- Jan 3, 2015
- 2,936 (0.85/day)
System Name | The beast and the little runt. |
Processor | Ryzen 5 5600X - Ryzen 9 5950X |
Motherboard | ASUS ROG STRIX B550-I GAMING - ASUS ROG Crosshair VIII Dark Hero X570 |
Cooling | Noctua NH-L9x65 SE-AM4a - NH-D15 chromax.black with IPPC Industrial 3000 RPM 120/140 MM fans. |
Memory | G.SKILL TRIDENT Z ROYAL GOLD/SILVER 32 GB (2 x 16 GB and 4 x 8 GB) 3600 MHz CL14-15-15-35 1.45 volts |
Video Card(s) | GIGABYTE RTX 4060 OC LOW PROFILE - GIGABYTE RTX 4090 GAMING OC |
Storage | Samsung 980 PRO 1 TB + 2 TB - Samsung 870 EVO 4 TB - 2 x WD RED PRO 16 GB + WD ULTRASTAR 22 TB |
Display(s) | Asus 27" TUF VG27AQL1A and a Dell 24" for dual setup |
Case | Phanteks Enthoo 719/LUXE 2 BLACK |
Audio Device(s) | Onboard on both boards |
Power Supply | Phanteks Revolt X 1200W |
Mouse | Logitech G903 Lightspeed Wireless Gaming Mouse |
Keyboard | Logitech G910 Orion Spectrum |
Software | WINDOWS 10 PRO 64 BITS on both systems |
Benchmark Scores | Se more about my 2 in 1 system here: kortlink.dk/2ca4x |
Go
Good that it is detected, how were the ratings on the adapter you got?
Ratings Arent bad on the adaptor and the heatsink does a good job to. Ilde about 30 C and max load havent seen the SSD exceed 45 C yet. M.2 SSD tends to be hot and throttle down speed, this adaptor prevents that from happening.
![](/forums/proxy.php?image=http%3A%2F%2Fpeecee.dk%2Fuploads%2F032017%2FSSD_temp.jpg&hash=e8c3a4037a94ac75bdce7e080ad34211)
Here is some speed comparison. Please note that at the given test mobo where sat to raid mode and not AHCI, that may effect results and as other X58 owners might know, these first gen sata 3 port driven by marvel controller does not have full real sata 3 speed. Max out at about 400 Mb/s read and 250 MB/s ride. Samsung 950 Pro does nok show its full speed cause of speed limitations on PCIe 2. Thats why it max out close to 1700 MB/s and not the rated 2200 MB/s. But the speeds are still better than any sata setup can give even two SSD in raid 0 at full sata 3 speed can not come up at those speeds 950 PRO hits.
![](/forums/proxy.php?image=http%3A%2F%2Fpeecee.dk%2Fuploads%2F032017%2Fdisk_speed.jpg&hash=ff95df5ffa5bee4bc0b148db7167035e)
