How many are using 24h2? Problems still?
Did you update to 24h2? How did it go?
  • Total voters
    50
  • Poll closed .
2,658 (6.31/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
Compared with what?
With every previous iteration of Win 11 and whatever was the 10 version I have moved off with 11. 21H1 I believe. I obviously cannot speak for every game I have played on this PC since I don’t make a habit of having all of them installed and re-tested with every major update (I am not THAT autistic) but things that I play regularly like OW, D2R, Grim Dawn, HoMM3 and 5, UT2004, SWTOR and several others all perform within a margin of error. Note that I have, in fact, not had any HW changes since I built this rig and installed first 10 and then shortly after 11. So it’s all been stable on that front. I had NV driver versions have more of an impact in some circumstances than an 11 OS update ever did.
22,951 (6.07/day)
Only made by you it seems. Same goes for you. A lot of people have issues with 24h2. Period.
Nobody is denying that 24h2 has issues. You also seem to have some.
28,627 (6.79/day)
Please stop blaming the user.
I'll blame what I deem appropriate. Sure there are issues with 24H2, however, none of the known issues are directly attributed to gaming performance. Additionally, some people configure Windows in a less than optimal way. I was also raising an eyebrow to the comments being made. More than a bit sus to me.
Whatever it is, some people are having issues. Most are not.
14,196 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
I can't change my vote in the Poll, but I have updated and my system as seen in my specs runs fine, no glitches or issues.
436 (0.24/day)
Panama City Beach, Florida
System Name EventHorizon
Processor Intel® Core™ Processor i9-13900KF 8P/16 + 16E 3.00GHz [Turbo 5.7GHz] 36MB Cache LGA1700
Motherboard ASUS PRIME Z790-P
Cooling CyberpowerPC MasterLiquid Lite 240mm ARGB CPU Liquid Cooler
Memory 32GB (16GBx2) DDR5/6000MHz Dual Channel Memory (KINGSTON FURY BEAST RGB)
Video Card(s) GeForce RTX™ 4080 16GB
Storage 2TB WD BLACK SN850X (PCIe Gen4) NVMe M.2 SSD - Seq R/W: Up to 7300/6600 MB/s, Rnd R/W up to 1200/110
Display(s) LG 34''
Case CyberPowerPC HYTE Y60 Dual Chamber Mid-Tower Gaming Case w/ Panoramic View Tempered Glass + 2x120mm
Audio Device(s) Asus Strix w/Alan Finote mod for Windows 11
Power Supply High Power 1300W 80+ GOLD Full Modular w/ PCIE 12+4Pins Connector for PCIe 5.0 graphics cards
Mouse Steelseries Rival 600 wired
Keyboard Steelseries Apex 7 TKL red Switch
Software Win 11 Pro
I've been on 24H2 for two days. Last night, I played about an hour of COD. I browsed the internet, including YouTube. I remoted into work for about 10 minutes. Internet speed tests are nominal.
I have not noticed one single negative issue. It's no different than it was before.
It's now Jan 4 2025 Still on 24H2 @home, still zero issues. I've also updated 11 PC's at work to 24H2 no issues there. All have varying configs and specs.
119 (0.10/day)
System Name Phenomenal1
Processor Ryzen 7 5800x3d
Motherboard MSI X570 Gaming Plus
Cooling Noctua NH-D15s with added NF-A12x25 fan on front
Memory Predator Vesta 32GB (2 x 16GB) DDR4 3600 BL.9BWWR.300 B-Die @3733 CL14
Video Card(s) PNY XLR8 RTX 4090 VERTO EPIC-X Triple Fan
Storage Boot SSD: SATA 500GB - 1tb + 4tb pcie3 nvme / Spinning Drives: 2tb + 6 tb
Display(s) Gigabyte M27Q 27" 1440P 170 Hz IPS BGR monitor
Case Fractal Torrent - Black
Audio Device(s) Realtek ALC1220P
Power Supply Super Flower Leadex VII XG 1000W
Mouse Razer Viper
Keyboard Razer Huntsman V2 Optical
Benchmark Scores Time Spy - 28594 https://www.3dmark.com/spy/51010148
What issues? File corruption? That was a major issue with especially 26100.2033 and the update before that. '2033 was the worst final (non-beta or preview) 11 update in history! It resulted in people blocking updating and staying with 26100.1742.
OTOH, 24H2 as of lately, updates better than 23H2 and earlier. I usually have to fix stuff on a clean install with 23H2 and earlier. (My non-gaming testing of 24H2)
After doing a clean install of 24H2, Assassins Creed Valhalla and Hogwarts legacy wouldn't run with a 5800x3d and 4090. Sometimes if I left a windowed program on the screen (notepad, etc) when my monitor returned from sleep whatever program it was would be full screen and unminimizable so I'd have to ctrl-alt-del and sign out and then sign in to get back to my desktop. I have no such problems on 23H2 so I've restored my 23H2 install and locked it to 23H2 with GRC's InControl.
14,196 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
I get terrible frame-pacing / stutters in CS2 / DOTA 2 when using Windows 11 24h2.
I've always had these kind of issues that happen randomly so it's hard to reproduce.
Windows 10 has better frame-times and is way smoother for me.
Same settings, same drivers, everything updated etc.
5800x3d / RTX 4070 / 32 GB 3600MHZ.
Watch this video, it may be relevant.
1,340 (0.36/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | Koss KSC75
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Tiny11 Windows 11 Education 24H2 x64
1) Sometimes I can't delete pictures after viewing them in Photos app unless I terminate COM Surrogate from task manager which gas quickly become annoying.
2) File Explorer has become laggy af. Previously in W10, I could search for files, delete some of the files, hit refresh and search result would say, "no results found" or some shit. Now it just crashes file explorer and needs a restart from task manager.
I am using Tiny11 build though so can anyone confirm if these are also problems in stick W11? Otherwise I might just go back to W10.
59 (1.74/day)
Thanks. I recently stumbled against these kind of issues. I personally uninstalled MSI / RTSS altogether to see if it fixes my 24h2 issues but it doesn't unfortunately :)
I still have these frame-spikes / frame-time issues MOSTLY in CS2. But the general consensus from the videos I have seen is that Windows 11 24h2 has worse 1% and 0.1% lows vs Windows 10 22h2, meaning Windows 10 22h2 is smoother.
My example is here - observe how the frame-time jump to 30ms randomly on Windows 11 24h2 and observe how smooth is on Windows 10 22h2.
VIDEOS
514 (0.42/day)
Processor Ryzen 7 9700x
Motherboard Asrock B650E PG Riptide WiFi
Cooling Underfloor CPU cooling
Memory 2x32GB 6200MT/s
Video Card(s) 4080 SUPER Noctua OC Edition
Storage Kingston Fury Renegade 1TB, Seagate Exos 12TB
Display(s) MSI Optix MAG301RF 2560x1080@200Hz
Case Phanteks Enthoo Pro
Power Supply NZXT C850 850W Gold
Mouse Bloody W95 Max Naraka
1) Reinstall Photos, this stupid app can be a problem for any version of Windows.
2) It's an Nvidia issue, but you can try DDU+New driver and see if that will fix it, or just switch to an AMD card where File Explorer is far snappier :p
1,340 (0.36/day)
Nowy Warsaw
System Name SYBARIS
I'll let you know if it works. I just aired it out not expecting any solution.
3,729 (1.71/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
I suggest installing stock 11 in a VM or something so you can quickly test, generally these pre modified ISOs with removed components are a bad idea.
89 (0.02/day)
System Name Ick
Processor Ryzen 7 9700X
Cooling Arctic Cooling Liquid Freezer III 420 Black
Memory 32GB T-Force Vulcan DDR5 6000MHz 30CL
Video Card(s) XFX Mercury Radeon RX 7900 XTX 24GB
Storage Western Digital Black NVMe SN850X 2TB x3
Display(s) 30" HP ZR30W + 27" Samsung 275T
Case Lain-Li X2000F real glass window modded
Power Supply Antec Signature SG-850
Software Win 11pro 64bit
I''m building a new AMD AM5 gaming system (9700x/X670E + 6800 RX), and was hoping to install W11 on it.
Should I be worried about the 24H2 as I can't seem to find a trust worthy version of 23H2 yet :/
MS only has the 24H2 media creator on their site now...
Should I look at a Win10 install and wait?
59 (1.74/day)
You can't go wrong with Windows 10 22h2.
But note that the last support date is Oct. 2025.
Currently I re-installed Windows 11 24h2 to reproduce some issues I have in game on it, Windows 10 is faster even on desktop usage...wtf.
2,543 (0.52/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Case Corsair 275R
Mouse Logitech G Pro (Hero)
It seems that AM4 is less likely to have major issues with 24H2, ironically! It's more likely to take a dump on AM5, strangely!
It's possible that 22H2 is the best version of 10! Seemed that sometime before 22H2, 10, in benchmarks shown, would have lower average FPS and/or %1 minimum FPS.
24H2 was lightning-bolt-fast with desktop usage on my A320 build with Ryzen 7 3700X. (My B450 got un-usably borked)
Culpa mía! Here we go again!
59 (1.74/day)
Forgot to mention the horrible latency the system has - mostly due to the nvidia drivers on Windows 11 24h2:
Look at the latency on Windows 10 22h2, while and after playing a match of CS2:
Now look at the latency of Windows 11 24h2 - same config, same drivers, same game, same settings etc.:
587 (3.37/day)
Around an hour ago I copied a hole folder. A while later I wanted to delete it. I can't.
That's ridicolous to be unable to delete files with only a single offline user Windows 11 pro installation. This is a fresh installation when i bought the hardware in may 2023.
It seems that folder does not exists. I checked visually the folder with ls. I sorted in this gui with the date motified field.
Regardless - when the folder does not exists - than it'S a visual bug + false error code bug.
both should never happen. expected behaviour = all files deleted; a folder is also a file.; no error message pop up box.
I'm forced to do more windows 11 pro updates in two days.
Last time the official monthly update package for windows 11 pro refused to install. I'm on a metered connection. My download is costly. Last time I did the update over the internet.
I doubt my KC3000 2TB drive has an issue. I would see it on this gnu gentoo linux installation in daily usage / backups / and other file tasks.
windows is unable to give a proper error code. I see those popups also with a gibberish hex code (thats a number format) for the failed windows upgrade packages also.
21,632 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
Hasn't on my system, at all. Smooth sailing.
587 (3.37/day)
The error can be reproduced after a windows warm boot a few minutes ago.
I could not find the folder.
To clarify if that folder exists - I just copied it.
If that folder existed - the folder name should have been different named.
Than I wanted to delete it. Nope.
(left bottom is the error message. top left i did the last - to check if i the dialog window comes for delete yes / no)
That folder does not show up with ls or caja in gnu gentoo linux.
514 (0.42/day)
If you don't see it under Linux, it may be a temporary directory that is created when Windows starts.
But if you really want to delete it (at your own risk), you can do so under Windows with this Take Ownership
1,043 (0.66/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH Z333 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard Laptop built-in keyboard
Software Windows 10 Enterprise 20H2
Just want to add CPU-Z 2.10.0.x64 works fine under 24H2.
but, what is the point? there is 2.13.. it's not the case when "old" is "better", IMHO
