Update
The thermalright cooler had so much coilwhine i had to,wanted to return it
The front fan is having a problem with my memory 42mm, not as i remember with my fuma 2 and my dark rock pro 4
I returned to my hyper 212 evo v2 with silent wing 2. Temps just gets high. at low load, medium fan speed when i did 21% or so i had temps rise to 75c, i thought what the f.. need a new fan for my fuma 2 and no one had it stock, 30+ euros is not unsually with shipping, i did what i didn't wanted, pain the but.
Removed the cooler and my mb and started to mount my dark rock pro 4, i thought i missed one bracket for amd (spend time looking for it) but i had the bracket, then i couldn't find the screws for the tower to connect it to the brackets on the mb,finally i managed to put it together.
The my m.2 slot (the one used by my cpu) died, lower m.2 slot did work
prime 95 small fft 76c (only 4475mhz) just under 700 rpm Blend 4825mhz 71c just over 600 rpm
Aida64 stress cpu,fpu,cache,gpu not very stable in speed 4500-4700mhz sometimes it goes under 4000mhz, 1000 rpm on the dark rock pro 4 noticeable but not loud, peaking at 81c (best test to do when wanting the heat from the gpu to effect the cooler like when you gaming)
