- Dec 8, 2020
- 3,069 (1.99/day)
- United Kingdom
Just found one of these, talk about specs: Fibre Optic HDMI 18G Extender - Transmission of 4K content over 300m (lindy.com)
System Name | FireBreather |
Processor | AMD Ryzen 9 7950x |
Motherboard | CrossHair Extreme x670E |
Cooling | Asus RoG Strix LC2 360 AIO |
Memory | G.Skill Trident Z5 RGB Series 64GB (2 x 32GB) 288-Pin SDRAM DDR5 6000 CL30-40-40-96 1.40 |
Video Card(s) | 7900 XTX Taichi |
Storage | 3x- PCI-E 4.0 Nvme 2TB 7GB/s - 2TB N7 USB-3.1 Nvme 1GB/s |
Display(s) | ASUS - VG259QM 2k 280hz HDR - LG-C1 4K 120hz OLED with Dobly vison |
Case | ROG Helios |
Audio Device(s) | SupremeFX ALC4082 codec, and an integrated ESS® ES9218 quad DAC |
Power Supply | HX1500i - 1500Watt |
Mouse | Corsair Dark Core |
Keyboard | Corsair K95 Platinum |
Software | Windows 11 pro |
Benchmark Scores | Time spy - 29000 Port Royal - 17500 Cinabench R23 - ST = 2150 MT = 40000 |
question about interactive x for this to work will it say interactive X in windows settings or just interactiveJust found one of these, talk about specs: Fibre Optic HDMI 18G Extender - Transmission of 4K content over 300m (lindy.com)
Case | ROG Helios |
Case | ROG Helios |
Case | ROG Helios |
I am waiting for more support to fully unlock lossless digital down SPDIF. My 889 can apparently do 8 channel PCM down SPDIF, I still don't know what my Toslink module is at this time.
The cable is a certified 125mpbs, I'm told it can do slightly more. The two main specifications (in short) for Toslink is rev A and rev B, 3.1mbps and 125mpbs.
Regardless, the driver will allow you to do lossless PCM, 192khz, 8 channels, 32 bit | For Interactive, lossless PCM, 192khz, 6 channels, 32 bit.
At this time to push PCM down SPDIF, you need WASAPI exclusive, else analogue is natively encoded to DTS Surround.
DTS Surround - 48khz, 6 channels, 24 bit, bitrate: 1510kbps (compressed).
Droptek - Inject | Droptek - Fragments | Rogue - Nemesis
Case | ROG Helios |
Case | ROG Helios |
Case | ROG Helios |
hmm so it seems to be reading that hdmi almost like anologe can you use windows settings for speaker set up with hdmi also its kinda rare you see LPCM 5.1 over optical means you should be able to decode and passthrough just about any formate wonder what the restrictions are on the quality for that PCMMost later HDMI's, if 1.4+, should do 8 channels out, but depends on GPU or HDMI audio device, I suggest HDMI 2.0.
For my Z906, I use the .reg files in 'DTS Settings' (Personal), and use Interactive, as it fully supports it.
The unit stays in bitstream mode, always digital (like SPDIF).
I made my own driver for the 'internal monitor' the unit comes with (no real monitor).
Case | ROG Helios |
Case | ROG Helios |
Case | ROG Helios |
Case | ROG Helios |
Case | ROG Helios |
