Cable Management Helpdesk
Co_Op
55 (0.01/day)
Cluj.RO
System Name OC on a budget
Processor Intel E4400 3Ghz (9x333@1.4375 bios) a.k.a. "Sh!tclocker"
Motherboard Gigabyte P35-DS3 rev. 1 bios F11
Cooling Scythe Infinity stock fan + AS5 + custom mount
Memory 4x1 Gb A-Data Vitesta 800 Extreme @ 833 4-4-4-12@2.1V
Video Card(s) Gigabyte 8800GTS 320 stock cooling @ 653/1566/1008
Storage WD 3200 AAKS
Display(s) Dell 2407WFP
Case Thermaltake Soprano
Power Supply Fortron BlueStorm II 500W
Software Vista 32bit
Benchmark Scores 3DMark06(vista) 11265 with CPU@3,2Ghz (9x356 @ 1.525V bios), RAM 890Mhz@4-4-4-12@2.1 V
won't work in my current setup (my case is behind the monitor, parallel to it), but definitely do-able DIY. I'll get some velcro tape, easy to tie/easy to untie :D
t_ski
Former Staff
11,941 (1.73/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
Yeah, the velcro straps work pretty good. I have some I was using for a second set of cables I'd use when I was going to a LAN party.
2,706 (0.41/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
Just a bump for a good thread
6,959 (1.03/day)
Australia, Sydney
*bumps*
Taking requests
Who has an ultra messy PC, and wishes it would be neater? Go to the first page, read the breif conditions, and post your PC here for us to fix up! :)
GTX
109 (0.02/day)
Hello to every one I have a new project and some cool spex but I dont have enough money for a cool case I have only 60 $ please can you recomand me sth ???? It would be very nice if it would be good for cable management !! :)
Thank you
Ur faithfull GTX
thoughtdisorder
1,818 (0.29/day)
Just South of Mars
System Name Decent Lappy
Thank you
Ur faithfull GTX
Do you have a psu or do you need one in the case?
If you do have a psu, check out the case below. It's a few bucks more (with shipping) then you stated you had, but it's a sweet case. Btw, I rarely ever recommend buying a case WITH a psu, they're usually unreliable.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811148012
jrherras_iii
85 (0.01/day)
Belleville, New Jersey
System Name Dunno :s
Processor I7-920 @ 4.2ghz
Motherboard Gigabyte X58A UD7
Cooling Corsair Hydro Series
Memory 1600mhz OCZ 6GB
Video Card(s) ATI Powercolor 5970 OC to 850/1200
Storage 128gb Patriot SSD (Boot drive) WD 300gb Velociraptor
Display(s) 28" Hanns-G
Case Thermaltake Armor Plus
Audio Device(s) On board =s
Power Supply Antec 850 watts
Software Windows 7 ultimate 64-bit
This is my PC Cable management simple but clean using thermaltake armor plus.Im using PSP camera thats why its kinda blurry :laugh:
jrherras_iii
85 (0.01/day)
heres the video before those pictures http://youtube.com/watch?v=7rRruStC0hU all u can see on the cd drives are the power cables I tried to hide it there..
and some pics again:
Ive managed to run the powercable behind the mobo tray
6,959 (1.03/day)
Australia, Sydney
You dont really have anything more to do. If you like, run the IO cable through the same hole that you used to route the 24 pin. I'd shove the IDE cable under the DVD+RW, to make less of it there.
With the PSU cables, use a zip tie and push them down (with the right side panel on) until you see as less of them as possible.
jrherras_iii
85 (0.01/day)
Thanks ill try to lower the dvd so i can shove it down.I also tried what you've said about the IDE its too short im going to fix the PSU cables now
hat
Enthusiast
21,753 (3.26/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
I think mine's O.K. I tried routing my 24-pin and 8-pin behind the motherboard tray and through one of those holes but the cade side got in the way.
And I don't have a camera. :(
I don't think there's anything else I can do though. Better than most people's though...
Rapid
25 (0.00/day)
Processor Intel e6550 Oc'd to 3.17Ghz
Motherboard Gigabyte GA-N650SLI-DS4L
Cooling Akasa Evo Blue AK-922
Memory GeIL 2GB (2x1GB) PC2-6400C4 800MHz Black Dragon
Video Card(s) Sapphire ATI Radeon X1950XT 256mb
Storage 2 x Maxtor 250GB 16mb Cache (RAID 0)
Display(s) 2 x Iiyama Prolite 17inch LCD
Case Thermaltake Armour
Audio Device(s) Creative Audigy
Power Supply Hiper Type R- 580W
Software Windows XP
Hi all, a newbie to this forum. This thread made me want to join :) I went on a cable management frenzy on my pc, I was inspired :D
This is stage one, im going to replace that ugly IDE cable somehow and hide it a lot better
Also try to straighten the blue power cables and make them more regimented
Am i on track :D
6,959 (1.03/day)
Australia, Sydney
Am i on track :D
Somewhat on but off. PCI-E 6 pin could be routed under motherboard, going straight down vertically. Reduce the slack on the cables, remember the fact that horizontallly and vertically running wires look the best, anything out of that looks bad.
I'd do the same to the 12v CPU power, or maybe make LESS of it visible, instead of it running like that, why not make the rest of it behind the mobo tray, then run straight down vertically to the mobo?
Get SATA burners, a smarter choice overall..
Hmm, how does that board overclock by the way? I might get it as well as another 8800GT...
Rapid
25 (0.00/day)
Software Windows XP
Cheers for the friendly advice dude, i will be doing phase two very soon :D Ill try what you suggested and see how far i get.
The mobo is a gigabyte ga-n650sli-ds4, i bought it based on this review in Tomshardware
I Overclocked the e6550 from stock to 3.2ghz very easily. The board is very stable in my opinion. The overclocking features arent as extensive as some other boards, but for myself it has enough features, and is easy enough to navigate around.
6,959 (1.03/day)
Australia, Sydney
You tried Ctrl + F1 in BIOS main menu yet? :), that will unlock most of the needed options.
Wait, 3.2Ghz? 465FSB? Can the board do 500+?
Rapid
25 (0.00/day)
Software Windows XP
Yeah i used the Ctrl + F1 to get the options, the reason i said its not as fully fledged in terms of options as my previous motherboard was a DFI Lanparty, which had no end of overclocking/ tweaking options.
Im running the FSB @ ~455 at the moment which with the cpu multiplier of 7 gives me around 3.185Ghz. The Ram which is Geil is running linked with that FSB @ 910 Mhz.
Pushing it 500+ im not sure, the Northbridge is pretty hot at the moment, had to stick a fan over it,(ref my pics posted) Im not sure if thats just because ive let the mobo deal with the voltage of the NB its self, if i fiddled with it, it may run cooler, Im not sure. Im not that profficient at overclocking so a more experienced person would probably get it over 500 :D
6,959 (1.03/day)
Australia, Sydney
I see. Yeah DFI Boards are LOADED with features in the bios... done with the second stage?
Rapid
25 (0.00/day)
Software Windows XP
Not yet dude, gonna do so tomorrow, got university today and plenty of work to get on with :D
*edited*
freaksavior
To infinity ... and beyond!
8,095 (1.22/day)
System Name Server. Gamer. Worker.
Processor Xeon 2659 v3 / 9800x3D / m1 pro
Motherboard Asus X99-E-10G WS / ASRock steel legend x870 / Apple
Cooling Noctua low profile / Noctua NH-L12 / Apple
Memory 64Gb 2133 ecc ddr4/ T-force 6400 32Gbddr5/ 32GB HBLM
Video Card(s) Evga gt 7300 / zotac 3070 / m1 pro
Storage Samsung 970 512 Evo NVMe+3x14Tb /2Tb 990 pro + 1Tb HP 920 ex. / 1Tb
Display(s) Headless / Acer Predator X34 / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MacBook Pro 16”
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corsair TX750 / Corais ax860 | / Internal 250w
Mouse Headless / corsair m65 / g502 proteus core
Any hope for mine?
Wile E
Power User
24,318 (3.61/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
Somebody broke out the dremel. lol. Very nice freaksavior. That's about the best I've seen a Stacker 83x
43,620 (6.41/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Crooked cathode :\ :p I didn't realize that was a stacker! (the fans on the door should of given that away) It looks amazing! Following Tk's guidelines, you may want to try hiding those smaller wires around the HDD bay area.:toast:
freaksavior
8,095 (1.22/day)
i plan on cutting one more hole were the 8pin can slip through and fixing the cathode.
