Cooling Wars: Episode IX - The Rise of Air v Water
2,261 (0.99/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
i used to use Acrylic its fragile it cracks easy its not as good a PETG to bend but it do look better it has the look of glass. ill still use it if a customer asks but for my self no not anymore ive moved on :) .
543 (0.35/day)
Not Chicago, Illinois
System Name Desktop-TJ84TBK
Processor Ryzen 5 3600
Motherboard Asus ROG Strix B350-F Gaming
Cooling ARCTIC Liquid Freezer II 120mm, Noctua NF-F12
Memory B-Die 2x8GB 3200 CL14, Vengeance LPX 2x8GB 3200 CL16, OC'd to 3333 MT/s C16-16-16-32 tRC 48
Video Card(s) PNY GTX 690
Storage Crucial MX500 1TB, MX500 500GB, WD Blue 1TB, WD Black 2TB, WD Caviar Green 3TB, Intel Optane 16GB
Display(s) Sceptre M25 1080p200, ASUS 1080p74, Apple Studio Display M7649 17"
Case Rosewill CRUISER Black Gaming
Audio Device(s) SupremeFX S1220A
Power Supply Seasonic FOCUS GM-750
Mouse Kensington K72369
Keyboard Razer BlackWidow Ultimate 2013
Software Windows 10 Home 64-bit, macOS 11.7.8
Benchmark Scores are good
The last bit I need for P4HT's water loop is 2 80mm radiators with 1/8" inner diameter pipe (It can be 1/4" but adapters aren't cheap).
Any thoughts on which radiators I should get? I'm not looking to go ultra cheapo mode but I don't want to spend $70+ per radiator. I'm using Arctic F8 80mm fans in a Lian Li PC-62 if you're curious.
4,226 (0.95/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
I don't disagree with that, but reviews for cheap products are scarce. It's crazy how hard it is to find a review of say Pentium G6400 or Celeron G5900, compared to i9. It's also hard to find thermal tests done on cheap cards like 1650 from say Asus Phoenix. And yet pretty much every RTX 3070 and up are tested in depth. Same with motherboards and SSDs. If you want to build a cheap machine, then finding reviews for components is next to impossible. Even worse if you want to learn something about regional brands like Alpenfohn, SilentiumPC or Chieftec.
See, as someone who has used a recent pentium product in a build, I want to see someone watercool a pentium. I know from experience that the pentium will run without a heatsink. Not fan, heatsink, just bare IHS is sufficient in a case with no fans for some time before it overheats with heavy constant load. i want to see someone put a waterblock on it and keep it at room temp, for lulz.
14,650 (6.55/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
Though not a pentium, I put a 120 mm AIO on a 35 W T-series Sandy i3 once. It ran under 50 °C in every scenario... without a fan.
7,762 (2.71/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
Somebody by the name of, 'you,' said you ran your water cooler that hot. Anyway, you don't determine biofouling, Dow Chemical Company does. That is where the biocides are produced.
Finally a straight answer! So that's where you claim to get that from. Except that I said this:
I have a custom loop, and run my CPU around 80°C.
So, what does that say? That my CPU runs at around 80. Not the cooler. Not the water in the loop. The CPU. This was my entire point: it's clear that you flat-out misread what was said, and took that in a rather weird direction. All I was trying to say is that nobody is claiming their water loop runs at that temperature, nor is anyone claiming that this would be safe - or even possible at all. You can't run a water loop at 80°C liquid temperatures. Nobody has said they did so either. You misread what I said. Discussion done. Now can we please move on from this stupid side-track?
2,540 (0.47/day)
You seem to forget water is 10 times better at extracting heat than copper. If your cpu is 80°C, your copper cold plate could be 79°C and water could be 78.9°C while still at the same carrying capacity, that is the difference. Your water is not far behind.
MxPhenom 216
ASIC Engineer
13,083 (2.47/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
That's an example of what people are afraid of with liquid cooling.
Acrylic has other problems. I generally recommend soft tubing.
Like what? soft looks like shit.
14,650 (6.55/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
Watercooling works with much bigger temperature differences than that. Water that hot would never be able to keep your CPU anywhere near its operating temperature range, exactly because of the transfer among materials that you mentioned.
(Not that I understand what the point of the argument is, but never mind.)
2,540 (0.47/day)
I don't think you really understand specific heat, but carry on.
7,762 (2.71/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
Uh... No. That's not how thermal transfer works. You're assuming essentially perfect and immediate transfer. That is a semi-utopian best case scenario. A real water block is never that good. Also, I have temperature sensors in my loop, so I know how hot the fluid gets. Now, I don't have one directly after the CPU, and some heat does sink into the GPU when it's idle, but... My fluid temps peak in the low 40s when the entire system is running flat out. Yeah, no, the GPU is not lowering water temperatures by 40-50 degrees (especially seeing how the radiator only lowers temps by 2-5 degrees depending on pump speed). So no, at no point in my loop is the fluid anywhere near 80 degrees.
Edit: derp, 2-5, not 2-50.
11,880 (2.17/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
14,650 (6.55/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
I never even mentioned anything remotely related to specific heat. I was talking about heat transfer among materials, but carry on.
MxPhenom 216
ASIC Engineer
13,083 (2.47/day)
Loveland, CO
Uh... No. That's not how thermal transfer works. You're assuming essentially perfect and immediate transfer. That is a semi-utopian best case scenario. A real water block is never that good. Also, I have temperature sensors in my loop, so I know how hot the fluid gets. Now, I don't have one directly after the CPU, and some heat does sink into the GPU when it's idle, but... My fluid temps peak in the low 40s when the entire system is running flat out. Yeah, no, the GPU is not lowering water temperatures by 40-50 degrees (especially seeing how the radiator only lowers temps by 2-50 degrees depending on pump speed). So no, at no point in my loop is the fluid anywhere near 80 degrees.
mtcn is our resident HVAC expert...or so he thinks
It doesn't matter exactly where you have the temp sensors for the fluid in the loop. After a couple minutes, it should reach equilibrium and water temps will be the same throughout. I have one sensor in mine as a plug for an unused port on my res. My water temps bounce around 38-41c depending on the game.
2,540 (0.47/day)
You must be a different type of science enthusiast, but do carry on.
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
Stagnant water/ fluid maybe but we all have pumps that circulate fluid so your thinking/ science does not apply here.
14,650 (6.55/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
What's your point? Let's not sink to the level of making things personal.
2,540 (0.47/day)
Stagnant water/ fluid maybe but we all have pumps that circulate fluid so your thinking does not apply here.
Really, like equilibrium? That is what I said. Heat exchange is the same at the radiator, the ihs and the water.
Heat transmittance function is not up to debate.
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
Yeah you worded your statement earlier a little freaky but i get what you're saying now my bad.
1,978 (1.42/day)
Lithuania
System Name Shizuka
Processor Intel Core i5 10400F
Motherboard Gigabyte B460M Aorus Pro
Cooling Scythe Choten
Memory 2x8GB G.Skill Aegis 2666 MHz
Video Card(s) PowerColor Red Dragon V2 RX 580 8GB ~100 watts in Wattman
Storage 512GB WD Blue + 256GB WD Green + 4TH Toshiba X300
Display(s) BenQ BL2420PT
Case Cooler Master Silencio S400
Audio Device(s) Topping D10 + AIWA NSX-V70
Power Supply Chieftec A90 550W (GDP-550C)
Mouse Steel Series Rival 100
Keyboard Hama SL 570
Well, it might even run well under all loads with just stock heatsink without a fan. It would be nice to know that.
2,540 (0.47/day)
I never take an apology for granted. Eventually, we shall all agree what is happening is in accordance with physical phenomena and taking the optimal heat transfer as the benchmark is a good starting point to which we can add side functions.
Enough trolling, good night gentlemen.
29,377 (6.90/day)
Like what?
Oh, like...
...this for example.
Big problem when you want to keep a sealed fluid system actually sealed. But it also tends to react with the chemicals used to kill bio-growth, which causes discolouration.
That is YOUR opinion. A lot of people would disagree and consider hard tubing a very real PITA, especially if you do frequent upgrades.
17,769 (4.69/day)
System Name Paladin
Processor 7800X3D -25 all core ($196)
Motherboard B650 Steel Legend (silver/white) ($179)
Cooling Frost Commander (silver) 140 ($42)
Memory 32gb ddr5 (2x16) cl 30 6000 (white) ($80)
Video Card(s) Merc 310 7900 XT @3100 core $(705) (July 2023)
Display(s) Agon 27" QD-OLED Glossy 240hz 1440p ($399)
Case NZXT H710 ($60)
Power Supply Corsair RM850x ($109)
VR HMD Valve Deckard
As promised earlier.
Still have some things to fix and refine but the basic concept of it's application works.
this is going to be epic. honestly can't wait to see what the final product looks like. also this is kind of genius, I am surprised the big companies have not thought of this yet.
354 (0.09/day)
Oztralia down under
System Name K9
Processor i9 9900K @ 5.1Ghz and 32deg C - delid + Grizzly Conductonaught LM
Motherboard Gigabyte Aorus Z390 Gaming X
Cooling Custom water cooling loop - GPU + mobo (+VRM's) + CPU
Memory G Skill - Trident Z RGB DDR4 - 3866Mhz x 32Gb @ 3800Mhz
Video Card(s) Gigabyte Aorus 11Gb GTX 1080 Ti Waterforce Extreme @ 2250Mhz
Storage Samsung 500Gb M2 970 EVO + Samsung 850 Pro SSD + ADATA 512Gb SSD + Samsung 1Tb & 3T + WD 1Tb + 3Tb
Display(s) ASUS 27" ROG Swift 1440p @ 165Hz & BenQ 27" LED
Case Thermaltake Core P7 - Open frame
Audio Device(s) Logitech Z906 - 5.1ch
Power Supply EVGA 1200W
Mouse Roccat LeadR + Razer Nagar V2 Pro
Keyboard Corsair K70 LUX with Cherry Red switches
Software Win 10 Pro 64bit
Benchmark Scores v/fast
hi m8,
Nice bit of DIY, but, where's the cooling component of the loop = no radiator/fans ?? :confused:
17,769 (4.69/day)
System Name Paladin
hi m8,
I am confused as well, I was thinking he was 3D printing then like shaping a connector/enclosure to support an AIO mounting device... but I can't tell from the video either what is going on really. Wither way, it is a great idea and neat concept.
