- Aug 13, 2010
- 5,525 (1.01/day)
59$ is hella-steep. You can destroy it in half this price.
This cooler is marketing for AMD. It should cost 25$ max.
System Name | Bo-minator (my name is bo) |
Processor | AMD 3900X |
Motherboard | Gigabyte X570 AORUS MASTER |
Cooling | Noctua NH-D15 |
Memory | G-SkiLL 2x8GB RAM 3600Mhz (CL16-16-16-16-36) |
Video Card(s) | ASUS STRIX 1080Ti OC |
Storage | Samsung EVO 850 1TB |
Display(s) | ACER XB271HU + DELL 2717D |
Case | Fractal Design Define R4 |
Audio Device(s) | ASUS Xonar Essence STX |
Power Supply | Antec HCP 1000W |
Mouse | G403 |
Keyboard | CM STORM Quick Fire Rapid |
Software | Windows 10 64-bit Pro |
Benchmark Scores | XX |
I know that *now*. A few months ago it was unclear what that USB header cable was for, it was only mentioned that it had a USB header cable along with the 4-pin cable. Did not occur to me that the USB header cable would be used for the lighting, I didn't look past the AM4 compatibility.it's a RGB connector though, not USB
Processor | Intel Core i7 10850K@5.2GHz |
Motherboard | AsRock Z470 Taichi |
Cooling | Corsair H115i Pro w/ Noctua NF-A14 Fans |
Memory | 32GB DDR4-3600 |
Video Card(s) | RTX 2070 Super |
Storage | 500GB SX8200 Pro + 8TB with 1TB SSD Cache |
Display(s) | Acer Nitro VG280K 4K 28" |
Case | Fractal Design Define S |
Audio Device(s) | Onboard is good enough for me |
Power Supply | eVGA SuperNOVA 1000w G3 |
Software | Windows 10 Pro x64 |
Processor | i5-4670k |
Motherboard | MSI Z87-GD65 |
Cooling | Magicool G2 Slim 240+360, Watercool Heatkiller 3.0, Alphacool GPX 290 M05 |
Memory | G.Skill RipjawsX DDR3 2x4GB 2133MHz CL9 |
Video Card(s) | Gigabyte Radeon R9 290 |
Storage | Samsung 850 EVO 250GB, 320GB+1TB HDDs |
Case | SilentiumPC Aquarius X90 Pure Black |
Power Supply | Chieftec Navitas GPM-1000C |
System Name | Moving into the mobile space |
Processor | 7940HS |
Motherboard | HP trash |
Cooling | HP trash |
Memory | 2x8GB |
Video Card(s) | 4070 mobile |
Storage | 512GB+2TB NVME |
Display(s) | some 165hz thing that isn't as nice as it sounded |
I have worked in recycling and resale for about 6 years and have never seen a broken AMD retention bracket from standard use. Sure, if they bounce around in a gaylord and get smashed to shit then the brackets could break on you but as they come out of the mold? Highly doubtful. I would expect (and have seen) the PCB or socket to begin cracking under that kind of pressure.
Perhaps I'm the exception and have just never been in the right place at the right time to experience a bracket failure.
I've only ever seen one, and that was someone that way over tightened a water block hold down. Over tightening isn't an issue with the lever style like the Wraith uses.I have worked in repairs a bit and never seen a broken AMD bracket myself.
System Name | 3 desktop systems: Gaming / Internet / HTPC |
Processor | Ryzen 5 7600 / Ryzen 5 4600G / Ryzen 5 5500 |
Motherboard | X670E Gaming Plus WiFi / MSI X470 Gaming Plus Max (1) / MSI X470 Gaming Plus Max (2) |
Cooling | Snowman / Segotep T4 / Νoctua U12S |
Memory | Kingston FURY Beast 32GB DDR5 6000 / 16GB JUHOR / 32GB G.Skill RIPJAWS 3600 + Aegis 3200 |
Video Card(s) | ASRock RX 6600+GTX 1660 / Vega 7 integrated / Radeon RX 580+GTX 1050 |
Storage | NVMes, ONLY NVMes / NVMes, SATA Storage / NVMe, SATA, external storage |
Display(s) | Philips 43PUS8857/12 UHD TV (120Hz, HDR, FreeSync Premium) / 19'' HP monitor + BlitzWolf BW-V5 |
Case | Sharkoon Rebel 12 / CoolerMaster Elite 361 / Xigmatek Midguard |
Audio Device(s) | onboard |
Power Supply | Chieftec 850W / Silver Power 400W / Sharkoon 650W |
Mouse | CoolerMaster Devastator III Plus / CoolerMaster Devastator / Logitech |
Keyboard | CoolerMaster Devastator III Plus / CoolerMaster Devastator / Logitech |
Software | Windows 10 / Windows 10&Windows 11 / Windows 10 |
About every 4 months or so I have someone come in with a broken AMD bracket. Most were from them moving the system but a few just broke while sitting on the desk/floor. If someone brings in one to scrap that has a good bracket I make sure to yank it out.I have worked in repairs a bit and never seen a broken AMD bracket myself.
Mouse | G403 |
I think people are using that for comparison since its been the golden 'value/money' cooler for so many builds.Guys, did you forget that AMD in the beginning said that they won't sell them standalone because they don't want to undermine their partners. People asked so much for it anyway(mainly on reddit) that they finally released it.
Also why are you guys compare it to 212 evo? It's a tower. Wraith is a horizontal cooler, actually the best horizontal cooler out there at the moment, not even talking about the fact it's RGB. You don't buy it because you need it, you buy it when you WANT it.
System Name | Dark Monolith |
Processor | AMD Ryzen 7 5800X3D |
Motherboard | ASUS Strix X570-E |
Cooling | Arctic Cooling Freezer II 240mm + 2x SilentWings 3 120mm |
Memory | 64 GB G.Skill Ripjaws V Black 3600 MHz |
Video Card(s) | XFX Radeon RX 9070 XT Mercury OC Magnetic Air |
Storage | Seagate Firecuda 530 4 TB SSD + Samsung 850 Pro 2 TB SSD + Seagate Barracuda 8 TB HDD |
Display(s) | ASUS ROG Swift PG27AQDM 240Hz OLED |
Case | Silverstone Kublai KL-07 |
Audio Device(s) | Sound Blaster AE-9 MUSES Edition + Altec Lansing MX5021 2.1 Nichicon Gold |
Power Supply | BeQuiet DarkPower 11 Pro 750W |
Mouse | Logitech G502 Proteus Spectrum |
Keyboard | UVI Pride MechaOptical |
Software | Windows 11 Pro |
System Name | SolarwindMobile |
Processor | AMD FX-9800P RADEON R7, 12 COMPUTE CORES 4C+8G |
Motherboard | Acer Wasp_BR |
Cooling | It's Copper. |
Memory | 2 x 8GB SK Hynix/HMA41GS6AFR8N-TF |
Video Card(s) | ATI/AMD Radeon R7 Series (Bristol Ridge FP4) [ACER] |
Storage | TOSHIBA MQ01ABD100 1TB + KINGSTON RBU-SNS8152S3128GG2 128 GB |
Display(s) | ViewSonic XG2401 SERIES |
Case | Acer Aspire E5-553G |
Audio Device(s) | Realtek ALC255 |
Power Supply | PANASONIC AS16A5K |
Mouse | SteelSeries Rival |
Keyboard | Ducky Channel Shine 3 |
Software | Windows 10 Home 64-bit (Version 1607, Build 14393.969) |
Memory | 2x8GB |
System Name | Miami |
Processor | Ryzen 3800X |
Motherboard | Asus Crosshair VII Formula |
Cooling | Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover |
Memory | F4-3600C16Q-32GTZNC |
Video Card(s) | XFX 6900 XT Speedster 0 |
Storage | 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD |
Display(s) | DELL AW3420DW / HP ZR24w |
Case | Lian Li O11 Dynamic XL |
Audio Device(s) | EVGA Nu Audio |
Power Supply | Seasonic Prime Gold 1000W+750W |
Mouse | Corsair Scimitar/Glorious Model O- |
Keyboard | Corsair K95 Platinum |
Software | Windows 10 Pro |
I don't understand one thing: why is the Wraith Max (the best one) using the plastic mounting bracket that comes with the motherboard, but Stealth and Spire are screwed in?
Basically the best CPU cooler from AMD uses the worst mounting system.
Honestly, I bet half that price is because of the RGB. I'd like to see a cheaper version without the RGB.
As for destroying it at half the price, I don't think so. The Wraith Max performs the same as the 212 EVO and is quieter at the same time. That's a pretty good combination. Sure, you can probably find something that performs better, but probably not by much, and I'm doubting it would be much cheaper. And at the same time, 120mm tower style coolers have their limitations. They can't be used in most HTPC computers because of their height. The Wraith on the other hand can. The Wraith is only 8cm tall, most 120mm tower coolers are right about double that.
And, really, if you hop on ebay, you can find the non-RGB version on sale for about $30. That isn't a bad deal.
Edit: http://www.tomshardware.com/reviews/amd-wraith-cpu-cooler,4450.html
Here is a good review by Tom's comparing it to a Thermalright Macho. The Macho costs right about the same as the Wraith Max. They still performed right about the same temperature wise. The only thing the Macho wins at is noise, beating the Wraith by 6dBA. But another thing to note was that the VRMs on the motherboard ran a good 15°C cooler with the Wraith than with the Macho, and the Wraith was still quiet enough to not be heard over the other components in a closed case.
System Name | Dumbass |
Processor | AMD Ryzen 7800X3D |
Motherboard | ASUS TUF gaming B650 |
Cooling | Artic Liquid Freezer 2 - 420mm |
Memory | G.Skill Sniper 32gb DDR5 6000 |
Video Card(s) | GreenTeam 4070 ti super 16gb |
Storage | Samsung EVO 500gb & 1Tb, 2tb HDD, 500gb WD Black |
Display(s) | 1x Nixeus NX_EDG27, 2x Dell S2440L (16:9) |
Case | Phanteks Enthoo Primo w/8 140mm SP Fans |
Audio Device(s) | onboard (realtek?) - SPKRS:Logitech Z623 200w 2.1 |
Power Supply | Corsair HX1000i |
Mouse | Steeseries Esports Wireless |
Keyboard | Corsair K100 |
Software | windows 10 H |
Benchmark Scores | https://i.imgur.com/aoz3vWY.jpg?2 |
Its not like you can over tighten a spring bracket. I call BS and what you see is intentional or someone clueless messing with something they shouldnt. Far from a design flaw.About every 4 months or so I have someone come in with a broken AMD bracket. Most were from them moving the system but a few just broke while sitting on the desk/floor. If someone brings in one to scrap that has a good bracket I make sure to yank it out.
Memory | 2x8GB |
Yea I kinda fall behind this as well. I mean for years that bracket has worked fine. I have seen far more intel push pin coolers sitting in pieces than the AMD ones.
Never intimated it was a design flaw. Simply pointing out that the plastic nubs on those brackets *can* simply break. Some of you are reading into my statements or concluding that it can't happen because it has never happened to you.Its not like you can over tighten a spring bracket. I call BS and what you see is intentional or someone clueless messing with something they shouldnt. Far from a design flaw.
you implied it happened a lot. I built many a system, and yea, it never happened to me. You are right about one thing, that anything CAN be broken. Expecting plastic to last forever is also foolish.Never intimated it was a design flaw. Simply pointing out that the plastic nubs on those brackets *can* simply break. Some of you are reading into my statements or concluding that it can't happen because it has never happened to you.![]()
Processor | 9800x3D| 5800x | 4800H | Rog ally |
Motherboard | Gb x870 Aorus Elite ice | Asrack x470d4u | Asus Tuf A15 |
Cooling | Air | Air | duh laptop |
Memory | 64gb G.skill SniperX @3600 CL16 | 128gb | 32GB | 192gb |
Video Card(s) | RTX 4080 |Quadro P5000 | RTX2060M |
Storage | Many drives |
Display(s) | AW3423dwf. |
Case | Jonsbo D41 |
Power Supply | Corsair RM850x |
Mouse | g502x Lightspeed |
Keyboard | G913 tkl |
Software | win11, proxmox |
System Name | ChoreBoy |
Processor | 8700k Delided |
Motherboard | Gigabyte Z390 Master |
Cooling | 420mm Custom Loop |
Memory | CMK16GX4M2B3000C15 2x8GB @ 3000Mhz |
Video Card(s) | EVGA 1080 SC |
Storage | 1TB SX8200, 250GB 850 EVO, 250GB Barracuda |
Display(s) | Pixio PX329 and Dell E228WFP |
Case | Fractal R6 |
Audio Device(s) | On-Board |
Power Supply | 1000w Corsair |
Software | Win 10 Pro |
Benchmark Scores | A million on everything.... |
It's pretty much the same... but the fan that came with the old Phenom II coolers was crap, and loud as hell, I think it was 70mm... I would always replace the fan on the thing with an 80mm 2600rpm-ish fan, mega upgrade. This one has a 90 or 92mm.... It's way better then the Phenom II coolers, but the sink is basically the same.Isn't this the same cooler they've been using since the phenom 2's now with RGB lighting?
If so they are definitely good up to 140w...
And these things are fantastic for HTPC use or even for gaming with a decent but not great OC.
I've probably installed twenty or so at least... never an issue, even using the force of God to put an Arctic Freezer 64 on multiple times.How curious I see quite a few AMD boxes and even the original s939 stuff I see is still in one piece.
System Name | Intel NUC 12 Extreme |
Processor | Intel Core i7 12700 12 Core 20 Thread CPU |
Motherboard | Intel NUC Module Motherboard |
Cooling | NUC Blower Cooler + 3 x 92mm Fans |
Memory | 64GB RAM Corsair 3200Mhz CL22 |
Video Card(s) | PowerColor RX 9070 16GB Reaper |
Storage | Silicon 500GB M.2 + WD 2TB External HDD |
Display(s) | Sony 4K Bravia X85J 43Inch TV 120Hz |
Case | Intel NUC 12 Extreme Mini ITX Case |
Audio Device(s) | Realtek Audio + Dolby Atmos |
Power Supply | SFX FSP 650 Gold Rated PSU |
Mouse | Logitech G203 Lightsync Mouse |
Keyboard | Red Dragon K552W RGB White KB. |
VR HMD | ( ◔ ʖ̯ ◔ ) |
Software | Windows 10 Home 64bit |
Benchmark Scores | None. I also own a Apple Macbook Air M2 |
I was going to bash AMD for jumping on the LED bandwagon, but then I remembered that a fool and his money are soon parted. And if you fork out 60 bucks for this POS, you're a fool, and I have no problem with anyone taking your money.
System Name | RYZEN RECKER |
Processor | Ryzen 7 9700x |
Motherboard | Gigabyte B650 Gaming AX2 |
Cooling | Arctic Cooler 120mm CPU, Cougar case fans. |
Memory | 32GB Gskill 6000mhz |
Video Card(s) | Sapphire 7900xt |
Storage | 3TB NVME with multiple TB back up HDDs |
Display(s) | Acer 32" 170hz VA |
Case | Fractal Pop XL |
Audio Device(s) | Corsair Void headset |
Power Supply | Thermaltake 1050w Gold |
Mouse | Steel Series Sensei Ten |
Keyboard | Corsair K55 |
Software | Windows 10 64-bit |
