Low random writes Samsung 990 Pro
VuRKaN
2 (0.00/day)
990 pro with heatsink. r5 5600 cpu, b550 motherboad, windows not installed. (english very bad sory) and random read cpu use %100
18 (0.00/day)
This problem is NOT just for the 4TB drives and it even shows on an older PCIe Gen3 system! Latest 4B2QJXD7 firmware with full performance mode enabled as well. These drivers are utter garbage!! Regret my purchase now. Samsung NEVER again!! My guess is they had to do something to the write algorithm to band aid the previous write amplification issue in earlier firmware.
83 (0.11/day)
Processor AMD Ryzen 9 5950X (4900 Mhz)
Cooling Corsair H150i PRO RGB
Memory Corsair Dominator Platinum RGB 64 GB DDR4 3600 Mhz
Video Card(s) nVidia GeForce RTX 4080 Founders Edition
Storage Samsung 990 PRO NVMe SSD 4000 GB (OS) / Samsung 860 EVO SSD 2000 GB / Samsung 860 EVO SSD 4000 GB
Display(s) Samsung 46" TV
Case Phanteks Enthoo Luxe (Black)
Audio Device(s) Creative Sound Blaster AE-7
Power Supply Corsair AX1500i (1500W)
Mouse Logitech MX518 Legendary 16000 DPI
Keyboard Logitech G910 Orion Spectrum RGB
You are not going to get the full advertised speed of the 980/990 PRO on a system with only PCIe Gen 3.0 on it.
You would be limited to around 3500 MB/s Reads/Writes (since that is the maximum speed of PCIe Gen 3.0).
890 (1.16/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 7 9800X3D
Motherboard ASUS ROG Crosshair X870E Extreme Gaming Wifi
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5 6000Mhz CL30
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium, RM850X (2024)
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB Platinum Cherry MX
Software W10-11 Enterprise- Linux Mint 22.1 Cinnamon Edition.
This is what you can expect from a 990PRO at PCIe 4.0. I could not call this exactly garbage...
86 (0.20/day)
Cooling Thermalright Peerless Assasin 120
Memory 32GB at 6000/30
Video Card(s) 7900 XT soon to be replaced by 4080 Super
Storage WD Black SN850X 4TB
Display(s) 1440p 360 Hz IPS + 34" Ultrawide 3440x1440 165 Hz IPS ... Hopefully going OLED this year
990 Pro garbage? Nah it is literally in the top 3 fastest PCIe 4.0 SSDs, probably the overall best drive for most people. Tested the 2GB model and it was slightly faster than my 4TB SN850X in most stuff. Both are great drives tho.
18,584 (2.65/day)
System Name AlderLake
So you buy SSD's purely for benchmarking huh?.....
9,340 (5.04/day)
Louisiana
Keyboard G710+x3
Weird drop in writes and read speeds are still looking okay
What amount of data have you added ?
For others here checking read/ write speeds every month or two is hardly buying for benchmarks lol
If y'all can't see the history dates get glasses please.
Writes dropping like this is hardly normal and frankly I wouldn't be all that thrilled either pci-e 3 or not.
83 (0.11/day)
That's a really good point, most SSD's will drop in speed as they get filled with data.
Most SSD's I've seen won't even get the advertised speed anymore, once they are filled past 25% full.
I'm not sure why it's like that, but it's certainly a huge drawback with SSD's.
9,340 (5.04/day)
Louisiana
Keyboard G710+x3
Most SSD's I've seen won't get the advertised speed anymore, once they are filled past 25% full.
Indeed notice the other member testing a empty partition.
I can test my os 970 evo+ and get better write results than the 990 the member with issue and mine is obviously old so I agree something is fishy with these terrible write speeds from a top of the line 990 pro.
Matter of fact I did post it the other day
890 (1.16/day)
Belgium
AFAIK, because SSDs can only write to and store data to an empty block, and if the block is not open, solid-state drives need to delete the data marked as deleted and then fill it with new data.
If the SSD is too full, its read and write speed and lifespan will be affected and will decrease to varying degrees. I think it's an disadvantage we have to live with...
4,021 (0.60/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
Might find more to compare to here
215 (0.07/day)
People here do not want to hear that there is an issue with these drives. When there is 800k random write iops on a 1,550,000 iops rated drive....that is NOT normal. But everyone here is like nah no big deal.
Good luck. Maybe a firmware update in the future will fix this. As of now nothing we can do.
AsRock
TPU addict
19,212 (2.97/day)
UK\USA
Cooling D15
EDIT: 980 pro is Gen 3, so even if he had Gen4 or 5 it would not be better.
How ever i have not noticed any slow down on my 990 pro's or 980 pro.
9,340 (5.04/day)
Louisiana
Keyboard G710+x3
So is a 980 pro ?.
Yes.
Problem is they weren't even getting that on the 990 pro
Pro versions read/ write are really close to each other
After a while they turn into evo's write speed lol
AsRock
TPU addict
19,212 (2.97/day)
UK\USA
Cooling D15
Yes.
Could be many things wrong as, wrong m.2 slot, bad bios setting and could be a bad drive or a compatibility issue. Who knows with lack of so many details.
18 (0.00/day)
I know this! did you look at all at my screenshot?
no, but I want an SSD that doesn't halve the writes in 2 months! I'm willing to bet Samsung disabled or greatly reduced garbage collection to reduce the write error from early firmware. Use a band-aid to fix one problem to create another.. are their engineers inept?!
83 (0.11/day)
The 980 PRO is actually a PCIe Gen 4 drive (with Read/Write speeds of 7000/5000 MB/s).
I did look at it, and in your screenshot it appears you cannot get any faster speed than 3500 MB/s.
You also said yourself that you tested the drive in a motherboard with only PCIe Gen 3 on it,
so your speed are not going to get any faster than 3500 MB/s (just like in your screenshot).
18 (0.00/day)
since this thread has revolved around the write reduction problem I presented proof of this.. guess you overlooked that aspect
83 (0.11/day)
How full is your drive? SSD's sadly get slower and slower the more data you put on them.
Some SSD's can't even retain their advertised speed anymore once you reach 25% full (or more).
AsRock
TPU addict
19,212 (2.97/day)
UK\USA
Cooling D15
Yes my bad, i was thinking of the none pro :| .
18 (0.00/day)
I may do a backup and secure erase on this drive to see if it really is an issue with Samsung refusing to do nand garbage collection in firmware now.. has anyone else with low writes now tried this?
9,340 (5.04/day)
Louisiana
Keyboard G710+x3
Sorry if I missed it but what are your system spec's with the issue ?
You barely have any data on the drive 134gb is nearly nothing.
I'd lean more to bios update or roll back as more viable time spent besides contacting samsumg and giving them the history with their own app.
890 (1.16/day)
Belgium
Even old HDD became slower towards the end of capacity, and in real life, how much random writings will ever happen? Almost never going to happen in an OS or games that just reading.
And an PCIe SSD is so fast that you also will never notice it while using it. Just go on with your life and don't let your sleep for this, it's meaningless.
Besides downgrade firmware is not possible on most SSD, blocked by manufacturer.
3,892 (1.74/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Reviews probably need to emphasis some parts of the nvme results are CPU dependent. Particularly random i/o.
Intel 12-14 gen are perhaps especially vulnerable, as it might end up going on an e-core. Any older systems also that just wont have the grunt.
I first learnt this when I was diagnosing SSD issues some years back and was wondering why SSD was slower on my 2600X vs 9900K.
I also always stick to the Microsoft driver.
