Cooling Wars: Episode IX - The Rise of Air v Water
2,540 (0.47/day)
I think 80°C is definitely biofouling territory. Whoever runs water coolers at that temperature is asking for it.
my 5800X for example loses almost 200Mhz in Cinebench when going from an NH U12S to a 360mm AIO.
You know, ryzens have an ihs concavity problem that resolves only with high tension pressure.
Deleted member 24505
You may have misquoted me, my comment has nothing to do with running at 80c or water temp
2,540 (0.47/day)
Yeah, sorry about that. Should have quoted your source.
I have a custom loop, and run my CPU around 80°C. Why not? The CPU has absolutely zero problems delivering peak performance at that temperature.
That is how you get a dead system long term.
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
Sometimes it's matter of luck.
Building custom loop for many years and i've never done a leaking test :kookoo:
That's luck or madness :D
Well technically just filling with fluid is leak testing
No leaks is not luck it's just making sure all fittings/... are installed/ assembled well a not getting in a hurry
Speed kills in loop assembly we should save that for benchmarks lol
To the op
GPU's benefit the most temp wise on water blocks
You go from a loud 60c++ gpu to a quiet 40++ gpu just with a water block, that's a big difference lol
QDC's are sweet :D
3,023 (2.04/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
i know.
that's why i don't use Asetek AIOs.
but a Noctua Cooler works perfectly fine on ryzen. it's just that even my NH D15 at 100% RPM (1500RPM) is around 10-15% warmer than my AIO at 1200 RPM Fan Speed and balanced pump speed (inaudible even with an open case)
Outback Bronze
Super Moderator
2,144 (0.43/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
Yeah, I love Water Cooling but Air Cooling is way more practical.
FireFox
The Power Of Intel
7,507 (1.86/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
I had one for a few hours.
Arrived, installed, tested it and sent back the same day :roll:
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
Yeah I just keep a little 212 evo for emergency use
I was looking to get a new one but just threw that to a back burner because the be-quiet I was interested in had a shit mounting system new model was supposed to be better.
FireFox
The Power Of Intel
7,507 (1.86/day)
Germany
One thing i have to admit about the Noctua NH D15, that cooler is damn Sexy.
I paid €100 for the Noctua, when i sent it back and got the refund i bought an Alphacool Eisbaer LT360 for €100+, that said, for an Air cooler was expensive
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
Yeah about time they went black but yes they are prowd their old color scheme is nasty.
FireFox
The Power Of Intel
7,507 (1.86/day)
Germany
Right.
I remember a funny fact that happened to a friend of mine, he built a custom loop and filled it up with the pump speed at 3000rpm, everything seemed ok, no leaks, but when he increased the pump speed at 5000rpm due to the air bubbles the loop started to leak in 2 different points :D
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
Right.
Yep just leak testing in real time I do it too
Most consider leak testing using air pressure not water but it's not as much fun that way lol
11,880 (2.17/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Systems die long-term anyway, might as well use the shit.
I'm with him but at 70°C all the time, oh and my last pc exceeded it's usefulness way before I killed it and it was a cooker FX at high temperatures for life.
We do have cooler's attached and it's thermal cutoff would save it if it's frequency drop control didn't?!.
Or you could leave it on standby all its life bar gaming ,I imagine it would last age's.
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
20c under tj max should be fine for 24/7 365
But I have a system from 2009 acer q9550 still working but can't oc it so definitely increases life span not being able to play with it as much as my other systems not near as old x99 being the oldest after that one which hopefully it will last 12+ years to on a custom loop :D
freeagent
9,920 (4.21/day)
Winnipeg, Canada
Processor AMD R9 9900X
Cooling Thermalright Frozen Edge 360, 3x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 26-36-36-68 1.45v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I aim for the 70s but am ok in the low 80s. Though I have seen a hundred + a few times. All core clocks will getcha every time..
4,869 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
14,650 (6.55/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
My notification dropped me to page 5, where the topic was the Noctua NH-D15. I can't be asked to read back so much, so I jumped to page 8. The topic is still the D15. It looks like I didn't miss a thing. :)
2,540 (0.47/day)
This was a reply to that. You need to dissociate between cpu life and loop life which is heavily compromised by temperature.
FireFox
The Power Of Intel
7,507 (1.86/day)
Germany
Spikes?
Sorry for asking the same question 2 times but the first one wasn't answered.
11,880 (2.17/day)
Manchester uk
VR HMD Oculus rift
Yeah but CPU at 80 isn't watercooling at 80.
And he said his CPU is at 80 not his loop.
Beyond 60 on the loop is as you say.
FireFox
The Power Of Intel
7,507 (1.86/day)
Germany
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
Depends on system and clocks used
80c is pretty easy to achieve not really that dangerous either :cool:
11,880 (2.17/day)
Manchester uk
VR HMD Oculus rift
60°C water temperature and above kills pumps.
Well pc watercooling ones.
I aim for 50 max on water and achieve with relative ease.
Plus if you're water is 80°c it's not going to cool a CPU at 80 is it you need a temperature differential.
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
You just said 80c water cooling not 80c water temperature though lol
FireFox
The Power Of Intel
7,507 (1.86/day)
Germany
I would like to see that one with 60/80c water temp :kookoo:
Maybe they are planning to boil a chicken:roll:
