Need Help Finding: Coinmine RX 580 2048sp (8gb) stockbios
izy
998 (1.21/day)
So your ram is H5GC8H24AJR ( not H5GC8H24MJR ) , let me see what i can find. Can you post a picture from CPU-Z or it doesnt work at all?
42 (0.05/day)
It looked extremely similar same porta and innards but it has a different case on it
U mean gpu-z?
I can post one pic but after that I gtg
Heres a better picture of whats under the thermalpad
I'm going on vacation so I might not be able to flash it for 3 weeks
izy
998 (1.21/day)
Well have fun , i think you u posted all the infos we need and when you get back we will give you some bios suggestions to flash.
Found something on Gamer Nexus youtube channel about this gpu type: (RX 570 TI :D , interesting)
42 (0.05/day)
Found something on Gamer Nexus youtube channel about this gpu type: (RX 570 TI :D)
You're the greatest.
42 (0.05/day)
Izy, is there any way for me to contact you specifically when I get back?
or can i just type something in this thread and you'll get a notification?
welp cya
izy
998 (1.21/day)
You can just write here. There are many great guys here than can help you (maybe even better) if i am not around.
My first option would be this one:
(it has your memory type + its has the same GPU name (RX580 2048SP), but i think it will work even with rx 570 with the same memory type)
Edit: Ah nevermind it had H5GC8H24MJR, ill search one for you and post it later.
All the bios types i found in TPU database with RX 580 2048SP have H5GC8H24MJR (or other vendor, ill have to search better). Are you sure it was H5GC8H24AJR and not H5GC8H24MJR ? If is correct then ill have to look for an RX 570 vbios with H5GC8H24AJR . (Gamer Nexus is pretty sure its an rebranded RX 570 so thats the best bet.)
Edit2: Here you go ( H5GC8H24AJR vbios):
RX580 2048SP vbios:
Rx 570 vbios that might work:
Rx 580 vbios that might work:
41,479 (6.58/day)
Im so sorry I already put the gpu back in my pc so I cant do that... however if you guys can make an educated guess on a gaming bios I could use I would be willing to risk bricking it.
I guess we can 't help you then
1,884 (1.49/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
I won't promise, but please save your current BIOS into a file and upload it here.
I will take a look at it and i will try to revert it to a "normal" BIOS not mining.
41,479 (6.58/day)
U mean gpu-z?
Heres a better picture of whats under the thermalpadView attachment 256346
Since you Finally Gave the info needed.
Here you go
1002 6FDF 1002 0B31
Hynix AJR
All these are the latest.
Follow this guide
Download atiflash/amdvbflash 2.93
Go here https://www.techpowerup.com/download/ati-atiflash/
Then look for Version 4.68, underneath 4.68 you will see a link to show older version, click that and you should see version 2.93
Follow these steps carefully:
1. Open your "C:" drive in Windows, create a new folder, call it atiflash.
2. Extract the contents of atiflash_293.zip to the "C:\atiflash" folder
3. Find the bios file you downloaded and rename the bios file to biosname.rom
(Biosname.rom is just an example, change it to match your card model in 5 characters with .rom on end)
4. Move biosname.rom to the "C:\atiflash" folder
5. Open the start menu, type cmd, when cmd.exe appears right click it and hit "Run as administrator"
6. At the command prompt type in cd\ and press enter until only C:\> is on the screen.
7. Type in cd/atiflash and press enter, you should see C:\atiflash>
8. At the C:\atiflash> prompt type in
amdvbflash.exe -unlockrom 0
(there is a space between the e and -unlockrom and 0)(0 is the number zero)
press enter and you will be prompted that the "ROM Unlocked"
9. At the C:\atiflash> prompt type in
amdvbflash.exe -f -p 0 biosname.rom
(there is a space between the .exe and -f, and a space between -f and -p and 0)press enter.
Follow directions on screen and if flash is successful exit the command prompt and restart, windows should show up on screen.
41,479 (6.58/day)
42 (0.05/day)
HI I'm back for vacation here's my current bios btw, and which gaming bios would you think would be the best bet?
hello?
anyone online?
  • Ellesmere.rom
41,479 (6.58/day)
Mussels
Freshwater Moderator
58,413 (8.00/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
welp cya
You really need to take proper photos
Keep the camera further back, and use brighter lighting. Don't use camera flash.
The text needs to be clear on the VRAM modules, and we would benefit from knowing what actual GPU it is - either from GPU-Z, or from the card itself under the thermal paste
Under this - yes, you would need thermal paste to replace it.
You also would have needed that anyway, as you're meant to clean and replace it every time the cooler comes apart
yes
42 (0.05/day)
  • Ellesmere.rom
1,884 (1.49/day)
Romania
Hello @AlphaKelo
You saw the files that @eidairaman1 posted above?
All those files are a perfect match for your card ID, subID and memory producer.
So no need to edit a BIOS
41,479 (6.58/day)
42 (0.05/day)
I tried the maxsun one and it bricked my card
currently trying to bring back my stock bios
none of the fixes are working cause my pc is simply not showing anything when i use the rx 580 2048sp, even the motherboard bios boot screen is all black I have another GPU on hand though which I'm trying to use to fix my pc but nothing is working, please help if you can
another big issue is that I have only 2 gpu slots on my motherboard and the secondary slot cant fit my rx 580 2048sp so i cant use the second gpu to fix it
and im not sure if there is a way to switch the primary gpu slots
hello?
I managed to get into teamviewr but i cant fix the bios flash because i need an 800x600 resoloutin to run amdvbflash
any ideas on how to get around the minimum resolution requirement
anyone online?
I can do only an educated guess and give you like 3 4 different vbios versions to flash and hope one of them will work but you can brick your card and you wont be able to unbrick if you dont have another GPU (as you can get no video output). What i tend to do in this type of situation is using TeamViewer from my laptop (or phone) if im lazy to get my other GPU so i can reflash in case the screen goes black.
I'm trying to fix my bricked card with team viewer and its working but in order to re-flash my card it says i need a minimum screen res of 800x600 do you know of any ways to get around this?
I'm in desperate need of help, is anyone online???
hello?
izy
998 (1.21/day)
@AlphaKelo hi , did you try to change the resolution?
You should get video output with rx 580 in first slot and the other card in second slot (you have to connect your monitor to that video card)
Edit: Or you can try flash it in cmd mode:
42 (0.05/day)
Im not getting a change in resoloution, but ill try the cmd thing
IT WORKED
Thank you!!!
41,479 (6.58/day)
