Does antifreeze work well for watercooling loops!?
43,620 (6.42/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
I don't see the point. The loop won't be freezing and I doubt the loop gets hot enough that it's needed either. It'll add a small bit of viscosity, so the pump will run a little harder. Well, don't want that either. Someone mentioned lubrication. No. Unless you think lubricating a plastic impeller is somehow important.
Outback Bronze
Super Moderator
2,142 (0.43/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
I have seen older guys say they have been using the car stuff almost exclusively.
I didn't think I was that old : )
Some people here saying that it doesn't cool as well as straight distilled probably don't have first hand experience. It still cools very well.
I'm guessing the 1-2°C difference in temps that maybe the difference between the two has negligible effect over all the other benefits of using car coolant.
freeagent
9,844 (4.19/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
To me it would make sense to use the car stuff.. I am sure it would still cool better than an air cooled heatsink would :)
2,516 (1.18/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
-reminds me...
I wonder if those 'water wetting' additives that claim to aid in engine cooling would have any appreciable effects in PC water cooling?
2,100 (0.47/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
-reminds me...
None. Straight distilled is the only way to go for best ambient cooling.
1,025 (0.29/day)
Nova Scotia, Canada
Cooling Cooler Master Hyper 212 Plus
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
I use 50/50 Ethyl AF in my water chiller for the freeze resistance and corrosion protection, the copper and aluminum A/C evaporator sits in the reservoir and so far no noticeable corrosion has formed after years. So it'd probably work pretty well for a mixed metal loop.
In my main system I run RO water with a couple splashes of Dazmode protector which is mostly just ethylene glycol. Does it help? No idea, but I have some so I use it.
1,812 (0.33/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
Fly at it.
You just go right ahead and jump into a pool of it. When you get out, if on your own, slam an 8oz glass of it, and see just how well you feel. Chances are, if you wake up, it will be in ICU.
I hope you don't eat any processed food since propylene glycol is in just about everything especially food coloring.
2,373 (0.56/day)
Audio Device(s) A LOT
The advantages of using antifreeze in mixed metal loops is obvious, but otherwise I’ve yet to see any actual evidence that it’s beneficial in anyway.
Sure, back when I used my dad’s Citation’s radiator and an aquarium pump with random aluminum blocks it was necessary, as it is with CLCs that use mixed metals now, but now that we have DDC/D5 pumps and copper everything, all designed for use in water, I’m not sure what the benefit is other than piece of mind when some manufacturer skimps on the plating or whatever.
(Do whatever you like of course, just saying)
2,516 (1.18/day)
Olympia, WA
Propylene Glycol is animal safe
Not for felines, IIRC.
While it is overblown (pun intended) the issue came up in the vaping community.
5,340 (3.72/day)
Colorado, U.S.A.
Software Windows 11 Home
There may be some temperature drop at the liquid solid interface and wetting could help with this.
2,516 (1.18/day)
Olympia, WA
That was where I was coming from.
But, Mr.Scott's been around the community long enough to know by experience and experimentation.
Also, water is pretty amazing stuff, thermally.
It's literally why past-present-future power generation all revolves around:
So... Boiling water, faster?
5,340 (3.72/day)
Colorado, U.S.A.
Absolutely, water has a very high specific heat, but I would suppose that very little wetting agent was needed.
2,100 (0.47/day)
Spencerport NY
System Name Master
Been there, done that. No appreciable improvement what so ever.
FWIW, Redline Water Wetter is what I tried.
There is no reason to run antifreeze in your loop unless you plan on going sub ambient.
801 (0.11/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
I'll add that if you are going sub ambient with some type of chiller, low temp windshield washer fluid is a better option than radiator coolant.
2,516 (1.18/day)
Olympia, WA
IIRC, the 'active ingredient' in that stuff is methanol.
I've never tried to ignite the stuff, but I believe there is a flammability warning.
Not trying to scare anyone, but there was a reason automobiles moved from water/alcohol anti-freeze-coolant to Ethylene glycol.
In the proposed use however: Cold alcohols, fume less; there shouldn't be any active ignition sources inside a PC/test bench, either.
I suppose the only real concern would be ensuring your tubing and fittings are chemically compatible with methanol. (Oh, and methanol erodes aluminum, last I checked. No Alu rads/blocks.)
vondur
1 (0.00/day)
As noted earlier, AntiFreeze makes use of the chemical property called Freezing Point Depression/Boiling point elevation. This is a good thing in automobiles, as it helps stop the water in a cars freezing and expanding in freezing weather, which would be a bad thing. It's also handy in the summer, allowing the boiling point of the solution to be higher than pure water alone. Not sure if it would make much of a difference in water cooling as the solution would have less overall heat capacity than water alone.
821 (1.28/day)
System Name Naboo (2019)
Processor AMD 3800x
Motherboard Gigabyte Aorus Master V1 (X470)
Cooling individual EKWB/Heatkiller loop
Memory 4*8 GB 3600 Corsair Vengeance
Video Card(s) Sapphire Pulse 5700XT
Storage SSD 1TB PCIe 4.0x4, 2 TB PCIe 3.0
Display(s) 2*WQHD
Case Lian Li O11 Rog
Audio Device(s) Hifiman, Topping DAC/KHV
Power Supply Seasonic 850W Gold
Mouse Logitech MX2, Logitech MX Ergo Trackball
Keyboard Cherry Stream Wireless, Logitech MX Keys
Software Linux Mint "Vera" Cinnamon
If one builds a pool he also needs money to fill it. The people pay a hell of money for their rig. But when it comes to coolant they tray to save a few cents.
Outback Bronze
Super Moderator
2,142 (0.43/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Asus
Keyboard Corsair
Software Win 11
12,124 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Keyboard Razer
Software A lot.
So,
The people here that are using car coolant what was your main reason for doing so? Would like to hear your thoughts.
I remember years ago when I first starting using it, I got into quite a few arguments about whether it's any good or not. Basically, a lot of people writing me off.
Well, here I am almost two decades later, and I see some people are starting to see the light.
I remember pulling my first loop apart (Asetek custom loop for socket 478) after using distiller water and the rust was very nasty. Even saw the water going all brown. Prob the reason why I disassembled it.
Pretty sure I tried distilled again (thinking I did something wrong) and the rust started happened again. Mixed metals maybe?
This was when I thought of Car Coolant. I had nothing to lose. Well, here we are.
I was involved in engineering updates for cooling systems on large machines, part of my education was on cooling, electrolysis and cavitation damage.
I have used/been using a 25% glycol antifreeze with 75% distilled water in my system for 10 years in the same pump, the additive package contains moly as a pump lubricant and it’s no longer good when it changes from blue to green or any other color. I add about 10ml of water every year is all.
-reminds me...
I tried water wetter specifically, it didn’t make any appreciable difference.
It’s typically added to pure water systems on track cars as glycol acts a surfactant and lubricant.
The tiny difference on heat carrying capacity is negligible with such a low concentration.
Also I have had my PC outside when it was -20F and colder to push the overclocking and see where temps would end up. With water it would have frozen.
Outback Bronze
Super Moderator
2,142 (0.43/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Asus
Keyboard Corsair
Software Win 11
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
➡️I want to absolutely point this out!!⬅️
Because no one mentioned it besides you!
Antifreeze has great lubricative properties which will improove the life of any moving parts it comes into contact with! If used in right proportions of course!
Thanks for the reply!!
On your car or your PC?
Lol all this Glycol marketing got me confused .
It was in the source link from the reddit quotes i made, they covered it there (can't recall if its in the quotes itself)
That's the second reason you need to dilute these coolants - thicker ones transfer less heat, and they make pumps work harder.
A hotter, harder working pump is not a happy pump.
It's about which chemical is used, as one of them is also what's used as the biocide in regular PC coolants
The other one is not, and is a bad choice
Mussels
58,412 (7.85/day)
Oystralia
Keep in mind my EK hardware corroded and grew all sorts of fun on plain distilled - whether or not distilled works depends entirely on what metals they used in your hardware
This is not advice anyone should give out blindly just because it worked for them with their specific hardware, without a biocide
599 (0.29/day)
Hungary
System Name Detox sleeper
Processor Intel i9-7980XE@4,5Ghz
Motherboard Asrock x299 Taichi XE (custom bios with ecc reg support, old microcode)
Cooling Custom water: Alphacool XT45 1080 + 9xArctic P12, EK-D5 pump combo, EK Velocity D-RGB block
Memory 8x16Gb Hynix DJR ECC REG 3200@4000
Video Card(s) Sapphire RX7900XT - NITRO+ Vapor-X 20GB
Storage Samsung PM9A1 1Tb + 2x PM981 512Gb + Kingston HyperX 480Gb + Samsung Evo 860 500Gb
Display(s) HP ZR30W (30" 2560x1600 10 bit)
Case Chieftec 1E0-500A-CT04 + AMD Sempron sticker
Mouse Logitech G400
Keyboard IBM Model M122 (boltmod, micro pro usbc)
Software Windows 11 Pro x64
Can i add home made Palinka (hungarian made strong alcoholic drink ~50%) to the distilled water in the loop?
freeagent
9,844 (4.19/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I am dumb, this is why I stayed with air coolers :D
