Core 2 Duo System Temps
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Processor E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz)
Motherboard ASUS P5Q-e
Cooling CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan
Memory G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15
Video Card(s) Sapphire HD4850 512mb with ASUS EAH4850 BIOS
Storage 2x 500GB Seagate 7200.12 Raid 0
Display(s) Acer AL1912, 19" LCD screen
Case Thermaltake Soprano Black ATX case
Audio Device(s) Onboard 7.1, Speakers - 5 + Sub + Monitor speakers
Power Supply Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails
Software Win 7 Pro x64, MSN, CS:Source, etc etc
Hmmm....i think mine is so hot cus the CPU fan is the wrong way. I remember before i had the heatpipes facing the back of the case...now they are facing the RAM.
I also remember before when i had the heatpipes facing the back, my temps were 52*C idle (v.core on auto, which was 1.45)...so if i turn it back around, it should go to mid 40's
2,555 (0.39/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
Hey pinchy. Does your hsf have the fan facing sideways rather then blowing down on the cpu like a stock one? If so, yes. Blowing the heat toward the back of the case will help greaty if you have rear fans blowing outwards to blow that heat out of the case right away. My next hsf will have a fan perpendicular to the board and blowing towards the back of the case. I have 2 fans in the back. =) What cooler do you use? Nevermind. I see it. I don't know that rotating the heatpipes 180deg should make that much of a difference. Perhaps the thermal compound was disturbed more this time?
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
made a 2*C diff, but that was probably cus of the arctic cooler moving.
but, i turned it around because now i can put the ASUS NB cooler on (when the CPU HSF is the other way, it blocks it off) so now my mobo is 5*C or so cooler
My temps are like 5-8*C higher then revens, but im pretty sure thats because he is in an air conditioned room, whereas its pretty hot where i am, and his case has better cooling
2,555 (0.39/day)
Illinois
Software Windows 7
Any improvement at no cost is a good thing! Even 5c is good because that's 5c cooler air cooling your cpu.
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Error:
This processor does not support DTS readings. Thr program will not continue.
Spc
19 (0.00/day)
Core temp supports only Core 2 Duo processors.
Core 2 Duo processors are all the same (architectural) only that better models have:
1. More cache
2. Higher FSB
Because there's alot more cache higher models with 4MB of cache run hotter at the same frequency than the 2MB version does.
ex_reven
5,217 (0.77/day)
Error:
i got the same reading
come to think of it, lots of programs arnt recognising our cpu...
the only thing that picks it up as an e6400 is Everest Ultimate Edition
eg if i go into properties for "My computer" it says its a Pentium D 000 3Ghz
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
CPU-z, Everest say its an E6400 core 2 duo
Its only when i properties "My Computer" that i get "Pentium D CPU 000"
and i have a core 2 duo and cant run core temp...
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Screenshot:
Spc
19 (0.00/day)
That's very strange.
Maybe your motherboard doesn't "fully" support core 2 duo processors.
I've tryed core temp on 6 computers with different configurations and it was allways working.
So it may be a bios thing or not fully compatible board.
Do you have the latest bios ?
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Ive noticed ASUS have released a later version of the BIOS, havent tried it yet. We also get that CPU uCode error thing at the start (which we bypassed, but its still there)
BUT, the BIOS ive flashed it to does support core 2 duo...i thought the My Computer thing was normal :(
Spc
19 (0.00/day)
Yes my friend got the same damn thing uCode error and it was anoying him but because he is not very technical guy i flashed him bios and then it worked without uCode error so maybe you should try to update bios.
He has P5B (non deluxe version)
My current setup:
MSI 975X Platinum PowerUP edition
E6600 @ 3.33GHz
1 GB Ram DDR 800 @ 900MHz
320GB Disk Seagate
SB Live! Platinum
Radeon X1600 PRO
System recognized e6600 with the first bios it came with this motherboard and i haven't got any problems with it.
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Ill update bios now and post back here
P.S. To other core 2 duo users: What do you guys get when right clicking "My Computer" in properties for the CPU?
ex_reven
5,217 (0.77/day)
ive got the latest bios asfaik
and LOTS of people have/want our mobo...its not possible that it isnt supported fully
Spc
19 (0.00/day)
I perfectly agree with you.
But there's something that's causing this..
ex_reven
5,217 (0.77/day)
i thought it might be a side effect of the ucode error...but update of bios didnt fix it in our case
(many people had the error, some being able to fix it with a new bios, and others unable).
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
BIOS update: unsuccessful. My comp has crashed 3 times in a row as soon as windows loads up (with my regular BIOS options)...Just got it working now when reverted to complete setup defaults...
Stupid CPU :p
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Ok fixed BIOS crashing error...something to do with changing the sound :p
Anyways, i noticed even in BIOS it says the CPU is a Pentium D 000 blah blah...thats probably why the uCode error is there...
Spc
19 (0.00/day)
Yes seems like your motherboard doesn't recognize your CPU as it should.
But anyway if it works good then you're ok.
:rockout:
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
It works fine, but i got a strange feeling its messing with my temps and overclock...
