How to quickly & easily fix coil-whine(coil choke noise)
GraveUypo
4 (0.00/day)
I did it. Twice. It categorically did not work for me :(
disappointed. time to shove the case behind the desk again to muffle the noise and learn to live with that.
Dj0ntist
4 (0.00/day)
What card did you try it on? Didn't really do anything for my 4090 strix either.
30,289 (7.04/day)
So I tried gluing also the SAP caps from my 4090 strix, still didn't really do anything. Don't know what I could've done wrong, maybe the glue was too watery, prolly not possible tho. Or maybe I'm just noticing it more since its water cooled now lol. Oh well, maybe the 5090 will be quieter.
Sorry it didn't work for you. Maybe it's something else in your system, like the PSU.
GraveUypo
4 (0.00/day)
Got a post-op photo for us?
sorry, i don't. didn't even think of that at the time.
it might have partially worked. i couldn't tell where it was coming from before, but now it's CLEARLY from the two coils near the power plugs. maybe all the other were also noisy, making it harder to pinpoint the sound, and this fixed them, but not the loudest two. in fact it seems to be even louder than before. idk for sure, i didn't bother to measure anything. i'm just glad my card still works.
i might try again at a later date. maybe burrow those two coils in something else other than glue, like thermal paste or something.
166 (0.03/day)
Processor E6750 @ 2.66ghz (3.7 in a few weeks)
Motherboard gigabyte p35 ds3L
Cooling thermalright ultra 120 extreme
Memory kingston 2gb kit (crucial ballistix 2x1gb in a few weeks)
Video Card(s) palit gtx 260 sonic 216sp 55nm
Storage 3 x 1.5tb seagate
Display(s) philips 24" IPS pw9eb (1920x1200)
Case CM centurion 5
Power Supply seasonic-x 650w
Software windows 7 32bit
Did u do all the chokes? In the photo Lex posted a few posts back sir?
630 (0.15/day)
Processor Ryzen 9 3900x
Memory 32GB GSkill Ripjaws V 3600CL16
Video Card(s) 3060Ti FE 0.9v
Storage Samsung 970 EVO 1TB, 2x Samsung 840 EVO 1TB
Display(s) ASUS ProArt PA278QV
Case be quiet! Pure Base 500
Audio Device(s) Edifier R1850DB
Power Supply Super Flower Leadex III 650W
Mouse A4Tech X-748K
Keyboard Logitech K300
Software Win 10 Pro 64bit
My old Strix 970 and Strix 1070Ti had some coil whine. Best way to get rid of it was to just limit FPS to monitor's refresh rate.
166 (0.03/day)
Case CM centurion 5
My old Strix 970 and Strix 1070Ti had some coil whine. Bet way to get rid of it was to just limit FPS to monitor's refresh rate.
sadly that's insufficient given the higher FPS brackets that the current cards swim in. besides my 4090 is obnoxious even at 100fps on my 240hz monitor
Mussels
Freshwater Moderator
58,412 (7.79/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
This does not work 99.9% of the time.
It did for my all my 10 series GPU's, 200FPS limit solved the issues
Some things like unigine heavens exit screen or skyrims load screens would *scream* without it
30,289 (7.04/day)
Interesting. I've never had that kind of luck. It's always been consistent.
166 (0.03/day)
Case CM centurion 5
Watched a video that suggested that CW comes from the mosfets instead.. so far nobody’s been successful with their 4090s right?
30,289 (7.04/day)
Not sure how. MOSFETs are a sealed and encased part. I suppose it's possible, but very unlikely.
I have, twice. One Asus, one PNY. The Asus still made a little bit of noise, but the owner was happy with it as is was dramatically less noisy and the fans in her system drowned it out what little remained. The PNY was completely silent after.
381 (0.46/day)
Processor AMD Ryzen 7 7800X3D (4.2Ghz base, 5.0Ghz boost, -30 PBO offset)
Video Card(s) PowerColor Radeon RX 7900 XTX Red Devil OC 24GB (2.39Ghz base, 2.99Ghz boost, -30 core offset)
Mouse Logitech G502 X LIGHTSPEED Wireless Gaming Mouse
Keyboard Keychron K4 Wireless Mechanical Keyboard
Software Arch Linux
Electronics and hardware layman here with a question: does gluing the choke coils have the potential to make them heat up more than factory recommended? Does it have an insulating effect or not really?
I don't have an issue with coil whine, this is just wanting to learn more.
Count von Schwalbe
Nocturnus Moderatus
3,430 (2.75/day)
Knoxville, TN, USA
A choke should not produce heat of any significance - no more than a transformer. They work by absorbing higher voltage as magnetic "charge" and releasing it as the voltage drops. A properly designed choke loses very little of this as heat, especially as the smaller ones cannot form the (wasteful) eddy currents of a larger one.
381 (0.46/day)
Software Arch Linux
Great, thank you. I'll keep this idea in mind if my PowerColor ever starts whining. So far so good.
Count von Schwalbe
Nocturnus Moderatus
3,430 (2.75/day)
Knoxville, TN, USA
The choke's magnetism pulling it slightly one direction then releasing it as the voltage fluctuates is what causes the vibration, which is at extremely high frequency due to the voltage ripple from a power supply.
If you needed more explanation.
1,886 (0.73/day)
Arizona
System Name Space Heater MKIV
Processor AMD Ryzen 7 5800X
Case Phanteks Enthoo Pro M
Mouse Logitech MX Master 3
Keyboard Glorious GMMK 2 96%
I'll second that limiting framerate has helped me. As Mussels said, the end screens on Unigine Heaven and Valley always jump to like 5000 FPS and cause GPUs to literally scream.
I've noticed that underclocking my GPU (PowerColor RX 6800 XT) helps significantly. The coil whine at 2150MHz vs 2500MHz is night and day. It's probably related to power consumption, which drops from 230-270W to 190-200W under load.
Still, maybe I should try the superglue trick at some point.
166 (0.03/day)
Case CM centurion 5
Hi lex
Hi, may I know which ASUS 4090 you did it on? Tuf or strix? I’m preparing to do this when I fly back home… bit nervous tbh. You did it for all the parts in the yellow and red box drawings in the previous photos or were u selective?
30,289 (7.04/day)
Fair enough. I'm not calling either of you liars or anything similar, just saying I've never seen it in modern cards. Old cards, like pre-GeforceFX, it happened. Just haven't seen(heard) it since.
Strix version.
I did the whole card to be safe. I usually do.
166 (0.03/day)
Case CM centurion 5
Strix version.
Could you link the exact glue you used please?
166 (0.03/day)
Case CM centurion 5
Not really. I bought a 3pack of generic superglue last time. The brand really doesn't matter. It's the type. Make sure it's liquid, not gel.
got it thank you
Mussels
58,412 (7.79/day)
Oystralia
Strix version.
Give it a shot - heavens a super small download, and you just need to run it and quit it
That final screen is literally how i test GPU's for coil whine, just make sure you have no frame rate limiters on
