- Jul 5, 2013
- 30,222 (7.03/day)
True! Doesn't happen very often, but it is possible. Believe it or not, super-glue can solve that problem as well and for the exact same reason. Transformer windings can vibrate in the same way and for very similar reasons to choke coils.HOWEVER, if the noise is coming from the power supply, it could be loose transformer plates buzzing.
That one is new to me. I'll have to read up on it. Maybe this is why some caps get glued down with silicone? I've always wondered about that.Or perhaps capacitors singing.
Not the same thing, even if it might have a similar sound. What you're hearing is the motor actuation, or motor spin if you wish. Different kind of vibration resonance.Could the Arctic Freezer III, that, compared to II i'd call verry noisy, have coil whine ?.. or is it by design ?
The New Best: Arctic Liquid Freezer III 360 & 280 CPU Cooler Review & Benchmarks | GamersNexus
Coolers The New Best: Arctic Liquid Freezer III 360 & 280 CPU Cooler Review & Benchmarks February 26, 2024 Last Updated: 2024-02-26 We put the Arctic Liquid Freezer III through a gauntlet of 100% fan speed, VRM thermal, pressure scan, and laser scan tests. The Highlights The Liquid Freezer III...gamersnexus.net
