Cooler Master Scout True Gaming Chassis Comes Forward
3,779 (0.64/day)
Latin America, Uruguay
System Name The Lizard v2.4
Processor Intel Celeron G1840 (for the time being
Motherboard Gigabyte GA-H81-S2PH
Cooling Intel Stock Fan
Memory 16GB Kingston HyperX 1600
Video Card(s) MSI Gaming GTX 750Ti (For the time being)
Storage 500GB Samsung F1, 160GB Maxtor "Older than god"
Display(s) AOC 28' LCD
Case Coolermaster N200
Power Supply Antec VP500P
Benchmark Scores No crashes in the last 24 minutes.
110 dollars for that awesome chassis :eek:, DO WANT
DrPepper
The Doctor is in the house
7,482 (1.20/day)
Scotland (It rains alot)
System Name Rusky
Processor Intel Core i7 D0 3.8Ghz
Motherboard Asus P6T
Cooling Thermaltake Dark Knight
Memory 12GB Patriot Viper's 1866mhz 9-9-9-24
Video Card(s) GTX470 1280MB
Storage OCZ Summit 60GB + Samsung 1TB + Samsung 2TB
Display(s) Sharp Aquos L32X20E 1920 x 1080
Case Silverstone Raven RV01
Power Supply Corsair 650 Watt
Software Windows 7 x64
Benchmark Scores 3DMark06 - 18064 http://img.techpowerup.org/090720/Capture002.jpg
I wish they'd make something like that except extreme weight saving. I did extreme weight saving on my little HTPC. Wasn't pretty but I dont care :p
82 (0.01/day)
Processor Xeon E3-1240 v2
Motherboard Z77X-UD3R
Cooling Thermalright Frost Spirit 140
Memory 4x8GB KHX 1866c10
Video Card(s) Asus Strix GTX 1080
Storage 500GB SN 550 | 2TB Hynix P31
Display(s) Asus VG259QR | Acer 24" 1080p
Case CM RC-690 modded
Audio Device(s) Razer Kraken Ultimate
Power Supply Evga G+ 650W
Mouse Razer Deathadder
Keyboard Razer Tarantula
I like it. Only change I'd make would be covering the entire front with 5.25" sections just to retain consistency, but I guess that's a very overused look. I'd consider this case. :p
It's even dark-colored on the inside. Bit of a surprise. :p
Yeah, I agree. A few small things I'd change. 1)I like the left side panel, if not both, to be completely solid(no holes). 2) Redesign the slightly Fugly top(remove handles and/or just make it flat on top w/ handles, guess I don't like the slants on the Antec 900/1200 etc.). 3) Hmm, don't use LED fans.
6,959 (1.04/day)
Australia, Sydney
this is just a reinvented version of their centurion lol. Not saying that thats really bad, cause it does have the good qualities of the centurion (and a nice hole in the CPU area of the mobo tray).
3,393 (0.55/day)
BC.CAN
Processor 2700x under H100i progeebee
Motherboard ASUS x470 prime
Cooling Fans
Memory gskill ripjaw 3200
Video Card(s) MSi Vega 64 ref
Storage 120Gb OCZ Vertex 2E SSD - 500Gb Games - 1.5tb Storage and Media
Case CM HAF 932
Power Supply Corsair TX750
Software Win 10
crtecha
2,407 (0.41/day)
ipsay meechigan
System Name Coolin Runnings
Processor AMD X4 Phenom 9950 B.E. @ 3.3ghz
Motherboard Gigabyte GA-MA790x-DS4 BIOS Ver. F6
Cooling CM Vortex 752
Memory apacer PC6400 800mhz x 2
Video Card(s) Two ATI Radeon 4850's in xfire
Storage Seagate 7200.9 320gig+250gigx2
Display(s) Acer P191w 19' wide
Case Antec 900
Power Supply Antec Power trio 550watts
Software Windows 7 x64 Build 7100
pretty good looking case. i dont care much for the handles on the top or the red led's but other than that its a pretty cool case
DrPepper
7,482 (1.20/day)
System Name Rusky
3,393 (0.55/day)
BC.CAN
Cooling Fans
Case CM HAF 932
Software Win 10
In my experience some psu's dont have a long enough 8 pin cpu connector.
I guess that's why good cases come with extensions for the 8 pin. My HAF (which is huge) came with an extension but my PSU has more than enough length to make it to the connector even though its routed behind the mobo tray.
2,143 (0.37/day)
System Name THE MAD BEAST!!!
Processor Tinfoil rapper with some coathangers
Motherboard Graham cracker with with frosting
Cooling A shovel full of snow
Memory Grey matter out of a corpse
Video Card(s) Cat eyes
Storage A whales brain
Display(s) Cyclops eyeball
Case Inside a yetis hollowed out corpse
Audio Device(s) howling banchee
Power Supply 32 hamster on a massive wheel
Software WHo needs software when you have a box of kittens
Benchmark Scores IS gatrillions a number?
i shall purchase one and roll it down a hill on fire...HAHAHAHAHAH nah just kidding it looks aight
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
90` hdd bays are rubbish,all they do is block the air-flow from the front fan.
I'd get this for every rig that isn't my main one. That looks awesome. The one thing I've got against it though is those 90 degree HDD mounts. You're right Tigger, that is rubbish.
I've got a HAF case and I think quite the contrary - there's a nice gap (roughly 1/2"-3/4") beween each HDD, so plenty of air gets through, not to mention cooling the drives.
And, with only 3 HDDs in my system, I'm staggering them, so there's a ton of airflow.
The slide out tool-less HDD cages are some of the simplest and best I've worked with, albeit not terribly sturdy. The only tricky thing is you need to remove the back panel to unplug the drives if cables are short or stiff.
...I'm assuming this case has the same HDD cage dimensions of the HAF
2,304 (0.38/day)
Edmonton, Alberta
System Name AMD | Intel | Chumpy
Processor PHII 955BE Stock | i7 920 D0 4.01 GHz | i7 920 D0 4.01 GHz
Motherboard MSI 790FX-GD70 | EX58 - UD5 | E760 4 Way SLI
Cooling Zalman 9700 CNPS | Water Loop | Water Loop
Memory 4 GB XMS3 1600 MHz | 6 GB Dominators 1600 MHz | 6 GB Dominators 1866 MHz
Video Card(s) 3 x 9600GSO, GTX260 216 | 2 x GTX 260 216 | GTX 260 216, 9600 GSO
Storage WD 640GB | Couple o' 5400RPMs | WD 1TB
Case Cosmos S | Lancool K62 Dragonlord | Lian Li PC-P80 Armor
Power Supply TX850 | HX 1000 | HX 1000
Software Win 7 Home Premium | Win 7 Ultimate | Vista Home Premium
It just seems so pointless to have a fan there when 1 cm behind it is a large fairly restrictive hunk of metal. First thing I'd do is rip that out and either make my own or use the CD Drive space.
h3llb3nd4
3,323 (0.57/day)
Durban, South Africa
System Name My mobo is Laughing at me
Processor E7400
Motherboard P5KPL-E Bios flashed to 0601 (Piece of poo!!)
Cooling Thermalright Ultra 120a
Memory GENERIC 2 GB DDR2 800
Video Card(s) NONE!! Beat that!!
Storage 500GB SAMSUNG SATAII, 250GB SAMSUNG SATAII and o'l crappy 4gb maxtor
Display(s) ACER X223W Q
Case AEROCOOL ZERODEGREE (planning to mod)
Audio Device(s) REALTEK ONBOARD
Power Supply GIGABYTE 460W
Software Win 7 x86 build 7022
Benchmark Scores Super Pi 1m 17.000 :(
one up on that el fiendo
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
The point is - it isn't restrictive. That "hunk of metal" has large holes for air passage across the hard drives.
One thing I didn't like was the case punchouts for the fan, so I took a jig-saw and went to town.
5,250 (0.86/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
you can't mod upper fans with this case
3,301 (0.53/day)
System Name Thakk
Processor 9800X3D
Motherboard MSI B650M Gaming Wifi
Cooling Id Cooling A410 + 2400 RPM push pull
Memory 32GB DDR5 6000 C30
Video Card(s) Zotac RTX3080 Trinity
Storage Crucial NVME 512 / Intel 250GB SSD / Samsung Pro 512 SSD / SanDIsk 1TB SSD / WD Black 6TB
Display(s) Acer Predator X34 100hz IPS Gsync
Case Generic mATX
Audio Device(s) Hyper X 7.1 USB Soundcard
Power Supply Corsair CV750 Bronze
Mouse Logitech G200
Keyboard Monsgeek MG75S Hall Effect + XDA Keycaps + Holee Mod
VR HMD HTC Vive
Software Windows
Benchmark Scores https://www.3dmark.com/3dm/123890762?
So umm... wait. I have a fake gaming chassis?
5,976 (1.03/day)
Cybertron aka Canada
Processor Intel Core i5-3570K
Motherboard Asus P8Z77-V Pro
Cooling Noctua NH-D14
Memory 8GB Mushkin Blackline DDR3-1600
Video Card(s) Gigabyte GTX 670
Storage Intel 520 60GB, Seagate Barracuda XT 2TB
Display(s) BenQ 24" XL2420T
Case Corsair 550D
Audio Device(s) Sennheiser HD600, Audeze LCD-3F, Mytek Stereo 192 DSD, La Figaro 339, Burson HA-160, Geek Pulse X
Power Supply Corsair AX650
Mouse steelseries Sensei MLG edition
Keyboard Cooler Master QuickFire Pro
Software Windows 7 64-bit Home Premium
I think he means there is no radiator mounting options at the top just a 140mm exhaust but it might have 120mm mounting holes.
the problem is the front intake fan is used to cool the hard drives not cool the motherboard, the holes on the side of the hard drive cage is meant to let the hard drives breathe.
if fan filters and wire grills can add restriction i'm sure this hard drive cage will. but you are right if you want to change it so it brings cool air onto the motherboard you would have to turn the hard drive cage 90 degrees. of course most people will probably compromise and mount there hard drive at the very bottom of the cage and remove the unused hard drive brackets.
Nothing here fancy me here I've seen it all. Look different outside but same thing inside (no improvement whatsoever). Kind of got tired of company releasing new case with nothing change except the outside (color, more junk port, heavier, same cooling, same placement, same boring stuff). Come on bring something fresh to the table!
I agree, I like the carrying handle and the led button but there is nothing special about this case.
Cooler Master Centurion 590 is only $69 and has more fan mounts, water cooling grommets (scout does not), radiator mount and a forward facing hard drive cage.
Icejon
122 (0.02/day)
Los Angeles
I saw this recently in person at a Cooler Master event. The case is much slicker than it looks in the pictures for two reasons. The case has the highest quality black coating I have seen. The coating covers all the sharp edges even inside the 5.25" bay cutouts.
It is much smaller in person and that isn't so bad. When I go to a LAN party I take my 2nd computer. Why do I need to bring my watercooling stuff and lug it up steps and such, that's why the water cooling grommets aren't a big thing for me. It's not exactly a water cooling champion and to be honest I wouldn't have much use for WC on a system that passes through my front door often.
Bruce R
1 (0.00/day)
Coolermaster SCOUT Case - Warning
I may have received a factory reject case but its '5.25 inch' drive bays do NOT accept standard 146mm wide optical drives, even with the left hand side 'latch-pins' withdrawn.
A standard drive bay is 147mm wide, but metal 'dimple' protrusions on the bay's right hand side reduce the SCOUT case bays to just 144m in width, so be warned. :wtf:
In all other respects the case that I have been supplied with is really superb, but completely unusable because I cannot fit any optical drives :banghead:
Perhaps reviews and exhibitions used correctly made drives ? :respect:
