TV, I never have any of those issues
2,360 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
You have never used an Amazon branded/subsidized product, I see. It really is exactly that.
203 (0.07/day)
Where exactly does it say this is an Amazon branded product? Is this the new Fire Monitor 34?
You are complaining about something that is not even relevant to the conversation.
400 (0.34/day)
And there's a reason why Vincent is so excited for QD-OLED too (hint: it's brighter than LG's W-OLED)
Anyway, I strongly disagree with TheLostSwede's take here. I've never seen anyone suggest that HDR600 LCD monitors have more impressive HDR capabilities than an OLED TV before, and this display actually offers several significant advantages over LG's OLED tech including higher brightness levels, better color saturation, and less black crush. There's more to a panel's HDR capabilities than the number at the end of the certification.
3,907 (0.81/day)
Case Antec 1200
100% agreed, the Vincmeister posted a vid a couple of days ago about potential prices of the upcoming QD-LED Sony TV's too and they seem to confirm QD-OLED based screens being more affordable than first feared, especially for such new tech, whilst doing away with some of the limitations of LG's tech, I still cringe a bit when people put it on such a high pedestal.
1,131 (0.79/day)
Bavaria ⌬ Germany
System Name ✨ Lenovo M75q-1 [Tiny]
Display(s) DELL S2722DGM
Software Windows 11 Pro (Debloated)
Burn-In proof, UltraWide, curved (QD) OLED, finally a dream comes true. :cool: Expected the price to be more close to 2k instead of 1k.
Not into "Alien" branding, G-Sync tax & "G4M3R" finish, so I will wait for versions from other manufacturers (Samsung, LG, Lenovo, etc. get on it!)
Btw. here's the product video:
Sounds like you do not understand (new) tech & love to throw out money for products that are not designed for static content, and will get damaged in such use cases.
(Non QD) OLED will even get burn in from basic TV content, as the Real Life OLED Burn-In Test on 6 TVs shows.
Never wondered why they haven't released "wicked gaming" OLED monitors, until now (QD OLED)? Hint: Burn-In ;)
814 (0.18/day)
Poland
System Name THU
Processor Intel Core i5-13600KF
Motherboard ASUS PRIME Z790-P D4
Cooling SilentiumPC Fortis 3 v2 + Arctic Cooling MX-2
Memory Crucial Ballistix 2x16 GB DDR4-3600 CL16 (dual rank)
Video Card(s) MSI GeForce RTX 4070 Ventus 3X OC 12 GB GDDR6X (2610/21000 @ 0.91 V)
Storage Lexar NM790 2 TB + Corsair MP510 960 GB + PNY XLR8 CS3030 500 GB + Toshiba E300 3 TB
Display(s) LG OLED C8 55" + ASUS VP229Q
Case Fractal Design Define R6
Audio Device(s) Yamaha RX-V381 + Monitor Audio Bronze 6 + Bronze FX | FiiO E10K-TC + Sony MDR-7506
Power Supply Corsair RM650
Mouse Logitech M705 Marathon
Keyboard Corsair K55 RGB PRO
Software Windows 10 Home
Benchmark Scores Benchmarks in 2024?
I am not saying the new tech will not be better, but I have been using my LG C8 as a monitor for 2.5 years and I have never had any image retention, not to mention burn-in.
Of course I have all the "safeties" enabled, I use dark mode and have it set at ~100 nits in SDR. But I would use these settings with any display.
But yes, burn-in can happen when using the display improperly (cranking up the brightness and leaving on the same image for hours).
By the way, my 2008 Samsung LCD TV developed horrible image retention after a few years. And later some permanent black spots showed up near the edges.
My 2015 Sony LCD TV developed some stuck pixels or something pretty quickly. Permanent little white spots in a few places.
The LG OLED is the best display I have ever owned so far. But I realize it will not last forever. I actually hope MicroLED will become the ultimate display tech when they can scale it down enough.
1,131 (0.79/day)
Bavaria ⌬ Germany
They literally just announced it will be 1299$
I said "expected" and not "expecting". ;) I did read the article, and the previous article from Jan 6th (which didn't include the price tag).
Let's be honest, there is no "perfect" display tech out there. And I have to agree, for TV's OLED is still the best we got today.
It could get burn in, but LCD has to deal with dead pixels or they just break after 2 years. OLED seems more durable in the long run (while also having superior image quality).
I am still running a 60" Pioneer KURO (last version), it got a little burn in from gaming, but it is only visible at bootup or longer unicolored images.
Most won't even notice burn in unless they really looking for it, f.e. with monitor test images.
245 (0.15/day)
2nd Earth
Processor Ryzen 5700X
Motherboard Gigabyte AX-370 Gaming 5, BIOS F51h
Cooling MSI Core Frozr L
Memory 32GB 3200MHz CL16
Video Card(s) MSI GTX 1080 Ti Trio
Storage Crucial MX300 525GB + Samsung 970 Evo 1TB + 3TB 7.2k + 4TB 5.4k
Display(s) LG 34UC99 3440x1440 75Hz + LG 24MP88HM
Case Phanteks Enthoo Evolv ATX TG Galaxy Silver
Audio Device(s) Edifier XM6PF 2.1
Power Supply EVGA Supernova 750 G3
Mouse Steelseries Rival 3
Keyboard Razer Blackwidow Lite Stormtrooper Edition
Wow, not bad, but Alienware is not official in my country so I expect $1700-2000 price here.
If they use panel from LG, I'll wait for LG to make one. Should be cheaper.
717 (0.26/day)
France
Processor RYZEN 7 5800X3D
Motherboard Aorus B-550I Pro AX
Cooling HEATKILLER IV PRO , EKWB Vector FTW3 3080/3090 , Barrow res + Xylem DDC 4.2, SE 240 + Dabel 20b 240
Memory Viper Steel 4000 PVS416G400C6K
Video Card(s) EVGA 3080Ti FTW3
Storage XPG SX8200 Pro 512 GB NVMe + Samsung 980 1TB
Display(s) ROG Strix OLED XG27AQDMG
Case NR 200
Power Supply CORSAIR SF750
Mouse Logitech G PRO
Keyboard Meletrix Zoom 75 GT Silver
Software Windows 11 22H2
Keep in mind this is an Alienware product + ultrawide form factor meaning it certainly comes with a significant markup , 32'' QD-OLED panes may come at sub 1000$ maybe even sub 900$ .
This is great princing for a 1st gen .
1,131 (0.79/day)
Bavaria ⌬ Germany
QD OLED is from Samsung's tech. ;) Highly doubt they will sell their panels to LG, or LG buy panels from their main competitor.
For now there are only confirmed Sony TV's & Alienware Monitors with QD OLED (with Samsung panels), strangely no Samsung monitor with the new tech.
Pretty sure more TV producers will follow to ditch LG OLED panels for Samsung QD OLED, same goes for those wo bought LG widescreen panels for their widescreen (gaming) monitors.
717 (0.26/day)
France
Case NR 200
Although it is unlikely , it is far more plausible than it appears to be . LG much like Samsung is divided into LG Electronics ( the ones who sell products ) and LG Display ( the ones who make panels ) . Since Samsung Electronics doesn't seem to be willing to jump on QD-OLED this generation ( it would make their LCDs TVs a very hard sell ) Samsung Displays needs to find customers for their QD-OLED panels so Samsung Display selling to LG Electronics is not an absurdity at all .
1,131 (0.79/day)
Bavaria ⌬ Germany
I don't see it. ;) Samsung didn't buy LG's OLED panels either, instead they tried to "survive" with their inferior & expensive QLED TV's while LG's OLED's where selling like hot cakes.
I did read a comment on one of the QD-OLED video's on Youtube, and there was a guy who seems to have some knowledge about OLED production. He mentioned that QD-OLED will be easier to produce, better yields, which means cheaper prices. If true it will be Samsung's "turn the tide" tech & LG's OLED's will collect dust on the shelfs.
245 (0.15/day)
2nd Earth
I see. Regardless LG may follow anytime soon with their own OLED panel, surely the will, hopefully as good as or better than Samsung's.
This monitor is really appealing.
2,018 (0.48/day)
Plus LG Electronics did not even make a monitor using LG Display WOLED panel. I mean if LG Electronics wont use "their own" WOLED then why would it use competitors QD-OLED?
3,571 (1.18/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
18,231 (2.46/day)
Sorry, where did I say that? I said the HDR "certification" was still mostly pointless.
Never said the other display was better, I said I was surprised by the fact that the QD-OLED display was only rated at HDR400, as it seems really low.
17,777 (4.68/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710
It does seem a little weird... @Inle will you get a review of this done before launch day or release the review on launch day? would be interesting to get some details asap... $1300 is a lot of money, but on same hand don't want to wait to long to buy this cause I am certain it will sell out...
6,320 (2.86/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Not everyone has space for a tall 42" model. Plus it has agressive auto brightness that cant be turned off.
And we still don't know if Dell won't have the same thing.
Hint: they ditched that test after x7 series came out. Doesn't mean you won't get burn in (just ask Wendell from L1T).
7,762 (2.71/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
Burn-In proof
No. More resistant? Yes. Proof? No. There is no such thing. Organic emitters will always decay over time, and will decay in ways that leave visible patterns if left showing static images for too long. That's just how the physics of OLEDs work, and there is no workaround that can fully fix this save for non-organic emitters, i.e. microLED and the like. That doesn't mean OLED can't be made to last for quite a long time without visible image retention, but it can never be removed outright.
Sounds to me like you've had some pretty bad luck. Sure, there are absolutely a lot of crap LCDs out there where the backlight has died way prematurely, and dead pixels are also an issue (though OLEDs are by no means immune to those). But my Dell U2711 from 2011 would like to say hello, as would the hundreds of thousands if not millions of LCDs from at least a decade ago that are still in service in offices, stores, workshops, and homes across the globe. LCDs can last for a long time. There is a huge span of quality variance within LCDs as well, both in backlight longevity and image retention, but even suggesting LCDs are prone to "just breaking after 2 years" is wildly misleading.
Have you looked at the 32" 2160p monitor market recently? The cheapest high refresh rate monitors there are still close to $1000, though they are creeping down - 27-28" variants are $100-200 cheaper. It's entirely possible that Samsung aims for QD-OLED to be disruptive on price, but I see no reason for the $1300 pricing of this to be indicative of sub-$1000 32" 16:9 panels. Also, 1440p/1600p ultrawides are generally far cheaper than 2160p 16:9 panels.
Samsung's QLED panels have sold like hotcakes as well, so I don't think they've seen the need. Also, calling them "inferior & expensive" is a bit odd - at least where I'm from they're generally the same price as similar LG OLEDs if not a tad cheaper (Q70 ~Bx, Q80 ~ Cx, Q90 ~Gx), and they are far superior in any semi-bright room simply due to the low overall brightness of OLED (not to mention the extremely reflective display coatings on the CX and previous generations, which reportedly the C1 fixed). OLEDs still kick their butt in dim conditions, but ... that's how technology works - different technologies have different strengths.
That's because WOLED for PC usage is overall pretty poorly suited to the job - that white subpixel doesn't really work well with Windows' way of rendering things, particularly with text rendering. It's usable at lower pixel densities and longer viewing distances, but close up it can lead to weird visual artifacts. It's still fantastic for gaming, video, and anything dynamic, where the white subpixel creating added brightness at the cost of saturation doesn't matter much, but for monitors it's really not the best tech around. There's a reason LG's 32" Ultrafine OLED doesn't use WOLED, but rather JOLED's printed OLED panels.
17,777 (4.68/day)
Case NZXT H710
yeah if I buy this $1300 one, I will be babying it... keeping it turned off when not gaming, or movie watching. actual web browsing and desktop stuff will still be done on my laptop or tablet.
