Different low reading
20 (0.01/day)
Hello,
Lately my pc start to crash when playing AC or ACC, after the reboot sometimes it crash the whole pc again or it continued normal, i check the "Event Viewer" and i got this message "The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly." "EVENT 41" i did some research and i noticed that the 3.3v 5v and 12v (fromHWiNFO) reading is really off, i checked the wall plug voltage i got 217V(living in morocco), surprised by another reading from AIDA64, i donnu if it PSU problem or MB issue, i hope someoneto help me
PC Spec :
R5 3600
RTX 2060
BIOSTAR A520HM Ver6.1
AEROCOOL LUX 550W 80 PLUS BRONZE
16GB DDR4 Samsung
264 (2.78/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
Power supply. Can check it with a multimeter to be sure, but I bet it's toast. I'd quit using it before it fries something.
746 (0.12/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
Replace the power supply with something better. A cheap bronze power supply is usually a waste of your money, and this particular one has a F/Replace Immediately rating on the cultist PSU tier list.
I would replace the power supply first no matter what, and then troubleshoot if the problem continues.
20 (0.01/day)
Thanks "DirtyDingusMcgee" and "ty_ger" for the answers, that was my worries, i thought the power on my house is not stable but i believe it's the psu, i will change it asap and i'll post here the results
20 (0.01/day)
Update :
i bought today "MAG A650BN" psu , it is a tier c psu , after launching the pc i got the same reading on both apps (different values), what i should do ?
1,635 (1.07/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
Do you mean that after replacing the PSU with a brand new one you are still getting the same voltage readings as in the first message?
232 (2.04/day)
Mitten State, USA
System Name Sim Racing PC/Dell XPS 15 7590
Processor AMD Ryzen 7 5800x/Intel Core i7-9750h
Motherboard ASUS TUF B450-Plus II/Dell Laptop MB
Cooling Arctic Freezer A35 CO/laptop cooling
Memory 2*8 GB G.Skill Ripjaws V DDR4-3200/2*8 GB Crucial DDR4-2666 SO-DIMM
Video Card(s) XFX SWFT309 RX 6700 XT/Laptop GTX 1650
Storage 1 TB Crucial 3400 PCIe Gen 4 SSD/Ediloca EN605 512 GB PCIe Gen 3 SSD
Display(s) 77" LG OLED TV (4K@120Hz)/15" Dell integrated panel (1080p@60Hz) and 30" Dell U3011 (1600p@60 Hz)
Case Cougar MX330-G Air / XPS 15 7590 chassis
Audio Device(s) Beyerdynamic DT 770 Pro via Yamaha HT receiver/Integrated speakers or Creative Pebble Plus
Power Supply EVGA 600 BA / Dell 130W laptop brick
Mouse Logitech K400+ / Cherry MW 4500
Keyboard Logitech K400+ / Drop ENTR or E-YOOSO Z-686 or integrated keyboard
VR HMD Meta Quest 2
Software Windows 11 Home/Windows 11 Pro (meaning to try Linux)
Update :
Could be bad motherboard power regulators and/or caps. I remember a vid on YouTube of an old PC that was reporting improper voltages in the BIOS, but replacing the capacitors on the board fixed it. I'd check the BIOS to see what it reported the voltages as (press DEL when you start your PC from shutdown).
20 (0.01/day)
i checked last time the bios and couldn't found anything related to the 3.3v 5v 12v , only reporting the CPU's voltage, the thing is, HWiNFO report different values to AIDA64
1,635 (1.07/day)
The readings for CPU Vcore are also off. You should be seeing much lower voltage in idle, yet it is nearly the same as when stressed.
The max temp of the CPU seems too high (I assume 89 C is the socket temperature). What's your CPU cooler and CPU temp under stress? Perhaps motherboard thermal protection is kicking in.
From your mobo manual:
20 (0.01/day)
For CPU Vcore value I think in the bios it sets to 1.35v iirc, my cpu temps i never saw it goes above 90c, i did some stress tests last couple weeks for like 15-20min and the system never shut down and temps were in the 80s temperature zone, i will do some testing when i go back home, thanks.
Edit : cpu cooler is the stock amd cooler
de.das.dude
Pro Indian Modder
9,044 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
80c is still quite a lot. Motherboard reporting isnt always 100% accurate. So a hotspot could easily be going over the threshold.
Did you remove the plastic sticker from under the heatsink before installing it?
20 (0.01/day)
I bought the pc as a pre-build in May last year from a friend, i comfort to say that the sticker is removed but i'll check it this evening
1,635 (1.07/day)
While at it, it would be a good idea to remove any dust and debris from the heatsink and fan, and replace the stock thermal paste with a fresh application. Also, make sure the cooler is seated evenly and latched properly onto the socket.
The Ryzen 5 3600 is an easy processor to cool and it shouldn't be near 90 C even with the stock cooler. Judging by your SATA SSD temp, your room must be at about 25 C, which isn't a high ambient.
In the BIOS, check whether CPU Vcore is set to default/auto rather than a fixed value. Run a proper CPU stress test afterwards and please report back with CPU voltages and temps.
365 (0.82/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000CL30, 64GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
Looking at the deviations between HWiNFO64 and AIDA64, I'd say it looks like your BIOSTAR motherboard doesn't have good sensor support in those software suites. AIDA64 was in the ballpark on two of them, but that makes the 14+V even more concerning lol.
Can you show a fresh screenshot of those two with the new power supply? I'm just curious if some are different, all, or none.
Also, per the previous suggestion about checking in your BIOS, this is a really good idea. The manual for that motherboard shows on page 15 if you go to the "Advanced" tab and go to "Hardware Monitor", it should show +12V and +5V rails:
20 (0.01/day)
i did some "really basic" cleaning, and did a stress test for 11mins, and this is the result, and yeah temps are really high, i never changed the thermal paste, so i think i know my next mission :d, thanks for the pointing out the temps
seems okay voltage's wise (MSI psu)
365 (0.82/day)
USA
so yeah, I wouldn't trust any software reading of your voltages anymore. Depending on your GPU, it may give a +12V sensor reading that's more reliable, but your motherboard is not reading correctly in these software.
I would also say that 49C seems a bit high for just idling in BIOS.
264 (2.78/day)
Texas, USA
+1 for temps being a bit high. r5-3600 run cool as a cucumber.
1,635 (1.07/day)
Right, now we're getting somewhere. As mentioned before, please set the CPU core voltage to auto:
232 (2.04/day)
Mitten State, USA
VR HMD Meta Quest 2
alright i'll do, just one thing, i did a race in "ACC" and i didnt have any lag spikes or weird lagging sound as i used to have with lux psu, everything went smooth
I suppose that's a lesson not to buy a PSU worse than c tier on the list unless you don't have an option. I once tried upgrading a GPU from an RX 480 to a 1080 Ti that was given to me when I had a terrible ULTRA LSP "750 W" PSU. It would cause the PC to shutdown with the 1080 Ti. Replaced it with an EVGA 600 BA about two years ago that I snagged for $40 US on sale on EVGA's website and it's handled my 5800X + 6700 XT sim racing PC just fine since.
20 (0.01/day)
well i didnt know the psu tier list when i bought the pc last year, as for pc part prizes here in morocco arent the best in term of quality/price ratio
here's the result of the "auto" voltage :
1,635 (1.07/day)
So it's a bit better now. I'd also set the power plan to "balanced" and move the power slider to "best energy savings" to lower the idle temps.
After re-applying the thermal paste and thorough cleaning of the case, you could try to improve the airflow for better thermals. However, since it's a pre-built, I wouldn't expect miracles here.
For now, you can just use your PC as you normally do and see whether the crashes come back.
20 (0.01/day)
Thanks for the tips man, really appreciate.
The "Pre-build" isn't as those pc from companies if i could say. It's just a normal respectable build. It got 3 intakes and 1 exhaust fans, my plan is total cleaning and maybe changing the cpu cooler.
So far no crashes from a +1h gaming session ACC
