AMD Zen 4 Reportedly Features a 29% IPC Boost Over Zen 3
107 (0.06/day)
There is no wide-spread issues with the 5600X as you imply. You are just taking a few reddit posts (which aren't even verified evidence FYI) and extrapolating those to the extreme. I've seen FAR more posts about heat issues on the Intel 10xx series than AMD WHEA errors.
In addition, your pricing estimates are misleading. You are forgetting the cost of a CPU cooler. The AMD processor comes with one, not to mention Intel is harder to cool due to the higher power requirements. In addition, in order to get the most out of an Intel CPU you need a Z class motherboard (You can't even enable XMP on anything but Z class for Intel). The 5600X on the otherhand runs just fine on a $65 motherboard and you can still run your RAM at high frequencies.
Last you are quoting the inflated AMD prices, not MSRP. There's a reason the Intel CPUs are still in stock, they are worse in every metric often by a wide margin. Hell the 5600X matches in multi-threading performance to Intel's higher core count parts and consumes half the power while doing it.
If you want the best CPU on the market, you buy the 5800X / 5900X / 5950X (depending on core count need). If you want a budget CPU you get the 3600. The 10400f is a decent proposition and beats the 3600 in gaming by a small amount but at this price point people won't have a GPU that can realize the difference and in order to get that performance out of the 10400f you need a Z class motherboard. Your performance advantage is moot with a B class mobo. The 3600 beats the 10400f in every other metric though, so really you are buying it if you only care about gaming.
Those will relax as the market returns to normal demand levels. Right now demand was placed at around 2.8 times normal.
That's very expensive for a 3600. That said the 3600 still comes with a CPU cooler and can run just fine on a low end motherboard. In the end you are going to be paying about the same for the Intel and AMD platform. Retailers in your area seem to have up-priced the AMD CPU knowing this.
Look, is him! The most famous AMD fanboy on techspot!
Btw 10400f comes with a cooler and its performance doesnt get affected a single bit by using it.
Z490 motherboard? 120€ and you're set. Cooler for 10600k? Cyorig m9i and you are good to go. Still cheaper than 5600x+b550 motherboard.
Oh also forgot that you dont need b die RAM on Intel, wich is more expensive.
You can Say what you want, no One on a budget buys AMD right now. Plus... Stocks are awful anyway.
PS: yes there are common stability issues with zen3. Go on overclock dot net forum and look at the poll. The most recent chips have a high errors rate, at stock! Pure crap.
2,881 (1.17/day)
Maybe my inability to purchase Zen 3 is a blessing and I'll just wait for Zen4 becuase we get AM5 socket, DDR5, possibly PCI-E 5.0 and of course all new MB's. This of course assumes the situation is any better in 2022. TSMC"s lack of capacity will not improve much.
3,984 (1.10/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
hopefully AM5 CPU bracket is backward compatible with AM4 so that AM4 CPU cooler would work with AM5
If you have a Noctua they will send you any adapters at no cost.
good11
6 (0.00/day)
Nah Zen 3 Milan is the codename of EPYC platform not AM4.
Warhol is it and I think it still on socket AM4 with ZEN3+ for A520/B550/X570 only.
1,491 (0.93/day)
System Name Chip
Processor Amd 5600X
Motherboard MSI B450M Mortar Max
Cooling Hyper 212
Memory 2x 16g ddr4 3200mz
Video Card(s) RX 6700
Storage 5.5 tb hd 220 g ssd
Display(s) Normal moniter
Case something cheap
VR HMD Vive
anyone one on a budget goes amd
the 3200g kicks the i3s teeth in for a quater of the price
943 (0.41/day)
I will not be surprised if they make their ryzen 7 xxxx series selling price go up by another 100 by then.
10,933 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
For sure at least 100... plus DDR5 is going to be expensive AF as well.
1,772 (1.00/day)
the i5 also comes with a stock cooler which is enough for it as it's not very power hungry and non-overclockable
Actually it depends on which i5 model you are using. While most of them are not as highly clocked like the i7/i9, and almost all not overclockable, they still draw enough power at load to overwhelm the mini stock cooler that came with it. My younger brother's i5 9400 can hit mid 80 degs when playing CS Go with that stock cooler. Simply by changing it to a third party cooler (I got a Scythe Shuriken 3), load temps are now in the 60s. The Intel stock cooler in my opinion is a bad joke.
WIth cost increasing, this is inevitable. For early adopters of next gen CPUs, there will be significant upgrade cost because you will need to get a new motherboard and likely ram as well. All of which will come with a premium.
3,440 (1.10/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
The i5 10400F consumes 149W stock, which is only slightly less than the 8700K stock. It is still power hungry. With the stock cooler you are looking at getting up to over 82c in under 20 seconds. Sure, you can run on stock cooler but the CPU will certainly throttle under any sort of sustained loads. At that point though you aren't going to get near the performance shown in benchmarks.
You still want a decent VRM as well and you can only use XMP on Z class motherboards. Again, most reviews use higher than default memory speeds. If the only reason you are buying a 10400F is because of the gaming performance, you had better at least make sure you are actually getting that advantage. The margin in performance in games between the 10400F and 3600 is less than the difference between having RAM set to default speeds and XMP 3200 or higher.
TBH the best deal was when the 1600AF was going for $85 USD. That was an absolute steal. Zen+ IPC, 6 cores, good platform all for under $100. Current CPU prices aren't that good and I would simply advise people to wait if possible.
17,503 (4.66/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
There is no way Zen 4 will be out in 2022, maybe a paper launch in 2022 like Zen 3 was. Demand is up and won't be going down, so using that excuse doesn't count anymore. I doubt I will even be able to buy a PS5 in Fall 2021... not to mention all the other products TSMC makes... yeah there is just no way Zen 4 will be out in 2022, sorry but I don't believe it for one second. I'd bet money more like spring/summer 2023.
2,262 (0.33/day)
Toronto, Ontario
System Name The Expanse
Processor AMD Ryzen 7 5800X3D
Cooling Corsair H150i Pro
Video Card(s) XFX Radeon RX 7900 XTX Magnetic Air (24.12.1)
If intel does launch Alderlake in Q3 of this year I think we will see Zen 4 in Q1 of 2022 but I wouldn't expect that to be a volume launch.
And if Alderlake does meet its performance claims AMD Can't really wait until 2023 to provide an answer.
17,503 (4.66/day)
If intel does launch Aderlake in Q3 of this year I think we will see Zen 4 in Q1 of 2022 but I wouldn't expect that to be a volume launch.
If alderlake does does meet its performance claims AMD Can't really wait until 2023 to provide an answer.
hmm interesting. well if it a paper launch and I happen to get lucky again, I'll be selling my zen 3 on here shortly after lol but i am not selling it until i have a zen 4 chip in my hand... with the world is going i'm still very skeptical about any sort of normal stock at msrp stuff. especially as the bots become more and more enhanced, and the companies are flat out refusing to be aggressive in innovation when it comes to scalpers. it seriously wouldn't be that hard to stop scalpers if we were to say require unique address and drivers license photo copy for all orders placed, and each order verified by a rep/customer service agent. it would slow down order fulfillment that is certain, but two week delay is better than 2 year.
17,503 (4.66/day)
I say that's a good thing!
indeed, but I don't think this will be sustainable. I think zen 3 and zen 4 are going to be the very peak of all these increases. silicon can only do so much after all... I hope I am wrong of course :D
1,491 (0.93/day)
System Name Chip
Processor Amd 5600X
Cooling Hyper 212
VR HMD Vive
no silicone is a substrait we are going to hit a performance wall in the next 10 or so years with gains getting smaller or smaller
283 (0.06/day)
System Name Amazing Experience
Processor Intel Core i5 7500
Motherboard MSI H110M Pro-VD
Cooling Deepcool Alta 7 (CPU) | 2x 120mm RGB Case Fans (Rear and Front)
Memory Hynix 16GB (2x8) 2400Mhz (13-13-13-28)
Video Card(s) Zotac GTX 750 Ti 2GB GDDR5
Storage Crucial BX500 120GB; Seagate Barracuda 1TB+2TB; Dell 1TB Ext. HDD
Display(s) HP 22es
Case Ant Esports ICE-211TG
Audio Device(s) F&D A110 2.1 Stereo Speakers
Power Supply Circle 500 Watts APFC
Mouse Redragon M609
Keyboard TVS Gold Mechanical Keyboard (MX Blue, PS/2)
WTH you talking about? it has 65w tdp just like the ryzen chip
people running them totally fine on h410 boards and xmp is not really necessary with intel 2966mhz is fast enough for them and now on 10th gen they do allow overclocking above jedec speeds
4,473 (1.41/day)
Currently Norway
System Name Bro2
Processor Ryzen 5800X
Cooling Corsair h115i pro rgb
Case Fractal Design G
Audio Device(s) Realtec 5.1
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
Yeah 65W like it matters. take a look here and TDP means nothing for power consumption.
28,782 (6.81/day)
Replacement substrate materials are being developed. Pure silicon is at the end of it's usefulness. Compound materials are the future of IC development. Arsenide seems to be leading the charge ATM.
Under max load it uses about 140 to 150w of power. However, that is not the same as a measured TDP. TDP is the total maximum nominal heat output. Officially, TDP = Thermal Design Power. However, some people also use the following because it actually applies; TDP = Thermal Dissipation Profile.
2,533 (0.78/day)
All I really desire is a AMD Zen 3+ 8c/16t single or 6c/12t single CCX Threadripper with 6 channel or 8 channel. I'm not picking I just want insane bandwidth and sufficient core count.
688 (0.24/day)
Weird, that Zen3+ will be AM5 socket.
I'm waiting for 5900XT as a 5900X with improved clocks, but immediatelly appliable in current motherboards. This idea is now destroyed.
AMD promised AM4 support until 2020. That promise was fulfilled.
Am I?
First you say they said 50%. They said up to 50%. Then you link this presentation slide where only 2 games get around 50% boost. Check LOL. It's not even 50% at the end but 84% (against a 3900X but there is minimal difference between the 3900X and 3900XT). Tested with a 3090. Linus' CS GO results nearly match the graphs: 44% against 46%. And average improvement over Zen2 was 20%, not 10-15%.
So I would appreciate if you would stop lying.
You are saying nonsense. 50% for League of legends in a one game scenario not overall performance.
And they didnt lie about it. 5900X has a 50% increase in performance in that particular case.
The IPC gain from zen 2 to zen 3 was 19% and that was also accurate.
They lied because in the above linked video it's not 50, but 84% faster. :D Bad AMD. :D
4,473 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
AMD didn't lie about anything. If somebody misinterprets the graphs, charts about performance or simply doesn't understand what's being shown we have silly comments sometimes :)
7,613 (1.77/day)
What performance claims :confused:
Pretty sure Alderlake tops out at 8 "big cores" so there's no reason for AMD to counter them at MSDT top end, for HEDT Intel's not even in the frame. Having said that it'd be nice if zen4 or zen3+ launches in 2021, even if only to reduce the process on zen3 parts.
283 (0.06/day)
Display(s) HP 22es
Mouse Redragon M609
Same can be said about 3600 too? because they are rated at same tdp too and ryzen is notorious for running hot as well
well, it doesn't matter much because i saw JTC video when 10th gen launched he was impressed by i9 10900k temps despite high power consumption, iirc it was barely anything above 80c so an i5 should run much cooler than that
486 (0.16/day)
Processor Intel i7 4770k
Motherboard ASUS Sabertooth Z87
Cooling BeQuiet! Shadow Rock 3
Memory Patriot Viper 3 RedD 16 GB @ 1866 MHz
Video Card(s) XFX RX 480 GTR 8GB
Storage 1x SSD Samsung EVO 250 GB 1x HDD Seagate Barracuda 3 TB 1x HDD Seagate Barracuda 4 TB
Display(s) AOC Q27G2U QHD, Dell S2415H FHD
Case Cooler Master HAF XM
Audio Device(s) Magnat LZR 980, Razer BlackShark V2, Altec Lansing 251
Power Supply Corsair AX860
Mouse Razer DeathAdder V2
Keyboard Razer Huntsman Tournament Edition
Thought it's supposed to be graphene.
Think?
More like you read that in an article here and are now parroting it as if you had that thought.
Where did I exactly read that? It's my opinion.
14,205 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
"AMD appears to be preparing a bridging series of processors based on the Zen 3+ architecture before the release of Zen 4. Zen 3+ is expected to be AMD's first AM5 CPU design and should bring small IPC gains similar to the improvements from Zen to Zen+ in the range of 4% - 7%. The Zen 3+ processors will be manufactured on TSMC's refined N7 node with a potential announcement sometime later in 2021."
All you did is reword it. It's called plagiarism.
