Intel Marketing Claims i5-9600KF Better than 3800X, i3-9350KF Better than 3600X
3,152 (0.92/day)
Argentina
System Name Ciel / Akane
Keyboard VSG Alnilam / Dell
Holy cow, they are in complete denial.
551 (0.17/day)
Texas
System Name O-Clock
Processor Intel Core i9-9900K @ 52x/49x 8c8t
Motherboard ASUS Maximus XI Gene
Cooling EK Quantum Velocity C+A, EK Quantum Vector C+A, CE 280, Monsta 280, GTS 280 all w/ A14 IP67
Memory 2x16GB G.Skill TridentZ @3900 MHz CL16
Video Card(s) EVGA RTX 2080 Ti XC Black
Storage Samsung 983 ZET 960GB, 2x WD SN850X 4TB
Display(s) Asus VG259QM
Case Corsair 900D
Audio Device(s) beyerdynamic DT 990 600Ω, Asus SupremeFX Hi-Fi 5.25", Elgato Wave 3
Power Supply EVGA 1600 T2 w/ A14 IP67
Mouse Logitech G403 Wireless (PMW3366)
Keyboard Monsgeek M5W w/ Cherry MX Silent Black RGBs
Benchmark Scores https://hwbot.org/search/submissions/permalink?userId=92615&cpuId=5773
Intel is now bringing the most bullshit reasons ever to sell their CPUs. When Intel's CPUs are OVERCLOCKED, then yes it is believable, but um, under stock performance, the 9600K has rather low clocks. Under gaming? The CPU will (hopefully) be used to 100% to maximize performance, and has a frequency of 4.3 GHz all core. If Ryzen 3000 has more IPC, then actually, the 3800X is expected to beat the 9600K. Oh by the way you don't need an expensive motherboard to tune the Ryzen CPU past stock performance, where it is the case with the Intel CPU. And you do not need to purchase a cooler, you can run the CPU on the stock cooler, where you need a cooler with the K CPU. Basically, the 3800X is on par with the 9600K for gaming, and actually the 9600K will be garbage for EVERYTHING ELSE compared to the 3800X. Yes, 16 threads vs 6 makes quite a difference for almost everything else. Oh I forgot to use my big brain, the 3800X takes less poer than the 9600K, and the 9600K has a turbo TDP of 131W. 3800X is 105W. Yea. Big Brain Intel uses more power for less than half the threads. Sad.
I want Intel to grow the balls to show their CPU's actual power consumption when running past their base clocks. I want them to show how much power they are rated to take. I know how much power they are rated to take at turbo clocks. Intel isn't going to fool me. Two hundred ten watts for a fucking 8 core CPU (131W for the 9600K which is the normal CPU, which people usually buy), when AMD's 8 core 3800X is rated for half.
16 (0.01/day)
Tasmania
Processor Ryzen 2400GE
Motherboard MSI B450I Gaming Plus AC
Cooling Noctua NH-L9a-AM4
Memory Corsair Vengeance LPX 16GB 3000MHz CL15 DDR4, clocked to 3200
Storage ADATA XPG SX8200 Pro NVMe 1TB, Drive tank with 18TB of assorted drives for media etc
Display(s) Philips BDM3270
Case Jonsbo UMX3 black
Power Supply Seasonic SS-250SUB
Mouse Logitech M585
Keyboard MSI Vigor GK50
Software Everything imaginable except games
Stability and drivers? I got Ryzen 2700x and I haven't noticed any driver issues or stability issues since day one. This is marketing scheme again and totally not justified claim.
Yes, same here with my 2400GE/B450i system, rock solid, no issues, and I run a shitload of different software on here including Adobe CS, but no games though...
Intel is definitely on a downward slide, they can't even make 10nm work properly and AMD is on 7nm and heading towards 5nm (TSMC is getting over 50% good chips on their 5nm trials), why anyone would buy Intel at this stage, given the higher prices, the higher power consumption and the vast number of inbuilt security flaws (many times more than AMD CPUs) is just hard to fathom.
2,715 (0.57/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
I am not going to let Intel tell me which processor opens my porn tabs up faster. I will experience that on my own, brb, going to test some stuff out.
I won't buy a new cpu right now but if I did as an ITX user. I would get an i5 9600kf for 185 plus Asus rog z390i strix for 200. Add a 50 usd cooler and I can hit all cores 4.7 ghz with lower voltages even in stock voltages.
435 usd total.
Ryzen5 3600x costs 225 plus Asus rog x570i strix 250. Nevermind a cpu cooler thathis 475 usd total. 4.4 ghz all cores? No way? Overclock 4.2? Probably but very high power draw and heat. Plus million of issues with super slow boot times and at least 500 mhz slower system with more price in total, more heat and more power draw and probably more noise cpu cooler.... if you need the threads I do not debate it Ryzen5 is good but for gaming no way not even close to Intel.even Steve from GamersNexus said stop treating AMD as underdogs and do not let them get away with false advertisings....
The booting is handled by the SSD or hard drive.
3,794 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 85C temp limit, CO -8~14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
Do your selfs the favor and watch the whole thing please...
5,458 (0.88/day)
Australia
intel did the same thing with the P4 and look how many people fell for it lol this is no different .
2,190 (0.50/day)
Deez Nutz, bozo!
that said, if your use case is all about gaming, the i5-9400F or 9600KF would do just fine. For a balanced build, R5 3600 or R7 3700X is perfect for less money, more PCIe lanes & no need to worry about AVX adjusted all-core boosts or hardware mitigation tanking the chip's performance.
8,703 (3.99/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
It's called marketing spin. They know their product is riddled with vulnerabilities, running on old architecture and an old manufacturing node that can't compete any more.
Everyone here knows that Skylake++++ is hopeless in 2020, and 2019 belongs to AMD. Intel just have to look like they're doing something to keep the investors and shareholders happy.
The problem with marketing spin is that for everyone one of us enthusiasts that follow this stuff and can see right through Intel's BS, there are five other people who will fall for this ****; Hook, line, and sinker. They lie because the average or median person is a gullible fool and lies work on them.
53 (0.02/day)
This must be where Intel$ $3bn in reserved funding is going, propogandizing their "performance leadership" Lolz.
23,179 (6.10/day)
If you check the description of that video, the AMD's at stock speeds, while the Intel's running at 5GHz all-core. Not all that useful a comparison if we're going to be OCing one but not the other
Well, Ryzen's XFR does most of the work, so I'd say its a pretty decent comparison and there is absolutely no way in hell the gap is just from OC. May get more pronounced, but then who buys K CPUs not to OC them?
Bottom line, overclocking on Intel is so easy, its a given, just be fair enough to count the added cost of cooling and perhaps board in your comparison when buying.
So the comparison I think is pretty damn useful, because it shows both systems at or near the top of their game.
wat? next time check your source..
Indeed, you should have longer look, because your video contains a 2nd Gen Ryzen, but ok. The first video in your link shows this, 3rd rig being the Ryzen. The gap is visible in most of that sequence in the game.
Second game, big win for Ryzen, clearly loves cores (the i5 is also lagging by >10%)
It kinda goes on like that, doesn't it. When quad is enough, the 9350K leads, and by some noticeable margins too. When its not enough, Ryzen edges past, and sometimes even destroys it. Your PurePC link shows no 9350K... and the TPU link has no OC on the 9350K, while F version of it is on the very bottom.
And when I look onward in the video, the comparison is almost the same as the one I linked.
TL DR: nothing new to see here, is there?
Different setting? As you can see the left side has some kind of fog...
Who knows, I didn't make the video. But like pointed out above... this isn't rocket science guys. There is no reason to question those numbers in the greater scheme of it and they confirm everything we know about Intel, AMD, CPUs and gaming.
But, since its apparently hard to grasp, here's the summary
- Intel still wins on clockspeed, and still leads in games where clocks matter more than cores.
- AMD seems to get similar performance with lower clocks, hinting at higher IPC in some situations
- AMD cannot seem to extract high maximum FPS due to lower clocks and probably CCX latencies.
- Intel offers lower core counts at similar price.
- If price is no object, Intel still makes a better gaming CPU.
Its possible for competing products to... you know, compete. Its also possible to overestimate Zen's performance and come out losing. So let's not do that, and keep the info realistic. There is simply a lot to choose these days, everybody wins. The above still wouldn't mean I'd jump on an Intel CPU again today... but from the viewpoint of Intel's marketing team, they're actually not completely wrong.
xeroxide
1 (0.00/day)
So next year I plan on upgrading my 3700x to maybe a 4700x or equivalent and all I need to do is swap out my cpu.... Intel, tell me about your upgrade path options?
What's that?
New motherboard?
New ram too?
Basically a whole new PC all over again...
Why would I buy a chip which is basically end of life, when I can invest my money into technology which has an upgrade path and performs almost as well in single thread performance while dominating in multi threaded performance.
Also for all the talks that Intel claim about real world, what I know is this.
An OS which I have been running for over a year, greatly benefits from multi thread performance simply because it's no longer pristine. You have stuff running behind the scenes everywhere.... Give me multi core performance and my OS will run smoother for longer.
Both companies do shady garbage in marketing, take a look at ryzen's boost clocks for example. But for me, I can see that ryzen is the better product of the two.
Intel wants my money?
Do better Intel, cause I'm sick of marketing be and can smell it from a mile away.
2,190 (0.50/day)
Deez Nutz, bozo!
2021 will be the year Ryzen 4000 will beat Intel's rather old 14nm node 10th Gen & maybe 11th gen Core Series CPUs. I don't have any hopes for Intel to improve their products or even reduce the price.
4,480 (1.41/day)
Currently Norway
System Name Bro2
Processor Ryzen 5800X
Cooling Corsair h115i pro rgb
Case Fractal Design G
Audio Device(s) Realtec 5.1
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
2021 or 2020? The 4000 series Ryzen is going to be released next year. Besides Intel's 10th gen is already beaten price and performance wise. I think no reasonable person is expecting miracles with Intel's 11th gen CPUs. But hope for the best.
4,849 (1.49/day)
Processor Core i7-13700
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro 5600 32GB kit OCed to 6600
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply EVGA 850 BQ
Software Windows 11 Professional v24H2
Those would be consumers after the higher clock speed the K suffix has compared to the K less models (9900/9700.)
2,190 (0.50/day)
Deez Nutz, bozo!
@ratirt according to rumor mills, AMD's Ryzen 4th gen Mobile CPUs will be releasing around Spring 2020, with the desktop variant, which uses the new Zen3 architecture, will be released around Fall 2020. It also stated that the new 7nm+ Ryzen 4000 Desktop uses has about 8-15% IPC gain, lower cache latency, higher Infinity Fabric clocks & 200MHz higher clocks per core over Zen2. For the Ryzen 4000 Mobile SKUs, it will use Navi GPU cores, has ~30% gain in multi-threaded scenario over Ryzen 3000 Mobile SKUs & a rumored R9 4xxx laptop CPU to compete directly with Intel's Ice Lake mobile CPUs. Good news is the Ryzen 4th gen Desktop will still be compatible with AM4 socket boards.
4,480 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
I thought it was 2020 but maybe something changed lately. With all the gains % I will leave it until I see it :)
I'd like to see Intel's response to AMD offerings in 2020. More curious about Intel's line-up.
2,190 (0.50/day)
Deez Nutz, bozo!
@ratirt yea. I'm interested to see how Intel will respond to AMD's new lineup. Will we see 10nm Core SKUs that has ~15% IPC gain over 14nm+++++, better all-core boost, higher AVX adjusted all-core boost, better hardware mitigation with minimal impact on performance, more PCIe lanes on processor instead of relying on chipset etc? Only time will tell. 2020 will be an interesting year no matter what.
9,721 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
By the time Intel responds on the desktop it may be a little too late. If AMD can get that boost they will be faster than Intel in all applications. Hardware Unboxed did a video of the 3950X vs the 9900KS and once the RAM was OC (important for Ryzen) the 9900KS only beat the 3950X in 5 or 6 games and the 3950X was just as fast or faster than the 9900KS in another 15 games. If we get the next AM4 CPUs in 2020 with another 15% IPC watchout Intel. The test was done using a 2080TI at 1080P.
23,179 (6.10/day)
Ah yes, all five of them :D
Come on now. If you're after higher clocks, you're going to eventually figure out how to get them.
2,190 (0.50/day)
Deez Nutz, bozo!
@kapone32 well, it's an apparent thing right now in terms of workloads, for AMD Ryzen 3rd gen, that is. On a value standpoint, it's very obvious that AMD is the sweeter deal right now over Intel's entire Core i5 9th gen SKU, on top of beating nearly all of them.
4,480 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
I still see that the IPC is strictly combined with games and frames as an indication of a CPU performance for some unknown reason. It would appear that there's nothing else aside games to look at CPU's performance and evaluation. This is probably the Intel's "real world benchmark" treatment.
9,721 (3.46/day)
Cooling In Win SR36
Agreed, the only thing Intel is better overall is the value for new HEDT. They stupidly still have the last gen of Cascade Lake overpriced but the Cascade_X CPUs are well priced but the 2nd Gen TR4 chips compete with those for price and performance but give you more PCI_E goodness. Having said that it is my opinion that AMD has everything covered from $89 (R5 2400G) to $2000 (3970X) so unless you specifically want Intel there is no objective reason to build an Intel based desktop.
Well since they cannot compete on anything other than Gaming it makes sense that they would focus on that. I have a I7 on my work computer and the 1700 would run circles around that chip in Office based applications. Intel cannot even promote Premiere as AMD is now faster in that application as well.
4,480 (1.41/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
Maybe these CPUs can't but it doesn't mean you have to cross this benchmarks out and focus on gaming only. You've mentioned competing in desktops and this is not gaming.
Anyway I know what you are saying. Pretty sad times for Intel these days.
2,190 (0.50/day)
Deez Nutz, bozo!
As much as I hate to see Intel doing crummy things, AMD will be their savior for them, bringing some common sense back into the blue camp, ramp up competition & whatnot. If Intel execs aren't responding to AMD's fierce marketing strategy, it'll be game over for them. The entire low-end to mid-end market is taken over by AMD. Soon to be taken up will be the mid-high, high-end & HEDTs.
