Cable Management Helpdesk
3,471 (0.58/day)
System Name Acer Aspire V3-771G-53218G75Maii
Processor Core i5 3210M (2,5-3,1Ghz)
Memory 8GB DDR3 SODIMM
Video Card(s) Geforce GT650M
Storage Samsung 830 256GB - 750GB Toshiba drive
Software Windows 7 x64 Home Premium (non-acer-bloatware)
Step 1: the one cable going towards your front bays. Tuck is through the top hole shown on pic 2 and reroute it back through the side of the 5.25" bays where you need it.
Step 2: figure out which cables can be eliminated and stuff them through the top hole as well.
Step 3: in order to keep your cabling in 1 place, you could move the HDD's upwards. Reroute the power cables for it like you did with the one in step 1.
Step 4: see if you can route the 24-pin cable in straight lines: From PSU to the front, make a curve inside the 5.25" bays and straight back to the socket on the mobo.
Step 5: front panel (usb) cables. From the front panel, route them through the 5.25" bays out sideways toward the right (seen from the front) and stick them back in the small hole on the bottom. If possible, see if you can even get them through the big lower hole behind the mobo.
Step 6 is a bit personal, but I tend to refrain from tying up bunches of PSU cables. Makes it look like a big knot imho.
Step 7: post new pics to see if we can help you more :D
_jM
1,453 (0.24/day)
Ocala,FL
System Name The money pit v.2 (v.1 is the wife!)
Processor Core2Quad-Q9550@3.9ghz/1860mhzFSB @1.344v
Motherboard ASUS Maximus II Formula = best damn P45 OCer out there!
Cooling CoolerMster V8-- Custom WC system on the way! =]
Memory 8GB DOMINATORS @1100mhz 5-5-5-18
Video Card(s) EVGA GTX 280
Storage 150GB WesternDigital Velociraptor OS Drive/1 WD 500AAKS for Storage
Display(s) SAMSUNG 2243SWX 22" LCD
Case Cooler Master Cosmos S w/custom lighting and cable management
Audio Device(s) X-Fi Titanium (Fatality edition) - paired with RAZER Barracuda's
Power Supply CORSAIR HX1000W modular PSU
Software Windows 7 RC 7100--eats vista for breakfast lunch and dinner!
Benchmark Scores Coming to a theater near you!
also try and take advantage of the holes behind the mobo for your front panel connections and route them behind the mobo and down to the connections on the bottom of the mobo.
6,487 (1.11/day)
Midlands,UK
System Name Ultraman|Living room
Processor Intel core i9 13900HK|AMD Ryzen 7 5700x
Motherboard Alienware/Dell inverted motherboard|Asus B550m Prime Wifi
Cooling Alienware/Dell cooling + IETS GT500 cooling pad | Thermalright Silversoul 135 + Corsair 140mm white
Memory Alienware/Dell 32GB 6000mhz DDR5|Corsair DDR4 16GB 3200mhz
Video Card(s) Nvidia RTX4080 12GB| Zotac Nvidia RTX 4080 Super Trinity black edition 10GB
Storage 1TB Dell NVME + Samsung Evo 1TB NVME|WD Blue 500GB NVME,Kingston 240GB SSD,2TB Corsair NVME
Display(s) AOC Gaming CU34G3S/BK | LG C1 65" TV
Case Alienware X16| Corsair Carbide Air 240 White
Audio Device(s) onboard/Speakers: Logitech G560 | LG Eclair QP5 soundbar
Power Supply Alienware/Dell battery + 330W charger | Corsair RMx White 750w Gold Modular
Mouse Microsoft Pro Intellimouse - White | Logitech wireless
Keyboard EPOS mechanical keyboard| Logitech wireless
this is what i manage to come up with so far as managements:
134 (0.02/day)
Pittsfield, Massachusetts
System Name Gaming rig
Processor Intel i7 7700K at 4.4GHZ
Motherboard Asrock Z270M-ITX/AC
Cooling Cryorig H7
Memory Crappy 16GB memory
Video Card(s) Zotac 3060ti undervolted at .850mv
Storage WD m2 Sata SSD + WD 10TB HD
Display(s) 27 inch LG 1440p 144hz + 27 inch Lenovo Thinkvision 1440p 60hz
Case Thermaltake Versa H18
Audio Device(s) Klipsch Promedia 2.1 speakers
Power Supply EVGA 600W
Mouse Coolermaster MM711
Keyboard Steelseries Merc Stealth
So guys what do you think of this ??
6,487 (1.11/day)
Midlands,UK
the bottom looks very messy lol,well it looks messy to me
freaksavior
To infinity ... and beyond!
8,095 (1.22/day)
System Name Server. Gamer. Worker.
Processor Xeon 2659 v3 / 9800x3D / m1 pro
Motherboard Asus X99-E-10G WS / ASRock steel legend x870 / Apple
Cooling Noctua low profile / Noctua NH-L12 / Apple
Memory 64Gb 2133 ecc ddr4/ T-force 6400 32Gbddr5/ 32GB HBLM
Video Card(s) Evga gt 7300 / zotac 3070 / m1 pro
Storage Samsung 970 512 Evo NVMe+3x14Tb /2Tb 990 pro + 1Tb HP 920 ex. / 1Tb
Display(s) Headless / Acer Predator X34 / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MacBook Pro 16”
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corsair TX750 / Corais ax860 | / Internal 250w
Mouse Headless / corsair m65 / g502 proteus core
3,471 (0.58/day)
Unused PSU wires? Through the hole near the PSU. just keep em on the back of the mobo tray.
Used PSU wires? stick em through there as well if you're using them for anything in the front.
Front panel wires can be directed through the hole in right side of the upper 5.25" bay on top, then behind the 5.25" bays and if length permits, through one of those holes just below your mobo.
Now I know the hole near the PSU isn't that big, but I can fit the ATX, 4-pin, 8-pin and 2 Molex/Sata PSU cables plus a fancable through there. Just make sure to do the ATX plug first :D
Oh, and bunching up SATA cables is good, but do it after they run out of sight ;)
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
System Name Cozad (Asus G60JX)
Processor Core i5 M 430
Memory 8 GB DDR3 1066
Video Card(s) nVidia GeForce 360M
Storage 500GB
Display(s) 16 inch LED LCD
Software Windows 7 Ultimate x64 SP1
:( my case it a MESS inside - I'll have to take pix and post them later - I've actually considered chopping out the cables I don't use and capping off the 'stumps' with those electritians wire caps.
5,123 (0.89/day)
North of Germany
System Name Nexus PC
Processor Intel Xeon E3-1231 v3, 3600 MHz
Motherboard Gigabyte GA-H97-HD3
Cooling Thermalright Macho V2
Memory 24GB DDR3, 1400MHZ CL8
Video Card(s) Sapphire Radeon R9 290
Storage Samsung EVO 960 250gb, EVO 850 250gb, Vertex 3 128gb. 2 TB of Rotational.
Display(s) 1xAsus MX299, 2x Asus MX239, Oculus Rift CV1
Case Sunflower Tower
Audio Device(s) C-Media CMI8738/C3DX
Power Supply Corsair TX850
Mouse Cyborg R.A.T. 7
Software Win7 64Bit Ultimate
i hope you didnt want to loose any rma rights?^^
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
3,471 (0.58/day)
Warranty is for those who don't trust their own skills when it comes to seriously cutting stuff up :D
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
5,123 (0.89/day)
North of Germany
if i thought so i had lost exactly 140 euro...i used my legitimate rights, to return not physically damaged hardware to its buying place (in my case a relatively big internet shop), and got my board the third time, now they tell, it was heatbugged,died fast thru it, and i got revision 2.0 board for my old revision 1.0 (which was bugged, but not destroyed thru heat,read further)
i have literally screwed an asus 3870... i hacked several transistors off (with a very pointy, very big and heavy screwdriver),ripping a little line in the red pcb, i bridged them with pencil, and sealed them with arctic ceramique. the card ran half a year before it died. taking the pci-e area of the chipset with it, so not even onboard worked. i wasnt able to rma the card.... but i got my actual board back as replacement^^
FelipeV
95 (0.02/day)
Brazil
Processor Core2Duo E8500@4250Mhz 8,5x500
Motherboard ASUS P5Q-E
Cooling Thermal True X 120
Memory 8GB Gskill F2-8000CL5D-4GBPQ @ 1000Mhz
Video Card(s) PowerColor HD 4870X2
Storage 2x320GB R0 + 2x80GB
Display(s) AOC 212va 22"
Case Asys Freedom
Software Vista Business 64/ W7 RC7100 64
A few hours and a lot of zip ties later.
3,471 (0.58/day)
Nice work FelipeV!
GeneralDodo
87 (0.01/day)
Miami
System Name Dodo's PC
Processor Intel Core 2 Quad Q9550 2.83GHZ @ 3.83GHZ
Motherboard eVGA 750i SLi FTW
Cooling Rosewill RCX-Z775-EX
Memory G.Skill 2x2GB 1066 @ 900MHZ
Video Card(s) eVGA GeForce GTX 285 SLi
Storage Western Digital 1TB HDD 7200RPM
Case CM Stacker 830 SE
Power Supply Corsair TX750 750W
Tons of great pics of cable management on here.. gives me more ideas! =)
This is actually my first attempt at cable management.. Sometimes it just seems impossible to find a place to put the extra PSU cables. That and with mid-tower cases it's a damn pain to try and tuck them in somewhere out of sight. At any rate, tell me what you think.
Any suggestions on what I can do about the bundle of cables i've got visible there would be nice though.
5,123 (0.89/day)
North of Germany
try to reroute the 6v cables from the back through the harddisk-cage to you card, so i did
DreamSeller
lol i don't get it whats so hard about cable managment ://
i love doing it... to others :D
Ocean Master
7 (0.00/day)
Lockerbie , Dumfriesshire
System Name Oceans Rigger
Processor AMD Athlon64 x 2 7850
Motherboard Asus Deluxe M4A79
Cooling 2 x 8cm case fans , 1 x 12cm front case fan , 1 x CPU fan
Memory 4GB Corsair 240 dimm
Video Card(s) Gainward NVidia 9500GT 512BM
Storage Seagate Barracuda 7200 500GB
Display(s) Lg Flatron 24" widescreen
Case Apevia X-Cruiser
Power Supply Akasa PowerMax 850 850W
Totally New to Computers
Hi There
Totally new to computers so please excuse my ignorance if I get things horribly wrong.I read that you require a photo etc but hope that my question is so somple to answer that this won't be necessary.
I have an Apevia X - Cruiser case with Fan Speed , Temp and VU dials on front of case. I've wired up all of the internal components and am ready to switch on but there is one connector from the front of the case which is puzzling me. It is the Fan Speed output connector whch is of the 4 pin Molex type but which has only one yellow and 1 black wire.
Specs on this Molex connector are (0.23A 5 Fan Max 1.2A).
Having checked and checked I can find no slot to plug this into.
Can you help maybe please?
System Specs
Motherboard = Asus Deluxe M4A79
PSU = Akasa 850W PowerMax 850
Processor = AMD Athlon x 2 7850
Graphics = Gainward NVidia 9500GT
SeaGate Barracuda 7200 500GB hard Drive
After several barrages of PMs for cable management help, I've decided its necessary for this, to improve TPU's system's standards. Here are some instructions:
Instructions to request and recieve help
Post request, and post images in a similar way to this, image under, camera angle and image wise (except size, using small image as an example)
http://www.techpowerup.com/gallery/1350/1.jpg
Several requirements need to be met at the initial image post:
-Image must be clear and unblurred; must have clarity
-Flash MUST be used, to show everything off; remember you need help to repair it, you aren't showing it off, do not leave flash off and post your systems with the neons running; I'll just ignore you
-Image MUST be at least 1024x786 OR 786x1024. Anything lower will be ignored.
-System specifications must be noted
-Images MUST be posted as URL links please refrain from using imageshack/photobucket and use www.techpowerup.org instead.
Recommendations:
-Show both sides of the case, front side of the case (where you usually look) and the back side of the motherboard tray; this will significantly speed things up.
NOTE: Please if you feel that any of my instructions will damage your hardware tell me, I do not want to be responsible if you accidentally tear a capacitor while trying to route something. Safety of your hardware first!
If anyone needs help please ask! Please keep discussion ON TOPIC. One sentence posts that are not of any relevance/constructive. I'll ask a moderator to delete those messages. (a moderator is looking at me in invisible mode!)
Self Help tips
-Vertical/horizontally running wires generally tend to look better
-Pay Attention to how much slack the wire has, if there is no slack then that is good, however make sure that it ISNT under too much stress
-Try to exploit ever nook and cranny of your case to hide the wires, out of the way of an airflow channel
-Check the space behind the motherboard tray, or behind the 3'25/5'25 bays, use cable ties to hold spare cables/cabling (such as DATA cables etcetra) there using the spare holes on unoccupied drive bays.
-If you have IDE, rather than spending money on rounded IDE cables, instead fold your cables, make sure you carefully and neatly fold them as you can damage the IDE cable by just scrunching it, if its too long, fold it back and zip tie it, however making sure that the zip tie only is tight enough to hold it in place.
-With unsleeved cables, such as fan headers, try twisting them up. This ensures that they will be bunched together and overall look better, however do not overdo it as you may end up doing damage on the wires; too much stress.
Purchase Tips
-Stay well away from cases that have been proven to have poor cable management. One recommendation, if you have a look at Antec, their Plus View II, SOHO file server; there are many cases based off that chassis; that kind of chassis is generally poor for cable management
-Tall cases make it difficult for cable management thanks to the massive space between the PSU and the motherboard
-Make sure to purchase a PSU that uses either mesh sleeving or the flexforce type of wiring, especially the flex force as they are very thin in comparison to meshed, and unsleeved. Either option will ensure that your cabling looks cleaner and more professional. Moreover, sleeved/flex force wires are less aiflow impeding.
-Modular PSUs are a good choice, however in some cases such as the RC690 or Cosmo 1000, they aren't necessarily the best choice as their cable management features greatly negate their advantage
Bad cases for cable management (without modding)
-Antec P180
-Antec PLUS VIEW, or any case based off that chassis
-Thermaltake Soprano, VX, etcetra
-Coolermaster Stacker 830
Recommended cases
-Antec SOLO/Sonata PLUS/Sonata Designer (the same case) - Cannot fit some ROG boards, but very tall standoffs to allow many cables to be routed under
-Coolermaster RC690
-Antec 900 (latest revision with cable management features)
-Coolermaster Cosmo1000
-Coolermaster Centurion 5 (requires a hole next to the PSU for the case to really be good, at stock it is fairly decent, but not near impressive, howver with the easy mod, the case is an excellent choice), or any other case that is based off this (most gigabyte cases, Coolermaster Mystique, etcetera)
-Apex PC series (Generic, very cheap on newegg with good quality)
-Lian Li VCool Series
-Ultra M988 (yay for the power grid block)
-Thermaltake Armor/Kandalf
Recommended Motherboards
Generally, do not purchase motherboards with the 24 pin power towards the rear of the board, best only to purchase motherboards with the 24pin power on the normal positioning (right of the RAM sockets). Take note of where the front IO cables are, they are best at the bottom edge of the motherboard, and not somewhere in the bottom half of the motherboard. SATA headers which are angled from the motherboard are something to look out for, they are far neater in comparison, and basically hide your cables (in some circumstances the traditional SATA layout looks better.
Recommended boards:
-DFI current lanparty series for Intel and AMD
-DFI Blood Iron series (similar to gigabyte)
-Gigabyte's X38/P35/P31 S series - Simple standard layout, on DS3P/DS4/DQ6, recommended due to full ATX size.
-ASUS Republic of Gamers motherboards with 90* SATA at edge of case, extremely neat for SATA routing.
-ASUS P5K-E WiFi - on edge, but not 90* SATA headers, however supplied with 90* SATA cables so cables can be neated EXTREMELY neatly like on the ROG boards.
. RECOMMENDED 1024x786, IF YOU WILL NOT BOTHER TO DOWNSIZE THEN POST THE IMAGES AS LINKS[/b]
3,471 (0.58/day)
Hi There
System Specs
Hi and welcome!
If the plug you mention looks exactly like a Molex 4-pin, I suggest you wire it up to your PSU (Power supply unit).
Yellow and black are the typical lines for 12v (yellow = 12v, black = ground) and, if I am guessing correctly, this connector is used to power up your Fan Speed thingy.
If your fan speed thingy has knobs and can actually control fans, it is not all too uncommon having to plug in a molex on it.
Ocean Master
7 (0.00/day)
Still Troubled
Hi Thracan
thanks for the very quick reply. I thought the same as you did but I'm still very wary that I've already connected the 12v Molex Connector for the fans.This Molex Connector has an off-shoot which is labelled as an Output (0.23A 5 Fan Max 1.2A).
My best guess is that this is for the actual speed of the fans in the case and somehow needs connecting to the motherboard perhaps?
Thanks
Ocean
Hi and welcome!
3,471 (0.58/day)
Hi Thracan
Thanks
Ocean
Hmm, I can see 2 options then:
1: the connector has female pins (like a normal PSU molex connector) and is directly connected to the connector you used for your fans. In this case it's just an extension so you don't "lose" a molex by plugging in your fans.
2: the connector has male pins. In this case it's most likely you need to plug a molex in it to power *something* up.
If you could provide a pic it would be helpful.
Ocean Master
7 (0.00/day)
Hi
Pics attached .Apologies the quality is not so good.
1. Left Molex is the Output Molex , Right Molex is the Power Supply to the Front Panel
2. Pic of Left Molex showing Female connectors x 2
3. Pic of front panel
The front panel has a speed control dial which controls the fan speeds within the case.All fans are/can be linked to this one connector and each fan is then runs at exactly the same speed.
Thanks again for the help
3,471 (0.58/day)
Hmm, I need to take a closer look. Does the manual say anything by the way?
Ocean Master
7 (0.00/day)
Hmm
I wish it did.The one thing missing with the case when it arrived was the manual!!!
I've not been able to locate the manual online yet , although I've been looking hard.It would be great if I could find it , it would probably solve this riddle.
I guess I could still power my baby up and start loading the Windows operating system.As long as the fans are running this should not pose a problem?
