Easy to mount cooler for a ryzen 5800x
tabascosauz
8,264 (2.31/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
do you know if the noctua buckle for am4 is compatible with the thermalright peerless assassin 120 se? mine broke somehow and there is no spare parts for thermalright.
The Noctua brackets are not unified either. Most of the Noctua coolers are not interchangeable and must use their included brackets because spacing is unique. You can try the AM4 Noctua mounting kit that they sell, but I wouldn't get my hopes up.
freeagent
10,259 (4.28/day)
Winnipeg, Canada
System Name Step_sis Rodeo
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
This is the part I had to replace once I got the new mounts:
poseidonss
4 (0.01/day)
I did the same with one of my FC140s. Put a little too much twist in it. You have to be very clear on what you need, I was able to get the part you stripped, but had to raid to top clamp from my Ultra120 Extreme. SO now I am very careful :D
I had a budget cooler that survived 4 generations of ryzen but this one... I will be more careful if I find a way to fix it. Thanks.
I see, Thermalright store in Aliexpress told me they will look for the parts. I hope they can help me.
2,019 (0.43/day)
Denmark
Processor i5 13600kf
Motherboard Asrock z690 pg riptide
Cooling arctic freezer III 280 non argb
Memory 32 gb g skille ripjaws v 3600mhz cl 16 (4000mhz cl 18)
Video Card(s) ASUS Dual GeForce RTX 4070 EVO
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case Corsair 5000D airflow tg
Audio Device(s) Yamaha R-N800A System audio signature 5
Power Supply Corsair RM850X White
Mouse Asus Rog Gladius III Wireless Aimpoint
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit, Free Avira Security
get someone to 3d print it ?
