AMD Begins Offering Wraith Max Cooler Through Retail Channels - $59
310 (0.05/day)
Processor AMD Ryzen R7 3900X
Motherboard Gigabyte X570 Asrock X570 Taichi
Cooling 2x LL140, 4x LL120 / bequiet! Dark Rock 4
Memory 32GB Corsair Vengence RGB DDR4 (3600 Mhz)
Video Card(s) Red Devil 5700XT
Storage x1 Inland 1TB Nvme, 1x Samsung 860 EVO 1TB, 1x WD 1TB, 1x Crucial MX500 500GB, 1x Sandisk X400 256GB
Display(s) Samsung C32H711
Case Fractal Design Meshify C
Keyboard Logitech G910
This may have been useful at launch. The way things played out in my case. I probably would have bought one while waiting for Cryorig to ship out compatible bracket hardware. Now that everyone is actually making compatible coolers though, I wouldn't get a Wraith.
18,382 (2.46/day)
I don't understand one thing: why is the Wraith Max (the best one) using the plastic mounting bracket that comes with the motherboard, but Stealth and Spire are screwed in?
Basically the best CPU cooler from AMD uses the worst mounting system.
I guess you haven't tried to install the screw in ones then? Or rather, remove them. I foolishly put mine on, as I couldn't find the mounting kit for my AIO at the time. Removing the Spire cooler was hell, as it got stuck somehow to the rear CPU bracket and wouldn't unscrew the entire way. I had to pry it off in the end, something you really don't want to do, as you could damage the motherboard. So no, the screw mount coolers don't have the best mount, in fact, it's utter crap.
620 (0.15/day)
System Name Headshot
Processor AMD Ryzen 7 3800X
Motherboard ASUS Crosshair VI Hero ROG
Cooling Phanteks Glacier One 360 MPH
Memory 2x16GB Corsair Vengence LPX DDR4 @ 3200 16-18-18-18-36
Video Card(s) AMD Radeon Vega64 (Linux)/Gigabyte RX 6600 (Windows VM)
Storage Cruscial P5 1TB nVME, Samsung 850 EVO 250GB, Seagate 1TBx2 (Home/Data), 2TB Seagate (Games)
Display(s) 2x Acer 1080P 144HZ
Case Phanteks Enthoo Luxe White
Audio Device(s) Schiit Stack (Schiit Audio Modi 2 DAC + Magni 3 AMP + Loki)
Power Supply eVGA Supernova 1000 G2
Mouse Razer DeathAdder V2
Keyboard Logitech G710+
Software Arch Linux with Windows 10 Gaming VM
I am completely confused how this could happen. I have removed mine a couple of times and I have no idea how it could get hung on anything.
18,382 (2.46/day)
That is a really good question. The screws just didn't come out of the screw sockets on the CPU bracket that came with my Asus board. I mean, there were some early reports about some CPU brackets not being done right, or maybe I was just unlucky, but It really struggled to get it off.
23,729 (6.14/day)
About every 4 months or so I have someone come in with a broken AMD bracket. Most were from them moving the system but a few just broke while sitting on the desk/floor. If someone brings in one to scrap that has a good bracket I make sure to yank it out.
Pictures with timestamp or it didn't happen. I get the sense you're talking BS
1,013 (0.14/day)
Processor 2500K @ 4.5GHz 1.28V
Motherboard ASUS P8P67 Deluxe
Cooling Corsair A70
Memory 8GB (2x4GB) Corsair Vengeance 1600 9-9-9-24 1T
Video Card(s) eVGA GTX 470
Storage Crucial m4 128GB + Seagate RAID 1 (1TB x 2)
Display(s) Dell 22" 1680x1050 nothing special
Case Antec 300
Power Supply PC Power & Cooling 750W
Software Windows 7 64bit Pro
Are these any different than the old Foxconn heatpipe coolers AMD bundled with their old Opteron processors back in the sockete 939 days just with a different fan and lights?
2,363 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
Yes these are much more robust. Larger overall with thicker heatpipes.
703 (0.14/day)
Pensacola, FL, USA, Earth
Indeed, I am totally making this all up to troll everyone here. *chuckle* Next time it happens, you'll be the first to get the timestamped picture. Promise!
337 (0.08/day)
43,627 (6.38/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Hopefully AMD can start selling CPU's without coolers again soon... You know to keep the CPU/Cooler ratio balanced. Totally important!! :peace:
It's happened to me a couple times going from s754 up to AM3. Sometimes you run into a bracket that is just brittle.. Threads can get stuck bind, just light pressure in the wrong spot can cause it to break. Not totally common though.
5,480 (0.88/day)
Australia
So the difference between this Wraith Max and just the original Wraith cooler is RGB is that correct?
2,363 (0.45/day)
System Name Miami
The Wraith rev.1 was kinda crap(smaller overall, fewer and lower diameter pipes, etc.) and no one really likes to talk about it but stil can be found being sold for $20
OTOH Rev.2 the current Wraith there are now 3 versions of:
Wraith "Basic" w/ no LED and no shroud over the fan - can be found for $18-20US(originally released socket AM2+/AM3?)
Wraith "Standard" w/ Shroud and White LED - can be found for $30-35US(released on socket AM3)
Wraith Max w/ Shroud and RGB LEDS - See article(AM4)
As you can see the the Wraith Spire/Stealth weren't originally Wraith coolers but I guess someone at AMD decided whytf not and slapped wraith on them also ignoring the 3 previous iterations of the Wraith cooler making it confusing/convoluted with 3 coolers sharing the same name and others very similar to one another. Should have named those two new entries to the lineup simply Spire(rgb) and Spire Stealth (non-rgb).
Fx
1,332 (0.22/day)
Portland, OR
Processor Ryzen 2600x
Cooling Noctua
Video Card(s) EVGA 980ti FTW
Case Fractal Design Define R5
Mouse Mionix Castor
Keyboard Deck Hassium Pro
Ruru
S.T.A.R.S.
13,699 (3.04/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + open GPU loop / Eisbaer 240
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector
Audio Device(s) Sony WH-CH720N / Hecate G1500
VR HMD Oculus Rift CV1
And still reminds me of those heatpipe stock coolers which were shipped since dual core S939 AMD CPUs.
20eur would be the max (pun intended) which this is worth of.
