- Jul 5, 2013
- 31,829 (7.25/day)
Booting and running the OS...Name one.
System Name | Ryzen TUF. |
Processor | AMD Ryzen7 3700X |
Motherboard | Asus TUF X570 Gaming Plus |
Cooling | Noctua |
Memory | Gskill RipJaws 3466MHz |
Video Card(s) | Asus TUF 1650 Super Clocked. |
Storage | CB 1T M.2 Drive. |
Display(s) | 73" Soney 4K. |
Case | Antech LanAir Pro. |
Audio Device(s) | Denon AVR-S750H |
Power Supply | Corsair TX750 |
Mouse | Optical |
Keyboard | K120 Logitech |
Software | Windows 10 64 bit Home OEM |
System Name | Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck |
Processor | i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t |
Memory | 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5 |
Video Card(s) | RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs |
Storage | 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme |
Display(s) | 50" 4k TV | Dell 27" |22" |3.3"|7" |
VR HMD | Samsung Odyssey+ | Oculus Quest 2 |
Software | Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro |
I just can't get enough of the Ryzen CPU's!
I have 2 first gen Ryzens and one 3rd gen.
Hope to add a 4th gen CPU soon!
LOVE YOU AMD!
And how many percent faster does threadripper boot compared to ryzen? My guess would be around 0%, but I guess you have more info about your claim.Booting and running the OS...
Was being a smart-ass. I do that when people make comments like the one you made. I'm not going to take time out of my day to give a lengthy explanation when such an effort would be a waste on the intended audience. Put short, if you do not already understand the benefit of extra memory channels to improve system performance then you need to do some research and reading. I'm not doing it for you.And how many percent faster does threadripper boot compared to ryzen? My guess would be around 0%, but I guess you have more info about your claim.
That 3900X is an excellent CPU, why would you need to upgrade?All that I hope for is Intel making actually good CPUs for once, so my Zen 5 chips are cheaper when I do eventually upgrade from my 3900X![]()
Well I don't consider a jump from Zen 2 to Zen 5 unreasonable. Upgrading to a 5900X would be. I also would prefer better single threaded perfThat 3900X is an excellent CPU, why would you need to upgrade?
Exactly hell part of the reason I want to switch to a modern quad channel DDR4 is to pair it with Primo Cache. Quad channel should be quite beneficial to it since it's a block level cache that utilizes memory capacity and bandwidth and it aids in speeding up NTFS compression performance. On a side note I wish I could install Windows 10 with NTFS 2048 byte size rather than the default 4K (4096byte) size. It's probably possible in some form perhaps, but Windows itself doesn't seem to allow doing so readily and easily. I don't know Windows 10 doesn't allow it though they allow 4K uncompressed and 2K compressed ends up at the same capacity because the compression ratio is 2:1 for NTFS.Was being a smart-ass. I do that when people make comments like the one you made. I'm not going to take time out of my day to give a lengthy explanation when such an effort would be a waste on the intended audience. Put short, if you do not already understand the benefit of extra memory channels to improve system performance then you need to do some research and reading. I'm not doing it for you.
Ok, so I guess it’s difficult to point out even one piece of software that benefits greatly from more memory channels and is typically run on basic PC hardware. For enthusiasts there are already platforms that have what you want and don’t cost that much extra.Was being a smart-ass. I do that when people make comments like the one you made. I'm not going to take time out of my day to give a lengthy explanation when such an effort would be a waste on the intended audience. Put short, if you do not already understand the benefit of extra memory channels to improve system performance then you need to do some research and reading. I'm not doing it for you.
Ah Zen5, I thought you meant Ryzen 5xxx. My bad.Well I don't consider a jump from Zen 2 to Zen 5 unreasonable. Upgrading to a 5900X would be. I also would prefer better single threaded perf
Nice, good example for why expanding memory channels can be of benefit. There many others.Exactly hell part of the reason I want to switch to a modern quad channel DDR4 is to pair it with Primo Cache. Quad channel should be quite beneficial to it since it's a block level cache that utilizes memory capacity and bandwidth and it aids in speeding up NTFS compression performance.
It can be done and indeed my install has 1024byte sectors. I also only have one partition. The key is to create the partition with an external utility such as EaseUS or AOMEI. As long as the partition is properly built, you can force Windows to use it during install. Windows then takes all of the files that would otherwise have separate partitions and puts them into folders.On a side note I wish I could install Windows 10 with NTFS 2048 byte size rather than the default 4K (4096byte) size. It's probably possible in some form perhaps, but Windows itself doesn't seem to allow doing so readily and easily.
System Name | RiseZEN Gaming PC |
Processor | AMD Ryzen 7 5800X @ Auto |
Motherboard | Asus ROG Strix X570-E Gaming ATX Motherboard |
Cooling | Corsair H115i Elite Capellix AIO, 280mm Radiator, Dual RGB 140mm ML Series PWM Fans |
Memory | G.Skill TridentZ 64GB (4 x 16GB) DDR4 3200 |
Video Card(s) | ASUS DUAL RX 6700 XT DUAL-RX6700XT-12G |
Storage | Corsair MP510 480GB M.2 - 2 x WD_BLACK 1TB SN850X M.2 1TB - Lexar NQ790 M.2 2TB |
Display(s) | ASUS ROG Strix 34” XG349C 144Hz 1440p + Asus ROG 27" MG278Q 144Hz WQHD 1440p |
Case | Corsair Obsidian Series 450D Gaming Case |
Audio Device(s) | SteelSeries 5Hv2 w/ Sound Blaster Z SE |
Power Supply | Corsair RM750x Power Supply |
Mouse | Razer Death-Adder + Viper 8K HZ Ambidextrous Gaming Mouse - Ergonomic Left Hand Edition |
Keyboard | Logitech G910 Orion Spectrum RGB Gaming Keyboard |
Software | Windows 10 Pro - 64-Bit Edition (Back to Win 10 because 11 is garbage) |
Benchmark Scores | I'm the Doctor, Doctor Who. The Definition of Gaming is PC Gaming... |
ZEN3+ should be on Socket AM4 just like ZEN to ZEN+ was on Socket AM4. It makes absolutely no sense to release a ZEN3 generation CPU on a new socket.Zen 3+ is expected to be AMD's first AM5 CPU design and should bring small IPC gains similar to the improvements from Zen to Zen+ in the range of 4% - 7%.
3-5% was an Intel problem.How have we moved from "3-5% and you should be happy" every year, to the "if it offers less than 15% we are going to be disappointing"?
Not all Games and Programs will gain you equal Performance. Some perform better than others.Am I?
Its an addiction for some it seemsThat 3900X is an excellent CPU, why would you need to upgrade?
System Name | Tiny the White Yeti |
Processor | 7800X3D |
Motherboard | MSI MAG Mortar b650m wifi |
Cooling | CPU: Thermalright Peerless Assassin / Case: Phanteks T30-120 x3 |
Memory | 32GB Corsair Vengeance 30CL6000 |
Video Card(s) | ASRock RX7900XT Phantom Gaming |
Storage | Lexar NM790 4TB + Samsung 850 EVO 1TB + Samsung 980 1TB + Crucial BX100 250GB |
Display(s) | Gigabyte G34QWC (3440x1440) |
Case | Lian Li A3 mATX White |
Audio Device(s) | Harman Kardon AVR137 + 2.1 |
Power Supply | EVGA Supernova G2 750W |
Mouse | Steelseries Aerox 5 |
Keyboard | Lenovo Thinkpad Trackpoint II |
VR HMD | HD 420 - Green Edition ;) |
Software | W11 IoT Enterprise LTSC |
Benchmark Scores | Over 9000 |
AOMEI ended up working well to move the reserve partition to the end of the NVME drive and was able to shrink the C:\ partition down in a size as well. Good enough to get over 400GB of NVME storage for Steam Games installs so as long as I don't install ARK on it quite a lot of games.Ah Zen5, I thought you meant Ryzen 5xxx. My bad.
It makes a lot more sense than making Bulldozer/Excavator CPU's for AM4 back in 2016, and yet that happened. Yeah, we could come up various explanations for this, but the same goes for Zen3(+) + DDR5.It makes absolutely no sense to release a ZEN3 generation CPU on a new socket.
AMD already muddled the naming scheme with mixing up ZEN2 and ZEN3 under the Ryzen 5000U series. This was a mistake by AMD. And it seems they are doing it again by mixing up ZEN3 that is Socket AM4 with ZEN3+ that is now said to be Socket AM5.It makes a lot more sense than making Bulldozer/Excavator CPU's for AM4 back in 2016, and yet that happened. Yeah, we could come up various explanations for this, but the same goes for Zen3(+) + DDR5.
New Process + new chiplets + new IO chip + new chip(sets) + new socket + new RAM standard + new PCIe standard, all in one generation? Now THAT doesn't make sense to me.
I'm not really longing for that.
It makes quite a lot of sense if they don't want to be overly late with their own ddr5 & pcie5 platform, especially after being so vocal with "We're the first with pcie 4.0!!!"ZEN3+ should be on Socket AM4 just like ZEN to ZEN+ was on Socket AM4. It makes absolutely no sense to release a ZEN3 generation CPU on a new socket.
If the rumour claims ZEN3+ is on the mysterious Socket AM5, that rumour is incorrect.
6 months late to what? Intel's launch? I've never seen AMD (or Intel) trying to align their launches like that, mainly because they can't, and also because it's stupid and short sighted.God knows they'll need it against Alder Lake, especially after coming in (probably) 6 months late to the party!
I like AMDs new ZEN strategy. In order to gain significant IPC increases, you need design overhauls versus just minor improvements.h and regarding the near 30% IPC uplift? God knows they'll need it against Alder Lake, especially after coming in (probably) 6 months late to the party!
System Name | KarymidoN TitaN |
Processor | AMD Ryzen 7 5700X |
Motherboard | ASUS TUF X570 |
Cooling | Custom Watercooling Loop |
Memory | 2x Kingston FURY RGB 16gb @ 3200mhz 18-20-20-39 |
Video Card(s) | MSI GTX 1070 GAMING X 8GB |
Storage | Kingston NV2 1TB| 4TB HDD |
Display(s) | 4X 1080P LG Monitors |
Case | Aigo Darkflash DLX 4000 MESH |
Power Supply | Corsair TX 600 |
Mouse | Logitech G300S |
wow that's amazing, i hope it's true, will totally blow intel out of the water
Like ZEN 2 into ZEN 3, ZEN 3 is pretty much a substantial overhaul over ZEN 2. It's like AMD took what it has learned about all it's ZEN designs and couples the best features all together.remember AMD promised 19% IPC increase on ZEN3 over ZEN2 and delivered that, so no reason to think they can't deliver it. i mean i wanna see it to believe cause ZEN3 is already so freaking powerful that is hard to believe they can squeeze more juice out of the ZEN architecture family... man what a bad time to be Intel.
Yeah, it feels weird to me how the ZEN architecture is volatile for AMD, almost every 2 years it gets a complete overhaul and some really solid gains...Like ZEN 2 into ZEN 3, ZEN 3 is pretty much a substantial overhaul over ZEN 2. It's like AMD took what it has learned about all it's ZEN designs and couples the best features all together.
ZEN 4 is also a new design, heavily overhauled according to Dr. Lisa Su. That's the only way to gain such incredible IPC gains per release.
We've witnessed it from ZEN to ZEN2 and from ZEN2 to ZEN3. Absolutely no reason to think ZEN4 won't follow this pattern in IPC gains.
System Name | The Expanse |
Processor | AMD Ryzen 7 9800X3D |
Motherboard | Asus Prime X670E-Pro Wifi BIOS 3222 AGESA PI 1.2.0.3a |
Cooling | Corsair H150i Elite LCD XT |
Memory | 64GB G.SKILL Trident Z5 Neo RGB DDR5 6000 CL 30-40-40-96 1T |
Video Card(s) | XFX Radeon RX 7900 XTX Magnetic Air (25.6.1) |
Storage | WD SN850X 2TB / Corsair MP600 1TB / Samsung 860Evo 1TB x2 Raid 0 / Asus NAS AS1004T V2 20TB |
Display(s) | LG 34GP83A-B 34 Inch 21: 9 UltraGear Curved QHD (3440 x 1440) 1ms Nano IPS 160Hz |
Case | Fractal Design Meshify S2 |
Audio Device(s) | Creative X-Fi + Logitech Z-5500 + HS80 Wireless |
Power Supply | Corsair AX850 Titanium |
Mouse | Corsair Dark Core RGB SE |
Keyboard | Corsair K100 |
Software | Windows 10 Pro x64 22H2 |
Benchmark Scores | https://valid.x86.fr/asijsu https://browser.geekbench.com/v6/cpu/11073923 |
Not sure why you claim the ZEN Architecture is volatile? When AMD has been achieving Technological Advancements, squeezing more efficiency, power savings and speed out of ZEN.Yeah, it feels weird to me how the ZEN architecture is volatile for AMD, almost every 2 years it gets a complete overhaul and some really solid gains...
AMD improved its processors by a large amount when they brought out the original Ryzen processors.How have we moved from "3-5% and you should be happy" every year, to the "if it offers less than 15% we are going to be disappointing"?
