electrowind
- Feb 14, 2023
- 20 (0.04/day)
While it is true that acetone can dissolve certain types of super glue, it is important to exercise caution when using it on electronic components or circuit boards. Acetone can damage or corrode certain materials and can also short circuit electrical components if it comes into contact with them.Ah. Acetone should fix that - it dissolves super glue.
If you need to remove super glue from a circuit board or electronic component, it is generally best to use a specialized adhesive remover that is designed for use with electronics. These products are less likely to damage the materials or components on the board, and are formulated to be safe to use on sensitive electronics.
