Core 2 Duo System Temps
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Processor E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz)
Motherboard ASUS P5Q-e
Cooling CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan
Memory G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15
Video Card(s) Sapphire HD4850 512mb with ASUS EAH4850 BIOS
Storage 2x 500GB Seagate 7200.12 Raid 0
Display(s) Acer AL1912, 19" LCD screen
Case Thermaltake Soprano Black ATX case
Audio Device(s) Onboard 7.1, Speakers - 5 + Sub + Monitor speakers
Power Supply Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails
Software Win 7 Pro x64, MSN, CS:Source, etc etc
i told u, its a strange feeling :p
But still, i reckon the temps are high. I thought the C2D would be cooler than a 3Ghz Prescott @ 4Ghz....obviously, i was way off :p
And, the high temps are holding the OC back. Currently, the comp doesnt even post after 410 FSB. Opened up case and put a desktop fan in front, posted at 470 FSB but crashed. Thats without tweaking (couldnt be bothered cus i knew the fan wouldnt stay there)
ex_reven
5,217 (0.77/day)
why are you trying to get to 470?
thats almost 3.7ghz
the multiplier is 8 remember :p
mines at approx 370fsb for 3ghz
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
thats almost 3.7ghz
Whats your point :p?
The higher the OC...the better...it actually posted at 470 FSB...its not like id run it at 470 24/7, but my point is, with the fan, it posted at over 60 FSB more...thats almost 500Mhz :p!
Spc
19 (0.00/day)
wow 470MHz FSB is really high.
If you want a good cooler i recommend you:
Scythe Infinity
This cooler is even better than zalman's water coller solution.
I have it in my system and it's really quiet and cools awesome.
2,555 (0.39/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
Scythe Infinity
Post pics please. :D
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
My cooler is meant to be a great cooler too. It was crazy with my Prescott....it kept my 4Ghz prescott at 35*C idle...not bad for $20AUD (RRP is $85...bargain on ebay :D)
Spc
19 (0.00/day)
Here you go:
:rockout:
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
i like how it blows the hot air straight to the back fan...altho i reckon the looks of it can be improved on :p
Wile E
Power User
24,318 (3.62/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Yeah ive seen that....It prolly wont fit in my case :p
Wile E
Power User
24,318 (3.62/day)
So. Cut the case to fit the cooler. It would be awesome to see those two fans sticking out the side. lol
2,555 (0.39/day)
Illinois
Software Windows 7
What about this when it releases.
http://forums.techpowerup.com/showthread.php?t=24898
You could be our guinea pig. lol
HAHA no thats TOO big. I think I'll order the Infinity tomorrow. I think I could hit 400 fsb with just a little more v+ to the core. I'm at 390 now but I need to get to 1.5v for 400 stable.
How much room is there between the bottom of the Infinity's fan and the top of the memory? I have a 120mm in the plexiglass side cover too but I think that will clear it. I could always put this crazy fast 90mm fan on it if I had too I guess.
Wile E
Power User
24,318 (3.62/day)
If you do have ram clearance issues, couldn't you just move your ram to the other slots?
EDIT: Just looked on their site. They have a picture of it mounted in a CM Stacker 830. I may get this when it releases to replace my aquagate mini.
ex_reven
5,217 (0.77/day)
YES! im so glad for my stacker :D
and to spc - is that a Sound Blaster Live bay on the front of your comp :p?
ex_reven
5,217 (0.77/day)
looks like its about 10 years old lol
i remember using soundblaster 16 when i was a kid, shitty midi music in games lol
Spc
19 (0.00/day)
Well yes.
it is 10 years old.
But i have 13 pc's in my home so i also have X-Fi Elite PRO.
But we're heavy offtopic now so let's stick to the topic.
ex_reven
5,217 (0.77/day)
Well yes.
it is 10 years old.
ok
im surprised intel hasnt released anything about the error...
theres some data on their site about it, but it basically says to use the latest bios
ex_reven
5,217 (0.77/day)
From the intel website:
Known issues
Issue: System does not boot, error codes may or may not appear
If the Intel® Core™2 Duo is installed before first upgrading the BIOS, the following error codes may appear (system dependant):
* Intel CPU uCode loading error
* Unknown BIOS error. Error Code = FFFF
Workaround: Install the original Intel® Core™ Duo processor (Yonah) and follow the steps above to upgrade the BIOS and then install the Core™2 Duo processor.
Because i really just have another older Core Duo processor lieing around lol...
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
wtf are intel smoking :p
