Cooling Wars: Episode IX - The Rise of Air v Water
freeagent
9,920 (4.21/day)
Winnipeg, Canada
Processor AMD R9 9900X
Cooling Thermalright Frozen Edge 360, 3x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 26-36-36-68 1.45v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I got lucky with my kids. Bottle of formula tipped over and dripped through the top fan on my Define R4 and onto the top of my 980 Classified. Right on the VRM area.. of course I didn't notice until god knows how long later, it had already long dried. Back then my systems were always running, because if it was off then I knew there was a problem lol..
Deleted member 24505
That is a terrible generalization. It is just better at the coldplate which can be easily equalised by liquid metal.
Aren't we discussing the two? Custom cooling is not in the same budget.
So putting liquid metal on a air cooler(generalization) coldplate, will make it better than a custom loop(generalization) I think it depends on the air cooler, the custom loop config, and the case and loads they are both under. "which can be easily equalised by liquid metal" this is a terrible generalization, without comparisons, or examples of one cooler or another vs a custom loop of some configuration.
A well setup custom loop cools both the CPU and GPU better than a air cooler, no doubt about it.
freeagent
9,920 (4.21/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
We will discuss this again when winter comes and I get my -40 and chilly house ambient :)
543 (0.35/day)
Not Chicago, Illinois
System Name Desktop-TJ84TBK
Processor Ryzen 5 3600
Motherboard Asus ROG Strix B350-F Gaming
Cooling ARCTIC Liquid Freezer II 120mm, Noctua NF-F12
Memory B-Die 2x8GB 3200 CL14, Vengeance LPX 2x8GB 3200 CL16, OC'd to 3333 MT/s C16-16-16-32 tRC 48
Video Card(s) PNY GTX 690
Storage Crucial MX500 1TB, MX500 500GB, WD Blue 1TB, WD Black 2TB, WD Caviar Green 3TB, Intel Optane 16GB
Display(s) Sceptre M25 1080p200, ASUS 1080p74, Apple Studio Display M7649 17"
Case Rosewill CRUISER Black Gaming
Audio Device(s) SupremeFX S1220A
Power Supply Seasonic FOCUS GM-750
Mouse Kensington K72369
Keyboard Razer BlackWidow Ultimate 2013
Software Windows 10 Home 64-bit, macOS 11.7.8
Benchmark Scores are good
It is the kind of thing I want to bring up. Heat spill from a gpu is very nasty and not vented properly.
Yeah, even with the tube it isn't all directed correctly. I'm considering getting a few 40mm fans and putting them in the front of my case to direct airflow.
2,540 (0.47/day)
I think we could discuss flow head characteristics of fans. Some should be able to pull from a longer duct. Personally, I think this is untreaded territory.
freeagent
9,920 (4.21/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
That's perfectly fine by me, I didn't ask for your help. Not to be rude or anything.
But you seem to think I need your expertise for some reason, all I am doing is just replying back to you.
I don't have anything beneficial to add because no one cares anyways.
2,540 (0.47/day)
Your case isn't the benchmark which all pc cases are measured by. I can make any point I want and you don't have to hold yourself responsible to fulfill those clauses.
Your personal replies tend to overarch my general inquiries which is not why I make them.
FireFox
The Power Of Intel
7,507 (1.86/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
I have seen/read so many threads/topics/debates about Air Vs Water, still some people are convinced and try to convince others that a simple tower with 1 fan or 2 when push/pull could match Watercooling:kookoo:
364 (0.28/day)
with so much testing results being easily available online it’s obvious water is superior, it’s just the setup and risk complexity compared to air that’s holding it back from being the first choice for the average person...
I personally like air , and I leave water for those times when air isn’t enough, or when air setup gets so huge and heavy .
I think water , or liquid cooling in general will take over in the future, air being backed by decades of research and development while water is fairly new and still being improved, with new liquid chemicals being tested etc...
2,261 (0.99/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
we all can argue untill the the cows come home but unless we were in the same room with our riggs doing the same test it dont mean shit, we cant prove nothing over the internet.
my own thoughts is its 50/50 horses for courses. but i lean towards a loop because i like the look but if thay got a bit more inventive with air coolers i could change in a heart beat or two for cpu but id keep a small loop on the gpu because in my view you carnt beat it for cooling.
LM ive only ever used it on laptops, for a rigg it dont impress me what drop you get in temp vs risk.
2,540 (0.47/day)
I think the sentiment should be the same for liquid metal conductors, but people overplay the risks while liquid metal won't ever leak, or seep like water does...
my own thoughts is its 50/50 horses for courses. but i lean towards a loop because i like the look but if thay got a bit more inventive with air coolers i could change in a heart beat or two.
I tend to agree air cooler enthusiasts need to be more inventive, there is nothing holding them back from a higher thermal transmittance paste, or airflow discretization. Personally, I think even crimped end fin arrays help in dedicating forced convection towards cooler exhaust without losing pressure toward the sides of the cooler.
FireFox
The Power Of Intel
7,507 (1.86/day)
Germany
I doubt it.
Too many people are afraid of a leak/drop of water :D
they prefer to run their CPUs at 80c rather than build a Custom Loop.
2,751 (0.67/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
If all goes well with the work I may have something kinda unique to show I created earlier.
Just finished reassembly and the setup part comes next, later today (I hope) and onto testing after that.
If all goes well I think you guys will like it.... But it's gotta work before I can show it.
Yeah, it's something crazy but then again, look who's making it. :D
7,762 (2.71/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
This discussion sure took a ... let's say interesting turn. I mean, arguing for introducing arbitrary limitations and/or advantages in order to "show" which is "best"? That sounds ... problematic. Should coke-v-pepsi taste tests be decided by adding mustard to the pepsi beforehand? Liquid metal can be used anywhere you want to. TIM is (mostly) universally applicable (just don't use LM on an aluminium cold plate). Cooler size is dependent on what the case can fit, regardless of whether that's air or liquid cooling. Etc., etc. Setting arbitrary limitations on any of these, whether it's only using LM on air cooling or not fully populating your radiator mount ... proves nothing except the radical notion that worse cooling = worse cooling.
It's obvious we can't come to any hard conclusion discussing like this. I would argue that such a conclusion is impossible, as there are too many variables in play - from CPU/GPU power, thermal density, case design (both in terms of cooler fitment/clearances as well as component layouts), case airflow, fans, pump speeds and flow rates, noise characteristics of various coolers (and cases and fan grilles and other relevant factors) - and a heap more.
But that's not the point either, is it? Is the interesting part of this discussion finding a universal and absolute conclusion? I would think the interesting part is the discussion itself, hearing the arguments (and thus use cases, priorities and preferences) of others. There is a 100% chance that someone will bring up something that you didn't consider or consider important; that someone will have very different priorities than you. Isn't exploring these connections - between preferences, priorities, desires and the choices made - the interesting part here? This becomes especially poignant once the search for some absolute answer leads us into some absurd nit-picky defining of conditions like what we've seen here. Is that interesting? Not to me, at least.
I mean, if it's hard answers we're looking for it's easy to just list the pros/cons of each broad type of cooling. We've all seen a hundred lists like that. Each solution has both advantages and disadvantages. Isn't it far more interesting to see which of these people choose to prioritize, and why?
This is a perfect example! I have a custom loop, and run my CPU around 80°C. Why not? The CPU has absolutely zero problems delivering peak performance at that temperature. And doing so allows me to run a (hot-running!) 5800X (-10 CO, +150MHz PBO, slightly lowered PPT/EDC/TDC, ~120W peak) and a 6900 XT (mostly running at a ~180W UV+UC profile, but fully capable of running at 330W if I need the performance) in a 14.7l case. Part of the reason for the high CPU temps is my Nouvolo Aquanaut CPU block+DDC pump mount, which isn't the best thermal performer. But who cares? I get a great pump, that runs very quietly, in a tiny form factor, and my CPU isn't complaining. I'm not extatic that my CPU is that hot, but the 5800X is notorious for running hot, so ... meh. The pros by far outweigh the cons. The overall package is fantastic - a tiny PC with fantastic performance, great efficiency (especially with the GPU profile), low noise (the system is literally inaudible over ambient noise for desktop usage, and even with the pump and fans pegged at 100% it's reasonably quiet, yet cools a ~500W load admirably). But as I said above: if I was starting from scratch today, I'd likely go air, due to cost and simplicity - something like a Noctua U9s or C14S and a honking huge air-cooled GPU in a Dan C4 or CM NR200 (could fit an even larger air cooler there) would likely be my choice then. It would be a bit louder under load (though deshrouding the GPU would no doubt alleviate some of that), but it would still be great.
The point is: air can be great, AIOs can be great, custom loops can be great - it all depends on the situation and implementation. Isn't that so much more interesting than some pointless trench warfare about which is "best"?
2,751 (0.67/day)
Alabama
Memory C.R.S.
I use air for my daily because it's hassle-free vs water but water overall does give the best temps, esp under load. I've been doing what I do for about 20 years now and I've practically done it all in one form or another to know that over my time of just running it to actually benchmarking competively with it at the bot.
Personally I go custom when I do water, don't care for an AIO and even gave one away once I had won because I just don't like them.
364 (0.28/day)
LM and Tims are a another topic that I am sure a lot of us will have different opinions about ....
my opinion about it is that’s it’s great to have as an option and should be used wisely, only use it when trying to overcome IHS<->Coldplate transfer bottleneck, which can be tricky to identify for the uninitiated
If thermal paste is not creating a bottleneck don’t bother unless you want it for fun or just want to test the liquid metal magic
I doubt it.
Man I can’t blame the regular folks , most of the people here are quite hardcore and we sometimes forget that we’re not the majority....
out there are people installing systems to run basic software for business management or telecommunication , hospitals and schools etc... I don’t expect oems to install water cooling on those systems because it’s not profitable and keeps entry cost low attracting more customers, probably those “regular “ systems are like 80% of the computers in the planet with the rest being some exotic cooling solutions for servers and a small percentage being custom loops ...
2,540 (0.47/day)
Agreed. It has its niche spot in the hearts of enthusiasts however, the majority would infact find distaste in their cpu fan suddenly overloading their case temperature, myself first. It is really difficult comparative to water cooling equipment, to keep case temperature
29,377 (6.90/day)
With good reason of course. No one wants a dead system or part.
This. We all need to remember that we are enthusiasts, effectively elite of the tech world. We represent a small fraction of the world's PC/Tech users.
FireFox
The Power Of Intel
7,507 (1.86/day)
Germany
I assume that the 80c your talking about is just temp spikes, right?
Everytime I am about to turn on the PC i start recording with my phone the moment when i press the power button just in case there was a leak and the PC the catches fire :laugh:
freeagent
9,920 (4.21/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
wish i'd recorded mine when the 1080 bit the dust, i was devastated, but fuck it, lesson learned, no more hard line.
FireFox
The Power Of Intel
7,507 (1.86/day)
Germany
Sometimes it's matter of luck.
Building custom loop for many years and i've never done a leaking test :kookoo:
That's luck or madness :D
3,023 (2.04/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
i really don't like any kind of liquid in my PC...
but something like an NH D15 is even worse.
i can't reach my M.2, GPU, RAM and GPU temps are going up by a lot when both fans are attached and suck air in before it reaches the GPU.
my first h150i pro xt even had a leak but i'd still stick to an AIO because of how it looks and for the performance. (my 5800X for example loses almost 200Mhz in Cinebench when going from an NH U12S to a 360mm AIO.)
2,261 (0.99/day)
south wales uk
i allways leak test ive allso got a pressure tester whats ment for putting air into motorbike shocks but it works just as well as the ek ones , i run the loop for a hour or two with no voltage from the psu just to be on the safe side ive only ever had one leak and it was just bad joint.
