- Oct 9, 2007
- 47,499 (7.49/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Intel is expanding its 13th Gen Core "Raptor Lake" desktop processor family with a number of new SKUs, led by the new flagship Core i9-13900KS. A leaked company slide confirmed the upper-end SKUs' specs. Led from the top, the new i9-13900KS packs the same 8P+16E (8 performance cores + 16 efficiency cores) configuration as the i9-13900K. It has a slightly higher 3.20 GHz base frequency compared to the 3.00 GHz of the i9-13900K, but boosts all the way up to 6.00 GHz, compared to 5.80 GHz of the i9-13900K. To ensure improved boost frequency residency, Intel bumped up the processor base power value from 125 W to 150 W, while leaving the maximum turbo power value untouched at 253 W.
We also see the specs of the non-K Core i9-13900 and Core i7-13700, which offer the same 8P+16E and 8P+8E core-configs as the i9-13900K and i9-13700K, respectively, but without unlocked multipliers. The i9-13900 ticks at 2.00 GHz with 5.60 GHz maximum turbo frequency, whereas the i7-13700 does 2.10 GHz base, with up to 5.20 GHz boost, compared to 3.40 GHz base and 5.40 GHz boost of the i7-13700K. As "locked" chips both have lower processor base power values of just 65 W, and maximum turbo power values of 219 W. Both these chips could include a cooling solution in the box, which is very likely the Laminar RH1 stock cooler that company includes with the i9-12900 and i9-12700. Intel is expected to announce these chips alongside a large number of 13th Gen Core i5 SKUs on January 3.
![](https://www.techpowerup.com/img/HOzaUgFPj6uDzWRu_thm.jpg)
