Corsair Readies Hydro H70 CPU Water Cooler
1,180 (0.19/day)
Australia
Processor Intel i7 4790K
Motherboard Asus Z97 Deluxe
Video Card(s) Asus R290X
Display(s) Samsung S23A950D
Case Corsair 850D
Power Supply Corsair AX850
Keyboard Logitech G710+
H-50/H-70 has its uses. Coolers that do better than these water coolers tend to not be very nice for your motherboard and also keep in mind that heatpipes suffer from degradation. Afaik the degradation is actually pretty severe. Not a problem if you update like every 2 months or something...
How are big air coolers not nice for your motherboard? I havent noticed any issues.
My TRUE is on its 3rd system, i've had it for a couple of years and i havent noticed any performance degradation at all so far.
CDdude55
Crazy 4 TPU!!!
8,178 (1.27/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
3,305 (0.53/day)
System Name Thakk
Processor 9800X3D
Motherboard MSI B650M Gaming Wifi
Cooling Id Cooling A410 + 2400 RPM push pull
Memory 32GB DDR5 6000 C30
Video Card(s) Zotac RTX3080 Trinity
Storage Crucial NVME 512 / Intel 250GB SSD / Samsung Pro 512 SSD / SanDIsk 1TB SSD / WD Black 6TB
Display(s) Acer Predator X34 100hz IPS Gsync
Case Generic mATX
Audio Device(s) Hyper X 7.1 USB Soundcard
Power Supply Corsair CV750 Bronze
Mouse Logitech G200
Keyboard Monsgeek MG75S Hall Effect + XDA Keycaps + Holee Mod
VR HMD HTC Vive
Software Windows
Benchmark Scores https://www.3dmark.com/3dm/123890762?
Rad looks fatter. Like twice of the previous' slim one. This would definitely increase its thermal capacity.
Check out its FPI, would definitely take advantage of high pressure fans. I wouldnt slap a 'silent' fan in those to get the most out of it.
1,132 (0.18/day)
System Name Grandpa
Processor i5 4690K
Motherboard Gigabyte Z97X-UD5H-BK
Cooling water
Memory 8GB Corsair Vengence 2400MHz
Video Card(s) Gigabyte 5850 x2
Storage Samsung SM951
Display(s) Catleap 27"
Case coolermaster stacker
Power Supply corsair AX860i
Mouse logitech g5 original
Keyboard Ducky
Software Windows 8.1
On many mobo's, the NB and voltage regulators need a constant flow of air over it to stay cool enough. This air comes from the CPU cooler. A big air cooler like the TRUE doesn't need as much air flowing through it and doesn't direct the air towards the NB. As it is likely that use of an aftermarket cooler also comes with overclocking, the end result is a mobo that fries in its own juices.
I agree about the heatpipes, I also have a TRUE years old and it still works the same.
cdawall
where the hell are my stars
27,683 (4.08/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
Fuunny thing about heatpipes they are in oems like dell and hp now if they suffered heavily from degredation this would lead to failures in oem machines which is uncommon. Also I would email amd and tell them bad news seeing how they have been pumping out heatpipe coolers for opterons since s940 and 939 7+ yrs ago. Trust me if anyone will kill a cooler its the server market and amd would never risk that. Hell they won't risk an overclockable server board because they believe it will damage the image of their quality.
From personal experience I have a amd heatpipe cooler on a s939 I built 3 years ago and its still chugging along@2.5ghz. As well as the largest heatpipe cooler I have seen in a bit the coolermaster v10 has never let me down and gave better temps than the h50 in push/pull could. In fact I could keep up with much larger homebuilt loops in clocks and temps on my x6 with a $10 mod.
582 (0.10/day)
System Name Flow
Processor AMD Phenom II 955 BE
Motherboard MSI 790fx GD70
Cooling Water
Memory 8gb Crucial Ballistix Tracer Blue ddr3 1600 c8
Video Card(s) 2 x XFX 6850 - Yet to go under water.
Storage Corsair s128
Display(s) HP 24" 1920x1200
Case Custom Lian-Li V2110b
Audio Device(s) Auzentech X-Fi Forte 7.1
Power Supply Corsair 850HX
yeah, heatpipes don't degrade thats some grade A rumormill
43,620 (6.42/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Some can bend/warp the PCB. If you use a backplate or if the cooler's mounting design is sufficient there should be no problem.
cadaveca
My name is Dave
17,232 (2.50/day)
Well, AMD's stock cooler in my house:
955BE, stock volts, stock speed, 66c. AMD Thermal Spec, 62c. 18c ambient.
965BE, stock volts, stock speed, 65c. AMD Thermal Spec, 62c. 20c ambient.
While the coolers may not die, they are completely inadequate. NO big deal, there's lots of options out there.
But, with socket placement, and cooler clearance, the H50 stood out, as it occupies very little space around the socket.
The H70 might provide that extra bit of capacity that might let me clock my cpu 24/7, year-round. I'm confident enough that it will, that I've ordered one.
I should be able to post results soon.
cdawall
27,683 (4.08/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
965 125w c2 on the stock amd hsf gets 55c with higher ambiants and a cheasy 10yr old case so either something is incorrect in your setup or the temp monitor is wrong.
cadaveca
My name is Dave
17,232 (2.50/day)
Nah, just my environment. Everything is hotter than what anyone else has, generally, by 15c, and because of that, stock cooling has never been an option for me. Even Intel Core/i7 chips come close to throttle, and this has been an issue I have been dealing with for many years now.
To the point, it was so bad back in 9800pro/sktA 2500+ non-mobiles, overheating and crash in 3D is the norm. Then we got a shuttle, and that I.C.E. cooler did a real good job, making gaming OK(one of the first heatpipecoolers I remember). Then got a second box...ugh...forget running both.
The current rig I've got now is the closest I've been to without water is a long time, not counting a TRUE that needed a 98CFM fan on it to stay cool enough overclocked.
There's a reason Dell, HP, and Even Apple tend to watercool thier high-end rigs...situations like mine.
Seriously...4 people is enough to overheat a room in summer in less than 30 minutes. In the dead of winter, minus 30 temps, having people over and I gotta open a window. All 6 of my family members cannot stay in the same room and be comfortable.
Keep that in mind. Temps range from -35c to +35c here(sometimes more). the cold temps means my house has far more insulation, and houses are built to retain heat, not give them off.
I live in a far different climate, so like everything else, nothing is comparable.
