How to quickly & easily fix coil-whine(coil choke noise)
5,330 (3.72/day)
Colorado, U.S.A.
Software Windows 11 Home
7,762 (2.72/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
It's probably possible to find something suitable like that - if anything, my guess would be that a low viscosity epoxy is exactly what they use to pot the inductor inside the casing. The problem is finding one that has the desired dampening characteristics, the required temperature tolerance, and has minimal shrinkage when curing so that there are no voids left afterwards. The one you linked, while obviously just an example, is rated for up to 145°C, but has its glass transition temperature at just 54°C, so you could risk it seeping out of the inductor under normal operating temperatures given sufficient time. My guess would be that the materials they're actually using is about as close as you can get to an optimal combination of traits without excessive costs, cure times/temperatures, environmental issues, or other problems.
5,330 (3.72/day)
Colorado, U.S.A.
If coil whine is disturbing to humans, I can hardly imagine how annoying it is to cats and dogs.
7,762 (2.72/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
And they probably hear a lot of it that we don't!
Me: Ah, blissful silence!
Neighbor's dog in the apartment below:
deepblade
4 (0.00/day)
Does anybody tried this method on ASUS GPUs? Their circuit boards have very specific inductors and there is no gap to apply the glue.
7,762 (2.72/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
Those look like perfectly ordinary SMD inductors to me (save for the silkscreened branding). The gap in question is the slight line between the inductor and the PCB, nothing more. That's why you need a low viscosity liquid to seep in through capillary action, as there isn't so much an opening as there are two hard objects imperfectly resting against each other, with the slight gaps that brings with it.
5,330 (3.72/day)
Colorado, U.S.A.
I would first try some toothpicks below the inductors, if that does not reduce the whine it is probably not going to help gluing them down.
29,242 (6.88/day)
Sure there is. The photo you posted shows a small gap very clearly. That's a enough space for high-pitched sound to emanate from. Seal that space up with SuperGlue and the sound either goes away or it is greatly diminished.
5,330 (3.72/day)
Colorado, U.S.A.
Concern
I had a clock that made a little noise, no big deal, but then I hung it on the wall which acted like a speaker and the noise became annoying; I wonder if the same thing might happen here.
29,242 (6.88/day)
Concern
Unfortunately, that's a different mechanism entirely. The solution would likely be easy, rubber pads on the back of the clock to prevent vibrations being transmitted into the wall panel.
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
5,330 (3.72/day)
Colorado, U.S.A.
*Sploosh* on all sides and hope for the best
Or should one leave one side open to try an avoid trapping air? When I apply flux for reflowing, I try to avoid blocking all sides for this reason.
Why need to put varnish on coils? | Custom Magnetic coils_Antenna Coils_Wireless Charging Colis_Electronic Coils Manufacturer (jhcoils.com)
vacuum pressure impregnation is one way to avoid air blockage
I am concerned that with things inside the box it may be hard to dampen winding vibrations
29,242 (6.88/day)
No. If you leave any area unsealed, the noise will have an avenue of escape. Seal it thoroughly on all sides and be done.
I'm curious. Why would you reflow a choke coil? That makes no sense what-so-ever...
You don't need to avoid air blockage. Choke coils are not like IC's, they don't need cooling because they generate very little(read almost none) heat.
Don't be concerned. Seal the air gaps, enjoy!
5,330 (3.72/day)
Colorado, U.S.A.
I meant apply from 3 sides till one sees it come out the 4th
Fluxing a chip, but not wanting any trapped air
I was thinking of this application where the box bottom may be flat.
I wonder how it all works out; I'm here to learn for I can see myself having to deal with this issue.
5,330 (3.72/day)
Colorado, U.S.A.
I very much appreciate you bring up topics like coil whine; it's a big deal in my opinion. We may quibble about which varnish to use or whether air bubbles are of consequence, but it's all good stuff.
Actually, I had a power strip with inbuilt USB power, but trashed it due to the whine when not under load.
5,330 (3.72/day)
Colorado, U.S.A.
I made a mess trying to open it; the glue joints were internal (that is what I meant by, I trashed it).
270 (0.28/day)
USA
Processor i9-11900K
Memory 4x8GB DDR4
Display(s) LG 27GN950-B
Power Supply Corsair RM1000x
Keyboard HyperX Alloy Elite 2
Mussels
58,412 (7.85/day)
Oystralia
Oh yeah, USB chargers are prone to this too
The problem is that opening most of them breaks the casing permanently, making it a hard repair to justify most of the time
deepblade
4 (0.00/day)
Reporting back.
Patient: Asus GeForce RTX 3070 ROG STRIX OC
Before: whining like hell
After: whining, but less
Conclusion: operation was partially successful, the coil whine is now more pleasant to ears, but it's still present
