Help me with my thesis - Researching consumer perceptions, obsolescence, and electronics.
6,452 (1.55/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Everything, everywhere, all the time, all at once, all things electronic become/go obsolete or borked...
The real question is: Why does it have to be this way....
And the answer is: Greed :(
19 (0.03/day)
I saw the damage on the old unit and so looked what was better locally, so when I saw a stainless option, I went for it; I just didn't want to do the work more than once.
What I like best is when I locate a broken component and find the replacement part has been updated; then I feel the original problem will probably not return.
Are you of the perception that 'older' products were created to last, or do you think that is just a romanticized view?
Thank you for the input! - and sorry for the late response:)
Do you think greed is the only aspect to it? Please enlighten me about your thoughts of it. (and everybody else's view as well)
  • Couldn't innovation be labeled as the main reason for obsolescence, either absolute (where things breaks) or relative (where we as consumers just want an upgrade)?
  • Isn't obsolescence a good way to spike the economy, while we are getting new gadgets?
5,347 (3.72/day)
Colorado, U.S.A.
Software Windows 11 Home
When it comes to cars, those of old did not last a fraction of modern ones.
366 (0.38/day)
France
Processor AMD Ryzen 7 5700X3D
Motherboard MSI MPG B550I GAMING EDGE WIFI Mini ITX
Cooling Noctua NH-U12S Chromax Black
Memory Corsair Vengeance RGB Pro SL 32 GB (2 x 16 GB) 3600MHz CL18
Video Card(s) AMD RX 6750XT Reference Design
Storage 2.5 TB 2.5" SSD / 3 TB HDD
Display(s) ASUS 27" 165HZ VG27WQ / Vertical 16/10 iiyama 25" 75Hz ProLite XUB2595WSU-B1
Case be quiet! Dark Base 700 RGB
Audio Device(s) PSB Alpha P3 / LOXJIE A30 Amp
Power Supply EVGA SuperNOVA 650 GA
Mouse Cooler master MM720
Keyboard Roccat horde
VR HMD Oculus Rift S (please Valve, release a new headset)
I think it was somewhat true, a lot of thing where not over-engineered for nothing, and was much simpler in how they work and how they can be repaired.
Lei
1,143 (0.86/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
Are you then willing to pay more for products that either have an extended warranty, known for their durability, or are you actively seeking products with a modular architecture that allows you to replace parts 'easily' by yourself?
Of course I like modular products like lego.
I replaced my Bluetooth headphones battery from original 100mAh to 1200mAh. It was designed to need recharging every 2 days, with new battery it still has 60% charge after 2 weeks...
I also try and keep things running, but sometimes this is not a good idea; fixing a CRT TV/Monitor for example as they consume so much electricity.
Sometimes I buy something old just because I can throw it in the operation room and make a zombie out of it. When I was about to start watercooling, I wanted an old cheap gpu as guinea pig.
Would you buy a used Porsche over a new Toyota? Considering the Porsche costs just 10% more and was driven for 6~8 years.
895 (0.63/day)
Hello everyone,
I'm a new member looking for help with my master thesis (which I hope is within your guidelines).
I have been lurking at the community for quite a while, experiencing how insightful you all are.
I'm doing a research project focusing on consumer's perception towards the concept of obsolescence / planned obsolescence, specifically in household level electronic devices. Thus, everyone with an opinion, experience, or even just owning an electronic device is interesting to me!
As the main method used is netnography, everything is expected to happen online, preferably in written format.
So, if you would like to answer a few question as an “interview”, share opinions and experiences, or just have any question to me or my study. Please let me know!
In advance, thank you very much.
Best regards.
To be honest, you would have a much easier time using your campus library to research this stuff as they will have online databases loaded with statistics/facts, not to mention it would make doing your works cited page less of a nightmare depending on the format(I would assume your particular Master Thesis requires APA).
5,347 (3.72/day)
Colorado, U.S.A.
Absolutely not; the Toyota is reliable and gas sipping.
6,452 (1.55/day)
Motherboard AZW SEI
Yes, innovation CAN be a driving factor for obsolescence in many cases, when used correctly, however, problem(s) can arise when:
A) The new item is NOT backwards compatible with older device(s).. hello W11 & it's so-called TPM requirement :(
B) Support for the older item is stopped/dropped too soon after the new device is released, making the old one essentially useless once it cannot support any new features
And yes, a lot of the time, we consumers just WANT an upgrade, just because we desire (and are willing to pay for) fancy new gadgets with all the most recent bells & whistles :)
Take cars for example:
One of my cars is a 2009 model. No, it doesn't have a touch screen, navigation, android/apple auto, or any other uber-techy stuff. HOWEVER, it does have remote start/unlock, digital ecm, and power everything. No, it isn't as pretty as it once was, but it has over 200K miles on it, has never failed to start, runs like a champ while getting ~30mpg, and can STILL do 0-60 in about 9 seconds, which is plenty fast for any normal human being IMHO... plus, I can still get reasonably priced parts for it from multiple vendors, it doesn't cost ~$1k just to run friggin diagnostics on it with a $100K machine, insurance for it is cheap, and the best part: It's was paid for a long time ago !
Would I LIKE to have a 2023/24 model ? Perhaps... do I NEED one ? NOPE, at least not until the one above dies :D
As for "spiking" the economy, if you meant "growing" the economy, there many other factors involved other than planned obsolescence that requires people to continuously buy new stuff....(local/regional/world politics, employment/unemployment, energy stability, monetary policies) just to name a few...so that's really not a valid point, at least not on it's own anyways....
19 (0.03/day)
Can a car even run without Apple CarPlay nowadays? ;)
I think you are coming with some very interesting points. - Which is why I just continue to poke you :)
Can I ask how often you are replacing products such as; smartphones, PC's, or TV's?
- And whether you only replace products when they malfunctions?
Thank you for your consideration. I have used a loooot of time with the materials available through the library for my literature, I however have to gather 'my own' empirical data. Thus, since the main scientific method used is Netnography, where I use different techniques of participatory observation to answer the question of how netnography can be utilized to understand consumer's perception towards obsolescence. I have to understand yours experiences, perspectives, and thoughts, all of which in subjective form.
The discussions by everybody above is therefore very useful for my analysis.
If you have any questions towards mentioned methods, or anything else. You are more than welcome to write me a private message.
You are moreover very welcome to join in the conversation, or if you are up for a short written interview in private, please let me know. - Everything is much appreciated.
lluvia
14 (0.01/day)
No mention of the Sony Timer yet? It's still quite relevant as with the PS5 and its varying issues, such as the orientation of the console affecting the liquid metal's coverage of the CPU.
Speaking of Sony, now that they are also creating one, a car certainly is a "household level electronic device" wouldn't you say?
Most Toyota and Tesla owners see their cars as appliances that take them from point A to point B.
(The only difference between them being that the Tesla owner has much more disposable income. lol)
The reason why Toyotas have great reliability is planned obsolescence... of the driver. lol.
Toyota does not trust the average (Toyota) buyer to do proper maintenance for the car at proper intervals.
Thus the car is bullet proof for those who do literally any maintanence, and for those who don't, the car still lasts much longer than a non-Toyota.
(One example would be: While most cars use only direct injection, Toyota utilizes both port and direct injections so tha the valves remain clean, ultimately prolonging the engine's life. The fuel timing is controlled by a computer, not mechanically, so it is [arguably] an electronic device.)
Tesla on the other hand, can be considered planned obsolescence. It's by design that it can't last, especially for those who need software like Apple CarPlay, disregarding its widespread QC issues.
(Yes, I do know that Tesla doesn't have Apple Carplay/Android Auto and probably never will.)
Teslas are even more appliance-like with Lithium-based batteries that will degrade over time, even more so when exposed to the elements in comparison to a traditional ICE car.
But as with our smart-whatever, most people don't care about that fact, so long as the appliance can be used to a degree.
So then my question is whether planned obsolescence is real, or just perceived notion when an uninformed/uneducated consumer shifts to a victim mindset when that "obsolescence" is by design/nature of the appliance? There is nothing in the universe that doesn't degrade over time.
P.S. I think you should mention your country and major, then also ask your respondents what country they're from at the very least. This is still very broad but significantly changes viewpoints. Availability and appliance itself, even with the same name, can be vastly different in each country's market.
9,824 (3.48/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Look at the X570 vs the X570S. Here are images of both boards. Technically the only real difference is 1 more M2 slot. When it comes to looks though you see the little things that make me fell the Ace Max is the most beautiful MB on AM4. You know that MSI must have invested in the little things (like White LED post codes) that will make a person spend $200-300 by selling the Unify and buying the Ace Max.
1,019 (0.55/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
Count me in!
View attachment 292917View attachment 292918
There's more than White LED. The RF protected sound chip, ESS Sabre DAC, 2oz thickness of copper lanes, Gold plated audio jacks are well deserved a higher price. Also, the Ace version features 4 more VRMs than Unify.
9,824 (3.48/day)
Cooling In Win SR36
Count me in!
I get that but looks do matter.
6,452 (1.55/day)
Motherboard AZW SEI
I generally only replace a TV/Monitor when it's picture/visual quality begins to degrade to the point that it makes it difficult to use for it's intended purpose, or it just up & dies altogether..
For pc's, I usually replace them about every 3-4 years, or whenever they can no longer keep up with new(ish) software requirements, or again, just up & dies, which BTW, has NOT happened for a very long time... I am currently running a 2 year old mini-me box with an 11th gen cpu & iGPU, if that tells you anything....
For smartphones, usually the declining battery life is the biggest reason for getting a new one, which for me is typically every 2-3 years, and even then, I normally go with the models that are 1 generation behind, instead of the latest & greatest flagships....that way I still get a great phone with great specs but NOT the platinum card price :D
5,347 (3.72/day)
Colorado, U.S.A.
I find they normally just need new capacitors.
29,348 (6.90/day)
It's not romanticized. As a general rule, the business model of "planned obsolescence" is more widespread now than it ever has been in the past. Products built in decent decades fail more easily and frequently, are more difficult to work on for repairs(or just not possible), or are made so cheaply the repairing them is a wasted effort.
19 (0.03/day)
Thank you for the input, and the well described thoughts.
I agree, that it can be argued that cars has changed into a household level electronic device, at least newer models. - The car industry is moreover an 'easy' reference point to the term of obsolescence, especially when lots of literature describes it as the cradle of various obsolescence techniques.
Undoubtedly, everything degrades over time. I think it is an interesting point you are making. However, have various examples, such as the famous printer industry, been a source of rich discussions relating to planned obsolescence. But do you believe that if customers informed themselves, stopped their consuming habits, and stood up to big corporations that obsolescence (both absolute and relative) would vanish over time?
I'm of course up for informing everybody that I'm a Danish student (which explains the odd language at times), studying a master in science, in product development & innovation. Your origin is although not the crucial part here, it is just a bonus. The focus is to explore how this community sees obsolescence, which then is compared to another community. :)
Most manufacturers explain those trends with the notion of Innovation or performance. I.e., smartphone manufacturers embeds batteries to ensure a slim design, and utilize adhesive to seal it better. Are you not buying those explanations? :)
That is also my strategy when I replace my smartphone ;-)
What are you doing with your replaced products? Are you selling it as used products, holding on to it, discarding it, or?
366 (0.38/day)
France
In response to the example of sealed battery (one of the worst thing that happened in the smartphone industry). The Galaxy S5 was slim and get a removable battery and IP protection, they prove everyone it can be done and shortly after, just make the S6 with glass and sealed battery. Only Fairphone is actually trying to make things better, theres other smaller brand too like terra, i don't know all of them. But innovation should not be done in the detriment of repairability or losing useful feature (hi Jack 3,5).
29,348 (6.90/day)
Of course not. It is planned obsolesce, engineering laziness and manufacturing cost-cutting all at once. Very transparent!
Lei
1,143 (0.86/day)
usually in my shirt
They could have made the batteries thicker, and not have the cameras bump out. Then make the phone shorter to keep the weight under 200g.
Longer battery life, safer cameras, easier to pick the phone up with trimmed nails, and easier to hold than a looong taaaall screen.
Don't charge your battery to 100%
Charge to 70% (the point charging becomes slower)
This will make your battery live 3 times longer. 8~9 years instead of 2~3 years.
And just replace the battery, it's very easy.
3,888 (2.56/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
Here at TPU you're among people who have an above average ability - and desire - to repurpose old parts, build new old PCs, and hand them over to less demanding users, such as their own parents or charities. They will likely complain less about P/O because they know how to run against it, at least when it comes to PCs.
Gotta go now, those pesky HP 338 ink cartridges need refilling again, it's a dirty job.
6,452 (1.55/day)
Motherboard AZW SEI
I started this from day 1 on my current phone (S21+), and it helped alot for the 1st 2 years, but not as much as it originally did... plus the battery on this phone is not that easy to replace, but there is a small shop downtown that I have used before, they will do it for $85 (parts & labor) so I will let them handle that, since my hands/eyes aren't as good as they used to be :D
I will try first to sell them to someone who wants a used/budget device, if this doesn't work out, I will take them to a recycling place......
Lei
1,143 (0.86/day)
usually in my shirt
I replaced mine for 9$
Just found a tall lady with long wavy hair, I asked her to bring me her hair dryer... I let her pull the battery out with her long fingers.
I bought some boiled eggs yesterday morning. Saw that lady again and put the warm egg on her cheeks, hahaha
I sold my monitor. My hdd.
I support return without reason.
Used parts may also end up being tossed at my sister or opened to steal the tech.
Steve Jobs said: good artist copies, great artist steals. So I think it's important to screw things open and steal the design inside.
I do buy 2nd hand stuff too. My psu, my mobo, ssd, hdd, keyboard, joystick, webcam, panoramic camera, gpu are all bought from 2nd hand market.
My brother says: the best guarantee is when something worked for 2 years and is still working. He repairs printers for a living. Including flashing their IC so they reset their counter instead of stop working.
5,347 (3.72/day)
Colorado, U.S.A.
For most phones changing the battery is easy, but not so for an Apple iPhone.
3,888 (2.56/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
My phone had an IP68 rating when it was new, which was 4.5 years ago. Water resistance becomes questionable over time, and even more problematic if the phone is taken apart to have battery or other parts changed.
