Cable Management Helpdesk
3,471 (0.58/day)
System Name Acer Aspire V3-771G-53218G75Maii
Processor Core i5 3210M (2,5-3,1Ghz)
Memory 8GB DDR3 SODIMM
Video Card(s) Geforce GT650M
Storage Samsung 830 256GB - 750GB Toshiba drive
Software Windows 7 x64 Home Premium (non-acer-bloatware)
Hmm
I wish it did.The one thing missing with the case when it arrived was the manual!!!
I've not been able to locate the manual online yet , although I've been looking hard.It would be great if I could find it , it would probably solve this riddle.
I guess I could still power my baby up and start loading the Windows operating system.As long as the fans are running this should not pose a problem?
Google was nice to me: http://www.apevia.com/umanual/um-x-cruiser.pdf
first hit...
Ocean Master
7 (0.00/day)
Lockerbie , Dumfriesshire
System Name Oceans Rigger
Processor AMD Athlon64 x 2 7850
Motherboard Asus Deluxe M4A79
Cooling 2 x 8cm case fans , 1 x 12cm front case fan , 1 x CPU fan
Memory 4GB Corsair 240 dimm
Video Card(s) Gainward NVidia 9500GT 512BM
Storage Seagate Barracuda 7200 500GB
Display(s) Lg Flatron 24" widescreen
Case Apevia X-Cruiser
Power Supply Akasa PowerMax 850 850W
FelipeV
95 (0.02/day)
Brazil
Processor Core2Duo E8500@4250Mhz 8,5x500
Motherboard ASUS P5Q-E
Cooling Thermal True X 120
Memory 8GB Gskill F2-8000CL5D-4GBPQ @ 1000Mhz
Video Card(s) PowerColor HD 4870X2
Storage 2x320GB R0 + 2x80GB
Display(s) AOC 212va 22"
Case Asys Freedom
Power Supply Corsair TX750
Software Vista Business 64/ W7 RC7100 64
Two new cases from friends that I´ve tried to make look better.
CM690, the best case so far to hide and organize cables, lots of options, and the best is that you can pass all the cables behind de MB.
Cosmos 1000, good looking, but you can´t even pass the USB and power switch cables in the back, the locking mechanism and sound isolation takes a lot of space.
That makes you pass de EPS12V cable over the MB since you wont find a PSU with a cable long enough to circulate the MB like it was done with the power cable.
2,330 (0.36/day)
Australia
System Name All Ryze
Processor Ryzen 7 1700
Motherboard MSI X370 Pro Carbon
Cooling Air
Memory G-skill Flare x 16GB 2400MHz
Video Card(s) MSI 1080
Storage Intel 600p NVMe 512GB for OS , 1TB WD Black and a 4TB Toshiba
Display(s) BENQ PD3200U
Case Phanteks
Power Supply Corsair 750W
Mouse Logitech G403 wired
Keyboard G19
Ocean Master
7 (0.00/day)
Hi Again
More help please if possible.
Now I've finally powered up I get the all clear beep from computer at switch on and checking in the bios all appears to A1 for all system compenents , however ....
At initial startup teh following message appears
Loading Asus Express gate then
Asus express gate Initialisation Incomplete
version l11209 8C000002
I then get a message asking me to insert boot disk into drive and hit any key.
What exactly does this mean? I've tried putting in Operating system disk for Windows Home and Windows Pro but neither will load?
Any help appreciated.
thanks
Ocean
Thanks !!
Just shows what a noobie I am. I see where I was going wrong. It's so easy when you know how.
Thanks for all your realy fast replies and great help.
3,471 (0.58/day)
Before that, you should get a message in the lower region of the screen:
Press <Del> to enter BIOS
Do that, look for Boot Options and make sure the CD/DVD is the first boot device.
Ocean Master
7 (0.00/day)
Thanks
I've already done this. I'm beginning to think that maybe the copy of windows may not be a good one. i'm going to try getting a registered copy of windows and try loading this instead just to see if it will work.
Will keep you posed.Thanks again for help
CombatLibrarian
7 (0.00/day)
Ellos!
My first stab at cable management in my new antec 1200.
Here's the hardware (also in my hardware info)
Motherboard: Gigabyte EP45-UD3P
CPU: Core 2 Duo E6550@2.33GHz, Cooling: ASUS Silent Knight II
GPU: XFX 9800 GTX+ 512MB
PSU: Corsair tx750w
Case: Antec 1200. Added optional 120 fan in door, and put a 120 in the extra bracket in the middle of the 3 bays.
1 Sata DVDRW Drive, top position
1 Sata HDD Drive, 2nd from bottom position
http://www.techpowerup.org/uploaded.php?file=090810/picture interior 1.jpg
Already on the to-do list:
+Route the 2x4 mobo power behind. I'm going to need to pick up an extension to do this, no amount of massaging was going to allow it without one thanks to having to run it to the right to the nearest hole before running it up the back.
I'm also considering doing some sleeving, at the very least on that cpu hsf.
I'm not sure what if anything to do about the front panel audio connection down there. There's simply not enough clearance to run it up from behind the left hand side of the motherboard.
cocosatul
2 (0.00/day)
Romania
System Name my little pc
Processor Intel Core i7 920 2.66GHz skt 1366
Motherboard Foxconn Bloodrage GTI
Cooling watercooling custom
Memory Corsair 6GB DDR3 2000MHz CL8 DominatorGT Triple Channel Kit
Video Card(s) HIS Radeon HD5870 1GB DDR5 256-bit
Storage 1x WD 250GB 7200RPM 16MB SATA2
Display(s) Dell 2408 WFP
Case Corsair Obsidian 800D Black
Power Supply Sirtec RockSolid Series 1000W-G14C
Software WINDOWS 7 64 BITI
hello
my new rig ,upgrade three hundred up to cooler master haf 932
i hope you like it
freaksavior
To infinity ... and beyond!
8,095 (1.22/day)
System Name Server. Gamer. Worker.
Processor Xeon 2659 v3 / 9800x3D / m1 pro
Motherboard Asus X99-E-10G WS / ASRock steel legend x870 / Apple
Cooling Noctua low profile / Noctua NH-L12 / Apple
Memory 64Gb 2133 ecc ddr4/ T-force 6400 32Gbddr5/ 32GB HBLM
Video Card(s) Evga gt 7300 / zotac 3070 / m1 pro
Storage Samsung 970 512 Evo NVMe+3x14Tb /2Tb 990 pro + 1Tb HP 920 ex. / 1Tb
Display(s) Headless / Acer Predator X34 / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MacBook Pro 16”
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corsair TX750 / Corais ax860 | / Internal 250w
Mouse Headless / corsair m65 / g502 proteus core
i hope you like it
Welcome to TPU m8 :toast: the case looks awesome congrats on a good job.
The only suggestion i have is get a extension 24 pin cable and sleeve it. :) that would make it look awesome!
cerver
68 (0.01/day)
Philly
i hope you like it
welcome :) very nice job mate, she looks great. i agree with freak ^ a 24 pin extension then sleeved would look purrty.
-cheers
adcom32
547 (0.10/day)
macon,GA
System Name new build
Processor INTEL E4300 @ 3.01GHz
Motherboard ASUS P5K-E P35 WIFI EDITION(ATX)
Cooling ThermalTake BigTyp 14Pro
Memory Crucial 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual Channel Kit Desktop Memory
Video Card(s) NVIDIA 9600GSO
Storage 61.4gb hard drive
Display(s) CRT COMPAQ
Case COOLERMASTER ELITE 310
Audio Device(s) ONBOARD-ADI AD1988B 8-CHANNEL HIGH DEFINITION
Power Supply coolermaster 460w
Software WINDOWS 7 64BIT
i was just wondering if the raidmax hurricane had good cable managment, i didnt buy it yet andi dont want to buy a case with bad cable managment.
3,471 (0.58/day)
I don't see any holes in the mobo tray, I'd say no.
rockleez
136 (0.02/day)
System Name AlanZ
Processor AMD Phenom II x2 550
Motherboard Asus M4A79XTD EVO
Cooling Xigmatek Dark Knight-S1283
Memory Crucial 2GB DDR3 1333MHz Ballistix Memory CL7
Video Card(s) HIS HD 5770 1GB GDDR5 PCI-E Graphics Card
Storage Western Digital 500GB SATAII 7200RPM 16MB
Display(s) Samsung Syncmaster 226BW
Case Antec Three Hundred
Power Supply Corsair PSU/VX Series 550 Watt ATX
Software Windows 7 Ultimate 64bit
I'm a newbie to computer building, this is my first build which i've nearly completed,just
ram to add now,
So i have no clue on any cable management, sorry if it's a disgrace to look at:banghead:
This case is a Antec 300
Any suggestions on what i can do?
3,471 (0.58/day)
Besides cable management I'd also check your cooling:
Your CPU cooler currently blows air down. It would be more efficient to turn it 180 degrees and let it blow your hot air straight out of the case.
Now for cables:
- The front panel cables can be run behind the motherboard.
- The 4 (or 8) pin mobo PSU cable should fit behind the motherboard as well. it looks like it's long enough.
If you feel the cable is a little too thick, use the indents you see in pic 2 to guide it.
After that it's just tucking some cables away behind the bays (you have ties there, use them) and you should be well on your way to get a cleaner looking rig.
6,487 (1.11/day)
Midlands,UK
System Name Ultraman|Living room
Processor Intel core i9 13900HK|AMD Ryzen 7 5700x
Motherboard Alienware/Dell inverted motherboard|Asus B550m Prime Wifi
Cooling Alienware/Dell cooling + IETS GT500 cooling pad | Thermalright Silversoul 135 + Corsair 140mm white
Memory Alienware/Dell 32GB 6000mhz DDR5|Corsair DDR4 16GB 3200mhz
Video Card(s) Nvidia RTX4080 12GB| Zotac Nvidia RTX 4080 Super Trinity black edition 10GB
Storage 1TB Dell NVME + Samsung Evo 1TB NVME|WD Blue 500GB NVME,Kingston 240GB SSD,2TB Corsair NVME
Display(s) AOC Gaming CU34G3S/BK | LG C1 65" TV
Case Alienware X16| Corsair Carbide Air 240 White
Audio Device(s) onboard/Speakers: Logitech G560 | LG Eclair QP5 soundbar
Power Supply Alienware/Dell battery + 330W charger | Corsair RMx White 750w Gold Modular
Mouse Microsoft Pro Intellimouse - White | Logitech wireless
Keyboard EPOS mechanical keyboard| Logitech wireless
The cpu fan is pushing air upward into the top 140mm exhaust fan.
pabloc74
184 (0.03/day)
Argentina
System Name Pabloc74
Processor i7 920
Motherboard Asus P6T Deluxe V2
Cooling Corsair H50
Memory Gskill 6gb Trident 2000mhz
Video Card(s) Sapphire 5870 Vapor-X
Storage Corsair Force GT 120gb + Samsung F1 1tb
Display(s) Samsung T260
Audio Device(s) X-Fi Titanium Fatality
Power Supply Corsair HX1000
Benchmark Scores no benchs!, machine use for gaming only!
best for me............
monday i have this new one, first on Argentina an too expensive:banghead::banghead:
3,471 (0.58/day)
Look twice... It's blowing down. You're looking at the open end of the fan, not the side with supports for the motor, which is always on the outlet side.
9,019 (1.39/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
sneekypeet
not-so supermod
29,690 (4.30/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Corsair Obsidian 800D ;) Great chassis!
pabloc74
184 (0.03/day)
Argentina
Processor i7 920
Cooling Corsair H50
5,202 (0.90/day)
System Name Dust Collector
Processor AMD Ryzen 5 3600X
Motherboard Asus B550I Aorus Pro WiFi AX
Cooling Alpenfohn Black Ridge V2 w/ Noctua NF-A9x14
Memory Corsair Vengeance LPX 16GB DDR4 3200MHz/CL16
Video Card(s) Power Color Red Dragon RX 5700 XT
Storage Samsung EVO+ 500GB NVMe
Display(s) Dell S2721DGF
Case Dan Case A4
Power Supply Corsair SF600 Platinum
Mouse Logitech G603
Keyboard Logitech G613
How do people hide cables when motherboard trays are like this?
If there's one thing I don't like about the Sniper is that cable management still looks messy thanks to the huge space between the bays and the tray.
3,405 (0.59/day)
Brunswick, GA
System Name Haz0
Processor i7-2700K
Motherboard Gigabyte Z68X-UD3H-B3
Cooling Chicken Stock
Memory 16GB G.Skill Ripshits X 1600MHz
Video Card(s) Sapphire 5850
Storage Kingston 128GB SSD + WD Black 640GB + 2x 1.5TB
Display(s) 24" Acer G245HQ + 19" Lenovo L194
Case Antec NSK-4482 Orangified
Audio Device(s) X-Fi XtremeGamer
Power Supply Corsair TX750W
Software Windows 7: Electric Boogaloo
http://i45.tinypic.com/2w382s5.png
I strap the 24-pin and PCIe connectors to those little cable tie spots and bring up all of the FP stuff through the bottom. Please ignore the 2 SATA cables and random power cable going in front of everything, that's my little Gigabyte eSATA thingy, it's impossible to hide but makes messing around with hard drives a lot easier.
Basically, don't be afraid to use shitloads of zippies. Oh and sorry for the crap-ish picture, my computer isn't in a very accessible spot now.
I think my UV cathode is about to fall down o_O
9,899 (1.68/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
http://img697.imageshack.us/img697/7991/dsc0002sm.jpg
That's nice. real nice.
I was going to suggest simply " tape" to kan, but your idea is probably better :laugh:
3,405 (0.59/day)
Brunswick, GA
System Name Haz0
Processor i7-2700K
Well, there is a ton of scotch and double-stick tape holding a whole molex line and a CC box behind my mobo tray.
