- Jan 8, 2024
- 259 (0.65/day)
About time, now we need widespread GPU support. Nvidia gave us the Stockholm Syndrome 12VHPWR Connector (tm) instead of a DisplayPort upgrade.
Keyboard | Corsair K70 Max |
Software | Windows 10 Pro |
What are you talking about? Official RDNA3 presentation clearly states that Radiance Display Engine is capable of 54 Gbps on DP 2.1 portsAMD with their RX7000 series and "DP 2.1" support which then turned out to be UHBR13.5
thanks a lot for the update.I can confirm it'll be glossy after checking with a source at the company.
Will get info next week with regards to the daisy-chain port and the USB-C input.
Thanks for this. Much appreciated.I can confirm it'll be glossy after checking with a source at the company.
Have Samsung and Nvidia been able to fix 120Hz limitation on RTX cards?The 57 inch I got has 2.1 but my 4090 doesn't
If the price I just got is correct, it'll be competitively priced, but obviously not be a bargain. I'll update the post once I have a proper confirmation next week.thanks a lot for the update.
Unless it cost 2000 EUR or releases in more than a year, I will therefore be going with this one, speakers, DP2.1 80gbps, glossy, flat...
I doubt I can get that.Thanks for this. Much appreciated.
Will we be able to get a photo and block diagram of new display IC?
System Name | Fractal |
Processor | Intel Core i5 13600K |
Motherboard | Asus ProArt Z790 Creator WiFi |
Cooling | Arctic Cooling Liquid Freezer II 360 |
Memory | 16GBx2 G.SKILL Ripjaws S5 DDR5 6000 CL30-40-40-96 (F5-6000J3040F16GX2-RS5K) |
Video Card(s) | PNY RTX A2000 6GB |
Storage | SK Hynix Platinum P41 2TB |
Display(s) | LG 34GK950F-B (34"/IPS/1440p/21:9/144Hz/FreeSync) |
Case | Fractal Design R6 Gunmetal Blackout w/ USB-C |
Audio Device(s) | Steelseries Arctis 7 Wireless/Klipsch Pro-Media 2.1BT |
Power Supply | Seasonic Prime 850w 80+ Titanium |
Mouse | Logitech G700S |
Keyboard | Corsair K68 |
Software | Windows 11 Pro |
It's fine. Someone will soon open the monitor to take a photo. I am simply curious to see whether this is first fully capable IC on all ports, and without hidden surprises.I doubt I can get that.
You are somewhat right, 4k 240hz needs 60g, 4k 360hz needs 90g, 4k 480hz needs 120g, 8k 120hz needs 120g. Maximum a dp 1.2 can do regarding 4k is 300hz 75g. That will be the limitation till something better comes out.The thing about DP 2.1 is that UHBR support is... optional. So unless GPU or monitor manufacturer clearly specifies which DP 2.1 features are supported you're kinda going in blind (case in point AMD with their RX7000 series and "DP 2.1" support which then turned out to be UHBR13.5).
Either way, even with full 80 Gbps support you won't avoid DSC once you go over 4K 240 Hz.When is DisplayPort 2.1 Going to be Used on Monitors? - TFTCentral
Where are all the DisplayPort 2.1 monitors? What is holding up their development and launch, and what confusion exists in the market?tftcentral.co.uk
On topic:
There is also a cut down version of the same panel with DP 1.4 support:
AORUS FO32U2 Key Features | Monitor - GIGABYTE Global
31.5" QD-OLED Display @ UHD Resolution (3840 x 2160) 15M:1 Contrast Ratio & Perfect Viewing Angle 240Hz Refresh Rate & 0.03 ms Response Time (GTG) GIGABYTE...www.gigabyte.com
DSC is garbage. There is no need for DSC at all, people need to fight against the BS, manufactures created DSC to cut costs and that is the truth, DSC is not lossless, they are lying.Yep this is what i've been waiting for. A true 4k 240Hz monitor. None of that DSC.
Interesting. Which monitor is that?My LG 4k 144hz monitor allows DSC to be toggled on and off. Is there a test that can reliably reproduce DSC artifacts or does it depend on the brand and model?
No need to be vulgar about the topic.DSC is garbage. There is no need for DSC at all, people need to fight against the BS, manufactures created DSC to cut costs and that is the truth, DSC is not lossless, they are lying.
A rather difficult task, because the PC side (GPU) sees the image uncompressed, and the compression takes place (real time) between the graphics card and the screen.My LG 4k 144hz monitor allows DSC to be toggled on and off. Is there a test that can reliably reproduce DSC artifacts or does it depend on the brand and model?
System Name | HELLSTAR |
Processor | AMD RYZEN 9 5950X |
Motherboard | ASUS Strix X570-E |
Cooling | 2x 360 + 280 rads. 3x Gentle Typhoons, 3x Phanteks T30, 2x TT T140 . EK-Quantum Momentum Monoblock. |
Memory | 4x8GB G.SKILL Trident Z RGB F4-4133C19D-16GTZR 14-16-12-30-44 |
Video Card(s) | Sapphire Pulse RX 7900XTX. Water block. Crossflashed. |
Storage | Optane 900P[Fedora] + WD BLACK SN850X 4TB + 750 EVO 500GB + 1TB 980PRO+SN560 1TB(W11) |
Display(s) | Philips PHL BDM3270 + Acer XV242Y |
Case | Lian Li O11 Dynamic EVO |
Audio Device(s) | SMSL RAW-MDA1 DAC |
Power Supply | Fractal Design Newton R3 1000W |
Mouse | Razer Basilisk |
Keyboard | Razer BlackWidow V3 - Yellow Switch |
Software | FEDORA 41 |
In practice, there should be a very accurate video camera that would record the screen (with the used screen refresh rate), compressed and uncompressed, and then compare these two videos with each other.
This works fine if you are using max 4K@60/120Hz - which do not require or use DSC compression.Why? Take a DP to HDMI adapter with DSC and feed the HDMI to a decent capture card.
DSC is great considering that, at this point, increasing resolution is pointless: the perceived resolution depends on the viewing angle which should be always the same no matter what display you buy (if you increase the diagonal the viewing distance has to increase too). Refresh rate wise, we reached a point where the image persistence (4ms on a 240hz, 3ms on a 360hz display) of a S&H monitor is equivalent to the old "impulse technology" of CRT/plasmas: anything above is placebo.DSC is garbage. There is no need for DSC at all, people need to fight against the BS, manufactures created DSC to cut costs and that is the truth, DSC is not lossless, they are lying.
LG 27GN95R-B. It let's me pick between DP1.4 with DSC, DP1.4 without DSC, and DP1.2. I'm guessing it's there to help with troubleshooting and/or older GPUs.Interesting. Which monitor is that?
Why would they offer a toggle?
This is incorrect. You can get active cables that aren't fibre.I also want to point out that increasing bandwidth reduce the lenght of copper cables (attenuation and noise heavily affect signal integrity): DP80 cables are 1.2m maximum, if you want longer cables for 80Gbps you need fiber. And a fiber cable is obviously way more expensive than a copper one.
It works with DSC as well, but it depends on the hardware. It's more of an Nvidia issue than a DSC issue.I would like some 27" versions; 32" is too big for using kbm at a desk.
Getting rid of dsc is good since it will allow for nvidia dsr to work again.
And this is exactly how marketing works: this is a DP 2.1 Vesa certified cable but the 80Gbps part isn't. This is a DP 2.1 DP40 certified cable.This is incorrect. You can get active cables that aren't fibre.
For example:
Silicon does support UHBR20, but the member mentioned RX cards, not W cards.I don't know what to tell you, that's what they advertised for the professional cards. Just because they said that in the regular consumer stuff presentation doesn't mean the silicon doesn't support more.
