Help with BF3 Micro-Stuttering
Status
Not open for further replies.
4,213 (0.72/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
try turning msaa off silky all your games then be silky you can leave post FXAA on whatever still and leave morpho off in catalyst
I tried that, it was still stuttery as hell. It's definetly the textures, i currently run at 2xmsaa with medium textures, no probs.
Even with the stuttering i was getting a good framerate according to fraps. Latest BF3 drivers. Weird
3,165 (0.54/day)
System Name White Theme
Processor Intel 12700K CPU
Motherboard ASUS STRIX Z690-A D4
Cooling Lian Li Galahad Uni w/ AL120 Fans
Memory 32GB DDR4-3200 Corsair Vengeance
Video Card(s) Gigabyte Aero 4080 Super 16GB
Storage 2TB Samsung 980 Pro PCIE 4.0
Display(s) Alienware 38" 3840x1600 (165Hz)
Case Lian Li O11 Dynamic EVO White
Audio Device(s) 2i2 Scarlett Solo + Schiit Magni 3 AMP
Power Supply Corsair HX 1000 Platinum
- Are you running Crossfire or SLI? Yes
- Do you have the 2nd gen i5s or i7s? Yes
- Are you maxing ALL the settings... including AA and v-sync on? Yes both MSAA and FXAA are on max
- Have you even tested to see if you have stutter... It only happens in a manifest way... when you get really close to an object and stare @ it while you move around (mouse + keyboard)...?
Nope, the only dips I get is when a tank explodes infront of mah face.
1,221 (0.24/day)
Canada
System Name Brutus
Processor i5 4690k @4.7Ghz (Watercooled)
Motherboard z97 MSI Gaming 5
Cooling NZXT Kraken x61 AIO watercooler
Memory Gskill Ripjaws 8gb (2x4gb) 1600mhz 7-8-7-24
Video Card(s) MSI Gaming GTX 980ti x2 (sli)
Storage 1 SSD 64GB (OS) + 2x500GB WesternDigital RAID 0
Display(s) YAMAKASI Catleap q270 SE 27inch Glossy 2560x1440
Case NZXT Phantom
Audio Device(s) ASUS Xonar DX
Power Supply Antec TPQ 1200w
Software Windows 7 (64 bit)
What I noticed is, the stuttering seems to come from my CPU having a hard time working with BF3 and my crossfire setup because of it's low speed (it's @ 3.6ghz instead of my usual 4ghz)...
Maybe my mobo doesn't help either... All I know is, when my cpu is @ 4ghz, no stutter whatsoever... but I can't keep that OC... too unstable for my current rig right now (especially temps a bit too high)...
So I'm thinking, U guys prob don't have the problems I have because you're on the 2nd gen of i7 or i5... running crazy high CPU speed... like 4.6ghz.. or 4.8ghz...
1,221 (0.24/day)
Canada
System Name Brutus
Case NZXT Phantom
My system is:
I5-2500k
HD6950 1GB
8GB
Win 7 64bit
With high/ultra settings, 1080p resolution and AA turned off I can run it without any stuttering. I haven't bothered to benchmark it because it runs so smooth. I'm planning to unlock and overclock my GPU today, but to make long story short, here is my advice for you.
1. It makes no sense at all tweaking your hardware. It is a beast and should run BF3 with everything maxed out. So my only guess is that you have software issues.
2. Run some tests to see what the stuttering is caused by. You can do this by opening the console pressing ~. Then type in the two commands.
- Render.drawFPS 1
- Render.PerfOverlayVisible 1 (Green is CPU and yellow is GPU)
Reference: http://www.tacticalgamer.com/battle...-performance-game-other-console-commands.html
3. If the GPU is being the bottleneck, download and try the latest "beta" nvidia driver. AMD Catalyst 11.10 Preview 3. With this driver I've had 0 problems.
Best of luck.
I went ahead and tried your test... and it looks like my CPU is holding back the cards a little... for me CPU is yellow and GPU green... When the stuttering happens I see that the GPU line seems to spike up a little while the CPU is pretty much at the same line the whole time...
I'm pretty sure that when I try this with my 4ghz OC and RAM oc, it should change a little...
dehdar
8 (0.00/day)
This sucks, I feel your pain.
Seems like you've tried pretty much everything. Did you try the driver I suggested? It's a beta driver and in the release notes it claims to fix a lot of issues for people running BF3 in "crossfire"... I don't know what else to do.
Best of luck.
1,770 (0.37/day)
Cussing desert
System Name Torquey Vulture
Processor Ryzen 5 2600
Motherboard Gigabyte B450 MiniITX
Cooling DDC water loop, EK block
Memory 16GB Patriot Viper RGB
Video Card(s) EVGA 1070
Storage 500gb NVME; some Phat HDDs
Display(s) Achieva Shimian 27" 2560x1440
Case Thermaltake V1 MiniITX
Power Supply EVGA supernova 850 G2
Mouse Corsair Harpoon
Keyboard Possibly the cheapest you can buy. Shift key broke recently. Space sounds like I'm kicking a ham
At AMDs Catalyst site, 11.9 specifically says: "- Battlefield 3 – Provides great CrossFire scaling and resolves stuttering issues when running in CrossFire mode"
43,606 (6.50/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
It's a lie. Best driver to use is the 11.10 WHQL with the latest CAP 4.
2,276 (0.35/day)
Cairns QLD, Aussie
System Name GaMEr / HTPC
Processor FX8320 4.5ghz so far NB- 2815mhz / X2 255 @ 3.2ghz (Temp till BD)
Motherboard 990FX-UD5 / GA-MA785GPMT-US2H
Cooling XSPC - 240rad 480rad 5 x 120mm out, 6 x 80mm in / H220-edge 1/2" & 2 x 120mm Magma
Memory 4gb PI 6,8,6,18 1T 1706mhz / 4gb Crucial D9's 1400 @ 6,6,6,18,1T
Video Card(s) 3gb HD7950 / Onboard
Storage 2 x 120gb Sandisk ultra plus 2tb WD / 60gb vertex 2 + 2 x 2tb WD Greens
Display(s) 3x24in Dell Ultra (portrait) / NEC 32" FullHD LCD
Case LL PC71A Full tower / Antec fusion black with Imon remote Modded for WC
Audio Device(s) OB / Auzentech cinema 7.1
Power Supply TT 700w TR2 / TT 600w Litepower modded with Noctua S12 fan.
Software 7 Ult / 7 premium x64
I haven't read the whole thread but just wanted to share my experience. I had a lot of stuttering in BF3 with my setup, it got progressively better with the newer drivers but was still noticeable. I have just installed the newest 11.10 WHQL and CAP4 and the game plays perfect. No stuttering and good FPS. I do still get some green flashes on the screen but these are only very small/quick and intermittent.
Mussels
Freshwater Moderator
58,413 (7.94/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
jonathan1107:
seriously?
just because you spent "2.8K" on a system doesnt mean anything. except that you spent more money than you should have >.>
and then you bring up an old game like crysis saying it runs fine?
I think you need to stop making assumptions and start thinking about the problem here - maybe your overclock is wrong, your unlocked cards arent working right, or your OS is just screwed (and yes, that happens. a format can fix a lot of problems)
blaming it on the game is the easy way out, it just means you dont want to admit something you did to your system, hardware or software, could be the problem.
3,165 (0.54/day)
Mate turn off hyperthreading and you'll be able to get that CPU stable at 4ghz. HT was shown to barely give BF3 any performance improvements infact it did the opposite for some people and hindered performance.
This guy for example: http://www.tomshardware.com/forum/114711-13-battlefield-hyperthreading-experience
And this thread: http://hardforum.com/showthread.php?p=1037951359
It is easy to mistake that the lag or small jumps and fluctuations you get in the game are cause by some keyboard/LAN/Network/Internet settings when it's not.
43,606 (6.50/day)
Storage WD m.2
Keyboard Tester84
jonathan1107:
seriously?
I agree, especially since this problem seems to have been happening well before BF3 was released:
http://www.techpowerup.com/forums/showthread.php?t=147460
1,221 (0.24/day)
Canada
System Name Brutus
Case NZXT Phantom
Ok here it goes:
1. I did not spend too much, I bought everything off the internet with the cheapest prices one could get (at the time of course)... There's no such thing as too much, when you want crisp and clean power from your PC... but that here is clearly a matter of opinion... so I consider that when you say "you spent too much" that is not a FACT but an opinion...
2. Crysis is known to be one of the most demanding pc game of all times (both crysis and crysis warhead. They are both very GPU and CPU demanding...) So yes sir, I do consider that game a good "benchmark" for anyone's overclock... unlock... you name it.
3. My cards are not unlocked with the 6970's bios... they only have their shaders unlocked... I restored them to their default bios and it didn't fix the stuttering... It is true that stuff like my OC, windows install or driver residue IS capable of causing problems. But Like I said, I tested all of those things, I even went back to older dx11 titles (like DA2, Witcher 2 etc...) and no stuttering (when @ 4ghz)
4. Clearly, if you have taken any 5 minutes of your time to google it, and looked @ the EA forums, you would see that I am indeed CORRECT in blaming the game this time.... or at least in saying it has had MAJOR issues since the beta, and even since the official release. But again, this has been true, mostly for SLI and CF users... TRUE enough for AMD (don't know about Nvidia) to release brand new drivers to fix the situation (right after the game's release...) Now doesn't that tell you in Neon lights that the game devs must have missed something... like possibly looking into possible CF glitchy performance?
4. I do believe that sometimes just a little patience goes a long way for PC games... Often, new drivers will come out or patches from the game devs... and stuff gets fixed... So, yes forgive my young age, when some games come out, I get excited and anticipating, and patience is not always the dominating sentiment in those moments...
1,221 (0.24/day)
Canada
System Name Brutus
Case NZXT Phantom
True that... I didn't try lowering the v-core now that HT's off... I'm gonna try upping the CPU speed back to 4ghz... (pretty sure that should bring the CPU up to speed with the GPUs...) Thx for the tip
brandonwh64
19,542 (3.51/day)
I tried turning off my HT and it made my game much worse. I guess its all up to your system.
1,221 (0.24/day)
Canada
System Name Brutus
Case NZXT Phantom
quick question: If I decide to upgrade for a better CPU @ 1 point, what CPU would U suggest when looking @ my specs...
and what's the socket for the new i7s (cause I'm not sure my mobo's compatible with the new gens...)
brandonwh64
19,542 (3.51/day)
Go for Z68+2500K/2600K
Or
Wait until X79 is released
1,770 (0.37/day)
Cussing desert
43,606 (6.50/day)
Storage WD m.2
Keyboard Tester84
crazyeyesreaper
Not a Moderator
9,816 (1.71/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
yea all X79 offers is better PCIE lane counts thats about it
brandonwh64
19,542 (3.51/day)
I believe a Z68+25/2600K+6950/70 2GB would be perfect for gaming at this time.
Wrigleyvillain
PTFO or GTFO
7,702 (1.23/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
^ Agreed. Get the 2GB VRAM while you're at it.
43,606 (6.50/day)
Storage WD m.2
Keyboard Tester84
I just don't understand why people think it's the CPU. If my 4 core, 8 thread FX-8150 can run this game with CrossFire (1gb cards no less) without stuttering, I would think his Intel chip could do the same. There HAS to be something else creating the stuttering.
crazyeyesreaper
Not a Moderator
9,816 (1.71/day)
Keyboard Mionix
lol dave i was gonna post it but i wanted to see how long it took them to read his specs before replying, sadly you said something ruining my fun
and i agree with erocker
its an ID-10T error
cadaveca
My name is Dave
17,232 (2.53/day)
Not for sure though. BD has higher memory bandwidth than 1156. 1156 needs 2000Mhz ram just to match BD @ 1600 MHz.
Like I hear where you are coming form, but there are only so many possible causes...software problems(possible and likely), or that the CPU just sucks for BF3(also possible).
BF3 is the wrong app to mention BD chips anyway, as AMD is even hyping 8150 with nV cards for BF3. Why?
All I know is that I have 2600K, HT on/HT off didn't make any difference. And I have no stutter. You know how big of a boost SB can give even single cards...and I know you perosnally have like NONE of the issues the rest of us do. The App sucks.:laugh:
Status
