How to quickly & easily fix coil-whine(coil choke noise)
28,985 (6.84/day)
I am concerned about temperature.
The Most Common Questions and Answers about Cyanoacrylate Adhesives (gluegun.com)
suggests 200F (93C), whereas some coils can run above boiling point. The red insulating varnish is good to 155C
No choke coil running in a consumer electronic device will ever reach 80C, let alone exceed it. They are not a heat-generating part. Full stop, end of story. Furthermore, this process applies superglue to the coil housing in the gap between it and the PCB. Any glue that directly contacts the coil is not a part of the sealing action of the procedure.
Simply put, there are no concerns about heat where the superglue is concerned, even in a power supply.
1,468 (0.94/day)
Tel Fyr
It's been some time since I've take a look at this thread, but I can confirm that the GPUs are terrified with:
unigine heavens exit screen or skyrims load screens
It's like their whole lives are passing on a few seconds film, "I'm done, the death is knocking on my door".
5,290 (3.73/day)
Colorado, U.S.A.
Software Windows 11 Home
A power supply transformer can run hotter than 100C, but unfortunately the Jonny Guru site is no longer around.
Not here to make trouble, and I am fine with your showing me I am mistaken.
28,985 (6.84/day)
But that is not a choke coil soldered to a GPU or motherboard. PSU transformers are well cooled by the PSU fan and PSU choke coils are not mounted near the transformer. This procedure applies only to parts in PC componants and general consumer electronics. Transformers are not a part of this discussion.
No worries, this is not about ego, it's about solving a problem that continues to cause PC users unpleasantness while being ignored by moronic manufacturer executives. Your suggestion was thoughtful and grounded in logic. However, it's been tested and doesn't work as well as superglue. Nothing personal intended.
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
166 (0.03/day)
Processor E6750 @ 2.66ghz (3.7 in a few weeks)
Motherboard gigabyte p35 ds3L
Cooling thermalright ultra 120 extreme
Memory kingston 2gb kit (crucial ballistix 2x1gb in a few weeks)
Video Card(s) palit gtx 260 sonic 216sp 55nm
Storage 3 x 1.5tb seagate
Display(s) philips 24" IPS pw9eb (1920x1200)
Case CM centurion 5
Power Supply seasonic-x 650w
Software windows 7 32bit
haha Lex so far looks like only you have had luck with the 4090s and this fix. My glue just arrived in the mail today. Kinda nervous about that
166 (0.03/day)
Case CM centurion 5
Not really.
Then don't do it. If you don't feel good about doing it then just live with the noise.
that’s just an observation from this thread as Ive been following everyone’s experience. I think a lot of us are attempting this for the first time and perhaps doing something differently idk. Well I’m sure I’ll do it anyway since that gpu is the only thing that’s not 100% silent in my system. I have a mora3 and 2 360 rads so water temps only rise 5 degrees on full load and low fans. The gpu in comparison is like a screaming engine. Just prepping mentally as it’s the one thing I’ve never tried across multiple builds.
28,985 (6.84/day)
It can be scary, especially with such an expensive item. The key point to remember is that you are applying only a small amount of glue to a gap between a part on the board and the board itself. You have to use enough of the glue to completely fill the gap but not so much that it runs all over the board. Yet even if that happens, superglue is chemically inert and electrically insulative, so you're not going to hurt anything. Excess superglue is easily cleaned up with cotton-swabs and acetone.
Just take things slow and careful. There's no rush.
It's all good. Don't stress about it. It's just superglue, you're not going to hurt anything, even if you're a bit careless. You don't seem like the careless type. You'll be fine.
166 (0.03/day)
Case CM centurion 5
thanks for the encouragement! it's greatly appreciated. and so is this whole thread. will definitely be careful about all of it especially since my 4090 is under a block and it's much more annoying to take it out and put it back in (requires drain and refill, even with my QDCs since i'm taking apart the block...).
and i agree with your previous post about manufacturer prioritization around noise. it's weird because obviously they care enough to overbuild these coolers such that there isn't a single 4090 out there with heat issues, and hence super low fan noise vs previous generations of high powered cards. if anything there're many accounts of vram being too cold having errors when ramping up. but we have coil whine that's louder than any fan.
Mussels
58,413 (7.86/day)
Oystralia
it's because they're using pre-assembled parts, they might get 10,000 of these arrive in one giant batch and have 50 random samples through them, they dont hand test each part before assembling the final product
Then they'll do a test of the final product, but they dont test for coil whine - especially since the type of load (and power supply) can change or remove it
166 (0.03/day)
Case CM centurion 5
That makes sense. I do think that there’s increasing customer feedback on it though, especially since GPUs have gotten more powerful at quieter fan speeds now. Coil whine becomes more obvious in quiet builds and a more obvious problem for even middle tier builds. Hopefully this changes the design priorities in the future. I would legit pay a hefty premium for a card with quiet coils. Just take my money and make it shut up! :) Binning for performance like the KS products is a real thing so why not binning for noise!
Mussels
58,413 (7.86/day)
Oystralia
Same - I've found reference cards have a lot less issues than custom ones (especially overclocked custom ones) - I've found that they'll add 25Mhz but also cut every possible corner on the GPU to save money despite charging more
I think it's mostly because you can get a GPU with whine and slap it in 5 different PC's and it'll behave differently in all of them - a 4090 wont whine unless its got a CPU (And workload) capable of pushing hundreds of FPS, so their test systems might spread the load more evenly and not catch it
166 (0.03/day)
Case CM centurion 5
All great points regarding test rigs. Regarding power though these 4090s are pretty much exactly the same. AIB cost is literally there as a branding factor and to justify staying in the business at all. These founder cards seem to be pretty quiet… except you simply can’t obtain them in many places. A sad state of things for the way consumerism works these days. Part of me thinks nvidia factors in the premiums on release for aib cards due to literal shortage, into how much they’re squeezing vendor margins these days.
28,985 (6.84/day)
This is exactly right.
SRV123
7 (0.01/day)
Please update us on how this works out for you!
Also, @lexluthermiester I think this thread is absolutely fascinating and I'm hoping it'll become the fix we need for coil whine. Kind of insane how people just live with it and didn't really try to find any solutions for it.
166 (0.03/day)
Case CM centurion 5
I got a 13900ks on the way decided to do it all at once when it’s here
ad1
31 (0.04/day)
No worries. Below is the same photo, but highlighted.
The ones in Red are the most likely culprits. The HCIs in Yellow might also be the culprits. Again, I recommend doing them all in one go.
Hi, late reply, thanks very much for helping me identify the possible culprits. I haven't gotten around to trying it yet, I was waiting for MSI to respond about possible RMA. They just wrote to me that this noise is considered normal as it doesn't affect the performance of the card, so RMA is out of the question.
I'm a bit nervous about voiding the warranty on a crazy expensive GPU, so I will probably wait and see how it sounds after I put a water block on it in a few weeks. If it gets even worse, which I suspect it might, I will probably do something about it.
I have a glimmer of hope that the whine is amplified by the stock cooler, since it does have a bit of a rattle in the fins. The fans produce a very similar sound at 30% and 60% speed and knocking on the card produces a buzzing rattle in the cooler.
I only wish there was a less invasive way of trying to fix this, like high-temp hot glue or silicone which you can take off with alcohol. Or maybe something more passive like high density foam in the gaps around the edges between the waterblock and pcb, and on the backplate.
Count von Schwalbe
Nocturnus Moderatus
3,284 (2.78/day)
Knoxville, TN, USA
If removing the HSF doesn't void the warranty (this depends on your location) then adding a little superglue will not. US and EU consumers are protected by "right to repair" legislation.
ad1
31 (0.04/day)
I'm more worried about if something goes wrong with these glued components and they need to be changed, but they're stuck to the board and the board can't be serviced. removing the cooler is one thing, modifying the board is another. They will always try to find a reason to reject warranty repair.
I'll probably end up doing it, but I'd like to see more success stories on 4090 cards first.
As for warranty being void in my region, I'm based in Switzerland and we have the same rights from this point of view as Germany. A wording in an email from MSI seems to indicate that changing cooler, paste, pads is ok, as long as the new cooler has as good or better performance than the original, and the card is returned to its original state before RMA.
Count von Schwalbe
Nocturnus Moderatus
3,284 (2.78/day)
Knoxville, TN, USA
Ah. Acetone should fix that - it dissolves super glue.
212 (0.06/day)
ID_SUB
System Name Asus X450JB
Processor Intel Core i7-4720HQ
Motherboard Asus
Memory 2x 4GiB
Video Card(s) nVidia GT940M
Storage 2x 1TB
Check first if acetone will dissolve or weaken the inductor molding itself before applying (It's more of a problem with the adjacent inductor since they're rarely alone). It's rare but not unheard of.
ad1
31 (0.04/day)
I don't think acetone is practical. Sure, it probably works if you want to remove a specific choke that you've glued down, but the idea is to be able to send in the card in an unmodified state, not to buy a professional solder station and start removing components myself :) Plus, I'm sure there would be marks left behind, or perhaps damage to the board or nearby components. That's why I was looking for solutions which are more temporary.
Scouring the internet, I wasn't able to come up with any real alternative, so I'll probably go down the superglue route if enough people confirm that it works for 4090 whine.
166 (0.03/day)
Case CM centurion 5
I think it’s pretty mixed. Lex obviously has the best track record with his cards but most have reported no change in noise with 4090. I think at the end of the day it’s just about having peace of mind that u tried everything you could. I’m going to do it once I rebuild with my 13900ks and direct die kit from ek which has been delayed for shipping. I was waiting for more reviews but i realized I’d never be satisfied till I try myself. Statistically, it’s not been a very high success rate with 4090 but it’s a manual process and the sample size is not large. I think RMA is overrated personally. If u have a 4090 right now you’re probably in the camp to buy the 5090 that will almost certainly come in 2024/2025. Very few failures of 4090s outside of the connector burnout issue, so you’re worrying about a process you’ll be very unlikely to have to go through
5,290 (3.73/day)
Colorado, U.S.A.
I would be concerned about invalidating the warrantee
