Intel Marketing Claims i5-9600KF Better than 3800X, i3-9350KF Better than 3600X
943 (0.41/day)
I think there is too much favourism going to AMD way here. Yea they were the underdogs and Intel milked us all. Bit times changed and no more AMD is the underdog. People should adjust their views accordingly now. I for one do not give a thought for the company. I care about my hard earned dollars.who gives me best performance for the games I play with minimal initial and running cost gets my money.
455 (0.10/day)
Existence
System Name Workstation
Processor Ryzen 9 5950x
Motherboard Msi B550-A pro
Cooling D5 Pump + 250ml res + 2 x 360mm rad + Ek cpu bloc + 6 x 120mm Artic P fans
Memory 64 GB DDR4 3200Mhz
Video Card(s) Amd Radeon pro W7700
Storage WD SN 850X 2 TB m2 + Seagate Exos 4 tb + WD 2tb Gold
Display(s) LG UltraGear 32GP850-B
Case Lian Li 011 DX
Audio Device(s) Hifiman Arya + Fiio Q15
Power Supply Seasonic 1050W Snow Edition
Mouse Razer Basilisk V3 X Hyperspeed
Keyboard Gskill Ripjaws KM 780 MX
Software W 11 pro 64
Benchmark Scores It works.
4. that Intel processors have "smooth and stable drivers" compared to AMD.
From my personal experience my 1800x has been stable since I've updated the drives and has more performance now than when I bought it back in 2017.
245 (0.10/day)
Intel = laughing stock bash in 3.2.1...
For some substance on this topic...
Its quite an interesting comparison to make and actually, Intel isn't entirely wrong here. In games where the thread count matters (Kingdom Come Deliverance is a good example) Ryzen easily gets 25-30% higher FPS peaks. Yet in for example AC you see the 9350K consistently on top (and not just a little bit!), and taken from all games, there are a few more examples where the Intel option is still leading. Pretty interesting.
But, kids, don't buy quad cores no more k?
Different setting? As you can see the left side has some kind of fog...
4,378 (0.66/day)
Hurst, Texas
System Name The86
Processor Ryzen 5 3600
Motherboard ASROCKS B450 Steel Legend
Cooling AMD Stealth
Memory 2x8gb DDR4 3200 Corsair
Storage WD Black 512gb, WD Blue 1TB
Display(s) AOC 24in
Case Raidmax Alpha Prime
Power Supply 700W Thermaltake Smart
Mouse Logitech Mx510
Keyboard Razer BlackWidow 2012
Software Windows 10 Professional
Well they are entitled to their opinion, it's wrong but they are entitled to it. This reminds me of back in the day when Athlon XP came out and beat Intel in everything except quake 3 eninge games, and Intel held onto that as proof and is worse. Same story different decade. History has repeated itself
AMD K5 = PHENOM (to late, hot and bad value)
AMD K6 = Phenom II (competed with older series quite well)
AMD K6-2 = AMD FX (good bang for buck but pushed to the limit and slower than compitior except in a few tests)
AMD K6-3 = RYZEN 1000 (performance parity forced Intel to make a move)
ATHLON = RYZEN 2000 (competes in most tasks and better bang for buck)
ATHLON XP = RYZEN 3000 (Intel only ahead in limited tests mostly games and light office work)
If the trend continues the next ryzen will be the second coming of Athlon 64.
8,661 (3.99/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
If Intel are talking about overclocking, perhaps they should be reminded about their arbitrary Z-series tax that adds $50+ to the cost of overclocking over an equivalent AMD system since decent B450 boards with excellent VRM cooling headroom are both plentiful and reasonably priced.
Also, whilst there is typically more overclocking headroom on Intel 9th gen than Zen2, you will need more expensive cooling to deal with the 200W power consumption that 5GHz requires on 14nm++. Meanwhile, the 3800X with it's decent quad-heatpipe air cooler INCLUDED FOR FREE will run that 3800X just fine, saving you $100 over the cooler necessary to handle Intel's 200W power draw.
If we're going to add $150 to the cost of overclocking an Intel 9600KF, we're fast-approaching 3900X price territory. I would like to see intel try and justify their 9600KF against a 3900X....
39 (0.01/day)
intel's own benchmarks with their "real world" angle
covered by adoredTv
adoredTv
Nothing, absolutely NOTHING should be taken for any form of seriousness coming from intel and their bought over benchmarks XPRT suites, and their idiot real-world idiocrazy (movie pun intended)
Bring in independent reviewers, with benchmarks that matter.
184 (0.07/day)
Processor AMD 5800X
Motherboard MSI X570 Tomahawk
Memory G.Skill 32GB
The only part I agree with all this is the system stability and drivers more being upto date. Which in my case is a very serious and very important factor.
Like everyone else, I haven't had any "stability" or "driver" issues with my 3700X. I suppose the only real "problem" was that I wasn't hitting boost clocks (just barely), but that was fixed with 1.0.0.4B anyway.
In any case, it'll be interesting to see how well those Intel chips age. CPUs aren't GPUs, and I think many of us hold onto them a lot longer (had my 3770K for 6 years but I've swapped GPUs 3 times in that span). If this is anything to go by, time won't be kind as games change:
Deleted member 178884
And everything should be taken seriously from AdoredTV? You linked a well known leaker than spills nothing but BS.
freeagent
9,521 (4.09/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
200w isn’t hard to deal with if you already have the cooling for it. Noctua isn’t the only game in town, no need to spend 100 bucks. Why would you take a top shelf cpu like the 3800X and then put it on a B450? A cut down stripped down chipset. Makes no sense.
As for drivers, AMD has a history with that, so because you have no problem with system drivers, doesn’t mean others don’t or haven’t. Since moving back to intel years ago, it has been smooth sailing for me on that front.
And then there is price. For a top end AMD cpu, and a good 570 board for it, you aren’t that far off from an upper end mainstream Intel system.
After Christmas I will be building new, and to be honest I could go either way. But I do know there is more to life than cinibench.
184 (0.07/day)
Processor AMD 5800X
Memory G.Skill 32GB
Because the vast majority of people don't need the features of X570? I have a 3700X paired with a B450 board and I'm not missing anything.
39 (0.01/day)
I would say the same if AMD showed some nice figures.
NOTHING absolutely nothing should be taken as fact from any company promoting their own products (directly or indirectly through bought companies).
Bring in the independent reviewers and independent benchmarks.
b.t.w. adored was right on a ton of stuff, so to call out his stuff as BS, well I think is shortsighted.
  • Like
Reactions: HTC
Why would you buy a value-orientated part to stick it in a high end board? Makes no sense.
8,661 (3.99/day)
Case Veddha T2
Mouse MX Anywhere 2
Makes perfect sense for the exact people Intel's marketing team is targeting in this article - gamers and light content creators. Those people have ZERO need for PCIe 4.0 or the extra PCIe lanes of an X570 motherboard. All they need, in fact, are decent VRMs to handle PBO+ power draw, which is still under 150W even with a 3900X and a high-end X570 board. On a 3800X it's likely to need barely 125W.
Honestly, look at the feature set of B450 and tell me what X570 feature it is lacking that a gamer or light content-creator would give a damn about?
freeagent
9,521 (4.09/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
8,661 (3.99/day)
Case Veddha T2
Mouse MX Anywhere 2
What are you talking about?
This article is specifically about stripped down, value-oriented parts - the i5-9600KF and the i3-9350KF.
There's very little point spending big money on a flagship z-series board if you're going to dump a cheapo i3 or i5 into it unless you're saving for an upgrade later (which is a dumb plan on Intel platforms as they abandon sockets almost every time they release a new generation rebrand their 14nm products)
943 (0.41/day)
I won't buy a new cpu right now but if I did as an ITX user. I would get an i5 9600kf for 185 plus Asus rog z390i strix for 200. Add a 50 usd cooler and I can hit all cores 4.7 ghz with lower voltages even in stock voltages.
435 usd total.
Ryzen5 3600x costs 225 plus Asus rog x570i strix 250. Nevermind a cpu cooler thathis 475 usd total. 4.4 ghz all cores? No way? Overclock 4.2? Probably but very high power draw and heat. Plus million of issues with super slow boot times and at least 500 mhz slower system with more price in total, more heat and more power draw and probably more noise cpu cooler.... if you need the threads I do not debate it Ryzen5 is good but for gaming no way not even close to Intel.even Steve from GamersNexus said stop treating AMD as underdogs and do not let them get away with false advertisings....
Cheeseball
Not a Potato
2,143 (0.36/day)
Pittsburgh, PA
System Name Titan
Storage Crucial T500 2TB x 3
Power Supply Corsair SF1000
VR HMD Meta Quest 3 512GB
You can get Ryzen 5 3600 for $189.00 off US Amazon at the moment. Grab a good Zen 2-ready B450 mATX motherboard (that has a ready AGESA 1.0.0.4AB BIOS) for $89.99 and you should be able to hit boost clocks well enough.
The only problem (and this is not AMD's issue) is that there aren't any good mATX X570 boards. Please don't suggest ASRock's X570M Pro4 as the latest BIOS is trash, so much that I had to return it once because thought the board was defective and then find out it really is the BIOS with the second.
2,187 (0.50/day)
Deez Nutz, bozo!
typical of Intel... still beating their old & tired race horse & expecting to win against AMD's well-treated, matured, do it all horse.
That said, R5 3600 + updated B450 with good VRM design is still a good deal for anyone. You don't really need an X570 unless you're planning on getting a R9 3950X. Those pair are better off that way.
freeagent
9,521 (4.09/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Well that makes sense. Blond moment for me. I did actually consider a 9400f and small matx mobo with Wi-Fi. because it would mop the floor with my current 3770K. I almost pulled the trigger a couple of times, but I'm not ready to say good bye to overclocking just yet. I almost pulled the trigger a few times on a Ryzen setup too, both second and third gen. Again, not ready to give up on overclocking just yet.. and honestly their pins really grind my gears. If you have ever folded a row of pins then you know what I'm talking about. Whoever comes up with a chip that can oc next wins my money lol. And I don't mean all core boost speed.. I mean real overclocking. But it seems that is becoming a thing of the past too. Where I live it gets cold for a good chunk of the year, it would be a shame to let those cool ambients and my many CFM's go to waste.
4,378 (0.66/day)
Hurst, Texas
System Name The86
Cooling AMD Stealth
Display(s) AOC 24in
435 usd total.
Ryzen 5 3500x 118 USD at alli express
You where saying?
2,047 (0.37/day)
Republic of Texas
Processor R9 5950x
Motherboard Asus x570 Crosshair VIII Formula
Cooling EK 360mm AIO D-RGB
Memory G.Skill Trident Z Neo 2x16gb (CL16@3800MHz)
Video Card(s) PNY GeForce RTX 3090 24GB
Storage Samsung 970 EVO Plus 1TB NVMe | Intel 660p 2TB NVMe
Display(s) Acer Predator XB323QK 4K 144Hz
Case Corsair 5000D Airflow
Audio Device(s) Objective2 Amp/DAC | GoXLR | AKG K612PRO | Beyerdynamic DT880| Rode Pod Mic
Power Supply Corsair AX 850w
Mouse Razer DeathAdder Elite V2
Keyboard Corsair K95 Platinum RGB "Cherry MX Brown"
VR HMD Oculus Rift
Software Window 11 Pro
Tell me again who has majority CPU market share?
2,355 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Everyone is being mad at Intel's marketing for telling lies to people,
But when my head and shoulders shampoo claims to vanish almost all dandruff and fails, nobody comes to my rescue.
Ofc no one is coming to your rescue, there are like 100 other brands of shampoo you could switch to. That's the top of the list of reasons to not come to the rescue behind "A bottle of shampoo is like what? 5 bucks."
47,449 (7.50/day)
If you bought that shampoo for $250/bottle and it didn't turn your locks to match a Victoria's Secret model, you should drag P&G to the Hague.
