Cable Management Helpdesk
6,959 (1.03/day)
Australia, Sydney
i plan on cutting one more hole were the 8pin can slip through and fixing the cathode.
Still a lot you can fix, reduce the slack in the IO wires at the bottom... it looks ugly with the excess wiring dangling out, use some tape or something to hold them.
freaksavior
To infinity ... and beyond!
8,095 (1.22/day)
System Name Server. Gamer. Worker.
Processor Xeon 2659 v3 / 9800x3D / m1 pro
Motherboard Asus X99-E-10G WS / ASRock steel legend x870 / Apple
Cooling Noctua low profile / Noctua NH-L12 / Apple
Memory 64Gb 2133 ecc ddr4/ T-force 6400 32Gbddr5/ 32GB HBLM
Video Card(s) Evga gt 7300 / zotac 3070 / m1 pro
Storage Samsung 970 512 Evo NVMe+3x14Tb /2Tb 990 pro + 1Tb HP 920 ex. / 1Tb
Display(s) Headless / Acer Predator X34 / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MacBook Pro 16”
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corsair TX750 / Corais ax860 | / Internal 250w
Mouse Headless / corsair m65 / g502 proteus core
ok :)
6,959 (1.03/day)
Australia, Sydney
Hmm freaksavior.. what else... oh yeah. With your SATA cables connecting to the HDD, need cleaning up, the power cables are just dangling there, make an effort into making them "arched" instead of just leaving them there, dangling looking rather messy. Try sliding the excess cabling behind the hdd tray, or mobo tray...
Whats the point of a cathode there? I'd instead run it down the mobo tray or the side panel... as if that cathode will light the case up with the tooless brackets and the 5'25 bay in the way..
If you follow my instructions, also move the inverter somewhere else; thats out of our view or more convenient/neater for wiring.
I'd also consider making a hole for the CPU 8 pin power.
The burner, SATA wire make it go STRAIGHT into the gap and not curve around the place when going in, its even better if you route it down, behind the HDD cage then go behind the mobo tray gap. The loose fan wires could be twisted to reduce length (not by much) and will look better. Do the same with the cathode wires but DONT overdo it as the cathode's wiring is fairly fragile. I'd invest in multi fan connector block with the number of fans you have... its purely for aesthetics remember.
Apart from that , your PC practically is 100% fine. Just remember what I told you to do is bordering on OCD, see i spend like minutes adjusting wires, lol. Very subtle changes can mean BIG things...
On a side note I think I should make a "Your wiring has slack in it" logo or something
freaksavior
8,095 (1.22/day)
:roll: go for it :)
and thanks for the tips. i will when i get a chance to take my comp apart again so i can hid the 8-pin cable.
Rapid
25 (0.00/day)
Processor Intel e6550 Oc'd to 3.17Ghz
Motherboard Gigabyte GA-N650SLI-DS4L
Cooling Akasa Evo Blue AK-922
Memory GeIL 2GB (2x1GB) PC2-6400C4 800MHz Black Dragon
Video Card(s) Sapphire ATI Radeon X1950XT 256mb
Storage 2 x Maxtor 250GB 16mb Cache (RAID 0)
Display(s) 2 x Iiyama Prolite 17inch LCD
Case Thermaltake Armour
Audio Device(s) Creative Audigy
Power Supply Hiper Type R- 580W
Software Windows XP
PrudentPrincess
669 (0.10/day)
Eugene
System Name Foobox3000
Processor Core 2 Duo 36750@3.46ghz
Motherboard Gigabyte GA-G33M-DS2R
Memory 2gb (2x1gb) Crucial Ballistix Tracer
Video Card(s) EVGA 9800gtx
Storage 500gb 7200prm IDE
Display(s) Sceptre 19"
Case Apevia X-Qpack 2 Red
Power Supply 500w Apevia generic
Hey guys I need some advice on how further improve my cable management. Please keep in mind I don't have the ability to feed wires underneath my motherboard tray etc. because of my form factor.
3,924 (0.63/day)
System Name Main / Home Media Serever
Processor Intel i5 2500k @ 4.75ghz / AMD AM3 5200+ x2
Motherboard ASRock Fatal1ty P67 Performance / Biostar 790GX
Cooling Xigmatek Dark Knight / XIGMATEK Apache
Memory 12gb of G.Skill Value Series DDR3 / 4x 1gb DDR2
Video Card(s) XFX Radeon 6870 1gb / Asus Radeon 5450 512mb
Storage 2x Samsung 830 64gb SSD Raid 0 & 750gb WD Blue HDD / OCZ Vertex II 80GB & 10TB of HDD Space
Display(s) 2x Acer 24" LED / Samsung 50" LED
Case Xigmatek Asgard II / APEX PC-389-C
Power Supply Rosewill 750w / Antec EArthwatts 380w
Software Windows 7 Professional x64 SP1 / Ubuntu 14.04
What do you guys think of mine? :p
Rapid
25 (0.00/day)
Software Windows XP
Fair play BrooksyX that looks ace imo :) could you not slot the floppy cable directly under the mobo instead of making that sort of triangular shape?
PrudentPrincess that looks fun :D I dont envy you :D
3,924 (0.63/day)
You mean the ide cable. I probably could put it under the motherboard but I really don't feel like taking off the motherboard to do it right now. I am glad you think mine looks good, honestly I just wanted to show off like TKpenalty. :p
edit: I think I am going to try to stick the ide cable under the mobo real quick.
jbunch07
5,260 (0.85/day)
Chattanooga,TN
Processor i5-2500k
Motherboard ASRock z68 pro3-m
Cooling Corsair A70
Memory Kingston HyperX 8GB 2 x 4GB 1600mhz
Storage OCZ Agility3 60GB(boot) 2x320GB Raid0(storage)
Display(s) Samsung 24" 1920x1200
Case Custom
Power Supply PC Power and Cooling 750w
Software Win 7 x64
ha its amazing how much difference good cable management will make on cooling!
my gpus dropped 5 deg each after doing a little management!
PrudentPrincess
669 (0.10/day)
Eugene
Thanks for the support.
3,924 (0.63/day)
Okay as suggested ide cable is now behind mobo. (sorry about the bad pics. Had to use phone because cant find the digital camera).
jbunch07
5,260 (0.85/day)
Chattanooga,TN
Processor i5-2500k
Cooling Corsair A70
Case Custom
Software Win 7 x64
omg thats clean!
you could like eat of that or something, although i would highly rec amend you don't!
:rockout:
jbunch07
5,260 (0.85/day)
Chattanooga,TN
Processor i5-2500k
Cooling Corsair A70
Case Custom
Software Win 7 x64
43,620 (6.41/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
jbunch07
5,260 (0.85/day)
Chattanooga,TN
Processor i5-2500k
Cooling Corsair A70
Case Custom
Software Win 7 x64
Since Tk isn't here at the moment, I'm sure he would say under the motherboard then out the bottom of the motherboard, with just enough slack to make the bend and into thier connections. I'm not quoting him or anything. Good luck.
thats what i thought thanx
jbunch07
5,260 (0.85/day)
Chattanooga,TN
Processor i5-2500k
Cooling Corsair A70
Case Custom
Software Win 7 x64
oops guess i should have read page 3 a lil more closely
6,959 (1.03/day)
Australia, Sydney
Yep.. that case owns for cbl management.
In a MATX case, you cant really do anything. However your wiring is good, so no need to worry, as the airflow isnt blocked by some wire mass or anything.
Latest update in old PC... not that nice looking because I dont care about cable management in the old PC that much [/lies!]
3,924 (0.63/day)
I just wish it had a side panel window so I could show everything off. Might have to add one in the future. I don't really want to buy a new case, especially since I don't have a lot of off extra money. I just fried my 8600gt so it looks like all of my extra cash will be going for a 3850/3870.
6,959 (1.03/day)
Australia, Sydney
SAME! Thats exactly what I wanted (and still want) for this case. I just need to get rid of the IDE drive and get two 1m long SATA cables, probably a better PSU as well.
Found a way to mount the fan :p duct tape anyone? Put the duct tape in the notches, then clamp two points. A very firm mount! Looks like i wont need to buy a new fan after all.
Anyone else need help?
1,203 (0.17/day)
FL
System Name Iam-a-computah
Processor i9 9900k @5 Ghz
Motherboard Gigabyte Auros z390x
Cooling Custom water loop, x2 280 radiators
Memory 16gb Corsair Dominator
Video Card(s) MSI 1080 TI FE 11gb WC
Storage SSD: 256gb Samsung 840pro & HHD: WD black 2T
Display(s) LG 34" UW screen
Case EVGA DG-86
Audio Device(s) Creative x-FI
Power Supply EVGA super NOVA 1300wtt
Keyboard G710
Software W 10
This is what i have so far, although my case is a soprano, it has a lot of space to cram cable in. Any suggestions?
jbunch07
5,260 (0.85/day)
Chattanooga,TN
Processor i5-2500k
Cooling Corsair A70
Case Custom
Software Win 7 x64
gotta love duct tape!
philbrown23
1,229 (0.20/day)
vermont
System Name Dominator
Processor INTEL C2Q Q6600 FTW!!
Motherboard ASUS P5Q-E!!!
Cooling TEC cooled cpu, everything else is under water :D
Memory 4GB CELL SHOCK D9GMH 1066MHZ/4GB CRUCIAL REDS
Video Card(s) 4850 (VT)/ 4850 IN CROSSFIRE!
Storage western digital= 1X 250GB, 1X 500GB, IDE 160GB (BOOT DRIVE ONLY). SEAGATE FREE AGENT 500GB EHDD
Display(s) viewsonic 19" hd widescreen
Case ROCKETFISH FOR NOW :(
Audio Device(s) ONBOARD WORKS JUST FINE FOR ME :p
Power Supply ULTRA X3 1KW MODULAR
Software win vista ultimate 64 TWEAKED!!!
Benchmark Scores http://valid.x86-secret.com/show_oc.php?id=434759 3dm06: http://service.futuremark.com/compare?3dm0
well I could not figure out how to make them a link but here are a few I will post a few more tomorrow but I'm in dire need of help here! I have 2 psu's to power everything and a water setup and the cables are a mess! please help!
SPECS:
Intel q6600
asus p5n-t deluxe 780I
2x 8800gts 512
160gb hdd sata2
300gb hdd sata2
dvdrw
4 case 120mm fans
ultra 800watt xpro psu (to power board and cards)
coolermaster 500watt psu(to power everything else)
case is a lian li A10 w/psu's/hdd's on the bottom and the rest on the top.
1,203 (0.17/day)
FL
Case EVGA DG-86
Keyboard G710
Software W 10
