Cooling problems persist on LGA1700
345 (0.12/day)
USA
System Name pr0n box, Version 12
Processor i7-14900K
Motherboard Asus ROG STRIX Z790-A II
Cooling Corsair H150i Elite Capellix XT (360mm AIO)
Memory 32GB Corsair Vengeance DDR5-7200 CL34
Video Card(s) 7900XTX 24GB XFX Merc 310 Black -- OC bios 444W ~2800mhz
Storage Samsung 990 Pro 2TB NVMe
Display(s) Samsung G95SC 49" Ultrawide, 5120x1440p240, HDR10
Case Corsair 3500X with Noctua fans
Audio Device(s) Beyerdynamic DT990 Pro, FX-Audio DAC X6, DTS Headphone:X
Power Supply be quiet! PurePower12M ATX3.0 1200W Gold
Mouse Corsair M65 Ultra
Keyboard Corsair K57
Same settings, OC on the memory
That's Enforced 253w power limit
Windows in Balanced mode.
Even installed core temp for better comparisons. (not that I think core four really got that hot?? false reading??* haven't used this in years.)
Your score looks fine, but wattage is high still. Should be able 253w enforced 5.7ghz (leave it all auto) 6000Mhz boost, 4.4 E-cores and 5ghz cache boost. Should hit close to 16800/16900 pts area, but actually be using less wattage than you are now. Wattage = heat dissipated. Try the stock enforced power limit settings under the Asus Core Performance Enhancement or w/e it's called. Should look better then. Just do your memory tweaks otherwise.
*****No reason to loose performance at a higher wattage (If Core Temp is accurate for that?)*****
EDIT: Update.
I flicked the chiller on to test the core temps vs hwinfo64. Looks close enough to me.
Here's a couple more screenies.
This is with LLC manually set to Lvl 2 Asus Bios. Score went up.
Temps went down, but that's my fault. I just know what it gets down to in temp on hwinfo64. (2c)
View attachment 390668View attachment 390669View attachment 390670
Are you saying leave 6.0 to TVB, or to change turbo ratios to hit 6.0 without TVB?
My cpu LLC is presently at 3, I will have to try 2. Setting intel extreme (253W) actually sets it to LLC level 4 by Asus so I’ve been turning it back down.
2,177 (4.32/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
TVB auto (auto = enabled). The cpu defaults short term 6ghz single core by default. All core loads are 5.7ghz default.
Intel extreme profile lifts power limits and uses LLC lvl4. Probably why it's near 280w.
Asus Multi-core enhancement set to enforce 253w limit. LLC should be no high than lvl 3. At default, the power limits are lifted. You want to enforce 253w. It'll still perform well, but be easy to keep cool.
345 (0.12/day)
USA
Processor i7-14900K
Intel extreme on my board sets 253W on both long-term and short term power limits. My cpuz scores still seem low and I can’t seem to make them go higher, I have tried quite a few combinations. I cannot seem to get higher than like 915/14300. My heat is very good, fully loaded is only like 85C.
2,177 (4.32/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
What you report is way off from what I'm asking of you to accomplish.
It's not 253w because MCE is set Auto = enabled lifted power limits.
Your previous screen shot even shows the power limit is lifted.
Don't use Intel Extreme Profile. This is snake oil.
Step 1. Clear cmos.
Step 2. Set XMP.
Step 3. Set MCE to enforce 253w limits.
Step 4. F10 save, enter windows.
Step 5. In windows testing CPU-Z benchmark again.
Step 6. Re-enter bios, now set only LLC to LVL 2. F10 save/restart.
Step 6. Compare results LLC lvl 2 and lvl 3.
Step 7. Share screen shots here.
That's all you need to do.
You score should be over 16k Cpu-z with the above settings. (14900K)
If not closer to 17K+. Let's say like 16.5k to 17.5k range.
345 (0.12/day)
USA
Processor i7-14900K
Step 1. Clear cmos.
Step 2. Set XMP.
Sure, I'll try it. I'm not stupid. MCE is off and has been off. Turning Asus MCE on actually REMOVES limits, not set them at 253W by the way.
2,177 (4.32/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Oh that's totally my fault, I honestly thought I didn't explain it well.
Optimistically, it might help new guys trying to figure out the possible cooling issue.
There is no such thing is MCE "off".
It's - Auto/Limits lifted and Limits lifted 90c (throttle lowered to 90c) and 253w enforced. 20250320_214957.jpg
345 (0.12/day)
USA
Processor i7-14900K
Disabled = OFF, for regular people
Your tip actually lowers my cpuz scores.
1st pic: bios reset, MCE off, XMPI
2nd pic: no other changes besides CPU LLC --> Level 2
2,177 (4.32/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
345 (0.12/day)
USA
Processor i7-14900K
And here's no other changes besides turning MCE on / remove all limits / 90C:
2,177 (4.32/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Nah man. Your telling us.
MCE 253w enforced
Show a screen shot of 270w
And have score like running 180w.
Screen shots that I can't validated time/date.
And even the Cpu-z compare shows like 16.9K
Which would be right for 253w power limit.
This chip, if the cooling is as good as they say, should be able to impress me with no less than 5.8ghz P-core and 4.5ghz E-core with MCE lifted 90c and only use of LLC Lvl 4 Asus Strix motherboard. This is how you get more performance. Or select a couple core to hit 6.2ghz. Look at XTU to figure out which cores are the fastest.
But no, you think my suggestions are false and want to paint a different picture. I'm sorry, that's not gonna happen today.
I could say fix OS, fresh OS, but you'll say you've done that a bunch.
Top board. Top Cpu. Entry lvl cooling. Unknown ambient temps. Unknown humidity. We just get strange return comments.
345 (0.12/day)
USA
Processor i7-14900K
MCE 253w enforced
You are mixing up my screenshots bro. Thanks for the inputs. I'll post back once I figure out what's going on. For now I'm just relieved by the sane temperatures I'm getting on a better MB and fresh 14900K compared to my old combo.
This guy has a very similar issue as what I'm seeing now:
It might be this newish bios, 1801, on this MB. I just can't win here o_O
2,177 (4.32/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
You don't have that board.
1801 for your board is 2 years old bios (newish??)
There has been 9 bios versions available for your board since version 1801.
345 (0.12/day)
USA
Processor i7-14900K
What are you talking about, kid?
1801 came out three months ago for my (new) Z790A and is the latest version. I flashed to that as soon as I got it. The guy on the rog forum with the dark hero updated to the same new version for his board that came out at the same time and has the same performance drop problem. So it’s either an Asus problem or an Intel microcode problem.
2,177 (4.32/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
I did a direct copy paste of your motherboard model then went to the bios tab.
2801 is the most current for your board.
This is not your board??
Also, my kid is well into his 20's. I'm quite a bit older than a kid.
345 (0.12/day)
USA
Processor i7-14900K
That is not my board, I have the newer WiFi-II / Wifi7 version
Maybe this is just a CPU-Z thing? I just ran Cinebench 2024 and I got 128/2064 scores -- baseline for 14900K is 128/2075. So it's good this baseline matches. But I wonder why CPU-Z reads low and scores go down and not up for what should be easy tweaks.
2,177 (4.32/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Maybe? Not sure. Sorry bout the board, your system specs don't include "II" but I guess wifi 7 should have pointed me in the right direction.
Cpuz is generally accurate. No sure why the score is so low.
Won't be able to compare for a while, I'm at the shop.
3 (0.23/day)
Processor Intel Core i7 3930K
Motherboard Intel DX79TO
Cooling Raijintek Leto Pro Rgb
Memory 32GB (8x4) Kingston DDR3 1333MHz
Video Card(s) EVGA GTX 980 Ti
Storage Sandisk 240GB SSD, Samsung 1 TB SSD (both SATA), 2 Western Digital Blue 2TB HDDs (3.5)
Display(s) Dell S2721HN
Case Corsair Carbide 400r
Audio Device(s) Logitech G Pro X Wired
Power Supply Corsair TX650M
Mouse Logitech G402
Keyboard Corsair K100 RGB Optical Gaming
maybe the cpu have a problem (Intel-disaster 13 & 14 th. gen)
And maybe he got a particularly bad CPU (unlucky I guess). There's no way an i7 14700k would just hit 100C doing anything while under a 360mm or a 280mm AIO.
345 (0.12/day)
USA
Processor i7-14900K
I think my 14700K was a bad / lower binned cpu. It ran incredibly hot with or without oc and did not oc stable beyond 5.6.
According to the bios scores this new 14900K is average, not great not terrible SP 95. The problem is any tweaks aren’t increasing my cpuz scores.
Right now my theory is the low cpuz score may be a windows power plan issue interfering somehow. Like the guy on the ROG forum, if I change windows power plan to high performance or GameTurbo high performance, my scores DROP farther from 915 ST to 850-880 ST in cpuz. Changing the plan to Balanced gives the highest score of 915 which is still low.
This is why I ran cinebench 24 to compare to, and since it is matching to the 14900K baseline with Intel defaults loaded in bios I’m less worried it’s an actuall performance problem. But something’s going on.
688 (0.13/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper
Keyboard Razer Huntsman Elite
So, here's a question, when you are using your system for your usual tasks and not running benchmarks, are you happy with how it is running? At this point, I'd just say use your system and enjoy. This chasing 2-3% improvement isn't worth the effort.
You got your cooling under control and are no longer throttling, that's a win.
As I noted before, the newer hardware is pushed to the limit out of the box. Those big gains from OC are over. Any sort of manual tweaking is going throw off the internal sensors/algorithms the hardware is set to use to determine boost clock, voltage, temperature, etc. If you are getting the advertised clocks out of it, leave it alone.
345 (0.12/day)
USA
Processor i7-14900K
Yeah, I tend to agree. I definitely call this a win having fixed the temperature problem by flipping the GB/14700k for a Strix/14900k. It will absolutely run lower and have less stutter in gaming since it will not ever throttle thermally.
It's a little let down since my 13900KS and Z790 Hero OC to 6.1 and get 970+ ST score in cpuz, but honestly it doesn't matter. That rig is for work which benefits greatly from that OC whereas my home rig on the 14900K is really just for gaming where the true ST score will never matter. Most games I play are around a 25-70% load. Not throttling and boosting as much as possible will surely be best for that.
