Massive stuttering, audio popping/cracking in games
Ruru
S.T.A.R.S.
12,676 (2.91/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X @ PBO +200 -20CO
Cooling Arctic Freezer 50, EKWB Vector TUF
Memory 32GB Kingston HyperX Fury DDR4-3466
Storage 3.3TB of SSDs + 3TB USB3.0 HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p60
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
Mouse Logitech MX518 + Asus ROG Strix Edge Nordic
VR HMD Oculus Rift CV1
What did you think happened? That's nuts, even with heavy CPU thermal throttling, due to a bad heatsink mount!
No idea. The issue existed with both R5 3600 and R7 5800X CPUs and with a custom loop so there wasn't temp issues. Updating the BIOS, clearing the CMOS, trying different RAM etc. didn't help.
2,369 (0.50/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Video Card(s) Sapphire Nitro+ Radeon RX 6750 XT
Case Corsair 275R
Mouse Logitech G Pro (Hero)
Could it have been a short by an arachnid, literally?! I saw an arachnid on the bottom of my Asus A7V8X-X, (Via KT400 version, from 2003, which I got before the A7N8X-X) around the time of seeing the BIOS giving false "New CPU installed!" messages.
1,975 (0.53/day)
Calabash, NC
System Name The Captain (2.0)
Processor Ryzen 7 7700X
Motherboard Asus ROG Strix X670E-A
Memory 32GB (2x16) Kingston Fury Beast CL30 6000MT/s
Keyboard Varies based on mood; currently Razer Blackwidow V4 75% and Hyper X Alloy 65
One thing that's making my issues particularly tricky to pin down is the fact that they don't happen 100 percent of the time that I game. Sometimes I'll encounter them while gaming/chatting with friends on Discord (I have my discord overlay disabled by default), and then other days I'll be able to game/chat without issue. The problems aren't happening every single time. Just last night I was able to play Lego Star Wars: The Skywalker Saga without so much as a hiccup, but the night before had the issues while playing Battlefront II (when I recorded my video evidence).
Ruru
S.T.A.R.S.
12,676 (2.91/day)
Jyväskylä, Finland
I hella doubt that as I clean my PC components regularly.
Sounds pretty much just like my issues with that CHVIIHero board. Maybe 1 of 5 reboots made everything work normally. I had mostly those stutter/cracking shit when watching videos from Youtube.
2,369 (0.50/day)
System Name KHR-1
Case Corsair 275R
I was wondering how it got there! I didn't have the motherboard for long at that time, LOL. I had my PC tower on the floor, right on the carpet, though.
Ruru
S.T.A.R.S.
12,676 (2.91/day)
Jyväskylä, Finland
I have actually the Nvidia version of that board. Surprisingly good for a single channel Nforce2 board without 12V plug.
2,369 (0.50/day)
System Name KHR-1
Case Corsair 275R
Before I got the nForce 2 version of that board, I got the A7V8X-X in November, 2003 and was using it until 2006, IIRC. (maybe 2007?) Yes, all the Asus socket 462 motherboards that I know of, draws from the +5V rail.
It somehow got into my "pac man" ATX tower case.
3 (0.03/day)
PNW
System Name Matcha (EndeavourOS)
Processor Ryzen 7600X (PBO: 85C, -20mV)
Motherboard ASRock B650E PG-ITX WIFI
Cooling Noctua NH-L12
Memory G.SKILL Trident Z5 RGB (2x16GB) DDR5 5600
Video Card(s) ASRock RX 6650xt 8GB SL
Storage Samsung 980 PRO SSD 1TB (x2)
Display(s) VIOTEK GNV27DB 27" 2560x1440p (2K) 144 Hz
Case Fractal Terra (jade)
Power Supply Corsair SF750
Keyboard FL980 - w/ filmed Outemu Toms; Redragon k585 - padded, Kraken caps, Outemu Silent Yellow Jades
Software Steam, Discord, VLC, LibreOffice
I'm jus curious if changing up RAM clocks done anything to mediate this?
1,975 (0.53/day)
Calabash, NC
2,369 (0.50/day)
System Name KHR-1
Case Corsair 275R
It was that there was an arachnid or I at least saw a tiny web! IIRC, I pulled the tiny webbing away, after my Asus A7V8X-X became possessed with a false "New CPU installed!" message from the BIOS.
It was not long after I got the motherboard, which was around $110, IIRC. (apparently was typical for 2003 dollars)
1,975 (0.53/day)
Calabash, NC
Here's some screenshots of my BIOS settings. Most everything is set to auto/stock because I don't know what needs changing and what doesn't :oops:
@tabascosauz @ir_cow -- any suggestions?
ir_cow
4,435 (0.75/day)
USA
I only know memory stuff really. But if looks like your are good on that. XMP / EXPO is enabled. FLCK is 2000, "Low Latency Mode" is Disabled (good thing) and your UCLK Ratio is 1:1
tabascosauz
8,126 (2.37/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
zentimings is more useful to see than screenshots of bios auto settings
As AM5 shouldn't really have the same rampant USB issues, I'd suspect the eBay board at this point
1,975 (0.53/day)
Calabash, NC
Damn...And I liked this board too. But I guess that's a risk you take with buying refurbs/used parts...or even new parts I guess. I'll keep testing/playing games, but also think about buying a new board. Newegg's got the X670E Master for $380, which isn't bad. I'll keep my options open though.
Here's my zen timings shots for you, Tabby:
ir_cow
4,435 (0.75/day)
USA
What BIOS are you on? I really like the Master too, but it couldn't run 8000 MT/s well so thats why I switched for testing.
Also do you have issues when XMP/EXPO is not enabled?
1,286 (1.64/day)
Processor 7950X3D
Motherboard AsRock X670E Pro RS
Cooling Arctic LF III 360
Memory 64GB 6000 CL30
Video Card(s) RTX 4070 Ti Super
Display(s) MSI MAG401QR
Case Phanteks P600s
Power Supply Vertex GX-1000
F32b from Zentimings above.
@Gmr_Chick -- That's a beta BIOS. You might try going back to the last stable - F30
I've had @#*(&@ luck with GB beta bios'
3 (0.03/day)
PNW
I noticed you've got an X670E, but your bios shows you have not enabled PBO on the CPU - are you using the higher tier chipset for the PCIE lanes and more i/o stuff?
My 7600x runs great on the ASRock B650E PG-ITX...I only needed an OC-capable board to use PBO for undertemp/volting the CPU for an SFF build. that said I uh, dont think pushing the CPU on yer board gonna fix this issue, necessarily, lol, but. If you're looking to save some cash on a new mobo, a B650(E) board that has the i/o you need may also work well? Also (if you can hold out long enough), when the X870 boards launch, I would guess the 600-series boards will drop in price, at least a lil bit? :ohwell:
tabascosauz
8,126 (2.37/day)
Western Canada
System Name ab┃ob
Try to go lower on VSOC if you can, I doubt you really need 1.25V for 2000/3000
Same story with BIOSes as it was on AM4 - if it ain't broke, don't fix it. I'm not sure you absolutely need the latest AGESA in the beta bios, AGESA and new BIOSes are the home of Murphy's law
I can't seem to remember. Did you do a clean install in the end?
1,975 (0.53/day)
Calabash, NC
Yeah GB Beta BIOS can be really iffy. Things randomly are enabled now when Auto before didn't. I would go back to the last none beta BIOS. aka anyone without a letter at the end.
Damn it, so THAT'S why the BIOS was marked F32b - the 'b' stands for "beta"! I feel like an idiot. I had no idea it was a beta BIOS...
@Bawdyknocker - I kept PBO disabled in order to test. I forgot to turn it back on :laugh:
ir_cow
4,435 (0.75/day)
USA
So does a, b,c and D. I haven't seen one with a E yet. But they are all beta.
235 (0.27/day)
Processor 7950X, PBO CO -15
Motherboard Gigabyte X670 AORUS Elite AX (rev. 1.0)
Cooling EVGA CLC 360 w/Arctic P12 PWM PST A-RGB fans
Memory 64GB G.Skill Trident Z5 RGB F5-6000J3040G32GA2-TZ5RK
Video Card(s) ASUS TUF Gaming GeForce RTX 3070
Storage 970 EVO Plus 2TB x2, 970 EVO 1TB; SATA: 850 EVO 500GB (HDD cache), HDDs: 6TB Seagate, 1TB Samsung
Display(s) ASUS 32" 165Hz IPS (VG32AQL1A), ASUS 27" 144Hz TN (MG278Q)
Case Corsair 4000D Airflow
Audio Device(s) Razer BlackShark V2 Pro
Power Supply Corsair RM1000x
Mouse Logitech M720
Keyboard G.Skill KM780R MX
Software Win10 Pro, PrimoCache, VMware Workstation Pro 16
Well if bios change doesn't fix it, I'd say remove all but your boot nvme drive and try the boot nvme in different slots. It was a problem for me and the guy in the link I posted.
