M.2 SSD on old X58 system with M.2 PCI adaptor. Can it work?
Greendale_Ghost
3 (0.01/day)
Hi, just putting feeler out in case there is anyone still here! I have a gigabyte x-58 i7 system which was a successful hackintosh build for 9 years before I stupidly filled up the boot SSD and killed it.
seeing this thread has me interested in rebirthing the machine as a dual
Boot windows / Mac OS with clover via m2 on a pci card! Looking for advice on the best choice for pci card?
also - does anyone know how far it’s possible to go with a GPU on these old boards?
The motherboard is Gigabyte GA-X58A-UD3R Rev 2, Intel X58, S1366, SLi/Xfire PCI-E 2, DDR3 2200,
Graphics card (x2) are 1GB Sapphire HD 5770 Vapor-X, PCI-E 2.1 (x16), 4800MHz GDDR5, GPU 860 MHz,
Processor is Intel Core i7 950 Bloomfield 45nm, 3.06 GHz, QPI 4.8GT/s, 8MB Cache, 23x Ratio,
4 (0.00/day)
Good morning. I tried 2 or 3 PCIe M2 adapters (very cheap from China) and all of them worked flawlessy.
My (very) old X58 Xeon W3690 now boots Mac OS Mojave from a Raid Zero on 2 x Samsung SM951 AHCI via Clover and still runs like a Red Bull.
As for the video card this one is equipped with an AMD RX 570 Nitro+ 4Gb and Mac OS fully supports it with native drivers.
Rob
Greendale_Ghost
3 (0.01/day)
Rob
Hi Rob, thanks for coming back to me, great to hear your system is working fine. Is there an upper palikir for the m2 speeds via pci2? - wondering if it’s worth getting a super fast wester digital m2 (7000mbps read)!
Regeneration
NGOHQ.COM
3,111 (0.45/day)
You can use M.2 and even NVMe without a bootloader:
4 (0.00/day)
I think if you go with 1 M2 disk only you won't get all the speed WD M2 is capable because of the PCIe 2nd generation limit. My write speed is about 2350 Mb/s and read speed 2650 Mb/s just because of the Raid Zero configuration with 2 M2 disks.
3,363 (1.62/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
I think its a try it and see, bios needs NVME support. Some boards without M.2 slots do have support as the earliest NVME drives were PCIE slot variants.
