BIOS for HIS Radeon 9200 128MB 128-bit
kamil445
18 (0.02/day)
I'm looking for BIOS for HIS Radeon 9200 128MB 128-bit because in GPU-Z is recorgonized as 64MB 64-bit, maybe BIOS is corrupt or something so i want to try reflash the bios.
Found BIOS for 128MB/64-bit 64MB/64-bit but not for 128MB/128-bit...
I also cant't extract bios using GPU-Z.
1,375 (0.83/day)
Hi!
It is more likely that GPU-Z is reading the card wrongly, I mean it's an old card and I've seen such cases before. Try using HWInfo32 and AIDA64 and see what they say about the card.
kamil445
18 (0.02/day)
All programs see 64MB/64-bit. AGP is 8x, fast write is off, tried enable but automatically is set to off in windows. Fast read is enabled.
I searched in google for 9200 and i seen my card doesn't have one capacitor near AGP:
This can be the problem ?
I found similar cards to my and all have this capacitor:
and this card, there are additional two capacitors
Should i first try to reflash bios or add missing one or two capacitors ?
Ruru
S.T.A.R.S.
12,839 (2.94/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-A
Cooling Arctic Freezer 50 / Thermaltake Contac 21
Video Card(s) RTX 3080 10GB / RX 6700 XT
Storage 3.3TB of SSDs / several small SSDs
Audio Device(s) Creative Omni BT speaker
VR HMD Oculus Rift CV1
Does other programs recognize it properly?
1,891 (1.43/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
What you circled in the picture is the capacitor that you have it also.
In that picture on the lower line there are 3 slots for capacitors but only 1 is soldered, the one nearest to AGP.
As i see in your picture you have the exact same capacitor soldered there.
I am guessing it is not about that capacitor.
42,354 (6.65/day)
Let's ensure the ram chips are infact 128MB total
From this datasheet they should be 16MB chips at 200MHz or 400Mbps
Also just get us a GPU-z Screenshot and then go to advanced tab and select Ram/Memory on context menu.
kamil445
18 (0.02/day)
Thank you for expalantion,
Default windows driver detecting GPU as
Omega Drivers detecting GPU as
GPU-Z:
Can't find "memory" tab in GPU-Z
Information from Driver software
So should I first try to flash different bios ?
1,891 (1.43/day)
Romania
Have you tried to upload the current BIOS in Techpowerup database ?
Do not actually do it, just go to that point when GPU-z check the existence in database of your BIOS.
On the other hand, i do not think that for your card were more than one producer of memory chip.
At that time i mean and for very old model.
11,988 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Download your BIOS with this and post it, its been awhile but I bet I still have my notes from back in the day of how to change memory size and mod the older BIOS's.
DO NOT FLASH A NEW BIOS UNLESS YOU HAVE A BACKUP CARD!!!
1,891 (1.43/day)
Romania
On the other hand, 9200 LE was made with 64MB as i remember.
I never saw LE edition with 128MB.
And i do not think you will find a true genuine specs for your card.
42,354 (6.65/day)
It's a SE IIRC
Ruru
S.T.A.R.S.
12,839 (2.94/day)
Jyväskylä, Finland
9200 SE is always with 4 memory chips (2 in both sides) as they're always 64-bit cards.
42,354 (6.65/day)
This has 4 on each side so from chip datasheet it is 128MB card
11,988 (1.72/day)
Motherboard Asus
Keyboard Razer
Software A lot.
Plus the two 128 stickers.
Based on what you have shown this BIOS should work for your card, but before you put it on make a backup copy of your current BIOS and make sure you have some way to backup flash the card if it fails, Integrated graphics, a PCI graphics card, or get used to blind flashing.
*** DON'T TRY IT UNLESS YOU ARE READY FOR A DEAD CARD, I'M NOT AT FAULT NOR IS TECHPOWERUP IF YOU FLASH IT AND IT DOESN"T WORK***
kamil445
18 (0.02/day)
When i clicked open onboard eeprom program show warning "BIOS CRC is incorrect!" but it can read it.
BIOS in attachment as ZIP archive
  • HIS 9200 128MB-128bit.zip
11,988 (1.72/day)
Motherboard Asus
Keyboard Razer
Software A lot.
As stated before this is a test BIOS and my not work. Its based off your BIOS but I have NOT had time to look at my old notes at home yet, so unless you want a possible dead card or have another way to backup flash don't flash a BIOS yet.
I'm assuming you are from EU or Asia as your sticker also shows its a PAL version instead of NTSC, looks like someone flashed a BIOS to make it work with NTSC and probably didn't realize what they were doing. If you use overclocking software you can see how far the GPU and memory can go and then write those clocks into the BIOS, a fan should be used if you want much more performance than the 250Mhz, these cards will typically artifact when they are clocked too high or get too hot as leakage was a much more significant problem with the process node.
  • Test BIOS.rom
42,354 (6.65/day)
In this instance I physically verify ram because of fake cards or improper bios.
11,988 (1.72/day)
Motherboard Asus
Keyboard Razer
Software A lot.
8X16 MB chips is 128, they are 5ns chips, the pictures don’t show any signs of resoldering. I think someone got the card and flashed a “working” NTSC BIOS on it that limited the VMEM size. I will know more after I get home and load my old VM that has all the old tools on it.
Somewhere I still probably have the 500Mhz fox for windows 95.
42,354 (6.65/day)
Yup I pull data sheets is why, so many fake 1050/1060s made me have to.
Use this bios
Ruru
S.T.A.R.S.
12,839 (2.94/day)
Jyväskylä, Finland
Should I flash BIOS via latest atiwinflash or older version ?
Try with older as it's almost 20 years old card. I guess an older version has better compatibility.
kamil445
18 (0.02/day)
Oldest version is 2.0.1.11 ?
This version can't detect current BIOS version
42,354 (6.65/day)
kamil445
18 (0.02/day)
I tried several versions, 1.06 from 2005 is oldest working on xp, but still can't detect current BIOS, maybe beacuse BIOS is corrupted ?
Ruru
S.T.A.R.S.
12,839 (2.94/day)
Jyväskylä, Finland
I'd try ATIFlash, though I can't remember does it work with command line or does it need to be in real DOS.
