System Name | Dark Palimpsest |
Processor | Intel i9 13900k with Optimus Foundation Block |
Motherboard | EVGA z690 Classified |
Cooling | MO-RA3 420mm Custom Loop |
Memory | G.Skill 6000CL30, 64GB |
Video Card(s) | Nvidia 4090 FE with Heatkiller Block |
Storage | 3 NVMe SSDs, 2TB-each, plus a SATA SSD |
Display(s) | Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24") |
Case | Be quiet! Dark Base Pro 900 |
Audio Device(s) | Logitech G Pro X |
Power Supply | Be quiet! Straight Power 12 1200W |
Mouse | Logitech G502 X |
Keyboard | GMMK Pro + Numpad |
Do you guys even know if the gigabyte monitor will have a Option in the Menu to turn off DSC?
As far as i know only the Asus has this Option. MSI not.
Any update on release date?For those that are interested, the DP 2.1 solution is from Realtek, but I don't have any further details on what it is.
Keyboard | Corsair K70 Max |
Software | Windows 10 Pro |
No, sorry, but it should be soon-ish.Any update on release date?![]()
Thanks for the response! I've not bought much from gigabyte, but I'm really hoping this is a winner...and that it shows up soon.No, sorry, but it should be soon-ish.
Let me see if I can get some more details.Thanks for the response! I've not bought much from gigabyte, but I'm really hoping this is a winner...and that it shows up soon.
System Name | "Icy Resurrection" |
Processor | 13th Gen Intel Core i9-13900KS |
Motherboard | ASUS ROG Maximus Z790 Apex Encore |
Cooling | Noctua NH-D15S upgraded with 2x NF-F12 iPPC-3000 fans and Honeywell PTM7950 TIM |
Memory | 32 GB G.SKILL Trident Z5 RGB F5-6800J3445G16GX2-TZ5RK @ 7600 MT/s 36-44-44-52-96 1.4V |
Video Card(s) | NVIDIA RTX A2000 (5090 shipping to me soon™) |
Storage | 500 GB WD Black SN750 SE NVMe SSD + 4 TB WD Red Plus WD40EFPX HDD |
Display(s) | 55-inch LG G3 OLED |
Case | Pichau Mancer CV500 White Edition |
Audio Device(s) | Sony MDR-V7 connected through Apple USB-C |
Power Supply | EVGA 1300 G2 1.3kW 80+ Gold |
Mouse | Microsoft Classic IntelliMouse (2017) |
Keyboard | IBM Model M type 1391405 |
Software | Windows 10 Pro 22H2 |
Benchmark Scores | I pulled a Qiqi~ |
All AMD 7000 client cards support DP 2.1 at 54 Gbps and PRO W7900 and W7800 support 80 Gbps. You want DP 2.1? Go AMD now or wait for next gen GPUs.
It's either segmentation or better data traces on PCB of Pro cards. We do not know until we see the analysis of PCBs.Now why exactly is AMD gating UHBR20 behind Radeon Pro then? Isn't the display controller the same?
The monitors are apparently being shipped as of right now and should arrive in retail over the next couple of weeks in major markets.Thanks for the response! I've not bought much from gigabyte, but I'm really hoping this is a winner...and that it shows up soon.
The Official Pricing for AORUS FO32U2P, FO32U2, FO27Q3
by u/GBT_Angela in OLED_Gaming
Let's see it in a wider perspective. AMD is the first company in the world to have introduced DP 2.1 on all graphics engines - in 2022 on APUs from Rembrandt onwards, in 2022 on Raphael CPUs and in 2022 on client and professional GPUs.Which amount to segmentation regardless just thought it's a weird limitation to impose on a GPU
Let's see in a wider perspective. AMD is the first company in the world to have introduced DP 2.1 on all graphics engines - in 2022 on APUs from Rembrandt onwards, in 2022 on Raphael CPUs and in 2022 on client and professional GPUs.
- UHBR10 40 Gbps was enabled for CPUs/APUs
- Result? No single motherboard, mini-PC or laptop vendor has exposed this port so far. It's them to blame for not using what CPU/APU can offer.
- UHBR13.5 54 Gbps was enabled for client GPUs
- Result? Only Samsung made an annoucement in 2022 to bring support for DP 2.1 on Neo G9 57-inch. Others? You can see how sluggish it is...
- UHBR20 80 Gbps was enabled fpr Pro GPUs
- Result? No professional monitor vendor has made any announcement whatsoever to support this speed, even not Asus with ProArt monitor line
The immediate question is why should AMD be wasting their time and money supporting new, modern video standard at any bandwidth if others are so lazy to follow through on this, enable it on their devices and bring benefit to us consumers?
Still, AMD enabled DP 2.1 on all new silicon despite few monitor vendors making any commitments. Nvidia will not have any DP 2.1 until Blackwell and Intel has only enabled it recently on Meteor Lake CPUs and via Barlow Ridge TB5 chip. There is one single laptop announced with TB5 - Blade 18.
The real problem here is not bandwidth segmentation, but other companies lacking ambition to move the industry towards DP 2.1 where necessary. AMD has done their job. Others have not. 54 Gbps port on RDNA3 is fine in vast majority of cases, as it supports uncompressed signal up to:
- 4K/230Hz 8-bit or 4K/240Hz RGB with custom timings
- 4K/187Hz 10-bit RGB
- 5K/136Hz 8-bit RGB
- 5K/110Hz 10-bit RGB
HDMI 2.1 FRL cannot do any of the above without DSC compression.
Fair enough. I mean even HBR3 is plenty enough for all but some edge cases nowadays.
No deafault DSC, please. The primary role of DSC is to deal with situations where there is not enough bandwidth for uncompressed signal offered by current video technologies over HDMI and DP.DSC is fine but it got such a bad rep that they should release a new version that is truly lossless and make it the default transmission mode.
DSC should only be used when necessary. For example, 5K/2K 180-240Hz 10-bit monitor will need more than 80 Gbps of data. DSC is fine here.
DSC should never be used as a cheap way to offer low bandwidth port when higher bandwidth port is clearly available. For example, new Asus ROG Swift PG32UQXR offers only DP40 port for 4K/160Hz 10-bit image, forcing the monitor to use DSC to deliver this image. This is not necessary and Asus contributes here to bad reputation of DSC. It is vendors being cheap on ports and still selling for premium prices. Nonsense. I'd never buy such monitor.
Many public displays will have video wall mode, whereby 80 Gbps connection uses DSC over MST to distribute signal to many displays. This is another case where DSC is very useful.Sending 80gbps of data (and more as we continue to push for higher res and refresh rates) with no compression whatsoever is not very smart and there are easy things that can bring those numbers down.
New compression codec development cycle will take several years, but I am sure research is being done on this.I'm talking about truly lossless, you could easily save a fair percentage of bandwidth simply tweaking how data is encoded.
System Name | Laptop ASUS TUF F15 | Desktop 1 | Desktop 2 |
Processor | Intel Core i7-11800H | Intel Core i5-14600K@135W | Intel Core i3-10100 |
Motherboard | ASUS FX506HC | Gigabyte B660M DS3H DDR4 | MSI MAG B560M Bazooka |
Cooling | Laptop built-in cooling lol | Thermalright Assassin Spirit w/ BeQuiet Shadow Wings fan| Stock Copper |
Memory | 24 GB @ 3200 | 32 GB @ 3200 | 16 GB @ 3200 |
Video Card(s) | Nvidia RTX 3050 Mobile 4GB | Nvidia GTX 1650 | Nvidia GTX 960 2 GB |
Storage | Adata XPG SX8200 Pro 512 GB | Samsung M2 SSD 256 GB & 1 TB 2.5" HDD @ 7200| SSD 250 GB & SSD 240 GB |
Display(s) | Laptop built-in 144 Hz FHD screen | Dell 27" WQHD @ 75 Hz & 49" TV FHD | Samsung 32" TV FHD |
Case | It's a laptop, it doesn't need case lmfao | Deepcool Mattrexx 55 MESH | Aerocool Cylon PRO |
Audio Device(s) | laptop built in audio | Logitech stereo speakers | Logitech 2.1 speakers |
Power Supply | ASUS 180W PSU | SeaSonic Focus GX-550 | MSI MAG A550BN |
Mouse | Logitech G604 | Corsair Harpoon wired mouse| Logitech G305 |
Keyboard | Laptop built-in keyboard |Razer Blackwidow | Steelseries APEX 7 TKL |
VR HMD | Quest 2 sold out and don't need VR anymore lol |
Software | Windows 10 Enterprise 20H2 | Windows 11 24H2 LTSC | Windows 11 24H2 LTSC |
Benchmark Scores | good enough |
